NLFV25T-220K-PF
NLFV25T-220K-PF
    TDK(东电化)
    SMD,2.5x2mm
    22UH ±10%
NLFV25T-220K-PF 数据手册
Inductors for Standard Circuits Wound/STD • magnetic shielded NLFV/NLFC series Type: NLFV25 NLFV32 NLFC453232 2520[1008 inch]* 3225[1210 inch] 4532[1812 inch] * Dimensions Code JIS[EIA] Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/6) Inductors for Standard Circuits Wound/STD • Magnetic Shielded Conformity to RoHS Directive NLFV Series NLFV25 FEATURES • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal. • The product uses metal terminals, which realize excellent connection reliability. • From 1µH to 100µH, all of the products are available in the E-6 series. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. APPLICATIONS • Audio-visual equipment including TVs, VCRs and digital cameras. • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Electronic equipment used in onboard automobile equipment including car audio and ECU systems. • Other electronic equipment including HDDs and ODDs. SPECIFICATIONS Operating temperature range Storage temperature range –40 to +105°C [Including self-temperature rise] –40 to +105°C RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLFV 25 T- 2R2 M -PF (1) (2) (3) (4) (5) (6) (1) Series name (2) Dimensions 25 2.5×2.0×1.8mm (L×W×T) (3) Packaging style T Taping (reel) (4) Inductance value 1R0 100 101 1µH 10µH 100µH (5) Inductance tolerance K M ±10% ±20% (6) Lead-free compatible product 10s max. 255˚C 230˚C IRON SOLDERING Natural cooling PF EF Conformity to RoHS directive, exemption regulations apply Conformity to RoHS directive 180˚C PACKAGING STYLE AND QUANTITIES 150˚C Pre-heating 90 to 120s Packaging style Taping 40s max. Quantity 2000 pieces/reel Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02 (2/6) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 0.5 1.8±0.1 1.5 2±0.1 2.5±0.2 Terminal electrode 1.0 1.5 1.0 (0.4) 1.4±0.1 Dimensions in mm Weight:25mg ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q ref. Test frequency L,Q (MHz) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 5 5 5 5 5 5 10 10 10 10 10 10 10 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 Self-resonant frequency (MHz)min. 100 80 70 55 45 38 32 28 16 14 11 10 8 DC resistance (Ω)±20% Rated current∗1 Part No. (mA)max. 0.07 0.09 0.1 0.2 0.24 0.29 0.36 0.75 1 1.4 1.7 3.3 4 455 350 315 280 210 175 155 130 105 85 60 50 40 NLFV25T-1R0MNLFV25T-1R5MNLFV25T-2R2MNLFV25T-3R3MNLFV25T-4R7MNLFV25T-6R8MNLFV25T-100KNLFV25T-150KNLFV25T-220KNLFV25T-330KNLFV25T-470KNLFV25T-680KNLFV25T-101K- ∗2 ∗1 Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify lead-free compatible product, PF (Conformity to RoHS directive, exemption regulations apply) or EF (Conformity to RoHS directive) • Test equipment L, Q: HP4194A IMPEDANCE ANALYZER(16085A+16093B+TDK TF-1) SRF: HP8753C NETWORK ANALYZER Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER Test circuit 1000 DC L=0.1H C=20000µF A Specimen HP model-4275A or equivalent 300 IMPEDANCE vs. FREQUENCY CHARACTERISTICS Universal bridge TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 100 30 100µH 100µH 100 10 10µH 10 3 3 1 0.3 1µH 1µH 1 0.1 0.3 0.1 Impedance(kΩ) Inductance(µH) 10µH 30 0.03 1 3 10 30 100 300 1000 3000 10000 DC current(mA) 0.01 0.1 0.3 1 3 10 Frequency(MHz) 30 100 • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02 (3/6) Inductors for Standard Circuits Wound/STD • Magnetic Shielded Conformity to RoHS Directive NLFV Series NLFV32 FEATURES • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal. • The product uses metal terminals, which realize excellent connection reliability. • From 1µH to 1000µH, all of the products are available in the E-6 series. • This product is in compliance with the RoHS Directive. Other products with specifications that do not include exemption regulations are also available. APPLICATIONS • Audio-visual equipment including TVs, VCRs and digital cameras. • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Electronic equipment used in onboard automobile equipment including car audio and car navigation systems. • Other electronic equipment including HDDs and ODDs. SPECIFICATIONS Operating temperature range Storage temperature range –40 to +105°C [Including self-temperature rise] –40 to +105°C RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING IRON SOLDERING Tip temperature Heating time Soldering rod specifications • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLFV 32 T- 2R2 M -EF (1) (2) (3) (4) (5) (6) (1) Series name (2) Dimensions 32 3.2×2.5×2.2mm (L×W×T) (3) Packaging style T Taping (reel) (4) Inductance value 1R0 100 101 1µH 10µH 100µH (5) Inductance tolerance K M ±10% ±20% (6) Lead-free compatible product 10s max. EF 255˚C 230˚C 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm Conformity to RoHS directive Natural cooling PACKAGING STYLE AND QUANTITIES 180˚C Packaging style Taping 150˚C Pre-heating 90 to 120s Quantity 2000 pieces/reel 40s max. Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02 (4/6) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 2.5±0.2 0.5 2.2±0.2 2 3.2±0.2 Terminal electrode 1.2 (0.4) 2 1.2 Dimensions in mm 1.9±0.1 Weight: 50mg ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q ref. Test frequency L,Q (MHz) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 470 680 1000 ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% 5 5 5 5 5 5 10 10 10 10 10 10 25 25 25 25 25 25 25 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.252 Self-resonant frequency (MHz)min. 100 80 68 54 46 38 30 26 21 17 14 12 10 8 7 5 4 3 2.4 DC resistance (Ω)±20% Rated current∗ (mA)max. Part No. 0.06 0.07 0.09 0.11 0.13 0.17 0.20 0.30 0.40 0.65 0.85 1.3 2.2 2.9 5.1 6.8 14.5 18.5 22.5 750 600 500 420 360 260 250 140 120 95 90 70 55 50 40 35 30 25 20 NLFV32T-1R0M-EF NLFV32T-1R5M-EF NLFV32T-2R2M-EF NLFV32T-3R3M-EF NLFV32T-4R7M-EF NLFV32T-6R8M-EF NLFV32T-100K-EF NLFV32T-150K-EF NLFV32T-220K-EF NLFV32T-330K-EF NLFV32T-470K-EF NLFV32T-680K-EF NLFV32T-101K-EF NLFV32T-151K-EF NLFV32T-221K-EF NLFV32T-331K-EF NLFV32T-471K-EF NLFV32T-681K-EF NLFV32T-102K-EF ∗ Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L, Q: HP4194A IMPEDANCE ANALYZER(16085A+16093B+TDK TF-1) or equivalent SRF: HP8753C NETWORK ANALYZER or equivalent Rdc: MATSUSHITA VP-2941A DIGITAL MILLIOHM METER or equivalent TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000 1µH 4.7µH 10µH 47µH 100µH 330µH 10000 Impedance(Ω) Inductance(µH) 100 100000 10 1µH 4.7µH 10µH 47µH 100µH 330µH 1000 100 1 10 0.1 10 100 1000 DC current(mA) 10000 1 0.1 1 10 100 Frequency (MHz) • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02 (5/6) Inductors for Standard Circuits Wound/STD • Magnetic Shielded Conformity to RoHS Directive NLFC Series NLFC453232 FEATURES • The NLFC series features magnetic shielding and is recommended for power supply line applications. • The product has good heat durability that withstands lead-free compatible reflow soldering