NLHV25T-R12J-PF
NLHV25T-R12J-PF
    TDK(东电化)
    固定电感器 Nonstandard 120nH ±5% 550mA 380mΩ 700MHz 30@25.2MHz
NLHV25T-R12J-PF 数据手册
(1/2) SMD Inductors(Coils) For Signal Line(Wound) NLHV Series NLHV25 FEATURES • High Q-factor is provided in frequency band more than 30MHz in comparison with existing NLV25 series. • Land pattern is compatible with an existing series product. • Lead-free material is used for the plating on the terminal APPLICATIONS Power supply lines, audio visual systems, electronic equipment for vehicle, IT equipment SPECIFICATIONS Operating temperature range Storage temperature range –40 to +105°C [Including self-temperature rise] –40 to +105°C PRODUCT IDENTIFICATION NLHV 25 T R12 J PF (1) (2) (3) (4) (5) (6) (1) Series name (2) Dimensions 25 2.5× 2.0× 1.8mm(L× W× T) (3) Packaging style T Taping (reel) (4) Inductance R12 0.12µH RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERING 10s max. 255˚C 230˚C 180˚C 150˚C Pre-heating 90 to 120s (5) Inductance tolerance J ±5% (6) Lead-free compatible product Natural cooling PF Lead-free compatible product 40s max. Time (s) FLOW SOLDERING 10s max. 260˚C max. Natural cooling 170˚C 150˚C Pre-heating 60 to 120s Time (s) IRON SOLDERING Tip temperature Heating time Soldering rod specifications 300 to 350°C 3 secconds/soldering Output: 30W Tip diameter: 1mm • Based on the above conditions, use a maximum product temperature of 260°C and a maximum accumulated heating time of 10 seconds as a guideline. • Please contact us for details. • All specifications are subject to change without notice. 001-04 / 20070417 / e531_nlhv25.fm (2/2) SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN R12 2.5±0.2 1.8±0.1 0.5 Terminal electrode (0.4) 2±0.1 Inductor Solder land pattern 1.5 1.0 1.5 1.0 1.4±0.1 Weight:25mg Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 Inductance tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Q min. 30 30 35 35 35 40 40 40 40 40 40 Test frequency L,Q (MHz) 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 Self-resonant frequency (MHz)min. 700 550 500 450 425 400 375 350 325 180 120 DC resistance (Ω)max. 0.38 0.42 0.45 0.5 0.58 0.68 0.73 0.83 0.93 0.98 1.05 Rated current (mA)max. 550 500 475 450 425 400 375 350 325 300 280 Part No. NLHV25T-R12J-PF NLHV25T-R15J-PF NLHV25T-R18J-PF NLHV25T-R22J-PF NLHV25T-R27J-PF NLHV25T-R33J-PF NLHV25T-R39J-PF NLHV25T-R47J-PF NLHV25T-R56J-PF NLHV25T-R68J-PF NLHV25T-R82J-PF TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE vs. FREQUENCY CHARACTERISTICS 1000 900 800 700 Inductance(nH) 600 500 400 300 200 100 0 0.22µH 1 0.18µH 0.15µH 0.12µH 100 10 Frequency (MHz) 0.68µH 0.56µH 0.47µH 0.39µH 0.27µH 0.82µH Q vs. FREQUENCY CHARACTERISTICS 100 90 80 70 60 Q 50 40 30 20 10 0 1 10 Frequency (MHz) 100 0.82µH 0.68µH 0.12µH 0.15µH 0.18µH 0.22µH 0.56µH 0.47µH 0.39µH 0.27µH • All specifications are subject to change without notice. 001-04 / 20070417 / e531_nlhv25.fm
NLHV25T-R12J-PF 价格&库存
很抱歉,暂时无法提供与“NLHV25T-R12J-PF”相匹配的价格&库存,您可以联系我们找货
NLHV25T-R12J-PF
    • 2000+0.71337
    库存:5678
