MPZAUTO-1-KIT
MPZAUTO-1-KIT
    TDK(东电化)
    MPZ1608/MPZ2012 AUTO BEADS
MPZAUTO-1-KIT 数据手册
MPZ Auto Series Ferrite Bead Kit Automotive Grade Ferrite Power Chip Bead Kit The TDK MPZ Series ferrite power chip beads are used to suppress noise in power supply circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. Static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could have the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MPZ series chip beads. Automotive Features  Noise reduction solution for power line  Has low direct current resistance for compatibility with large currents, optimal for low power consumption  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) AEC-Q200 Power Line MPZ1608 Datasheet MPZ2012 Datasheet Applications  Various ECUs  Powertrains  Body Controls  Car Multimedia (Telematics) MPZ Auto Series Ferrite Chip Bead Kit Includes: Case Size  Impedance  DC Resistance  Current Ra ng  Pieces/Reel  Kit Quan ty  1608  26‐1000Ω  0.007‐0.300Ω max.  6.0‐0.8A max.  4,000  20 pieces per value  2012  30‐1000Ω  0.010‐0.150Ω max.  6.0‐1.5A max.  4,000  20 pieces per value  Now Available at: 445-173105-KIT-ND Click the links above for ordering information. MPZ Auto Series Ferrite Chip Bead Kit Includes: Digi‐Key Part Number  445‐173105‐KIT‐ND  TDK Item List  Item Descrip on  MPZ1608B471ATD25  1608, Bead, 470Ω,  ±25%  MPZ1608S260ATDH5  1608, Bead, 26Ω,  ±25%  MPZ1608S300ATDH5  1608, Bead, 30Ω, ±10Ω  MPZ1608S600ATDH5  1608, Bead, 60Ω,  ±25%  MPZ1608S101ATDH5  1608, Bead, 100Ω,  ±25%  MPZ1608S121ATDH5  1608, Bead, 120Ω,  ±25%  MPZ1608S181ATDH5  1608, Bead, 180Ω,  ±25%  MPZ1608S221ATD25  1608, Bead, 220Ω,  ±25%  MPZ1608S331ATD25  1608, Bead, 330Ω,  ±25%  MPZ1608S471ATD25  1608, Bead, 470Ω,  ±25%  MPZ1608S601ATD25  1608, Bead, 600Ω,  ±25%  MPZ1608S102ATD25  1608, Bead, 1000Ω,  ±25%  MPZ1608R391ATD25  1608, Bead, 390Ω,  ±25%  MPZ1608Y600BTD25  1608, Bead, 60Ω,  ±25%  MPZ1608Y101BTD25  1608, Bead, 100Ω,  ±25%  MPZ1608Y151BTD25  1608, Bead, 150Ω,  ±25%  MPZ1608Y221BTD25  1608, Bead, 220Ω,  ±25%  MPZ1608D300BTD25  1608, Bead, 30Ω, ±10Ω  MPZ1608D600BTD25  1608, Bead, 60Ω,  ±25%  MPZ1608D101BTD25  1608, Bead, 100Ω,  ±25%  MPZ2012S300ATD25  2012, Bead, 30Ω, ±10Ω  MPZ2012S101ATD25  2012, Bead, 100Ω,  ±25%  MPZ2012S221ATD25  2012, Bead, 220Ω,  ±25%  MPZ2012S331ATD25  2012, Bead, 330Ω,  ±25%  MPZ2012S601ATD25  2012, Bead, 60Ω,  ±25%  MPZ2012S102ATD25  2012, Bead, 1000Ω,  ±25%
MPZAUTO-1-KIT 价格&库存
很抱歉,暂时无法提供与“MPZAUTO-1-KIT”相匹配的价格&库存,您可以联系我们找货
MPZAUTO-1-KIT
  • 1+467.523221+60.23300
