531_NLFC4532 (1/2)
Inductors
For Power Line SMD
FEATURES • The NLFC series features magnetic shielding and is recommended for power supply line applications. • They are available in 4 form factors ranging from 2016 to 4532. APPLICATIONS Personal computers, hard disk drives, and other electronic equipment. SPECIFICATIONS
Type NLFC201614 NLFC252018 NLFC322522 NLFC453232 Operating temperature range –20 to +80°C –20 to +80°C –20 to +80°C –20 to +80°C Storage temperature range [Unit of products] –40 to +85°C –40 to +85°C –40 to +85°C –40 to +80°C
NLFC Series NLFC4532 Type
FLUX AND CLEANING Rosin-based flux is recommended. Cleaning Conditions
Solvent Time Chlorine-based solvent (Do not use acid or alkali solvents.) 2min max.
PRODUCT IDENTIFICATION NLFC (1) 201614 T- 2R2 M (2) (3) (4) (5)
(1)Series name (2)Dimensions L×W×T
201614 252018 322522 453232 2.1×1.6×1.4mm 2.5×2.0×1.8mm 3.2×2.5×2.2mm 4.5×3.2×3.2mm
RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING
10s max. 230°C 200°C 150°C 100°C Preheating: 120s Time (s) Natural cooling 30s max.
(3)Packaging style
T Taping (reel)
(4)Inductance value
1R0 220 1µH 22µH
(5)Inductance tolerance
K M ±10% ±20%
FLOW SOLDERING
10s max. 260°C Natural cooling
PACKAGING STYLE AND QUANTITIES
Packaging style Taping Type NLFC201614T NLFC252018T NLFC322522T NLFC453232T Quantity 2000 pieces/reel 2000 pieces/reel 2000 pieces/reel 500 pieces/reel
IRON SOLDERING Perform soldering at 250°C on 30W max. within 5 seconds. VAPOR-PHASING
10s max. 220°C 215°C 150°C 100°C Preheating: 120s Time (s) Natural cooling 30s max.
Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice.
531_NLFC4532 (2/2)
Inductors
For Power Line SMD
SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN
120 4.5 ± 0.3
3.2 ± 0.2 0.5 Terminal electrode (0.4) 3.2 ± 0.2 Inductor Solder land pattern 2.8 1.5 Weight: 180mg 3 1.5 Dimensions in mm
C0.5 R0.2
2.6 ± 0.1
ELECTRICAL CHARACTERISTICS
Inductance (µH) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 Inductance tolerance ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Q ref. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Test frequency L, Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 Self-resonant frequency (MHz)min. 200 130 80 45 35 28 22 20 18 14 11.5 10 8 7 5.5 4 DC resistance (Ω)±30% 0.05 0.06 0.07 0.09 0.1 0.14 0.21 0.3 0.46 0.63 0.85 1.2 1.7 2.3 3.8 6 Rated current (mA)∗ max. Based on inductance Based on change temperature rise 800 1400 700 1200 600 1100 460 1050 400 1000 300 840 250 690 200 570 170 460 140 400 120 340 100 280 90 240 65 200 55 160 45 120 Part No. NLFC453232T-1R0M NLFC453232T-1R5M NLFC453232T-2R2M NLFC453232T-3R3M NLFC453232T-4R7M NLFC453232T-6R8M NLFC453232T-100K NLFC453232T-150K NLFC453232T-220K NLFC453232T-330K NLFC453232T-470K NLFC453232T-680K NLFC453232T-101K NLFC453232T-151K NLFC453232T-221K NLFC453232T-331K
∗ Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER+YHP16085A+YHP16093B+TF-1, or equivalent SRF:HP8753C NETWORK ANALYZER (Zin=Zout=50Ω), or equivalent Rdc:MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent
TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS
A Specimen Universal bridge 1000 330µH 300 100 Inductance (µH) 100µH Test circuit
DC
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
330µH 100 100µH 47µH 10 Impedance (kΩ) 10µH 3 1 4.7µH
L=5H C=20000µF
30
YHP model-4275A or equivalent
47µH 30 10 10µH 4.7µH 3 1 1µH
0.3 0.1
1µH
0.03 0.3 0.01 0.1 10 30 100 300 1000 DC current (mA) 3000 10000 0.1 0.3 1 3 10 Frequency (MHz) 30 100
531_NLFC4532 010405
很抱歉,暂时无法提供与“NLFC453232T-3R3M”相匹配的价格&库存,您可以联系我们找货