conditions. • Lead-free material is used for the plating on the terminal. • The product uses metal terminals, which realize excellent connection reliability. • From 1µH to 330µH, all of the products are available in the E-6 series. • It is a product conforming to RoHS directive. APPLICATIONS • Electronic equipment used in communication infrastructures including xDSL and mobile base stations. • Audio-visual equipment including TVs and VCRs. • Other electronic equipment including HDDs and ODDs. IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 seconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. PRODUCT IDENTIFICATION NLFC 453232 T- 2R2 M - PF (1) (2) (3) (4) (5) (6) (1)Series name (2)Dimensions 453232 (3)Packaging style T SPECIFICATIONS –40 to +105°C [Including self-temperature rise] –40 to +105°C Operating temperature range Storage temperature range RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 4.5×3.2×3.2mm (L×W×T) Taping (reel) (4)Inductance value 1R0 100 101 1µH 10µH 100µH (5)Inductance tolerance 10s max. 255˚C 230˚C Natural cooling K M ±10% ±20% (6) Lead-free compatible product 180˚C PF 150˚C Pre-heating 90 to 120s Lead-free compatible product PACKAGING STYLE AND QUANTITIES 40s max. Packaging style Taping Quantity 500 pieces/reel Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02 (6/6) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN Inductor Solder land pattern 100 3.2±0.2 0.5 Terminal electrode 2.8 C0.5 3.2±0.2 4.5±0.3 R0.2 (0.6) 2.6±0.1 1.5 3 1.5 Weight: 180mg Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 Inductance tolerance ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Q ref. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Test frequency L, Q (MHz) 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 Self-resonant frequency (MHz)min. 200 130 80 45 35 28 22 20 18 14 11.5 10 8 7 5.5 4 DC resistance (Ω )±30% 0.05 0.06 0.07 0.09 0.1 0.14 0.21 0.3 0.46 0.63 0.85 1.2 1.7 2.3 3.8 6 Rated current∗ (mA)max. 800 700 600 460 400 300 250 200 170 140 120 100 90 65 55 45 Part No. NLFC453232T-1R0M-PF NLFC453232T-1R5M-PF NLFC453232T-2R2M-PF NLFC453232T-3R3M-PF NLFC453232T-4R7M-PF NLFC453232T-6R8M-PF NLFC453232T-100K-PF NLFC453232T-150K-PF NLFC453232T-220K-PF NLFC453232T-330K-PF NLFC453232T-470K-PF NLFC453232T-680K-PF NLFC453232T-101K-PF NLFC453232T-151K-PF NLFC453232T-221K-PF NLFC453232T-331K-PF ∗ Rated current: Value obtained when current flows and the temperature has risen to 20°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L, Q: YHP4194A IMPEDANCE ANALYZER+YHP16085A+YHP16093B+TF-1, or equivalent SRF:HP8753C NETWORK ANALYZER (Zin=Zout=50Ω), or equivalent Rdc:MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent Test circuit 1000 330µH 300 DC L=5H C=20000µF A Specimen YHP model-4275A or equivalent IMPEDANCE vs. FREQUENCY CHARACTERISTICS 330µH Universal bridge TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 100 47µH 100µH 100 10 Impedance (kΩ) Inductance (µH) 47µH 30 10µH 10 4.7µH 3 1 10µH 3 4.7µH 1 0.3 1µH 1µH 0.1 0.3 0.1 100µH 30 0.03 10 30 100 300 1000 DC current (mA) 3000 10000 0.01 0.1 0.3 1 3 10 Frequency (MHz) 30 100 • All specifications are subject to change without notice. 001-03 / 20110928 / e511_nl_02
NLFV25T-220K-PF 价格&库存
很抱歉,暂时无法提供与“NLFV25T-220K-PF”相匹配的价格&库存,您可以联系我们找货
NLFV25T-220K-PF
  • 2000+0.906892000+0.11780
库存:2996
NLFV25T-220K-PF
  • 1+1.761251+0.22878
  • 10+1.4207410+0.18455
  • 100+1.16958100+0.15193
  • 1000+0.961891000+0.12495
库存:2996
