Discontinue Issue Date
Last Purchase Order Date
Last Shipment Date
May 28, 2020
Mar. 31, 2022
Sep. 30, 2022
• Please refer to our Web site about replacement information.
I N D U C T O R S
Inductors for standard circuits
Wound ferrite
NL series
RoHS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
NL453232 type
FEATURES
Resin mold type wound inductor for standard circuits.
E-12 series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as filter circuits.
Has excellent inductance temperature characteristics in the operating temperature range.
Operating temperature range: –40 to +105°C (including self-temperature rise)
APPLICATION
Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial equipment, other
PART NUMBER CONSTRUCTION
NL
Series name
453232
T
L×W×H dimensions
4.5×3.2×3.2 mm
Packaging style
1R0
J
Inductance
(µH)
Inductance
tolerance
PF
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
1
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
Q
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
min.
50
50
50
50
50
50
50
50
50
50
50
50
(MHz)
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
(MHz)min.
100
80
70
60
55
50
45
40
35
33
27
25
(Ω )max.
0.5
0.55
0.6
0.65
0.7
0.75
0.8
0.9
1
1.1
1.2
1.4
(mA)max.
450
430
410
390
380
370
355
330
315
300
285
270
NL453232T-1R0J-PF
NL453232T-1R2J-PF
NL453232T-1R5J-PF
NL453232T-1R8J-PF
NL453232T-2R2J-PF
NL453232T-2R7J-PF
NL453232T-3R3J-PF
NL453232T-3R9J-PF
NL453232T-4R7J-PF
NL453232T-5R6J-PF
NL453232T-6R8J-PF
NL453232T-8R2J-PF
Measurement equipment
Th
e
Measurement item
Product No.
L, Q
4294A
Self-resonant frequency
8753D
DC resistance
AX-114N
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
ADEX
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/6)
20200604
inductor_commercial_standard_nl453232_en.fm
I N D U C T O R S
NL453232 type
Q
(µH)
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1000
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
min.
50
50
50
50
50
50
50
50
50
50
50
50
40
40
40
40
40
40
40
40
40
30
30
30
30
(MHz)
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.252
(MHz)min.
17
15
13
12
11
10
10
9
9
8
8
6
5
5
4
4
3.5
3
3
3
3
2.5
2.5
(Ω )max.
1.6
2
2.5
2.8
3.2
3.6
4
4.5
5
5.5
6
7
8
8
9
9.5
10
12
14
16
26
30
30
35
40
(mA)max.
250
225
200
190
180
170
160
150
140
135
130
120
110
110
105
102
100
92
85
80
62
50
50
30
30
NL453232T-100J-PF
NL453232T-120J-PF
NL453232T-150J-PF
NL453232T-180J-PF
NL453232T-220J-PF
NL453232T-270J-PF
NL453232T-330J-PF
NL453232T-390J-PF
NL453232T-470J-PF
NL453232T-560J-PF
NL453232T-680J-PF
NL453232T-820J-PF
NL453232T-101J-PF
NL453232T-121J-PF
NL453232T-151J-PF
NL453232T-181J-PF
NL453232T-221J-PF
NL453232T-271J-PF
NL453232T-331J-PF
NL453232T-391J-PF
NL453232T-471J-PF
NL453232T-561J-PF
NL453232T-681J-PF
NL453232T-821J-PF
NL453232T-102J-PF
Manufacturer
ADEX
Th
e
Measurement item
Product No.
L, Q
4294A
E5063A
DC resistance
AX-114N
(2/6)
20200604
I N D U C T O R S
NL453232 type
L FREQUENCY CHARACTERISTICS
10000
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
100000
102J
821J
681J
561J
471J
391J
121J
1000
331J
271J
221J
181J 820J
680J
151J
101J
470J
560J
Inductance(µH)
390J
330J
270J
220J
180J
150J
120J
100
100J
8R2J
6R8J
5R6J
4R7J
3R9J
3R3J
10
2R7J
2R2J
1R8J
1R5J
1R2J
1R0J
1
0.1
0.01
0.1
1.0
10
100
1000
Frequency(MHz)
Th
e
Product No.
Manufacturer
4294A
(3/6)
20200604
I N D U C T O R S
NL453232 type
Q FREQUENCY CHARACTERISTICS
90
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
100
1R5J
1R0J
2R2J
80
4R7J
1R2J
5R6J
2R7J
470J
70
560J
6R8J
3R3J
60
120J
8R2J
680J
Q
331J
50
100J
150J
271J
40
471J
221J
820J
220J
101J
330J
30
391J
270J
681J
390J
121J
3R9J
821J
1R8J
10
181J
151J
180J
102J
561J
0.1
1.0
10
100
1000
Frequency(MHz)
Th
e
Product No.
Manufacturer
4294A
(4/6)
20200604
I N D U C T O R S
NL453232 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
4.5±0.3
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
R0.2
0.5
2.6±0.1
102J
3.2±0.2
2.0±0.5
(0.6)
0.5
(3.3)
(0.6)
ø60
3.2±0.2
C0.5
(1.0)
Dimensions in mm
ø13.0±0.5
13
ø21.0±0.8
17
ø180
Dimensions in mm
Sprocket
hole
1.5
3
B
2.8
2.00±0.05 4.00±0.10
1.5
Dimensions in mm
K
12.0±0.30
1.5 +0.1
–0
0.4
5.50±0.05
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
Cavity
A
8.00±0.10
Dimensions in mm
Type
NL453232
Package quantity
Soldering
Natural
cooling
255°C
230°C
Th
e
Temperature
K
3.2
500 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Peak
230°C
B
4.9
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
A
3.6
Operating
Storage
Individual
temperature range
temperature range
weight
–40 to +105 °C
–40 to +105 °C
180 mg
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
180°C
10s max.
150°C
90 to 120s
40s
Time
(5/6)
20200604
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(6/6)
20200604
很抱歉,暂时无法提供与“NL453232T-1R8J-PF”相匹配的价格&库存,您可以联系我们找货
