MMZ1608AUTO-1-KIT
MMZ1608AUTO-1-KIT
    TDK(东电化)
    EMI Ferrite Beads and Chips Kit 210 pcs - 10 ea of 21 values Surface Mount
MMZ1608AUTO-1-KIT 数据手册
MMZ1608 Series Ferrite Bead Kit Automotive Grade Ferrite Chip Bead Kit The TDK MMZ1608 Series ferrite chip beads are used to suppress noise in signal line circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. Static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could provide the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MMZ1608 series chip beads. Automotive Features  AEC-Q200 Qualified  Noise reduction solution for general signal line  Various frequency characteristics with different materials  Countermeasures from general signals to high-speed signals  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering General Signal Line Datasheet  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Applications  ECUs  Powertrains  Body Controls  Car Multimedia (Telematics) MMZ1608 Series Automotive Chip Bead Kit Includes: Kit  MMZ1608AUTO‐1‐KIT  Case Size  Impedance Range  Current Ra ng  Total Pieces in Kit  Now Available at: MMZ1608AUTO‐2‐KIT  1608—1.6x0.8mm  15‐2000Ω Z  3‐2500Ω Z  200‐1500mA   210 (10 pieces per value)  250 (10 pieces per value)  445-174604-KIT-ND 445-174605-KIT-ND Click the links above for ordering information. MMZ1608 Series Automotive Chip Bead Kit Includes: Digi‐Key Part Number  445‐174604‐KIT‐ND  445‐174605‐KIT‐ND  TDK Part Number  Case Size Impedance Value  Tol  Series  MMZ1608B121CTDH5  MMZ1608B221CTDH5  MMZ1608B301CTDH5  MMZ1608B471CTDH5  MMZ1608B601CTDH5  MMZ1608B102CTD25  MMZ1608R150ATD25  MMZ1608R300ATD25  MMZ1608R600ATD25  MMZ1608R121ATD25  MMZ1608R301ATD25  MMZ1608R471ATD25  MMZ1608R601ATD25  MMZ1608R102ATD25  MMZ1608S400ATD25  MMZ1608S800ATD25  MMZ1608S121ATD25  MMZ1608S181ATD25  MMZ1608S601ATD25  MMZ1608S102ATD25  MMZ1608S202ATD25  MMZ1608Y150BTD25  MMZ1608Y300BTD25  MMZ1608Y600BTD25  MMZ1608Y121BTD25  MMZ1608Y301BTD25  MMZ1608Y601BTD25  MMZ1608Y751BTD25  MMZ1608Y102BTD25  MMZ1608Y152BTD25  MMZ1608A182BTD25  MMZ1608A222BTD25  MMZ1608A252BTD25  MMZ1608Q221BTD25  MMZ1608Q601BTD25  MMZ1608Q102BTD25  MMZ1608D100CTDH5  MMZ1608D220CTDH5  MMZ1608D800BTD25  MMZ1608D500CTDH5  MMZ1608D121CTDH5  MMZ1608D241CTD25  MMZ1608D121BTD25  MMZ1608D301BTD25  MMZ1608F030BTD25  MMZ1608F750BTD25  1608, Bead, 120Ω±25%  1608, Bead, 220Ω±25%  1608, Bead, 300Ω±25%  1608, Bead, 470Ω±25%  1608, Bead, 600Ω±25%  1608, Bead, 1000Ω±25%  1608, Bead, 15Ω±25%  1608, Bead, 30Ω±25%  1608, Bead, 60Ω±25%  1608, Bead, 120Ω±25%  1608, Bead, 300Ω±25%  1608, Bead, 470Ω±25%  1608, Bead, 600Ω±25%  1608, Bead, 1000Ω±25%  1608, Bead, 40Ω±25%  1608, Bead, 80Ω±25%  1608, Bead, 120Ω±25%  1608, Bead, 180Ω±25%  1608, Bead, 600Ω±25%  1608, Bead, 1000Ω±25%  1608, Bead, 2000Ω±25%  1608, Bead, 15Ω±25%  1608, Bead, 30Ω±25%  1608, Bead, 60Ω±25%  1608, Bead, 120Ω±25%  1608, Bead, 300Ω±25%  1608, Bead, 600Ω±25%  1608, Bead, 750Ω±25%  1608, Bead, 1000Ω±25%  1608, Bead, 1500Ω±25%  1608, Bead, 1800Ω±25%  1608, Bead, 2200Ω±25%  1608, Bead, 2500Ω±25%  1608, Bead, 220Ω±25%  1608, Bead, 600Ω±25%  1608, Bead, 1000Ω±25%  1608, Bead, 10Ω±5Ω  1608, Bead, 22Ω±25%  1608, Bead, 80Ω±25%  1608, Bead, 50Ω±25%  1608, Bead, 120Ω±25%  1608, Bead, 240Ω±25%  1608, Bead, 120Ω±25%  1608, Bead, 300Ω±25%  1608, Bead, 3typ.Ω  1608, Bead, 75Ω±25%  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608  MMZ1608
MMZ1608AUTO-1-KIT 价格&库存
很抱歉,暂时无法提供与“MMZ1608AUTO-1-KIT”相匹配的价格&库存,您可以联系我们找货
