MTW15-51515
MTW15-51515
    TDK(东电化)
    15W至60W低剖面三路输出电源模块
MTW15-51515 数据手册
• 26mm height • 3 year Warranty • Peak Load capable • Light weight • Output 1 isolated from outputs 2 & 3 Key Market Segments & Applications MTW Series Factory Automation Test & Measurement Automated Service Portable Equipment 15W to 60W Low Profile Triple Output Power Supplies MTW Features and Benefits Features Benefits • Low Profile • Three Year Warranty • Output 1 is isolated from outputs 2 & 3 Specifications MODELS ITEMS Input Voltage Range Input Current Typ (1) Inrush Current (1) Leakage Current (240VAC, 60Hz) Max Output Power Efficiency (Typ) Hold Up Time Output Voltage Adjustment Overcurrent Protection Overvoltage Protection Operating Temperature Storage Temperature Humidity (Non condensing) Cooling Withstand Voltage Vibration (non operating) Shock Safety Agency Approvals Immunity Conducted EMI Weight (Typ) Size (WxHxL) Warranty Notes: (1) 100/240VAC (1) V A A mA W % ms V g mm yrs • Assists System Integration • Low Cost of Ownership • Outputs V2 & V3 can be connected in series MTW30-51212 MTW60-51212 MTW30-51515 MTW60-51515 85 - 265VAC (47 - 440Hz) 0.42 / 0.25 0.8 / 0.4 1.4 / 0.8 25 / 50 20 / 40 20 / 40 0.75mA Max 16 30 60 17.5 33 62.5 71 76 76 20 / 150 20 / 140 10 / 20 Fixed Yes, automatic recovery. Hiccup style on MTW30 & 60 V1: Zener Clamp V1: Zener Clamp V1 & V2: Zener Clamp -20°C start up. -10°C to +60°C, derating linearily to 70% load above 50°C -30°C to +75°C 10 - 90%RH (Operating & storage) at 35°C Convection Input to ground 2kVAC, Input to output 3kVAC, Output to ground 500VAC 5 - 10Hz: 10mm amplitude, 10 - 200Hz: 2G (19.6m/s2)10m sweep time, 3 axis, 1 hour each Acceleration: 60G (588m/s2) Half sine wave, 6 - 16ms pulse duration, 3x each direction IEC/UL/CSA/EN62368-1, 60950-1, CE Mark EN61000-4-2 (Lv 4), -3, -4 (Lv 3), -5 (Lv 4), -6 (Lv 3), -8 (Lv 4), -11 FCC-Class B, EN55011-B, EN55022-B 150 210 330 50 x 26 x 127 65 x 26 x 140 83 x 26 x 185 3 (2) Output V1 is isolated from outputs V2 & V3 MTW15-51212 MTW15-51515 MTW Series 1 M ode l Se l e c tor MTW15-51212 V1 V2 V3 V1 V2 V3 V1 V2 V3 V1 V2 V3 V1 V2 V3 V1 V2 V3 MTW15-51515 MTW30-51212 MTW30-51515 MTW60-51212 MTW60-1515 Mating Connectors Connectors JST 2 Voltage (V) Output Model Model MTW15 MTW30 MTW60 5V 12V -12V 5V 15V -15V 5V 12V -12V 5V 15V -15V 5V 12V -12V 5V 15V -15V Input B3P5-VH-B B3P5-VH-B B3P5-VH-B Minimum Regulation Current (A) 4.75 - 5.25V 11.4 - 12.6V 11.4 - 12.6V 4.75 - 5.25V 14.4 - 15.6V 14.4 - 15.6V 4.9 - 5.3V 11.4 - 12.6V 11.4 - 12.6V 4.9 - 5.3V 14.25 - 15.75V 14.25 - 15.75V 4.9 - 5.3V 11.4 - 12.6V 11.4 - 12.6V 4.9 - 5.3V 14.25 - 15.75V 14.25 - 15.75V 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Output B8B-XH-2 B6P-VH-B B8P-VH-B MTW Series Maximum Current (A) 2.0 0.3 0.2 2.0 0.3 0.2 3 1.2 0.3 3 0.8 0.3 5.0 2.5 0.5 5.0 2.0 0.5 Peak Current (A) 3.0 0.6 0.3 3.0 0.6 0.3 4.5 2.0 0.45 4.5 2.0 0.45 7.0 3.5 0.7 7.0 3.5 0.7 Ripple & Noise (mV) 120 150 150 120 150 150 120 150 150 120 150 150 120 150 150 120 150 150 Outline Drawing MTW15 Series Outline Drawing MTW30 Series MTW Series 3 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en MTW Jan21 v4 4 MTW Series For Additional Information, please visit https://product.tdk.com/en/power/
MTW15-51515 价格&库存
很抱歉,暂时无法提供与“MTW15-51515”相匹配的价格&库存,您可以联系我们找货
MTW15-51515
    • 1+256.890441+33.33969
    • 3+223.820673+29.04784
    • 4+219.693154+28.51216
    • 5+217.211675+28.19011
    • 9+212.802929+27.61794
    • 10+212.2487310+27.54601
    • 20+209.7672520+27.22396
    库存:50
    MTW15-51515
      • 1+411.577241+53.41522
      • 2+384.314122+49.87696
      • 3+375.231923+48.69826
      • 4+370.682554+48.10783
      • 5+367.961205+47.75465
      • 9+363.114069+47.12558
      • 10+362.5102310+47.04721
      库存:33
      MTW15-51515
        • 1+276.312111+35.86027
        • 3+239.420863+31.07246
        • 4+234.805324+30.47345
        • 5+232.034345+30.11383
        • 9+227.121039+29.47617
        • 10+226.5006610+29.39565
        • 20+223.7379520+29.03711
        库存:79
