I N D U C T O R S
April 2017
Inductors for Decoupling Circuits
Wound Ferrite
NLFV-EF Series
NLFV32-EF Type
NLFV32-EF
3225 [1210 inch]*
* Dimensions Code JIS[EIA]
(2/10)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20170419 / inductor_commercial_decoupling_nlfv32-ef_en.fm
(3/10)
I N D U C T O R S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
Wound Ferrite
Overview of NLFV32-EF Type
FEATURES
Resin mold type wound inductor for decoupling circuits.
Magnetic shield type containing ferrite powder in the exterior mold resin.
APPLICATION
Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial
equipment, other
PART NUMBER CONSTRUCTION
NLFV
Series name
32
L×W×H Dimensions
(mm)
32
3.2×2.5×2.2
T
Packaging style
T
Taping
1R0
M
Inductance
(µH)
1R0
1
100
10
101
100
102
1000
Inductance
tolerance
K
±10%
M
±20%
EF
Internal code
EF
Compatible with the RoHS
Directive
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Operating
Storage
Type
temperature
temperature
(pieces/reel)
(°C)
(°C)
NLFV32-EF
–40 to +105
–40 to +105
2000
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Individual weight
(mg)
50
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/10)
I N D U C T O R S
NLFV32-EF Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
(5/10)
I N D U C T O R S
NLFV32-EF Type
1.9±0.1
100
2.5±0.2
SHAPE & DIMENSIONS
0.55
(0.55)
(2.1)
(0.55)
2.2±0.2
3.2±0.2
Dimensions in mm
2
RECOMMENDED LAND PATTERN
1.2
2
1.2
Dimensions in mm
(6/10)
I N D U C T O R S
NLFV32-EF Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
1
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
330
470
680
1000
Tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
L measuring frequency
DC resistance
Rated current
Part No.
(MHz)
7.96
7.96
7.96
7.96
7.96
7.96
2.52
2.52
2.52
2.52
2.52
2.52
0.796
0.796
0.796
0.796
0.796
0.796
0.252
(Ω )±20%
0.06
0.07
0.09
0.11
0.13
0.17
0.20
0.30
0.40
0.65
0.85
1.3
2.2
2.9
5.1
6.8
14.5
18.5
22.5
(mA)max.
750
600
500
420
360
260
250
140
120
95
90
70
55
50
40
35
30
25
NLFV32T-1R0M-EF
NLFV32T-1R5M-EF
NLFV32T-2R2M-EF
NLFV32T-3R3M-EF
NLFV32T-4R7M-EF
NLFV32T-6R8M-EF
NLFV32T-100K-EF
NLFV32T-150K-EF
NLFV32T-220K-EF
NLFV32T-330K-EF
NLFV32T-470K-EF
NLFV32T-680K-EF
NLFV32T-101K-EF
NLFV32T-151K-EF
NLFV32T-221K-EF
NLFV32T-331K-EF
NLFV32T-471K-EF
NLFV32T-681K-EF
NLFV32T-102K-EF
Rated
current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial L value)
Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating)
○ Measurement equipment
Measurement item
Product No.
L
4194A+16085A+16093B
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
(7/10)
I N D U C T O R S
NLFV32-EF Type
L FREQUENCY CHARACTERISTICS GRAPH
10000
102K
681K
471K
331K
1000
221K
151K
101K
680K
100
470K
Inductance(μH)
330K
220K
150K
10
100K
6R8M
4R7M
3R3M
2R2M
1
1R5M
1R0M
0. 1
0.01
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
4294A
(8/10)
I N D U C T O R S
NLFV32-EF Type
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
10000
1000
102K
681K
471K
331K
221K
151K
100
101K
Inductance(μH)
680K
470K
330K
220K
150K
10
100K
6R8M
4R7M
3R3M
2R2M
1R5M
1
1R0M
0.1
0.01
0.1
1
10
DC current(A)
Product No.
Manufacturer
4285A+42841A+42842C
(9/10)
I N D U C T O R S
NLFV32-EF Type
IMPEDANCE FREQUENCY CHARACTERISTICS GRAPH
1000000
102K
100000
681K
471K
331K
221K
151K
101K
680K
470K
330K
220K
10000
150K
100K
6R8M
4R7M 3R3M
Impedance(Ω)
1000
1R0M
100
2R2M
1R5M
10
1
0.1
0.01
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
4294A
(10/10)
I N D U C T O R S
NLFV32-EF Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
NLFV32-EF
A
ø180
W1
9
W2
13
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
NLFV32-EF
A
2.8
B
3.5
B
W
F
E
øD0
øD0
1.5+0.1/-0
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.30
K
2.3
t
0.4
很抱歉,暂时无法提供与“NLFV32T-470K-EF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.53163
- 10+0.48540
- 30+0.47615
- 国内价格
- 5+1.41988
- 50+1.12990
- 150+1.00559
- 500+0.85050
- 2000+0.78149
- 4000+0.74002
- 国内价格 香港价格
- 2000+1.239852000+0.16118
- 4000+1.169074000+0.15198
- 6000+1.129586000+0.14685
- 10000+1.0818010000+0.14063
- 14000+1.0514414000+0.13669
- 20000+1.0202220000+0.13263
- 国内价格 香港价格
- 1+2.378491+0.30920
- 10+1.9849210+0.25804
- 100+1.63081100+0.21200
- 1000+1.340751000+0.17430
