I
N
D
U
C
T
O
R
S
December 2015
Inductors for Decoupling Circuits
Wound Ferrite
NLC Series
NLC565050 Type
NLC565050
5650 [2220 inch]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
May.21, 2015
Last Purchase Order Date
Dec.22, 2016
Last Shipment Date
Jan.30, 2017
Please refer to our Web site about replacement information.
(2/10)
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151217 / inductor_commercial_decoupling_nlc565050_en.fm
(3/10)
I
N
D
U
C
T
O
R
S
Product compatible with RoHS directive
Compatible with lead-free solders
Wound Ferrite
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Overview of NLC565050 Type
FEATURES
Resin mold type wound inductor for decoupling circuits.
E-12 Series, wide lineup compatible with K (±10%) tolerance allows for various usages.
APPLICATION
Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial
equipment, other
PART NUMBER CONSTRUCTION
NLC
Series name
565050
L×W×H Dimensions
(mm)
565050
5.6×5.0×5.0
T
Packaging style
T
Taping
1R0
K
Inductance
(μH)
1R0
1
100
10
101
100
102
1000
Inductance
tolerance
K
±10%
PF
Lead-free
compatible
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Type
NLC565050
Operating
temperature
(°C)
–40 to +105
Package quantity
Individual weight
(pieces/reel)
400
(mg)
380
Storage
temperature
(°C)
–40 to +105
Th
e
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
RECOMMENDED REFLOW PROFILE
Soldering
Natural
cooling
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Preheating
Peak
T: Temperature
T4
T3
T2
T1
t1
T3
t3
t2
t: Time
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
Th
e
Preheating
Temp.
T1
T2
150°C
180°C
(5/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
5±0.3
4±0.2
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SHAPE & DIMENSIONS
470
C1
1
(0.5)
(4.6)
(0.5)
5±0.3
5.6±0.3
Dimensions in mm
4.5
RECOMMENDED LAND PATTERN
4
2
Dimensions in mm
Th
e
2
(6/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
(μH)
1
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1000
Q
L, Q measuring
frequency
DC resistance
Rated current
min.
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
(MHz)
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.252
(ȍ )max.
0.03
0.035
0.04
0.05
0.06
0.07
0.08
0.09
0.11
0.13
0.15
0.18
0.21
0.25
0.3
0.36
0.43
0.52
0.62
0.72
0.85
1
1.2
1.4
1.6
1.9
2.2
2.8
3.4
4.2
4.9
5.8
7
8.5
10
13
15
(mA)max.
1800
1700
1600
1400
1300
1200
1120
1050
950
880
810
750
690
630
580
530
480
440
400
370
340
310
290
270
250
230
210
190
170
155
140
130
120
110
100
90
85
Part No.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L
Tolerance
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
NLC565050T-1R0K-PF
NLC565050T-1R2K-PF
NLC565050T-1R5K-PF
NLC565050T-1R8K-PF
NLC565050T-2R2K-PF
NLC565050T-2R7K-PF
NLC565050T-3R3K-PF
NLC565050T-3R9K-PF
NLC565050T-4R7K-PF
NLC565050T-5R6K-PF
NLC565050T-6R8K-PF
NLC565050T-8R2K-PF
NLC565050T-100K-PF
NLC565050T-120K-PF
NLC565050T-150K-PF
NLC565050T-180K-PF
NLC565050T-220K-PF
NLC565050T-270K-PF
NLC565050T-330K-PF
NLC565050T-390K-PF
NLC565050T-470K-PF
NLC565050T-560K-PF
NLC565050T-680K-PF
NLC565050T-820K-PF
NLC565050T-101K-PF
NLC565050T-121K-PF
NLC565050T-151K-PF
NLC565050T-181K-PF
NLC565050T-221K-PF
NLC565050T-271K-PF
NLC565050T-331K-PF
NLC565050T-391K-PF
NLC565050T-471K-PF
NLC565050T-561K-PF
NLC565050T-681K-PF
NLC565050T-821K-PF
NLC565050T-102K-PF
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial L value)
Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating)
Manufacturer
Agilent Technologies
Panasonic
Th
e
○ Measurement equipment
Measurement item
Product No.
L, Q
4194A+16085A+16093B
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
(7/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
10000
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L FREQUENCY CHARACTERISTICS GRAPH
102K
821K
561K
471K
681K
1000
391K
331K
271K
221K
181K
151K
121K
101K
820K
680K
560K
470K
390K
330K
100
270K
220K
180K
Inductance(μH)
150K
120K
100K
8R2K
6R8K
5R6K
10
4R7K
3R9K
3R3K
2R7K
2R2K
1R8K
1
0. 1
0.1
1
1R5K
1R2K
1R0K
10
100
Th
e
Frequency(MHz)
Product No.
Manufacturer
4294A
(8/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
10000
1000
Inductance(μH)
100
10
1
0.1
0.01
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
102K
821K
681K
561K
471K
391K
331K
271K
181K
221K
151K
121K
101K
820K
680K
560K
470K
390K
330K
270K
220K
180K
150K
120K
100K
8R2K
6R8K
5R6K
4R7K
3R9K
3R3K
2R7K
2R2K
1R8K
1R5K
1R2K
1R0K
0.1
1
10
Th
e
DC current(A)
Product No.
Manufacturer
4285A+42841A+42842C
(9/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
1000000
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
IMPEDANCE FREQUENCY CHARACTERISTICS GRAPH
681K
102K
821K
391K
100000
561K
471K
10000
271K
181K
151K
121K
820K
680K 560K
390K
270K
220K
150K
331K
221K
101K
Impedance(Ω)
1000
120K
100K
8R2K
5R6K
3R9K 3R3K
2R7K
6R8K 1R8K
1R0K
100
1R2K
1R5K
2R2K
4R7K
10
180K
330K
470K
1
0.1
0.1
1
10
100
Th
e
Frequency(MHz)
Product No.
Manufacturer
4294A
(10/10)
I
N
D
U
C
T
O
R
S
NLC565050 Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
NLC565050
A
ø180
W1
13
W2
17
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
A
Type
NLC565050
A
5.4
B
5.8
øD0
1.5+0.1/-0
B
W
F
E
øD0
t
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 5.50±0.05 4.00±0.10 8.00±0.10 2.00±0.05 12.0±0.30
K
5.4
t
0.4
很抱歉,暂时无法提供与“NLC565050T-102K-PF”相匹配的价格&库存,您可以联系我们找货
