I N D U C T O R S
September 2017
Inductors for Decoupling Circuits
Wound Ferrite
NLCV-PFRD Series (For automobiles)
NLCV32-PFRD Type
NLCV32-PFRD
3225 [1210 inch]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog is not recommended
to a new design
Please refer to our Web site about replacement information.
The products in this catalog is not recommended to a new design
(2/10)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20170920 / inductor_automotive_decoupling_nlcv32-pfrd_en.fm
(3/10)
I N D U C T O R S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
AEC-Q200
Wound Ferrite
Overview of NLCV32-PFRD Type
FEATURES
Resin mold type wound inductor for decoupling circuits.
APPLICATION
Vehicle accessories (car navigation systems, car audio, ETC, other)
PART NUMBER CONSTRUCTION
NLCV
Series name
32
L×W×H Dimensions
(mm)
32
3.2×2.5×2.2
T
R10
Inductance
(µH)
R10
0.1
1R0
1
100
10
Packaging style
T
M
Taping
Inductance
tolerance
K
±10%
M
±20%
PFRD
Internal code
PFRD
Compatible with the RoHS
Directive, Exemption
regulations apply
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Type
NLCV32-PFRD
Operating
temperature
(°C)
–40 to +125
Package quantity
Individual weight
(pieces/reel)
2000
(mg)
50
Storage
temperature
(°C)
–40 to +125
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/10)
I N D U C T O R S
NLCV32-PFRD Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
(5/10)
I N D U C T O R S
NLCV32-PFRD Type
1R0
1.9±0.1
2.5±0.2
SHAPE & DIMENSIONS
0.55
(0.55)
(2.1)
(0.55)
2.2±0.2
3.2±0.2
Dimensions in mm
2
RECOMMENDED LAND PATTERN
1.2
2
1.2
Dimensions in mm
(6/10)
I N D U C T O R S
NLCV32-PFRD Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
0.1
0.15
0.22
0.33
0.47
0.68
1
1.5
2.2
3.3
4.7
6.8
10
Tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±10%
Q
L, Q measuring frequency
DC resistance
Rated current
ref.
10
10
10
10
10
10
15
15
15
15
15
15
(MHz)
25.2
25.2
25.2
25.2
25.2
25.2
7.96
7.96
7.96
7.96
7.96
7.96
2.52
(Ω )±20%
0.02
0.024
0.027
0.035
0.038
0.045
0.055
0.095
0.115
0.16
0.2
0.29
0.42
(mA)max.
2850
2600
2400
2100
2000
1900
1700
1400
1200
1000
900
700
600
Part No.
NLCV32T-R10M-PFRD
NLCV32T-R15M-PFRD
NLCV32T-R22M-PFRD
NLCV32T-R33M-PFRD
NLCV32T-R47M-PFRD
NLCV32T-R68M-PFRD
NLCV32T-1R0M-PFRD
NLCV32T-1R5M-PFRD
NLCV32T-2R2M-PFRD
NLCV32T-3R3M-PFRD
NLCV32T-4R7M-PFRD
NLCV32T-6R8M-PFRD
NLCV32T-100K-PFRD
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial L value)
Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating)
○ Measurement equipment
Measurement item
Product No.
L, Q
4194A+16085A+16093B
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
(7/10)
I N D U C T O R S
NLCV32-PFRD Type
L FREQUENCY CHARACTERISTICS GRAPH
100
100K
6R8M
4R7M
10
3R3M
2R2M
Inductance(μH)
1R5M
1R0M
1
R68M
R47M
R33M
R22M
R15M
0.1
R10M
0.01
0.1
1
10
Frequency(MHz)
100
1000
Product No.
Manufacturer
4294A
(8/10)
I N D U C T O R S
NLCV32-PFRD Type
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
100
10
100K
6R8M
4R7M
3R3M
Inductance(μH)
2R2M
1R5M
1
1R0M
R68M
R47M
R33M
R22M
R15M
0.1
R10M
0.01
0.01
0.1
1
10
DC current(A)
Product No.
Manufacturer
4285A+42841A+42842C
(9/10)
I N D U C T O R S
NLCV32-PFRD Type
IMPEDANCE FREQUENCY CHARACTERISTICS GRAPH
100000
100K
10000
6R8M
4R7M
3R3M
2R2M 1R5M
1R0M
R68M
R47M
R33M
1000
100
Impedance(Ω)
R22M
R15M
R10M
10
1
0.1
0.01
0.1
1
10
Frequency(MHz)
100
1000
Product No.
Manufacturer
4294A
(10/10)
I N D U C T O R S
NLCV32-PFRD Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
NLCV32-PFRD
A
ø180
W1
9
W2
13
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
NLCV32-PFRD
A
2.8
B
3.5
B
W
F
E
øD0
øD0
1.5+0.1/-0
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.30
K
2.3
t
0.4
很抱歉,暂时无法提供与“NLCV32T-R10M-PFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+0.840572000+0.10782
- 4000+0.792564000+0.10166
- 国内价格
- 1+0.29251
- 100+0.27301
- 300+0.25351
- 500+0.23400
- 2000+0.22425
- 5000+0.21840
