NL565050T-103J-PF
NL565050T-103J-PF
    TDK(东电化)
    2220(5650公制)
    固定电感器 2220 10mH ±5% 25mA 150Ω 500KHz 20@79.6KHz
NL565050T-103J-PF 数据手册
I N D U C T O R S December 2015 Inductors for Standard Circuits Wound Ferrite NL Series NL565050 Type NL565050 5650 [2220 inch]* * Dimensions Code JIS[EIA] Caution The products in this catalog will be or have been stopped production Discontinue Issue Date May.21, 2015 Last Purchase Order Date Dec.22, 2016 Last Shipment Date Jan.30, 2017 Please refer to our Web site about replacement information. (2/9) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. Th e (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20151217 / inductor_commercial_standard_nl565050_en.fm (3/9) I N D U C T O R S Inductors for Standard Circuits Product compatible with RoHS directive Compatible with lead-free solders Wound Ferrite pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Overview of NL565050 Type FEATURES Resin mold type wound inductor for standard circuits. E-12 Series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as filter circuits. Has excellent inductance temperature characteristics in the operating temperature range. APPLICATION Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial equipment, other PART NUMBER CONSTRUCTION NL Series name 565050 L×W×H Dimensions (mm) 565050 5.6×5.0×5.0 T Packaging style T Taping - 1R0 J Inductance (mH) 102 1 103 10 Inductance tolerance J ±5% - PF Internal code OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Package quantity Individual weight (mg) 380 Th e Operating Storage Type temperature temperature (pieces/reel) (°C) (°C) NL565050 –40 to +105 –40 to +105 400 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (4/9) I N D U C T O R S NL565050 Type RECOMMENDED REFLOW PROFILE Soldering Natural cooling pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Preheating Peak T: Temperature T4 T3 T2 T1 t1 T3 t3 t2 t: Time Time t1 90 to 120s Soldering Temp. Time T3 t2 230°C 40s Peak Temp. T4 255°C Time t3 10s max. Th e Preheating Temp. T1 T2 150°C 180°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (5/9) I N D U C T O R S NL565050 Type pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SHAPE & DIMENSIONS 5±0.3 4±0.2 5.6±0.3 472J C1 (0.5) (4.6) (0.5) 5±0.3 1 Dimensions in mm 4.5 RECOMMENDED LAND PATTERN 4 2 Dimensions in mm Th e 2 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (6/9) I N D U C T O R S NL565050 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE (mH) 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10  Q L, Q measuring frequency Self-resonant frequency DC resistance Rated current Part No. min. 30 30 30 30 30 30 30 30 30 30 30 20 (MHz) 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.0796 (MHz)min. 1.5 1.4 1.3 1.2 1.1 1 1 0.9 0.8 0.7 0.6 0.5 (ȍ )max. 17 20 30 35 55 60 70 78 85 110 125 150 (mA)max. 75 70 60 55 45 40 38 36 33 30 28 25 NL565050T-122J-PF NL565050T-152J-PF NL565050T-182J-PF NL565050T-222J-PF NL565050T-272J-PF NL565050T-332J-PF NL565050T-392J-PF NL565050T-472J-PF NL565050T-562J-PF NL565050T-682J-PF NL565050T-822J-PF NL565050T-103J-PF pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L Tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (10% below the initial value) Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating) Manufacturer Agilent Technologies Agilent Technologies Panasonic Th e ○ Measurement equipment Measurement item Product No. L, Q 4194A Self-resonant frequency 8753C DC resistance VP-2941A * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (7/9) I N D U C T O R S NL565050Type ELECTRICAL CHARACTERISTICS 100000 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L FREQUENCY CHARACTERISTICS GRAPH 103J 100000 822J 392J 682J 562J 472J 332J 272J 222J 182J 152J Inductance(μH) 10000 1000 100 10 0.01 0.1 Frequency(MHz) 1 10 Th e 1 0.001 122J ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (8/9) I N D U C T O R S NL565050 Type ELECTRICAL CHARACTERISTICS 60 50 40 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Q FREQUENCY CHARACTERISTICS GRAPH 332J 562J 472J Q 182J 30 222J 822J 20 272J 682J 152J 10 392J 122J 103J 0.01 0.1 Frequency(MHz) 1 10 Th e 0 0.001 ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm (9/9) I N D U C T O R S NL565050 Type PACKAGING STYLE pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en REEL DIMENSIONS 2.0±0.5 E Type NL565050 A ø180 W1 13 W2 17 N ø60 E 0.5 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 A A 5.4 B 5.8 øD0 1.5+0.1/-0 t Dimensions in mm E F P0 P1 P2 W 1.75±0.1 5.50±0.05 4.00±0.10 8.00±0.10 2.00±0.05 12.0±0.30 K 5.4 t 0.4 Th e Type NL565050 B W F E øD0 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_standard_nl565050_en.fm
NL565050T-103J-PF 价格&库存
很抱歉,暂时无法提供与“NL565050T-103J-PF”相匹配的价格&库存,您可以联系我们找货
