NB-80E-01-H
NB-80E-01-H
    TDK(东电化)
    NB-80E-01-H
NB-80E-01-H 数据手册
N E B U L I Z E R S August 2021 Ultrasonic Nebulizer Units Humidifier for mist generating system Incorporate type NB series NB-59S-09S-0 NB-80E-01-H (1/4) N E B U L I Z E R S Ultrasonic Nebulizer Units Incorporate type Overview of NB series The TDK ultrasonic humidifier unit was the first such product in the world to be developed. There is an increasing need for indoor humidification due to the proliferation of clean air heat pumps and central heating systems. When the appropriate amount of humidity is added as determined by the relationship between humidity and sensible temperature (temperature perceived by the body), humidification is advantageous from the standpoint of both health and reduced energy consumption. In addition to such home uses, these ultrasonic humidifier units have numerous advantages for humidification of vegetable showcases, preservation and growth of agricultural products, industrial applications, etc. A wide variety of standard units are available from TDK. EXAMPLE OF ATOMIZATION CHAMBER CONSTRUCTION Tilt directions of the transducer NB-59S-09S Type Mist discharge tube Atomization chamber Air-flow Air-flow Transducer 35 to 45mm Mist TYPICAL TRANSDUCER INSTALLATION Water tank The direction of water column Transducer (tilted about 7°) 13mm Float switch Transducer Drive circuit Fan moter The arrows indicate the tilt direction of the transducer. Power transformer Ultrasonic humidifier unit  The tilt direction of transtucer will be the same as the direction of water column. TYPICAL CHARACTERISTICS OF HUMIDIFIER UNITS WATER TEMPERATURE CHARACTERISTICS(48V) WATER LEVEL CHARACTERISTICS +40 –30 –20 –10 (33.6V) (38.4V) (43.2V) –40 Input voltage ratio (%) 48V+10 +20 +30 (52.8V) (57.6V) (62.4V) –20 700 Mist output (ml/hr) +20 Mist output (ml/hr) Mist generation ratio(%) [0%=550(ml/hr)] VOLTAGE CHARACTERISTICS(48V) 600 500 600 48V series 400 200 12V series –60 10 20 30 40 Water temperature (˚C) 50 30 35 40 45 Water level (mm) 50 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210824 / nebulizer_nb_en.fm (2/4) N E B U L I Z E R S NB-59S-09S type FEATURES Compact, with highly reliable circuitry. Separate transducer and drive circuit sections provide superior layout versatility. SHAPE & DIMENSIONS 1C 5 24±0.2 20±0.2 2-ø4.5 Transistor 22±0.5 54±1 7±0.2 Aluminum base Driver circuit area (2-C3) PCB 20max. 68 3max. 42±0.5 32±0.2 9 30±0.5 ø24±0.4 4.5max. 100±10 Transducer Yellow AWG-24 Orange AWG-24 Supporting rubber Dimensions in mm ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part No. Rated input voltage Eac(V) Edc(V) Power consumption (W) Mist output ratio (l/h) Ultrasonic frequency (kHz) Normal water level (mm) External potentiometer (k ) Operating water temperature range (°C) Water quality Transducer element life (h) Cooling method Parallel connected operation Weight (g) Main application NB-59S-09S-0 48±10% 48±10% 30±5 45010–3min. 1600 to 1720 40 — 0 to 50 Drinking water 10000 Water cooled Yes 60 Various humidity control systems • The character at the end of the product number indicates the transducer’s direction of tilt. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210824 / nebulizer_nb_en.fm (3/4) N E B U L I Z E R S NB-80E-01 type FEATURES Compact, with highly reliable circuitry. Separate transducer and drive circuit sections provide superior layout versatility. Because the ultrasonic frequencies used are higher than with typical household-type units, mist particle size is extremely fine. This part is thus ideal for products intended for smaller spaces. SHAPE & DIMENSIONS 43.5max. 32±0.2 ø24±0.4 31.5max. ø18±0.3 4.5max. 18max. 40±0.2 32.5±0.2 2-ø3.5 120±15 21max. 26max. 1±0.2 63C 2-ø4.5±0.2 5max. NO. NB-80E-01 2-R15.6 TU-51X-H 4123 TYPE 65max. 9.5max. 32.25±0.2 53±0.2 Connector for VR(3 poles) SB3P-HVQ-CA(LF)(SN) Maker: JST 2-R5.5 Dimensions in mm Connector for power supply(2 poles) SB2P-HVQ-CA(LF)(SN) Maker: JST ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part No. Rated input voltage Eac(V) Edc(V) Power consumption (W) Mist output ratio (l/h) Ultrasonic frequency (kHz) Normal water level (mm) External potentiometer (k ) Operating water temperature range (°C) Water quality Transducer element life (h) Cooling method Parallel connected operation Weight (g) Main application NB-80E-01-H − 12±10% 13.2max. (150+100, –50)10–3 2350 to 2600 35 10 0 to 50 Drinking water 5000 Air cooled Yes 60 Microparticle applications such as for medical use • The character at the end of the product number indicates the transducer’s direction of tilt. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210824 / nebulizer_nb_en.fm (4/4) N E B U L I Z E R S Mountings (Reference) PRECAUTIONS These units are readily damaged by operation when empty ø24.8 (without water). Therefore a means (float switch, etc.) should be ø18 provided to assure operation does not occur when empty. Tank base Contact TDK prior to use of this unit for applications utilizing Rubber packing liquids other than drinking water. The unit should be used only after sufficient consideration of the Plastic case product specifications for that specific unit. (Metal case) When using units in parallel, make sure that voltage differences do not occur between the individual transducers. Screw:M4×15 Do not use the unit to atomize a liquid other than drinking water. Dimensions in mm Doing so can deteriorate the transducer. Do not operate the transducer when the atomization unit tank is The transducer can beak off if the A dimension depth is shallow. not charged with drinking water. TDK recommends a 2mm A-dimension depth and a screw Drain water from the transducer and clean the equipment into tightening torque of 0.39N • m. which the unit is incorporated if not used for a long period of time. Clean the transducer periodically to prevent any degradation in 2.CONSTRUCTION OF NB59S the atomizing capacity due to buildup in the transducer of such The drawing below shows an example method for transistor heat substances as calcium, sodium, magnesium, and silicon, dissipation. The attached aluminum cooling fins should fixed using commonly found in drinking water. silicon rubber to a metallic water tank, etc. with sufficient head TDK is not responsible for damage to the transducer resulting dissipation capacity. from use of oscillator circuitry not supplied or not approved by (It is recommended to use a plastic water tank. However, if a metallic TDK. water tank is absolutely must be used, be sure to insulate it from the TDK is not responsible for worsening of unit performance power supply line.) resulting from operation in environments other than those Metal tank P.C. board Silicon rubber recommended, storage in environments other than those recommended, or use of the unit in configurations other than those recommended by TDK for efficient mist generation. TDK is not responsible for the vaporization of pathogenic bacteria or particles, not responsible if drinking water contains substances that impede vaporization, and not responsible for bacterial growth Aluminum radiation board Transducer unit due to lack of a water purification function. Please select a plastic material of construction for the water tank design. Metallic construction can result in electrolytic corrosion between the chamber base and water tank. Furthermore, if multiple units are used with the same tank, and if each unit is equipped to be separately turned ON/OFF, the power supply terminal for each unit should use a double-pole switch. A 1.NB59S, NB-80E TYPES Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210824 / nebulizer_nb_en.fm
NB-80E-01-H 价格&库存
很抱歉,暂时无法提供与“NB-80E-01-H”相匹配的价格&库存,您可以联系我们找货
NB-80E-01-H
    • 1+325.16640
    • 200+125.84160
    • 500+121.41360
    • 1000+119.23200
    NB-80E-01-H
    • 1+1047.730221+136.17334
    • 5+974.355395+126.63683
    • 10+946.9971910+123.08108
    • 25+914.2618625+118.82648
    • 50+891.8495750+115.91356
    库存:241
    NB-80E-01-H
