NL201614T-2R2K
NL201614T-2R2K
    TDK(东电化)
    NL201614T-2R2K - For General Applications - TDK Electronics
NL201614T-2R2K 数据手册
511_NL2016 (1/2) Inductors For General Applications SMD FEATURES • The NL series are available in five form factors ranging from 2016 to 5650. • Utilizing a miniaturized winding structure, these products provide high Q characteristics. • Inductance tolerance is ±5 percent. APPLICATIONS Personal computers, hard disk drives, and other electronic equipment. SPECIFICATIONS Operating temperature range Storage temperature range –20 to +85°C –40 to +85°C [Unit of products] NL Series NL2016 Type FLUX AND CLEANING Rosin-based flux is recommended. Cleaning Conditions Solvent Time Chlorine-based solvent (Do not use acid or alkali solvents.) 2min max. PRODUCT IDENTIFICATION NL (1) 201614 T- 2R2 J (2) (3) (4) (5) (1)Series name (2)Dimensions L×W×T 201614 252018 322522 453232 565050 2.1×1.6×1.4mm 2.5×2.0×1.8mm 3.2×2.5×2.2mm 4.5×3.2×3.2mm 5.6×5.0×5.0mm RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 10s max. 230°C 200°C 150°C 100°C Preheating: 120s Time (s) Natural cooling 30s max. (3)Packaging style T Taping (reel) (4)Inductance value 1R0 330 1µH 33µH FLOW SOLDERING 10s max. 260°C Natural cooling (5)Inductance tolerance J K ±5% ±10% 150°C 100°C Preheating: 120s Time (s) PACKAGING STYLE AND QUANTITIES Packaging style Taping Type NL201614T NL252018T NL322522T NL453232T NL565050T Quantity 2000 pieces/reel 2000 pieces/reel 2000 pieces/reel 500 pieces/reel 400 pieces/reel IRON SOLDERING Perform soldering at 250°C on 30W max. within 5 seconds. VAPOR-PHASING 10s max. 220°C 215°C 150°C 100°C Preheating: 120s Time (s) Natural cooling 30s max. Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. 511_NL2016 (2/2) Inductors For General Applications SMD NL Series NL2016 Type SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 2.1± 0.2 1.4 ± 0.2 0.5 Terminal electrode (0.4) 1.6 ± 0.2 0.8 1 0.8 0.8 ± 0.1 Weight: 15mg 1 Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 Inductance tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Q min. 15 15 15 15 15 15 10 10 10 10 Test frequency L, Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 Self-resonant frequency (MHz)min. 63 60 58 50 43 36 30 23 20 17 DC resistance (Ω)max. 1.2 1.45 1.8 2.3 2.8 3.4 4.7 6.5 8 10.7 Rated current (mA)max. 245 225 200 175 140 115 98 80 68 60 Part No. NL201614T-1R0J NL201614T-1R5J NL201614T-2R2J NL201614T-3R3J NL201614T-4R7J NL201614T-6R8J NL201614T-100J NL201614T-150J NL201614T-220J NL201614T-330J • Inductance tolerance is only standard. • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER (16085A+16093B+TDK TF-1) SRF:HP8753C NETWORK ANALYZER Rdc:MATSUSHITA VP-2941A DIGITAL MILLIOHM METER TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE vs. FREQUENCY IMPEDANCE vs. FREQUENCY CHARACTERISTICS CHARACTERISTICS 100 33µH 30 10µH 10 30 100 INDUCTANCE vs. DC SUPERPOSITION CHARACTERISTICS 100 Universal bridge 1000 Test circuit DC L=5H C=20000µF A Specimen YHP model-4255A or equivalent 33µH 33µH 30 10µH 10 Inductance (µH) 3 Impedance (kΩ) 1µH 3 10µH Inductance (µH) 10 3 1µH 1 1 1 0.3 1µH 0.3 0.3 0.1 0.1 0.3 1 3 Frequency (MHz) 10 30 0.1 0.1 1 0.03 3 100 10 30 DC current (mA) 300 INDUCTANCE CHANGE vs. TEMPERATURE CHARACTERISTICS ∆L/L (25°C) 0.01 0.1 0.3 1 3 Frequency (MHz) 10 30 Q vs. FREQUENCY CHARACTERISTICS 100 80 Test equipment: YHP 4194A IMPEDANCE ANALYZER 5 33µH Q 1.5µH 60 20 40 80 Temperature (°C) 10µH 60 40 10µH 20 0 0.1 1 Frequency (MHz) 33µH 10 1µH – 40 – 20 0 –5 511_NL2016 990818 Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice.
NL201614T-2R2K 价格&库存
很抱歉,暂时无法提供与“NL201614T-2R2K”相匹配的价格&库存,您可以联系我们找货
