MPZ1608-1-KIT
MPZ1608-1-KIT
    TDK(东电化)
    EMI Ferrite Beads and Chips Kit 400 pcs - 20 ea of 20 values Surface Mount
MPZ1608-1-KIT 数据手册
MPZ1608 Series Ferrite Bead Kit Consumer Grade Ferrite Power Chip Bead Kit The TDK MPZ1608 Series ferrite power chip beads are used to suppress noise in power supply circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could have the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MPZ series chip beads. Features  Noise reduction solution for power line Power Line  Has low direct current resistance for compatibility with large currents, optimal for low power consumption Consumer  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Datasheet Applications  Household Appliances  Industrial Equipment  Smart Grids  Recorders  STBs  Mobile Devices, such as Smartphones and Tablet PCs MPZ1608 Series Ferrite Chip Bead Kit Includes: Case Size: 1608 Impedance Range: 26-1000Ω (±25%) Current Rating: 6000-800mA Kit contains 400 pieces total—20 pieces per value Now Available at: 445-173064-KIT-ND Click the links above for ordering information. MPZ1608 Series Ferrite Chip Bead Kit Includes: Digi‐Key Part Number   445‐173064‐KIT‐ND   TDK Item List  Item Descrip on  MPZ1608B471ATA00  1608, Bead, 470Ω,  ±25%, 1000mA  MPZ1608S260ATAH0  1608, Bead, 26Ω,  ±25%, 6000mA  MPZ1608S300ATAH0  1608, Bead, 30Ω, ±10Ω, 5000ma  MPZ1608S600ATAH0  1608, Bead 60Ω,  ±25%, 3500mA  MPZ1608S101ATAH0  1608, Bead, 100Ω,  ±25%, 3000mA  MPZ1608S121ATAH0  1608, Bead, 120Ω,  ±25%, 2000mA  MPZ1608S181ATAH0  1608, Bead, 180Ω,  ±25%, 2000mA  MPZ1608S221ATA00  1608, Bead, 220Ω,  ±25%, 2200mA  MPZ1608S331ATA00  1608, Bead, 330Ω,  ±25%, 1700mA  MPZ1608S471ATA00  1608, Bead, 470Ω,  ±25%, 1000mA  MPZ1608S601ATA00  1608, Bead, 600Ω,  ±25%, 1000mA  MPZ1608S102ATA00  1608, Bead, 1000Ω,  ±25%, 800mA  MPZ1608R391ATA00  1608, Bead, 390Ω,  ±25%, 1200mA  MPZ1608Y600BTA00  1608, Bead, 60Ω,  ±25%, 2000mA  MPZ1608Y101BTA00  1608, Bead, 100Ω,  ±25%, 2300mA  MPZ1608Y151BTA00  1608, Bead, 150Ω,  ±25%, 1800mA  MPZ1608Y221BTA00  1608, Bead, 220Ω,  ±25%, 1500mA  MPZ1608D300BTA00  1608, Bead, 30Ω, ±10Ω, 1800mA  MPZ1608D600BTA00  1608, Bead, 600Ω,  ±25%, 1200mA  MPZ1608D101BTA00  1608, Bead, 100Ω,  ±25%, 1000mA
MPZ1608-1-KIT 价格&库存
很抱歉,暂时无法提供与“MPZ1608-1-KIT”相匹配的价格&库存,您可以联系我们找货
MPZ1608-1-KIT
  • 1+363.895451+47.06989
  • 10+316.0613210+40.88255
库存:6
