NLC453232T-150K-PF
NLC453232T-150K-PF
    TDK(东电化)
    1812(4532公制)
    信号/去耦电感 15µH 450mA ±10% 700mΩ 1812
NLC453232T-150K-PF 数据手册
Inductors for Decoupling Circuits Wound/For Current NLCV/NLC series Type: NLCV25 NLCV32 NLCV25T-R NLCV32T-R NLC453232 NLC565050 2520[1008 inch]* 3225[1210 inch] 2520[1008 inch] 3225[1210 inch] 4532[1812 inch] 5650[2220 inch] * Dimensions Code JIS[EIA] Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLCV Series NLCV25 FEATURES • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal • The electrical characteristics, reliability, shape and pad shape are the same as the previous NL series. • The product uses metal terminals, which realize excellent connection reliability. • Highly heat resistant thermoplastic resin is used to form the exterior package. • From 1µH to 33µH, all of the products are available in the E-6 series. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. APPLICATIONS • Audio-visual equipment including TVs, VCRs and digital cameras. • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Electronic equipment used in onboard automobile equipment including car audio and ECU systems. • Other electronic equipment including HDDs and ODDs. FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: approx.1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLCV 25 T- 2R2 M - PF (1) (2) (3) (4) (5) (6) (1) Series name SPECIFICATIONS Operating temperature range Storage temperature range –40 to +105°C [Including self-temperature rise] –40 to +105°C (2) Dimensions 25 2.5×2.0×1.8mm (L×W×T) (3) Packaging style RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING T Taping (reel) (4) Inductance value 10s max. 255˚C 230˚C Natural cooling 1R0 220 1µH 22µH (5) Inductance tolerance 180˚C K M 150˚C Pre-heating 90 to 120s ±10% ±20% 40s max. (6) Lead-free compatible product Time (s) PF EF Conformity to RoHS directive, exemption regulations apply Conformity to RoHS directive PACKAGING STYLE AND QUANTITIES Packaging style Taping Quantity 2000 pieces/reel • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (2/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 1.8±0.1 0.5 1.5 2±0.1 2.5±0.2 Terminal electrode 1.0 1.5 1.0 (0.4) 1.4±0.1 Dimensions in mm Weight:25mg ELECTRICAL CHARACTERISTICS Inductance(µH) Inductance tolerance Q ref. Test frequency L,Q (MHz) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% 20 20 20 20 20 20 30 30 30 30 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 Self-resonant frequency (MHz)min. 200 165 95 55 43 39 32 21 18 16 DC resistance (Ω)±30% Rated current∗1 (mA)max. Part No. 0.34 0.42 0.5 0.65 0.8 1 1.69 2.2 2.8 4.2 475 435 390 340 285 275 210 175 160 120 NLCV25T-1R0MNLCV25T-1R5MNLCV25T-2R2MNLCV25T-3R3MNLCV25T-4R7MNLCV25T-6R8MNLCV25T-100KNLCV25T-150KNLCV25T-220KNLCV25T-330K- ∗2 ∗1 Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify lead-free compatible product, PF (Conformity to RoHS directive, exemption regulations apply) or EF (Conformity to RoHS directive) • Test equipment L, Q: HP4194A IMPEDANCE/GAIN PHASE ANALYZER+HP16085A+HP16093 B+TF-1 SRF: HP8753C NETWORK ANALYZER Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 100 IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 30 22µH 30 22µH Impedance(kΩ) Inductance(µH) 10µH 10µH 10 4.7µH 3 2.2µH 2.2µH 1µH 3 1µH 1 1 0.3 0.1 4.7µH 10 0.3 10 30 1000 100 300 DC current(mA) 3000 10000 0.1 1 3 100 10 30 Frequency(MHz) 300 1000 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (3/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLCV Series NLCV32 FEATURES • This is a renewed version of NLC322522. • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal • The electrical characteristics, reliability, shape and pad shape are the same as the previous NL series. • The product uses metal terminals, which realize excellent connection reliability. • Highly heat resistant thermoplastic resin is used to form the exterior package. • From 1.0µH to 330µH, all of the products are available. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. FLOW SOLDERING APPLICATIONS • Audio-visual equipment including TVs, VCRs and digital cameras. • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Electronic equipment used in onboard automobile equipment including car audio and ECU systems. • Other electronic equipment including HDDs and ODDs. • Based on the above conditions, use a maximum product temperature of 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: approx.1mm 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLCV 32 T- 2R2 M - PF (1) (2) (3) (4) (5) (6) (1) Series name SPECIFICATIONS –40 to +105°C [Including self-temperature rise] –40 to +105°C Operating temperature range Storage temperature range (2) Dimensions 32 3.2×2.5×2.2mm (L×W×T) (3) Packaging style RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING Taping (reel) (4) Inductance value 10s max. 255˚C 230˚C T Natural cooling 1R0 100 101 1µH 10µH 100µH 180˚C (5) Inductance tolerance 150˚C Pre-heating 90 to 120s K M ±10% ±20% 40s max. (6) Lead-free compatible product Time (s) PF EF Conformity to RoHS directive, exemption regulations apply Conformity to RoHS directive PACKAGING STYLE AND QUANTITIES Packaging style Taping Quantity 2000 pieces/reel • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (4/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 0.5 Terminal electrode 2.5±0.2 1.2 2.2±0.2 3.2±0.2 2 1R0 (0.4) 1.9±0.1 Weight: 50mg 2 1.2 Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 Inductance tolerance ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Q ref. 10 10 10 10 15 15 15 15 15 15 15 15 15 20 20 20 Test frequency L,Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 Self-resonant frequency (MHz)min. 100 80 68 54 46 38 30 26 21 17 14 12 10 8 7 6 DC resistance (Ω )±30% 0.06 0.11 0.13 0.16 0.2 0.27 0.36 0.56 0.77 1.1 1.64 2.8 3.7 6.1 8.4 12.3 Rated current∗1 (mA)max. 1000 830 770 690 620 530 450 370 300 240 180 140 120 100 80 70 Part No. NLCV32T-1R0MNLCV32T-1R5MNLCV32T-2R2MNLCV32T-3R3MNLCV32T-4R7MNLCV32T-6R8MNLCV32T-100KNLCV32T-150KNLCV32T-220KNLCV32T-330KNLCV32T-470KNLCV32T-680KNLCV32T-101KNLCV32T-151KNLCV32T-221KNLCV32T-331K- ∗2 ∗1 Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify lead-free compatible product, PF (Conformity to RoHS directive, exemption regulations apply) or EF (Conformity to RoHS directive) • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER+YHP16085A+YHP16093B+TF-1, or equivalent SRF: HP8753C NETWORK ANALYZER Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent TYPICAL ELECTRICAL CHARACTERISTICS • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (5/14) INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000 500 330µH 500 50 100 100µH 50 220µH 22µH 10 100µH 47µH 47µH Impedance (kΩ) Inductance (µH) 100 330µH 220µH 10µH 22µH 10µH 10 4.7µH 5 5 1 0.5 1 1µH 1µH 5 10 50 100 DC current (mA) 500 1000 0.1 0.5 1 5 10 Frequency (MHz) 50 100 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (5/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLCV Series NLCV25T-R FEATURES • Rated current is maintained in the range of 1.7 to 2.0 times compared to the existing NLCV25 series. • Stable inductance, as the inductance change in the maximum rated current load is within –10%. • Maximum operating temperature is +125°C (including selftemperature rise). • Lead-free material is adopted for terminal soldering. • PC board pattern is compatible with the existing NLCV25 series. