I N D U C T O R S
September 2017
Inductors for Standard Circuits
Wound Ferrite
NLV-PFD Series (For automobiles)
NLV25-PFDType
NLV25-PFD
2520 [1008 inch]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog is not recommended
to a new design
Please refer to our Web site about replacement information.
The products in this catalog is not recommended to a new design
(2/9)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20170920 / inductor_automotive_standard_nlv25-pfd_en.fm
(3/9)
I N D U C T O R S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
AEC-Q200
Wound Ferrite
Overview of NLV25-PFD Type
FEATURES
Resin mold type wound inductor for standard circuits.
E-12 Series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as
filter circuits.
Has excellent inductance temperature characteristics in the operating temperature range.
APPLICATION
Vehicle accessories (car navigation systems, car audio, ETC)
PART NUMBER CONSTRUCTION
NLV
Series name
25
T
L×W×H Dimensions
(mm)
25
2.5×2.0×1.8
Packaging style
T
Taping
010
Inductance
(µH)
010
0.01
R10
0.1
1R0
1
100
10
101
100
J
PFD
Inductance
tolerance
J
±5%
Internal code
PFD
Compatible with the RoHS
Directive, Exemption
regulations apply
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Operating
Storage
temperature
temperature
(pieces/reel)
(°C)
(°C)
NLV25-PFD
–40 to +105
–40 to +105
2000
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Individual weight
Type
(mg)
25
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I N D U C T O R S
NLV25-PFD Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
(5/9)
I N D U C T O R S
NLV25-PFD Type
2±0.1
100J
1.4±0.1
SHAPE & DIMENSIONS
0.5
(0.4)
(1.7)
(0.4)
1.8±0.1
2.5±0.2
Dimensions in mm
1.5
RECOMMENDED LAND PATTERN
1.0
1.5
1.0
Dimensions in mm
(6/9)
I N D U C T O R S
NLV25-PFD Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
0.01
0.012
0.015
0.018
0.022
0.027
0.033
0.039
0.047
0.056
0.068
0.082
0.1
0.12
0.15
0.18
0.22
0.27
0.33
0.39
0.47
0.56
0.68
0.82
1
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
Q
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
min.
15
15
15
15
15
15
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
25
25
25
25
25
25
25
25
25
25
(MHz)
100
100
100
100
100
100
100
100
100
100
100
100
100
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
0.796
(MHz)min.
2150
2050
2000
1850
1650
1550
1450
1350
1200
1100
1050
900
800
700
550
500
450
425
400
375
350
325
300
260
245
230
182
135
105
70
55
48
43
42
39
36
33
30
26
24
22
21
17
16
15
13
12
(Ω )max.
0.26
0.27
0.29
0.31
0.37
0.4
0.42
0.45
0.5
0.6
0.65
0.75
0.8
0.3
0.35
0.4
0.5
0.55
0.6
0.65
0.68
0.75
0.85
1
1.1
1.2
1.3
1.45
1.55
1.7
1.9
2.1
2.3
2.5
2.7
3.05
3.5
3.8
4.4
4.8
5.5
6.3
7.1
9.5
11.1
12.1
16.6
19
21
(mA)max.
530
500
480
450
420
410
400
380
360
340
320
300
280
550
500
460
430
420
400
375
350
325
300
260
245
230
220
210
200
195
185
180
175
170
165
160
155
150
140
130
125
115
110
90
80
75
70
66
60
NLV25T-010J-PFD
NLV25T-012J-PFD
NLV25T-015J-PFD
NLV25T-018J-PFD
NLV25T-022J-PFD
NLV25T-027J-PFD
NLV25T-033J-PFD
NLV25T-039J-PFD
NLV25T-047J-PFD
NLV25T-056J-PFD
NLV25T-068J-PFD
NLV25T-082J-PFD
NLV25T-R10J-PFD
NLV25T-R12J-PFD
NLV25T-R15J-PFD
NLV25T-R18J-PFD
NLV25T-R22J-PFD
NLV25T-R27J-PFD
NLV25T-R33J-PFD
NLV25T-R39J-PFD
NLV25T-R47J-PFD
NLV25T-R56J-PFD
NLV25T-R68J-PFD
NLV25T-R82J-PFD
NLV25T-1R0J-PFD
NLV25T-1R2J-PFD
NLV25T-1R5J-PFD
NLV25T-1R8J-PFD
NLV25T-2R2J-PFD
NLV25T-2R7J-PFD
NLV25T-3R3J-PFD
NLV25T-3R9J-PFD
NLV25T-4R7J-PFD
NLV25T-5R6J-PFD
NLV25T-6R8J-PFD
NLV25T-8R2J-PFD
NLV25T-100J-PFD
NLV25T-120J-PFD
NLV25T-150J-PFD
NLV25T-180J-PFD
NLV25T-220J-PFD
NLV25T-270J-PFD
NLV25T-330J-PFD
NLV25T-390J-PFD
NLV25T-470J-PFD
NLV25T-560J-PFD
NLV25T-680J-PFD
NLV25T-820J-PFD
NLV25T-101J-PFD
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial L value)
Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating)
○ Measurement equipment
Measurement item
Product No.
4191A+16092A
L, Q
4194A+16085A+16093B
Self-resonant frequency
8753C
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
(7/9)
I N D U C T O R S
NLV25-PFD Type
L FREQUENCY CHARACTERISTICS GRAPH
1000
101J
820J
680J
560J
470J
390J
330J
270J
220J
180J
150J
120J
100J
8R2J
100
6R8J
5R6J
4R7J
3R9J
3R3J
10
2R7J
2R2J
1R8J
Inductance(µH)
1R5J
1R2J
1R0J
R82J
R68J
1
R56J
R47J
R39J
R33J
R27J
0.1
0.01
010J
047J
039J
033J
027J
022J
R10J
082J
R22J
0.001
0.1
1
10
Frequency(MHz)
068J
R18J
018J
R15J
015J
012J
056J
R12J
100
1000
Product No.
Manufacturer
4291A
4294A
(8/9)
I N D U C T O R S
NLV25-PFD Type
Q FREQUENCY CHARACTERISTICS GRAPH
60
056J
50
047J
068J
4R7J
1R8J
150J
082J
3R3J
40
033J
180J
R33J
R39J
2R7J
3R9J
100J
1R0J
Q
6R8J
010J
R27J
30
R15J
R12J
R68J
1R2J
5R6J
120J
8R2J
039J
012J
022J
015J
470J
220J
2R2J
018J
270J
330J
390J
560J
R10J
027J
820J
680J
R22J 101J
R18J
1R5J
10
R82J
R56J
R47J
1
10
Frequency(MHz)
100
1000
Product No.
Manufacturer
4291A
4294A
(9/9)
I N D U C T O R S
NLV25-PFD Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
NLV25-PFD
A
ø180
W1
9
W2
13
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
NLV25-PFD
A
2.3
B
2.7
B
W
F
E
øD0
øD0
1.5+0.1/-0
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.30
K
2
t
0.4
很抱歉,暂时无法提供与“NLV25T-R56J-PFD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.539301+0.32820
- 10+2.1081010+0.27250
- 25+1.9524025+0.25240
- 100+1.50920100+0.19510
- 250+1.43740250+0.18580
- 1000+1.008501000+0.13040
- 2000+0.964202000+0.12470
- 4000+0.947504000+0.12250
- 10000+0.8504010000+0.11000
