NLC565050T-470K-PF
NLC565050T-470K-PF
    TDK(东电化)
    2220(5650公制)
    固定电感器 2220 ±10% 850mΩ 8.5MHz 10@2.52MHz
NLC565050T-470K-PF 数据手册
I N D U C T O R S December 2015 Inductors for Decoupling Circuits Wound Ferrite NLC Series NLC565050 Type NLC565050 5650 [2220 inch]* * Dimensions Code JIS[EIA] Caution The products in this catalog will be or have been stopped production Discontinue Issue Date May.21, 2015 Last Purchase Order Date Dec.22, 2016 Last Shipment Date Jan.30, 2017 Please refer to our Web site about replacement information. (2/10) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. Th e (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (3/10) I N D U C T O R S Inductors for Decoupling Circuits Product compatible with RoHS directive Compatible with lead-free solders Wound Ferrite pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Overview of NLC565050 Type FEATURES Resin mold type wound inductor for decoupling circuits. E-12 Series, wide lineup compatible with K (±10%) tolerance allows for various usages. APPLICATION Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial equipment, other PART NUMBER CONSTRUCTION NLC Series name 565050 L×W×H Dimensions (mm) 565050 5.6×5.0×5.0 T - Packaging style T Taping 1R0 K Inductance (μH) 1R0 1 100 10 101 100 102 1000 Inductance tolerance K ±10% - PF Lead-free compatible OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Type NLC565050 Operating temperature (°C) –40 to +105 Package quantity Individual weight (pieces/reel) 400 (mg) 380 Storage temperature (°C) –40 to +105 Th e Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (4/10) I N D U C T O R S NLC565050 Type RECOMMENDED REFLOW PROFILE Soldering Natural cooling pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Preheating Peak T: Temperature T4 T3 T2 T1 t1 T3 t3 t2 t: Time Time t1 90 to 120s Soldering Temp. Time T3 t2 230°C 40s Peak Temp. T4 255°C Time t3 10s max. Th e Preheating Temp. T1 T2 150°C 180°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (5/10) I N D U C T O R S NLC565050 Type 5±0.3 4±0.2 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SHAPE & DIMENSIONS 470 C1 1 (0.5) (4.6) (0.5) 5±0.3 5.6±0.3 Dimensions in mm 4.5 RECOMMENDED LAND PATTERN 4 2 Dimensions in mm Th e 2 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (6/10) I N D U C T O R S NLC565050 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE (μH) 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000  Q L, Q measuring frequency DC resistance Rated current min. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 20 20 20 20 20 20 20 20 20 20 20 20 20 (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.252 (ȍ )max. 0.03 0.035 0.04 0.05 0.06 0.07 0.08 0.09 0.11 0.13 0.15 0.18 0.21 0.25 0.3 0.36 0.43 0.52 0.62 0.72 0.85 1 1.2 1.4 1.6 1.9 2.2 2.8 3.4 4.2 4.9 5.8 7 8.5 10 13 15 (mA)max. 1800 1700 1600 1400 1300 1200 1120 1050 950 880 810 750 690 630 580 530 480 440 400 370 340 310 290 270 250 230 210 190 170 155 140 130 120 110 100 90 85 Part No. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L Tolerance ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% NLC565050T-1R0K-PF NLC565050T-1R2K-PF NLC565050T-1R5K-PF NLC565050T-1R8K-PF NLC565050T-2R2K-PF NLC565050T-2R7K-PF NLC565050T-3R3K-PF NLC565050T-3R9K-PF NLC565050T-4R7K-PF NLC565050T-5R6K-PF NLC565050T-6R8K-PF NLC565050T-8R2K-PF NLC565050T-100K-PF NLC565050T-120K-PF NLC565050T-150K-PF NLC565050T-180K-PF NLC565050T-220K-PF NLC565050T-270K-PF NLC565050T-330K-PF NLC565050T-390K-PF NLC565050T-470K-PF NLC565050T-560K-PF NLC565050T-680K-PF NLC565050T-820K-PF NLC565050T-101K-PF NLC565050T-121K-PF NLC565050T-151K-PF NLC565050T-181K-PF NLC565050T-221K-PF NLC565050T-271K-PF NLC565050T-331K-PF NLC565050T-391K-PF NLC565050T-471K-PF NLC565050T-561K-PF NLC565050T-681K-PF NLC565050T-821K-PF NLC565050T-102K-PF Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (10% below the initial L value) Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating) Manufacturer Agilent Technologies Panasonic Th e ○ Measurement equipment Measurement item Product No. L, Q 4194A+16085A+16093B DC resistance VP-2941A * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (7/10) I N D U C T O R S NLC565050 Type ELECTRICAL CHARACTERISTICS 10000 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L FREQUENCY CHARACTERISTICS GRAPH 102K 821K 561K 471K 681K 1000 391K 331K 271K 221K 181K 151K 121K 101K 820K 680K 560K 470K 390K 330K 100 270K 220K 180K Inductance(μH) 150K 120K 100K 8R2K 6R8K 5R6K 10 4R7K 3R9K 3R3K 2R7K 2R2K 1R8K 1 0. 1 0.1 1 1R5K 1R2K 1R0K 10 100 Th e Frequency(MHz) ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (8/10) I N D U C T O R S NLC565050 Type ELECTRICAL CHARACTERISTICS 10000 1000 Inductance(μH) 100 10 1 0.1 0.01 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 102K 821K 681K 561K 471K 391K 331K 271K 181K 221K 151K 121K 101K 820K 680K 560K 470K 390K 330K 270K 220K 180K 150K 120K 100K 8R2K 6R8K 5R6K 4R7K 3R9K 3R3K 2R7K 2R2K 1R8K 1R5K 1R2K 1R0K 0.1 1 10 Th e DC current(A) ○ Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (9/10) I N D U C T O R S NLC565050 Type ELECTRICAL CHARACTERISTICS 1000000 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en IMPEDANCE FREQUENCY CHARACTERISTICS GRAPH 681K 102K 821K 391K 100000 561K 471K 10000 271K 181K 151K 121K 820K 680K 560K 390K 270K 220K 150K 331K 221K 101K Impedance(Ω) 1000 120K 100K 8R2K 5R6K 3R9K 3R3K 2R7K 6R8K 1R8K 1R0K 100 1R2K 1R5K 2R2K 4R7K 10 180K 330K 470K 1 0.1 0.1 1 10 100 Th e Frequency(MHz) ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm (10/10) I N D U C T O R S NLC565050 Type PACKAGING STYLE REEL DIMENSIONS 2.0±0.5 E Type NLC565050 A ø180 W1 13 W2 17 N ø60 E 0.5 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 A Type NLC565050 A 5.4 B 5.8 øD0 1.5+0.1/-0 B W F E øD0 t Dimensions in mm E F P0 P1 P2 W 1.75±0.1 5.50±0.05 4.00±0.10 8.00±0.10 2.00±0.05 12.0±0.30 K 5.4 t 0.4 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151217 / inductor_commercial_decoupling_nlc565050_en.fm
NLC565050T-470K-PF 价格&库存
很抱歉,暂时无法提供与“NLC565050T-470K-PF”相匹配的价格&库存,您可以联系我们找货