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. APPLICATIONS Power supply lines, audio visual systems, electronic equipment for vehicle, IT equipment IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLCV 25 T R10 M PF R (1) (2) (3) (4) (5) (6) (7) (1) Series name (2) Dimensions 25 2.5×2.0×1.8mm(L×W×T) (3) Packaging style SPECIFICATIONS –40 to +125°C [Including self-temperature rise] –40 to +125°C Operating temperature range Storage temperature range RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 10s max. 255˚C 230˚C T Taping (reel) (4) Inductance R10 1R0 100 0.1µH 1µH 10µH (5) Inductance tolerance Natural cooling 180˚C K M ±10% ±20% (6) Lead-free compatible product 150˚C PF Pre-heating 90 to 120s EF 40s max. Conformity to RoHS directive, exemption regulations apply Conformity to RoHS directive (7) TDK internal code Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (6/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 2±0.1 1.8±0.1 0.5 1.5 2.5±0.2 Terminal electrode 1.0 1.5 1.0 (0.4) 1.4±0.1 Dimensions in mm Weight:25mg ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q ref. Test frequency L,Q (MHz) 0.1 0.15 0.22 0.33 0.47 0.68 1 1.5 2.2 3.3 4.7 6.8 10 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±10% 5 5 5 5 5 5 10 10 10 10 10 10 15 25.2 25.2 25.2 25.2 25.2 25.2 7.96 7.96 7.96 7.96 7.96 7.96 2.52 Self-resonant frequency (MHz)min. 800 500 400 300 220 160 100 80 68 54 46 38 30 DC resistance (Ω )±20% Rated current (mA)max. Part No. 0.04 0.044 0.05 0.065 0.08 0.09 0.14 0.18 0.27 0.44 0.57 0.92 1.1 1890 1800 1690 1480 1340 1260 1000 890 730 570 500 390 360 NLCV25T-R10M- ∗R NLCV25T-R15M- R NLCV25T-R22M- R NLCV25T-R33M- R NLCV25T-R47M- R NLCV25T-R68M- R NLCV25T-1R0M- R NLCV25T-1R5M- R NLCV25T-2R2M- R NLCV25T-3R3M- R NLCV25T-4R7M- R NLCV25T-6R8M- R NLCV25T-100K- R ∗ : Please specify lead-free compatible product, PF (Conformity to RoHS directive, exemption regulations apply) or EF (Conformity to RoHS directive) • Test equipment L, Q: HP4194A IMPEDANCE ANALYZER+16085A+16093B+TF-1 SRF: HP8753C NETWORK ANALYZER Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE vs. FREQUENCY CHARACTERISTICS INDUCTANCE vs. DC SUPERPOSITION CHARACTERISTICS 100 100 10 10µH 4.7µH Inductance(µH) Inductance(µH) 10 2.2µH 1 1µH 0.47µH 0.01 4.7µH 1µH 0.47µH 0.1 0.01 1 2.2µH 1 0.22µH 0.22µH 0.1µH 0.1 10µH 10 Frequency (MHz) 100 0.1µH 1 10 100 DC current(mA) 1000 10000 IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100000 Impedance(Ω) 10000 10µH 4.7µH 2.2µH 1µH 1000 100 10 1 0.47µH 0.22µH 0.1µH 1 10 Frequency (MHz) 100 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (7/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLCV Series NLCV32T-R FEATURES • Rated current is maintained in the range of 1.4 to 2.0 times compared to the existing NLCV32 series. • Stable inductance, as the inductance change in the maximum rated current load is within –10%. • Maximum operating temperature is +125°C (including selftemperature rise). • Lead-free material is adopted for terminal soldering. • PC board pattern is compatible with the existing NLCV32 series. