MMZ2012-1-KIT
MMZ2012-1-KIT
    TDK(东电化)
    Z 2012 1500-400MA 15-2000OHM
MMZ2012-1-KIT 数据手册
MMZ2012 Series Ferrite Bead Kit Consumer Grade Ferrite Chip Bead Kit The TDK MMZ2012 Series ferrite chip beads are used to suppress noise in signal line circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could have the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MMZ series chip beads. Features General Signal Line  Noise reduction solution for general signal line  Various frequency characteristics with different materials  Countermeasures from general signals to high-speed signals  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Consumer Datasheet Applications  Household Appliances  Industrial Equipment  Smart Meters  Recorders  STBs  Mobile Devices, such as Smartphones and Tablet PCs MMZ2012 Series Ferrite Chip Bead Kit Includes: Case Size: 2012 Impedance Range: 15-2000Ω (±25%) Current Rating: 1500-400mA Kit contains 520 pieces total—20 pieces per value Now Available at: 445-173063-KIT-ND Click the links above for ordering information. MMZ2012 Series Ferrite Chip Bead Kit Includes: Digi‐Key Part Number   445‐173063‐KIT‐ND   TDK Item List  Item Descrip on  MMZ2012R150AT000  2012, Bead, 15Ω,  ±25%, 1500mA  MMZ2012R300AT000  2012, Bead, 30Ω,  ±25%, 1500mA  MMZ2012R600AT000  2012, Bead, 60Ω,  ±25%, 1000mA  MMZ2012R121AT000  2012, Bead, 120Ω,  ±25%, 800mA  MMZ2012R301AT000  2012, Bead, 300Ω,  ±25%, 600mA  MMZ2012R601AT000  2012, Bead, 600Ω,  ±25%, 500mA  MMZ2012R102AT000  2012, Bead, 1000Ω,  ±25%, 500mA  MMZ2012S400AT000  2012, Bead 40Ω,  ±25%, 1000mA  MMZ2012S800AT000  2012, Bead, 80Ω,  ±25%, 800mA  MMZ2012S121AT000  2012, Bead, 120Ω,  ±25%, 800mA  MMZ2012S181AT000  2012, Bead, 180Ω,  ±25%, 600mA  MMZ2012S301AT000  2012, Bead, 300Ω,  ±25%, 600mA  MMZ2012S601AT000  2012, Bead, 600Ω,  ±25%, 500mA  MMZ2012S102AT000  2012, Bead, 1000Ω,  ±25%, 500mA  MMZ2012Y150BT000  2012, Bead, 15Ω,  ±25%, 1500mA  MMZ2012Y300BT000  2012, Bead, 30Ω,  ±25%, 1500mA  MMZ2012Y600BT000  2012, Bead, 60Ω,  ±25%, 1000mA  MMZ2012Y121BT000  2012, Bead, 120Ω,  ±25%, 800mA  MMZ2012Y301BT000  2012, Bead, 300Ω,  ±25%, 600mA  MMZ2012Y601BT000  2012, Bead, 600Ω,  ±25%, 500mA  MMZ2012Y102BT000  2012, Bead, 1000Ω,  ±25%, 500mA  MMZ2012Y152BT000  2012, Bead, 1500Ω,  ±25%, 500mA  MMZ2012Y202BT000  2012, Bead, 2000Ω,  ±25%, 400mA  MMZ2012D800BT000  2012, Bead, 80Ω,  ±25%, 500mA  MMZ2012D121BT000  2012, Bead, 120Ω,  ±25%, 500mA  MMZ2012D301BT000  2012, Bead, 300Ω,  ±25%, 400mA
MMZ2012-1-KIT 价格&库存
很抱歉,暂时无法提供与“MMZ2012-1-KIT”相匹配的价格&库存,您可以联系我们找货
