N E B U L I Z E R S
August 2021
Ultrasonic Nebulizer Units
Humidifier for mist generating system
Incorporate type
NB series
NB-59S-09S-0
NB-80E-01-H
(1/4)
N E B U L I Z E R S
Incorporate type
Overview of NB series
The TDK ultrasonic humidifier unit was the first such product in the world to be developed. There is an increasing need for indoor
humidification due to the proliferation of clean air heat pumps and central heating systems.
When the appropriate amount of humidity is added as determined by the relationship between humidity and sensible temperature
(temperature perceived by the body), humidification is advantageous from the standpoint of both health and reduced energy consumption.
In addition to such home uses, these ultrasonic humidifier units have numerous advantages for humidification of vegetable showcases,
preservation and growth of agricultural products, industrial applications, etc. A wide variety of standard units are available from TDK.
EXAMPLE OF ATOMIZATION CHAMBER
CONSTRUCTION
Tilt directions of the transducer
NB-59S-09S Type
Mist discharge tube
Atomization chamber
Air-flow
Air-flow
Transducer
35 to 45mm
Mist
TYPICAL TRANSDUCER INSTALLATION
Water tank
The direction of
water column
Transducer
(tilted about 7°)
13mm
Float switch
Transducer
Drive
circuit
Fan moter
The arrows indicate the tilt direction
of the transducer.
Power transformer
Ultrasonic humidifier unit
The tilt direction of transtucer will be the
same as the direction of water column.
TYPICAL CHARACTERISTICS OF HUMIDIFIER UNITS
WATER TEMPERATURE CHARACTERISTICS(48V)
WATER LEVEL CHARACTERISTICS
+40
–30 –20 –10
(33.6V) (38.4V) (43.2V)
–40
Input voltage ratio (%)
48V+10 +20 +30
(52.8V) (57.6V) (62.4V)
–20
700
Mist output (ml/hr)
+20
Mist output (ml/hr)
Mist generation
ratio(%)
[0%=550(ml/hr)]
VOLTAGE CHARACTERISTICS(48V)
600
500
600
48V series
400
200
12V series
–60
10
40
Water temperature (˚C)
50
30
35
40
45
Water level (mm)
50
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20210824 / nebulizer_nb_en.fm
(2/4)
N E B U L I Z E R S
NB-59S-09S type
FEATURES
Compact, with highly reliable circuitry.
Separate transducer and drive circuit sections provide superior layout versatility.
SHAPE & DIMENSIONS
1C
5
24±0.2
20±0.2
2-ø4.5
Transistor
22±0.5
54±1
7±0.2
Aluminum base
Driver
circuit
area
(2-C3)
PCB
20max.
68
3max.
42±0.5
32±0.2
9
30±0.5
ø24±0.4
4.5max.
100±10
Transducer
Yellow
AWG-24
Orange
AWG-24
Supporting
rubber
Dimensions in mm
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Part No.
Rated input voltage
Eac(V)
Edc(V)
Power consumption (W)
Mist output ratio (l/h)
Ultrasonic frequency (kHz)
Normal water level (mm)
External potentiometer (k )
Operating water temperature range (°C)
Water quality
Transducer element life (h)
Cooling method
Parallel connected operation
Weight (g)
Main application
NB-59S-09S-0
48±10%
48±10%
30±5
45010–3min.
1600 to 1720
40
0 to 50
Drinking water
10000
Water cooled
Yes
60
Various humidity control systems
• The character at the end of the product number indicates the transducer’s direction of tilt.
(3/4)
N E B U L I Z E R S
NB-80E-01 type
FEATURES
Because the ultrasonic frequencies used are higher than with typical household-type units, mist particle size is extremely fine. This part
is thus ideal for products intended for smaller spaces.
SHAPE & DIMENSIONS
43.5max.
32±0.2
ø24±0.4
31.5max.
ø18±0.3
4.5max.
18max.
40±0.2
32.5±0.2
2-ø3.5
120±15
21max.
26max.
1±0.2
63C
2-ø4.5±0.2
5max.
NO.
NB-80E-01
2-R15.6
TU-51X-H
4123
TYPE
65max.
9.5max.
32.25±0.2
53±0.2
Connector for VR(3 poles)
SB3P-HVQ-CA(LF)(SN)
Maker: JST
2-R5.5
Dimensions in mm
Connector for power supply(2 poles)
SB2P-HVQ-CA(LF)(SN)
Maker: JST
Part No.
Rated input voltage
Eac(V)
Edc(V)
Water quality
Cooling method
Weight (g)
Main application
NB-80E-01-H
12±10%
13.2max.
(150+100, –50)10–3
2350 to 2600
35
10
0 to 50
Drinking water
5000
Air cooled
Yes
60
Microparticle applications such as for medical use
(4/4)
N E B U L I Z E R S
Mountings (Reference)
PRECAUTIONS
These units are readily damaged by operation when empty
ø24.8
(without water). Therefore a means (float switch, etc.) should be
ø18
provided to assure operation does not occur when empty.
Tank base
Contact TDK prior to use of this unit for applications utilizing
Rubber packing
liquids other than drinking water.
The unit should be used only after sufficient consideration of the
Plastic case
product specifications for that specific unit.
(Metal case)
When using units in parallel, make sure that voltage differences
do not occur between the individual transducers.
Screw:M4×15
Do not use the unit to atomize a liquid other than drinking water.
Dimensions in mm
Doing so can deteriorate the transducer.
Do not operate the transducer when the atomization unit tank is
The transducer can beak off if the A dimension depth is shallow.
not charged with drinking water.
TDK recommends a 2mm A-dimension depth and a screw
Drain water from the transducer and clean the equipment into
tightening torque of 0.39N • m.
which the unit is incorporated if not used for a long period of time.
Clean the transducer periodically to prevent any degradation in
2.CONSTRUCTION OF NB59S
the atomizing capacity due to buildup in the transducer of such
The drawing below shows an example method for transistor heat
substances as calcium, sodium, magnesium, and silicon,
dissipation. The attached aluminum cooling fins should fixed using
commonly found in drinking water.
silicon rubber to a metallic water tank, etc. with sufficient head
TDK is not responsible for damage to the transducer resulting
dissipation capacity.
from use of oscillator circuitry not supplied or not approved by
(It is recommended to use a plastic water tank. However, if a metallic
TDK.
water tank is absolutely must be used, be sure to insulate it from the
TDK is not responsible for worsening of unit performance
power supply line.)
resulting from operation in environments other than those
Metal tank
P.C. board
Silicon rubber
recommended, storage in environments other than those
recommended, or use of the unit in configurations other than
those recommended by TDK for efficient mist generation.
TDK is not responsible for the vaporization of pathogenic bacteria
or particles, not responsible if drinking water contains substances
that impede vaporization, and not responsible for bacterial growth
Aluminum radiation board
Transducer unit
due to lack of a water purification function.
Please select a plastic material of construction for the water tank
design. Metallic construction can result in electrolytic corrosion
between the chamber base and water tank.
Furthermore, if multiple units are used with the same tank, and if
each unit is equipped to be separately turned ON/OFF, the power
supply terminal for each unit should use a double-pole switch.
A
1.NB59S, NB-80E TYPES
很抱歉,暂时无法提供与“NB-59S-09S-0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+770.595701+100.15421
- 5+714.119065+92.81395
- 10+693.0880710+90.08055
- 25+667.9212925+86.80963
- 50+650.6936850+84.57056
