MMZ1608-2-KIT
MMZ1608-2-KIT
    TDK(东电化)
    1608200-1500MA3-1500OHM
MMZ1608-2-KIT 数据手册
MMZ1608 Series Ferrite Bead Kit Consumer Grade Standard Ferrite Chip Bead Kit The TDK MMZ1608 Series ferrite chip beads are used to suppress noise in signal line circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. Static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could provide the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MMZ1608 series chip beads. Features General Signal Line  Noise reduction solution for general signal line  Various frequency characteristics with different materials  Countermeasures from general signals to high-speed signals  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Consumer Datasheet Applications  Household Appliances  Industrial Equipment  Smart Meters  Recorders  STBs  Mobile Devices, such as Smartphones and Tablet PCs MMZ1608 Series Ferrite Chip Bead Kit Includes: Kit  Case Size  Impedance Range  Current Ra ng  Total Pieces in Kit  Now Available at: MMZ1608‐1‐KIT  MMZ1608‐2‐KIT  1608—1.6x0.8mm  15‐2500Ω Z  3‐1500Ω Z  200‐1500mA  270 (10 pieces per value)  290 (10 pieces per value)  445-174606-KIT-ND 445-174607-KIT-ND Click the links above for ordering information. MMZ1608 Series Ferrite Chip Bead Kit Includes: Digi‐Key Part Number  445‐174606‐KIT‐ND  445‐174607‐KIT‐ND  TDK Part Number  MMZ1608B121CTAH0  MMZ1608B221CTAH0  MMZ1608B301CTAH0  MMZ1608B471CTAH0  MMZ1608B601CTAH0  MMZ1608B102CTA00  MMZ1608R150ATA00  MMZ1608R300ATA00  MMZ1608R600ATA00  MMZ1608R121ATA00  MMZ1608R301ATA00  MMZ1608R471ATA00  MMZ1608R601ATA00  MMZ1608R102ATA00  MMZ1608S400ATA00  MMZ1608S800ATA00  MMZ1608S121ATA00  MMZ1608S181ATA00  MMZ1608S221ATA00  MMZ1608S301ATA00  MMZ1608S471ATA00  MMZ1608S601ATA00  MMZ1608S102ATA00  MMZ1608S202ATA00  MMZ1608A182BTA00  MMZ1608A222BTA00  MMZ1608A252BTA00  MMZ1608Y150BTA00  MMZ1608Y300BTA00  MMZ1608Y600BTA00  MMZ1608Y221BTA00  MMZ1608Y301BTA00  MMZ1608Y471BTA00  MMZ1608Y601BTA00  MMZ1608Y751BTA00  MMZ1608Y102BTA00  MMZ1608Y152BTA00  MMZ1608Q121BTA00  MMZ1608Q221BTA00  MMZ1608Q331BTA00  MMZ1608Q471BTA00  MMZ1608Q601BTA00  MMZ1608Q102BTA00  MMZ1608D050CTA00  MMZ1608D100CTAH0  MMZ1608D220CTAH0  MMZ1608D800CTAH0  MMZ1608D800BTA00  MMZ1608D121CTAH0  MMZ1608D121BTA00  MMZ1608D241CTA00  MMZ1608D301BTA00  MMZ1608F030BTA00  MMZ1608F470BTA00  MMZ1608F750BTA00  MMZ1608F121BTA00  Case Size Impedance Value  Tol  1608, Bead, 120Ω (±25%)  1608, Bead, 220Ω (±25%)  1608, Bead, 300Ω (±25%)  1608, Bead, 470Ω (±25%)  1608, Bead, 600Ω (±25%)  1608, Bead, 1000Ω (±25%)  1608, Bead, 15Ω (±25%)  1608, Bead, 30Ω (±25%)  1608, Bead, 60Ω (±25%)  1608, Bead, 120Ω (±25%)  1608, Bead, 300Ω (±25%)  1608, Bead, 470Ω (±25%)  1608, Bead, 600Ω (±25%)  1608, Bead, 1000Ω (±25%)  1608, Bead, 40Ω (±25%)  1608, Bead, 80Ω (±25%)  1608, Bead, 120Ω (±25%)  1608, Bead, 180Ω (±25%)  1608, Bead, 220Ω (±25%)  1608, Bead, 300Ω (±25%)  1608, Bead, 470Ω (±25%)  1608, Bead, 600Ω (±25%)  1608, Bead, 1000Ω (±25%)  1608, Bead, 2000Ω (±25%)  1608, Bead, 1800Ω (±25%)  1608, Bead, 2200Ω (±25%)  1608, Bead, 2500Ω (±25%)  1608, Bead, 15Ω (±25%)  1608, Bead, 30Ω (±25%)  1608, Bead, 60Ω (±25%)  1608, Bead, 220Ω (±25%)  1608, Bead, 300Ω (±25%)  1608, Bead, 470Ω (±25%)  1608, Bead, 600Ω (±25%)  1608, Bead, 750Ω (±25%)  1608, Bead, 1000Ω (±25%)  1608, Bead, 1500Ω (±25%)  1608, Bead, 120Ω (±25%)  1608, Bead, 220Ω (±25%)  1608, Bead, 330Ω (±25%)  1608, Bead, 470Ω (±25%)  1608, Bead, 600Ω (±25%)  1608, Bead, 1000Ω (±25%)  1608, Bead, 5Ω (±2Ω)  1608, Bead, 10Ω (±5Ω)  1608, Bead, 22Ω (±25%)  1608, Bead, 80Ω (±25%)  1608, Bead, 80Ω (±25%)  1608, Bead, 120Ω (±25%)  1608, Bead, 120Ω (±25%)  1608, Bead, 240Ω (±25%)  1608, Bead, 300Ω (±25%)  1608, Bead, 3Ω  1608, Bead, 47Ω (±25%)  1608, Bead, 75Ω (±25%)  1608, Bead, 120Ω (±25%)  Series  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608
MMZ1608-2-KIT 价格&库存
很抱歉,暂时无法提供与“MMZ1608-2-KIT”相匹配的价格&库存,您可以联系我们找货
