NLFV25T-101K-EF
NLFV25T-101K-EF
    TDK(东电化)
    固定电感器 Nonstandard 100µH ±10% 40mA 4.8Ω
NLFV25T-101K-EF 数据手册
I N D U C T O R S Inductors for decoupling circuits Wound ferrite NLFV-EF series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free NLFV25-EF type FEATURES Resin mold type wound inductor for decoupling circuits. Magnetic shield type containing ferrite powder in the exterior mold resin. Operating temperature range: –40 to +105°C (including self-temperature rise) APPLICATION Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial equipment, other PART NUMBER CONSTRUCTION NLFV 25 T - Series name L×W×H dimensions 2.5×2.0×1.8 mm Packaging style 1R0 M - Inductance (µH) Inductance tolerance EF Internal code CHARACTERISTICS SPECIFICATION TABLE L (µH) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 Tolerance ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% L measuring frequency DC resistance Rated current Part No. (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 (Ω )±20% 0.07 0.09 0.1 0.2 0.24 0.29 0.36 0.75 1 1.4 1.7 3.3 4 (mA)max. 455 350 315 280 210 175 155 130 105 85 60 50 40 NLFV25T-1R0M-EF NLFV25T-1R5M-EF NLFV25T-2R2M-EF NLFV25T-3R3M-EF NLFV25T-4R7M-EF NLFV25T-6R8M-EF NLFV25T-100K-EF NLFV25T-150K-EF NLFV25T-220K-EF NLFV25T-330K-EF NLFV25T-470K-EF NLFV25T-680K-EF NLFV25T-101K-EF Measurement equipment Measurement item Product No. L 4294A+16093B DC resistance AX-114N * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm I N D U C T O R S NLFV25-EF type L FREQUENCY CHARACTERISTICS 1000 100 101K 680K 470K 330K Inductance(µH) 220K 150K 10 100K 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M 0.1 0.1 1 10 100 Frequency(MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm I N D U C T O R S NLFV25-EF type INDUCTANCE VS. DC BIAS CHARACTERISTICS 1000 100 101K 680K 470K 330K Inductance(µH) 220K 150K 10 100K 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M 0.1 0.01 0.1 1 10 DC current(A) Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm I N D U C T O R S NLFV25-EF type IMPEDANCE VS. FREQUENCY CHARACTERISTICS 100000 101K 680K 470K 330K 220K 10000 150K 100K 6R8M 4R7M 3R3M 2R2M 1R5M 1000 Impedance(Ω) 1R0M 100 10 1 0.1 0.1 1 10 Frequency(MHz) 100 1000 Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm I N D U C T O R S NLFV25-EF type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 2±0.1 1.4±0.1 2.0±0.5 0.55 (0.4) (1.7) (0.4) 1.8±0.1 ø60 2.5±0.2 0.5 (1.0) Dimensions in mm ø13.0±0.5 9 ø21.0±0.8 13 ø180 Dimensions in mm 1.5 +0.1 –0 2.00±0.05 4.00±0.10 B 1.5 8.00±0.30 Sprocket hole 0.4 3.50±0.05 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS 1.0 1.5 1.0 A K Dimensions in mm Cavity 4.00±0.10 Dimensions in mm Type NLFV25-EF Package quantity Soldering Natural cooling 255°C Temperature K 2 230°C 2000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Peak 230°C B 2.7 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 2.3   Operating Storage Individual temperature range temperature range weight –40 to +105 °C –40 to +105 °C 25 mg Operating temperature range includes self-temperature rise. The storage temperature range is for after the assembly. 180°C 10s max. 150°C 90 to 120s 40s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (6/6) 20180920 inductor_commercial_decoupling_nlfv25-ef_en.fm
NLFV25T-101K-EF 价格&库存
很抱歉,暂时无法提供与“NLFV25T-101K-EF”相匹配的价格&库存,您可以联系我们找货
NLFV25T-101K-EF
  • 5+1.81535
  • 50+1.49499
  • 250+1.23396
  • 500+1.08328
  • 1000+0.93259
  • 2000+0.86971
库存:462
NLFV25T-101K-EF
    • 1+0.70421
    • 100+0.58684
    • 500+0.53349
    • 1000+0.48944
    • 2000+0.45957
    库存:1600
    NLFV25T-101K-EF
    • 2000+0.804272000+0.10396
    • 4000+0.760564000+0.09831
    • 6000+0.743086000+0.09605
    NLFV25T-101K-EF
      • 2000+0.907202000+0.11727
      • 4000+0.855394000+0.11057
      • 6000+0.826486000+0.10683
      • 10000+0.7914910000+0.10231
      • 14000+0.7692514000+0.09944
      • 20000+0.7463920000+0.09648
      库存:22227
      NLFV25T-101K-EF
      • 1+1.761821+0.22774
      • 10+1.4478910+0.18716
      • 100+1.19291100+0.15420
      • 1000+0.981011000+0.12681
      库存:22227
      NLFV25T-101K-EF
      • 2000+0.74383
      • 4000+0.70670
      • 6000+0.68873
      • 10000+0.68514
      NLFV25T-101K-EF
      • 5+1.81535
      • 50+1.49499
      • 250+1.23396
      • 500+1.08328
      • 1000+0.93259
      • 2000+0.86971
      库存:462
      NLFV25T-101K-EF
        • 2000+0.45957
        库存:2000