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. APPLICATIONS Power supply lines, audio visual systems, electronic equipment for vehicle, IT equipment IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLCV 32 T R10 M PF R (1) (2) (3) (4) (5) (6) (7) (1) Series name (2) Dimensions 32 3.2×2.5×2.2mm(L×W×T) (3) Packaging style SPECIFICATIONS –40 to +125°C [Including self-temperature rise] –40 to +125°C Operating temperature range Storage temperature range RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 10s max. 255˚C 230˚C T Taping (reel) (4) Inductance R10 1R0 100 0.1µH 1µH 10µH (5) Inductance tolerance Natural cooling 180˚C K M ±10% ±20% (6) Lead-free compatible product 150˚C PF Pre-heating 90 to 120s EF 40s max. Conformity to RoHS directive, exemption regulations apply Conformity to RoHS directive (7) TDK internal code Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (8/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Pattern 100 2.5±0.2 0.5 2.2±0.2 2 3.2±0.2 Terminal electrode 1.2 (0.4) 1.9±0.1 2 1.2 Dimensions in mm Weight: 50mg ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q ref. Test frequency L,Q (MHz) 0.1 0.15 0.22 0.33 0.47 0.68 1 1.5 2.2 3.3 4.7 6.8 10 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±10% 10 10 10 10 10 10 15 15 15 15 15 15 20 25.2 25.2 25.2 25.2 25.2 25.2 7.96 7.96 7.96 7.96 7.96 7.96 2.52 ∗ Self-resonant frequency (MHz)min. 800 500 400 300 250 180 100 80 68 54 46 38 30 DC resistance (Ω )±20% Rated current (mA)max. Part No. 0.02 0.024 0.027 0.035 0.038 0.045 0.055 0.095 0.115 0.16 0.2 0.29 0.42 2850 2600 2400 2100 2000 1900 1700 1400 1200 1000 900 700 600 NLCV32T-R10M- ∗R NLCV32T-R15M- R NLCV32T-R22M- R NLCV32T-R33M- R NLCV32T-R47M- R NLCV32T-R68M- R NLCV32T-1R0M- R NLCV32T-1R5M- R NLCV32T-2R2M- R NLCV32T-3R3M- R NLCV32T-4R7M- R NLCV32T-6R8M- R NLCV32T-100K- R : Please specify lead-free compatible product, PF (Conformity to RoHS directive, exemption regulations apply) or EF (Conformity to RoHS directive) TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE vs. FREQUENCY CHARACTERISTICS INDUCTANCE vs. DC SUPERPOSITION CHARACTERISTICS 100 100 10 10µH Inductance(µH) Inductance(µH) 10 4.7µH 2.2µH 1 1µH 0.47µH 0.01 4.7µH 2.2µH 1 0.47µH 0.1 0.1µH 0.01 1 1µH 0.22µH 0.22µH 0.1 10µH 10 Frequency (MHz) 100 0.1µH 1 10 100 DC current(mA) 1000 10000 IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100000 Impedance(Ω) 10000 10µH 4.7µH 2.2µH 1µH 1000 100 10 1 0.47µH 0.22µH 0.1µH 1 10 Frequency (MHz) 100 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (9/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLC Series NLC453232 FEATURES • The NLC series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal. • The product uses metal terminals, which realize excellent connection reliability. • From 1µH to 330µH, all of the products in the E-12 series are K(±10%) tolerance products. • It is a product conforming to RoHS directive. APPLICATIONS • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Audio-visual equipment including TVs and VCRs. • Other electronic equipment including HDDs and ODDs. IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLC 453232 T- 2R2 K - PF (1) (2) (3) (4) (5) (6) (1) Series name (2) Dimensions 453232 4.5×3.2×3.2mm (L×W×T) (3) Packaging style T Taping (reel) SPECIFICATIONS –40 to +105°C [Including self-temperature rise] –40 to +105°C Operating temperature range Storage temperature range RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING (4) Inductance value 1R0 100 101 1µH 10µH 100µH (5) Inductance tolerance K ±10% 10s max. (6) Lead-free compatible product 255˚C 230˚C Natural cooling 180˚C PF Lead-free compatible product PACKAGING STYLE AND QUANTITIES 150˚C Packaging style Taping Pre-heating 90 to 120s Quantity 500 pieces/reel 40s max. Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (10/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 0.5 Terminal electrode 3.2±0.2 C0.5 1.5 3.2±0.2 4.5±0.3 2.8 120 3 1.5 R0.2 (0.6) 2.6±0.1 Weight: 180mg Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 Inductance tolerance ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Q min. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 20 20 20 20 20 20 20 Test frequency L, Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.796 Self-resonant frequency (MHz)min. 200 160 130 100 80 60 45 40 35 30 28 25 22 21 20 19 18 16 14 12 11.5 11 10 9 8 7.5 7 6.5 5.5 5 4 DC resistance (Ω )max. 0.11 0.12 0.15 0.16 0.18 0.2 0.22 0.24 0.27 0.3 0.35 0.4 0.5 0.6 0.7 0.8 0.9 1.2 1.4 1.6 1.9 2.2 2.6 3.5 4 4.5 6.5 7.5 9 11 13 Rated current∗ (mA)max. 1050 1000 950 900 850 800 750 700 650 650 600 600 550 500 450 400 370 330 300 280 260 240 220 200 180 160 140 120 120 100 90 Part No. NLC453232T-1R0K-PF NLC453232T-1R2K-PF NLC453232T-1R5K-PF NLC453232T-1R8K-PF NLC453232T-2R2K-PF NLC453232T-2R7K-PF NLC453232T-3R3K-PF NLC453232T-3R9K-PF NLC453232T-4R7K-PF NLC453232T-5R6K-PF NLC453232T-6R8K-PF NLC453232T-8R2K-PF NLC453232T-100K-PF NLC453232T-120K-PF NLC453232T-150K-PF NLC453232T-180K-PF NLC453232T-220K-PF NLC453232T-270K-PF NLC453232T-330K-PF NLC453232T-390K-PF NLC453232T-470K-PF NLC453232T-560K-PF NLC453232T-680K-PF NLC453232T-820K-PF NLC453232T-101K-PF NLC453232T-121K-PF NLC453232T-151K-PF NLC453232T-181K-PF NLC453232T-221K-PF NLC453232T-271K-PF NLC453232T-331K-PF ∗ Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER+YHP16085A+YHP16093B+TF-1, or equivalent SRF: HP8753C NETWORK ANALYZER (Zin=Zout=50Ω), or equivalent Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (11/14) TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 1000 DC 220µH L=5H C=20000µF A Specimen YHP model-4275A or equivalent 100 100µH 100 10 Impedance (kΩ) 47µH Inductance(µH) Test equipment: 4194A IMPEDANCE/ 50 GAIN-PHASE ANALYZER (16092A FIXTURE) Universal bridge Test circuit IMPEDANCE vs. FREQUENCY CHARACTERISTICS 22µH 10µH 10 3.9µH 5 220µH 100µH 1 1µH 1 22µH 0.5 10µH 3.9µH 1µH 0.1 0 100 1000 DC current (mA) 10000 0.1 0.1 0.5 1 5 Frequency (MHz) 10 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (12/14) Inductors for Decoupling Circuits Wound/For Current Conformity to RoHS Directive NLC Series NLC565050 FEATURES • The NLC series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal. • The product uses metal terminals, which realize excellent connection reliability. • From 1µH to 1000µH, all of the products in the E-12 series are K(±10%) tolerance products. • It is a product conforming to RoHS directive. APPLICATIONS • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Audio-visual equipment including TVs and VCRs. • Other electronic equipment including HDDs and ODDs. IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLC 565050 T- 2R2 K - PF (1) (2) (3) (4) (5) (6) (1) Series name (2) Dimensions 565050 5.6×5.0×5.0mm(L×W×T) (3) Packaging style T Taping(reel) SPECIFICATIONS –40 to +105°C [Including self-temperature rise] –40 to +105°C Operating temperature range Storage temperature range RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 1R0 100 101 102 Natural cooling 1µH 10µH 100µH 1000µH (5) Inductance