NLV32T-2R2J-PFD
NLV32T-2R2J-PFD
    TDK(东电化)
    IND_3.2X2.5MM_SM
    NLV32T-2R2J-PFD
NLV32T-2R2J-PFD 数据手册
I N D U C T O R S September 2017 Inductors for Standard Circuits Wound Ferrite NLV-PFD Series (For automobiles) NLV32-PFD Type NLV32-PFD 3225 [1210 inch]* * Dimensions Code JIS[EIA] Caution The products in this catalog is not recommended to a new design Please refer to our Web site about replacement information. The products in this catalog is not recommended to a new design (2/10) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (3/10) I N D U C T O R S Product compatible with RoHS directive Halogen-free Compatible with lead-free solders AEC-Q200 Inductors for Standard Circuits Wound Ferrite Overview of NLV32-PFD Type FEATURES Resin mold type wound inductor for standard circuits. E-12 Series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as filter circuits. Has excellent inductance temperature characteristics in the operating temperature range. APPLICATION Vehicle accessories (car navigation systems, car audio, ETC) PART NUMBER CONSTRUCTION NLV Series name 32 T L×W×H Dimensions (mm) 32 3.2×2.5×2.2 Packaging style T Taping - 010 - Inductance (µH) 010 0.01 R10 0.1 1R0 1 100 10 101 100 J - PFD Inductance tolerance J ±5% Internal code PFD Compatible with the RoHS Directive, Exemption regulations apply OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Package quantity Operating Storage temperature temperature (pieces/reel) (°C) (°C) NLV32-PFD –40 to +105 –40 to +105 2000 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. Individual weight Type (mg) 50 RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (4/10) I N D U C T O R S NLV32-PFD Type RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 90 to 120s Soldering Temp. Time T3 t2 230°C 40s Peak Temp. T4 255°C Time t3 10s max. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (5/10) I N D U C T O R S NLV32-PFD Type 470J 1.9±0.1 2.5±0.2 SHAPE & DIMENSIONS 0.55 (0.55) (2.1) (0.55) 2.2±0.2 3.2±0.2 Dimensions in mm 2 RECOMMENDED LAND PATTERN 1.2 2 1.2 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (6/10) I N D U C T O R S NLV32-PFD Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (µH) 0.01 0.012 0.015 0.018 0.022 0.027 0.033 0.039 0.047 0.056 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2  Tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Q L, Q measuring frequency Self-resonant frequency DC resistance Rated current Part No. min. 15 17 19 21 23 23 25 25 26 26 27 27 28 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 (MHz) 100 100 100 100 100 100 100 100 100 100 100 100 100 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 25.2 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 (MHz)min. 2500 2300 2100 1900 1700 1500 1400 1300 1200 1100 1000 900 700 500 450 400 350 320 300 250 220 180 160 140 120 100 85 80 75 70 60 55 50 45 40 35 (Ω )max. 0.13 0.14 0.16 0.18 0.2 0.22 0.24 0.27 0.3 0.33 0.36 0.4 0.44 0.22 0.25 0.28 0.32 0.36 0.4 0.45 0.5 0.55 0.6 0.65 0.7 0.75 0.85 0.9 1 1.1 1.2 1.3 1.5 1.6 1.8 2 (mA)max. 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 400 390 370 350 320 290 260 250 220 200 180 170 NLV32T-010J-PFD NLV32T-012J-PFD NLV32T-015J-PFD NLV32T-018J-PFD NLV32T-022J-PFD NLV32T-027J-PFD NLV32T-033J-PFD NLV32T-039J-PFD NLV32T-047J-PFD NLV32T-056J-PFD NLV32T-068J-PFD NLV32T-082J-PFD NLV32T-R10J-PFD NLV32T-R12J-PFD NLV32T-R15J-PFD NLV32T-R18J-PFD NLV32T-R22J-PFD NLV32T-R27J-PFD NLV32T-R33J-PFD NLV32T-R39J-PFD NLV32T-R47J-PFD NLV32T-R56J-PFD NLV32T-R68J-PFD NLV32T-R82J-PFD NLV32T-1R0J-PFD NLV32T-1R2J-PFD NLV32T-1R5J-PFD NLV32T-1R8J-PFD NLV32T-2R2J-PFD NLV32T-2R7J-PFD NLV32T-3R3J-PFD NLV32T-3R9J-PFD NLV32T-4R7J-PFD NLV32T-5R6J-PFD NLV32T-6R8J-PFD NLV32T-8R2J-PFD Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (10% below the initial L value) Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating) ○ Measurement equipment Measurement item Product No. 4191A+16092A L, Q 4194A+16085A+16093B Self-resonant frequency 8753C DC resistance VP-2941A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Panasonic Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (7/10) I N D U C T O R S NLV32-PFD Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (µH) 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470  Tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Q L, Q measuring frequency Self-resonant frequency DC resistance Rated current Part No. min. 30 30 30 30 30 30 30 30 30 30 30 30 20 20 20 20 20 20 20 20 20 (MHz) 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 (MHz)min. 30 20 20 20 20 20 17 16 15 13 12 11 10 10 8 7 7 6 5 5 4 (Ω )max. 2.1 2.5 2.8 3.3 3.7 5 5.6 6.4 7 8 9 10 10 11 15 17 21 28 34 36 40 (mA)max. 150 140 130 120 110 80 70 65 60 55 50 45 40 70 65 60 50 45 40 35 25 NLV32T-100J-PFD NLV32T-120J-PFD NLV32T-150J-PFD NLV32T-180J-PFD NLV32T-220J-PFD NLV32T-270J-PFD NLV32T-330J-PFD NLV32T-390J-PFD NLV32T-470J-PFD NLV32T-560J-PFD NLV32T-680J-PFD NLV32T-820J-PFD NLV32T-101J-PFD NLV32T-121J-PFD NLV32T-151J-PFD NLV32T-181J-PFD NLV32T-221J-PFD NLV32T-271J-PFD NLV32T-331J-PFD NLV32T-391J-PFD NLV32T-471J-PFD Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (10% below the initial L value) Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating) ○ Measurement equipment Measurement item Product No. 4191A+16092A L, Q 4194A+16085A+16093B Self-resonant frequency 8753C DC resistance VP-2941A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Panasonic Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (8/10) I N D U C T O R S NLV32-PFD Type ELECTRICAL CHARACTERISTICS L FREQUENCY CHARACTERISTICS GRAPH 10000 471J 221J 391J 331J 271J 181J 1000 101J 151J 121J 100 820J 100J 8R2J 6R8J 5R6J 4R7J 3R9J 3R3J 2R7J 2R2J 1R8J 680J 560J 470J 390J 330J 270J 220J 180J Inductance(µH) 10 R82J 150J 120J R68J R56J 1R5J 1R2J 1 R47J R39J R33J R27J 082J R22J 1R0J R10J 0.1 0.01 027J 033J 0.001 0.1 1 022J 018J 015J 010J 10 Frequency(MHz) 012J 047J 056J 068J R12J R15J R18J 100 039J 1000 ○ Measurement equipment Product No. Manufacturer 4291A Keysight Technologies 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (9/10) I N D U C T O R S NLV32-PFD Type ELECTRICAL CHARACTERISTICS Q FREQUENCY CHARACTERISTICS GRAPH 70 068J 056J 60 039J 047J 082J 50 220J 4R7J 8R2J 40 033J 180J 1R2J 100J 6R8J 1R0J 027J 270J 1R5J Q 010J 820J 120J 391J 1R8J 2R7J 2R2J R82J R56J R39J 330J R15J 390J R12J 5R6J 150J 30 271J 221J 121J 3R3J 3R9J R10J 012J 015J 018J 470J R47J 20 R68J R18J 331J R22J 560J 022J 680J 10 R27J 101J 151J R33J 181J 471J 0 0.1 1 10 Frequency(MHz) 100 1000 ○ Measurement equipment Product No. Manufacturer 4291A Keysight Technologies 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm The products in this catalog is not recommended to a new design (10/10) I N D U C T O R S NLV32-PFD Type PACKAGING STYLE REEL DIMENSIONS 2.0±0.5 E Type NLV32-PFD A ø180 W1 9 W2 13 N ø60 E 0.5 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 t A Type NLV32-PFD A 2.8 B 3.5 B W F E øD0 øD0 1.5+0.1/-0 Dimensions in mm E F P0 P1 P2 W 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.30 K 2.3 t 0.4 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170920 / inductor_automotive_standard_nlv32-pfd_en.fm
NLV32T-2R2J-PFD
物料型号:NLV32-PFD系列,兼容RoHS指令,无卤素,兼容无铅焊料,符合AEC-Q200标准。
器件简介:NLV32-PFD系列是用于标准电路的树脂封装型绕线电感器,具有E-12系列,兼容J(±5%)容差,适用于需要严格L容差如滤波电路的应用。
引脚分配:文档中提供了推荐的焊盘图案尺寸,但没有具体说明每个引脚的功能。
参数特性:电感值范围从0.01μH到10μH,容差为±5%或+5%,Q值最小为15,自谐振频率范围从700MHz到2500MHz,最大直流电阻和额定电流根据不同型号而变化。
功能详解:文档中提到了电感器在操作温度范围内具有出色的电感温度特性。
应用信息:适用于车辆配件,如汽车导航系统、汽车音响、ETC等。
封装信息:NLV32-PFD系列的尺寸为3225(1210英寸),并提供了包装风格、卷包装数量和单个产品重量等信息。
NLV32T-2R2J-PFD 价格&库存
很抱歉,暂时无法提供与“NLV32T-2R2J-PFD”相匹配的价格&库存,您可以联系我们找货
