I
N
D
U
C
T
O
R
S
December 2015
Inductors for Standard Circuits
Wound Ferrite
NL Series
NL565050 Type
NL565050
5650 [2220 inch]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
May.21, 2015
Last Purchase Order Date
Dec.22, 2016
Last Shipment Date
Jan.30, 2017
Please refer to our Web site about replacement information.
(2/9)
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151217 / inductor_commercial_standard_nl565050_en.fm
(3/9)
I
N
D
U
C
T
O
R
S
Product compatible with RoHS directive
Compatible with lead-free solders
Wound Ferrite
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Overview of NL565050 Type
FEATURES
Resin mold type wound inductor for standard circuits.
E-12 Series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as
filter circuits.
Has excellent inductance temperature characteristics in the operating temperature range.
APPLICATION
Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial
equipment, other
PART NUMBER CONSTRUCTION
NL
Series name
565050
L×W×H Dimensions
(mm)
565050
5.6×5.0×5.0
T
Packaging style
T
Taping
1R0
J
Inductance
(mH)
102
1
103
10
Inductance
tolerance
J
±5%
PF
Internal code
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Individual weight
(mg)
380
Th
e
Operating
Storage
Type
temperature
temperature
(pieces/reel)
(°C)
(°C)
NL565050
–40 to +105
–40 to +105
400
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I
N
D
U
C
T
O
R
S
NL565050 Type
RECOMMENDED REFLOW PROFILE
Soldering
Natural
cooling
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Preheating
Peak
T: Temperature
T4
T3
T2
T1
t1
T3
t3
t2
t: Time
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
Th
e
Preheating
Temp.
T1
T2
150°C
180°C
(5/9)
I
N
D
U
C
T
O
R
S
NL565050 Type
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SHAPE & DIMENSIONS
5±0.3
4±0.2
5.6±0.3
472J
C1
(0.5)
(4.6)
(0.5)
5±0.3
1
Dimensions in mm
4.5
RECOMMENDED LAND PATTERN
4
2
Dimensions in mm
Th
e
2
(6/9)
I
N
D
U
C
T
O
R
S
NL565050 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
(mH)
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
Q
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
min.
30
30
30
30
30
30
30
30
30
30
30
(MHz)
0.252
0.252
0.252
0.252
0.252
0.252
0.252
0.252
0.252
0.252
0.252
0.0796
(MHz)min.
1.5
1.4
1.3
1.2
1.1
1
1
0.9
0.8
0.7
0.6
0.5
(ȍ )max.
17
35
55
60
70
78
85
110
125
150
(mA)max.
75
70
60
55
45
40
38
36
33
30
28
25
NL565050T-122J-PF
NL565050T-152J-PF
NL565050T-182J-PF
NL565050T-222J-PF
NL565050T-272J-PF
NL565050T-332J-PF
NL565050T-392J-PF
NL565050T-472J-PF
NL565050T-562J-PF
NL565050T-682J-PF
NL565050T-822J-PF
NL565050T-103J-PF
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial value)
Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating)
Manufacturer
Agilent Technologies
Panasonic
Th
e
○ Measurement equipment
Measurement item
Product No.
L, Q
4194A
Self-resonant frequency
8753C
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
(7/9)
I
N
D
U
C
T
O
R
S
NL565050Type
100000
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L FREQUENCY CHARACTERISTICS GRAPH
103J
100000
822J
392J
682J
562J
472J
332J
272J
222J
182J
152J
Inductance(μH)
10000
1000
100
10
0.01
0.1
Frequency(MHz)
1
10
Th
e
1
0.001
122J
Product No.
Manufacturer
4294A
(8/9)
I
N
D
U
C
T
O
R
S
NL565050 Type
60
50
40
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Q FREQUENCY CHARACTERISTICS GRAPH
332J
562J
472J
Q
182J
30
222J
822J
272J
682J
152J
10
392J
122J
103J
0.01
0.1
Frequency(MHz)
1
10
Th
e
Product No.
Manufacturer
4294A
(9/9)
I
N
D
U
C
T
O
R
S
NL565050 Type
PACKAGING STYLE
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
REEL DIMENSIONS
2.0±0.5
E
Type
NL565050
A
ø180
W1
13
W2
17
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
A
A
5.4
B
5.8
øD0
1.5+0.1/-0
t
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 5.50±0.05 4.00±0.10 8.00±0.10 2.00±0.05 12.0±0.30
K
5.4
t
0.4
Th
e
Type
NL565050
B
W
F
E
øD0
很抱歉,暂时无法提供与“NL565050T-122J-PF”相匹配的价格&库存,您可以联系我们找货