tolerance K 10s max. 255˚C 230˚C (4) Inductance value ±10% (6) Lead-free compatible product PF Lead-free compatible product 180˚C 150˚C PACKAGING STYLE AND QUANTITIES Pre-heating 90 to 120s Packaging style Taping 40s max. Quantity 400 pieces/reel Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (13/14) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 1 Terminal electrode 5±0.3 C1 2 5±0.3 5.6±0.3 4.5 470 (0.5) 4±0.2 4 2 Dimensions in mm Weight: 380mg ELECTRICAL CHARACTERISTICS Inductance (µH) 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 Inductance tolerance ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Q min. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 20 20 20 20 20 20 20 20 20 20 20 20 20 Test frequency L, Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.252 Self-resonant frequency (MHz)min. 95 70 55 47 42 37 34 32 29 26 24 22 19 17 16 14 13 11.5 10.5 9.5 8.5 7.8 7 6.4 6 5.4 4.8 4.4 3.9 3.6 3.2 2.9 2.6 2.4 2.2 2 1.8 DC resistance (Ω )max. 0.03 0.035 0.04 0.05 0.06 0.07 0.08 0.09 0.11 0.13 0.15 0.18 0.21 0.25 0.3 0.36 0.43 0.52 0.62 0.72 0.85 1 1.2 1.4 1.6 1.9 2.2 2.8 3.4 4.2 4.9 5.8 7 8.5 10 13 15 Rated current∗ (mA)max. 1800 1700 1600 1400 1300 1200 1120 1050 950 880 810 750 690 630 580 530 480 440 400 370 340 310 290 270 250 230 210 190 170 155 140 130 120 110 100 90 85 Part No. NLC565050T-1R0K-PF NLC565050T-1R2K-PF NLC565050T-1R5K-PF NLC565050T-1R8K-PF NLC565050T-2R2K-PF NLC565050T-2R7K-PF NLC565050T-3R3K-PF NLC565050T-3R9K-PF NLC565050T-4R7K-PF NLC565050T-5R6K-PF NLC565050T-6R8K-PF NLC565050T-8R2K-PF NLC565050T-100K-PF NLC565050T-120K-PF NLC565050T-150K-PF NLC565050T-180K-PF NLC565050T-220K-PF NLC565050T-270K-PF NLC565050T-330K-PF NLC565050T-390K-PF NLC565050T-470K-PF NLC565050T-560K-PF NLC565050T-680K-PF NLC565050T-820K-PF NLC565050T-101K-PF NLC565050T-121K-PF NLC565050T-151K-PF NLC565050T-181K-PF NLC565050T-221K-PF NLC565050T-271K-PF NLC565050T-331K-PF NLC565050T-391K-PF NLC565050T-471K-PF NLC565050T-561K-PF NLC565050T-681K-PF NLC565050T-821K-PF NLC565050T-102K-PF ∗ Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER+YHP16085A+YHP16093B+TF-1, or equivalent SRF: HP8753C NETWORK ANALYZER (Zin=Zout=50Ω), or equivalent Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc (14/14) 1000µH 1000 Test circuit L=5H C=20000µF A DC Specimen 470µH 220µH 100µH 100 Inductance (µH) YHP model-4275A or equivalent LCR meter TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 39µH 15µH 10 3.9µH 1µH 1 Test equipment: 4275A MULTI-FREQUENCY LCR METER YHP(10kHz, 1Vrms) 0.1 0 100 1000 DC current (mA) 10000 • All specifications are subject to change without notice. 001-03 / 20110927 / e511_nlcv_nlc
NLC453232T-150K-PF
物料型号: - NLCV系列:包括NLCV25、NLCV32、NLCV25T-R、NLCV32T-R、NLC453232、NLC565050等不同尺寸和电感值的电感器。
器件简介: - 这些电感器适用于去耦电路,具有很好的耐热性,能够承受无铅兼容的回流焊接条件。使用无铅材料进行端子镀层,电气特性、可靠性、形状和焊盘形状与之前的NL系列相同。产品使用金属端子,实现优秀的连接可靠性。使用高耐热性热塑性树脂形成外部封装。
引脚分配: - 电感器的引脚分配和焊盘图案在文档中有详细描述,包括尺寸和重量。
参数特性: - 电感器的电感值范围从1µH到1000µH,公差为±10%或+20%,测试频率L,Q在7.96MHz,自谐振频率和直流电阻也有详细说明。
功能详解: - 这些电感器适用于多种电子设备,包括通信基础设施、音视频设备、车载电子设备等。
应用信息: - 电感器适用于电源线路、音视频系统、车辆电子设备和IT设备等。
封装信息: - 提供了不同尺寸的电感器封装信息,如NLCV25系列的尺寸为2.5×2.0×1.8mm,NLCV32系列的尺寸为3.2×2.5×2.2mm等。
焊接条件: - 文档推荐了回流焊接、波峰焊接和烙铁焊接的条件,包括预热时间、焊接时间、温度等。
产品识别: - 每个型号的电感器都有独特的产品识别码,用于区分不同的尺寸、电感值和公差。
电气特性: - 提供了详细的电气特性表,包括不同型号电感器的电感值、公差、Q值、测试频率、自谐振频率、直流电阻和额定电流。
NLC453232T-150K-PF 价格&库存
很抱歉,暂时无法提供与“NLC453232T-150K-PF”相匹配的价格&库存,您可以联系我们找货
NLC453232T-150K-PF
  • 1+0.67680
  • 100+0.62980
  • 300+0.58280
  • 500+0.53580
  • 2000+0.51230
  • 5000+0.49820
