I N D U C T O R S
September 2017
Inductors for Standard Circuits
Wound Ferrite
NLV-PFD Series (For automobiles)
NLV32-PFD Type
NLV32-PFD
3225 [1210 inch]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog is not recommended
to a new design
Please refer to our Web site about replacement information.
The products in this catalog is not recommended to a new design
(2/10)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20170920 / inductor_automotive_standard_nlv32-pfd_en.fm
(3/10)
I N D U C T O R S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
AEC-Q200
Wound Ferrite
Overview of NLV32-PFD Type
FEATURES
Resin mold type wound inductor for standard circuits.
E-12 Series, wide lineup compatible with J (±5%) tolerance, can be used for applications that need to meet strict L tolerance such as
filter circuits.
Has excellent inductance temperature characteristics in the operating temperature range.
APPLICATION
Vehicle accessories (car navigation systems, car audio, ETC)
PART NUMBER CONSTRUCTION
NLV
Series name
32
T
L×W×H Dimensions
(mm)
32
3.2×2.5×2.2
Packaging style
T
Taping
010
Inductance
(µH)
010
0.01
R10
0.1
1R0
1
100
10
101
100
J
PFD
Inductance
tolerance
J
±5%
Internal code
PFD
Compatible with the RoHS
Directive, Exemption
regulations apply
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Operating
Storage
temperature
temperature
(pieces/reel)
(°C)
(°C)
NLV32-PFD
–40 to +105
–40 to +105
2000
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Individual weight
Type
(mg)
50
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/10)
I N D U C T O R S
NLV32-PFD Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
90 to 120s
Soldering
Temp.
Time
T3
t2
230°C
40s
Peak
Temp.
T4
255°C
Time
t3
10s max.
(5/10)
I N D U C T O R S
NLV32-PFD Type
470J
1.9±0.1
2.5±0.2
SHAPE & DIMENSIONS
0.55
(0.55)
(2.1)
(0.55)
2.2±0.2
3.2±0.2
Dimensions in mm
2
RECOMMENDED LAND PATTERN
1.2
2
1.2
Dimensions in mm
(6/10)
I N D U C T O R S
NLV32-PFD Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
0.01
0.012
0.015
0.018
0.022
0.027
0.033
0.039
0.047
0.056
0.068
0.082
0.1
0.12
0.15
0.18
0.22
0.27
0.33
0.39
0.47
0.56
0.68
0.82
1
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
Q
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
min.
15
17
19
21
23
23
25
25
26
26
27
27
28
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
30
(MHz)
100
100
100
100
100
100
100
100
100
100
100
100
100
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
(MHz)min.
2500
2300
2100
1900
1700
1500
1400
1300
1200
1100
1000
900
700
500
450
400
350
320
300
250
220
180
160
140
120
100
85
80
75
70
60
55
50
45
40
35
(Ω )max.
0.13
0.14
0.16
0.18
0.2
0.22
0.24
0.27
0.3
0.33
0.36
0.4
0.44
0.22
0.25
0.28
0.32
0.36
0.4
0.45
0.5
0.55
0.6
0.65
0.7
0.75
0.85
0.9
1
1.1
1.2
1.3
1.5
1.6
1.8
2
(mA)max.
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
450
400
390
370
350
320
290
260
250
220
200
180
170
NLV32T-010J-PFD
NLV32T-012J-PFD
NLV32T-015J-PFD
NLV32T-018J-PFD
NLV32T-022J-PFD
NLV32T-027J-PFD
NLV32T-033J-PFD
NLV32T-039J-PFD
NLV32T-047J-PFD
NLV32T-056J-PFD
NLV32T-068J-PFD
NLV32T-082J-PFD
NLV32T-R10J-PFD
NLV32T-R12J-PFD
NLV32T-R15J-PFD
NLV32T-R18J-PFD
NLV32T-R22J-PFD
NLV32T-R27J-PFD
NLV32T-R33J-PFD
NLV32T-R39J-PFD
NLV32T-R47J-PFD
NLV32T-R56J-PFD
NLV32T-R68J-PFD
NLV32T-R82J-PFD
NLV32T-1R0J-PFD
NLV32T-1R2J-PFD
NLV32T-1R5J-PFD
NLV32T-1R8J-PFD
NLV32T-2R2J-PFD
NLV32T-2R7J-PFD
NLV32T-3R3J-PFD
NLV32T-3R9J-PFD
NLV32T-4R7J-PFD
NLV32T-5R6J-PFD
NLV32T-6R8J-PFD
NLV32T-8R2J-PFD
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial L value)
Idc2: When based on the temperature increase (Temperature increase of 20°C by self heating)
○ Measurement equipment
Measurement item
Product No.
4191A+16092A
L, Q
4194A+16085A+16093B
Self-resonant frequency
8753C
DC resistance
VP-2941A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
(7/10)
I N D U C T O R S
NLV32-PFD Type
L
(µH)
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
Tolerance
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
Q
L, Q measuring
frequency
Self-resonant
frequency
DC resistance
Rated current
Part No.
min.
30
30
30
30
30
30
30
30
30
30
30
30
(MHz)
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
0.796
(MHz)min.
30
16
15
13
12
11
10
10
8
7
7
6
5
5
4
(Ω )max.
2.1
2.5
2.8
3.3
3.7
5
5.6
6.4
7
8
9
10
10
11
15
17
21
28
34
36
40
(mA)max.
150
140
130
120
110
80
70
65
60
55
50
45
40
70
65
60
50
45
40
35
25
NLV32T-100J-PFD
NLV32T-120J-PFD
NLV32T-150J-PFD
NLV32T-180J-PFD
NLV32T-220J-PFD
NLV32T-270J-PFD
NLV32T-330J-PFD
NLV32T-390J-PFD
NLV32T-470J-PFD
NLV32T-560J-PFD
NLV32T-680J-PFD
NLV32T-820J-PFD
NLV32T-101J-PFD
NLV32T-121J-PFD
NLV32T-151J-PFD
NLV32T-181J-PFD
NLV32T-221J-PFD
NLV32T-271J-PFD
NLV32T-331J-PFD
NLV32T-391J-PFD
NLV32T-471J-PFD
Measurement item
Product No.
4191A+16092A
L, Q
4194A+16085A+16093B
8753C
DC resistance
VP-2941A
Manufacturer
Panasonic
(8/10)
I N D U C T O R S
NLV32-PFD Type
L FREQUENCY CHARACTERISTICS GRAPH
10000
471J
221J
391J
331J
271J
181J
1000
101J
151J
121J
100
820J
100J
8R2J
6R8J 5R6J
4R7J
3R9J
3R3J
2R7J
2R2J
1R8J
680J
560J
470J
390J
330J
270J
220J
180J
Inductance(µH)
10
R82J
150J
120J
R68J
R56J
1R5J
1R2J
1
R47J
R39J
R33J
R27J 082J
R22J
1R0J
R10J
0.1
0.01
027J
033J
0.001
0.1
1
022J
018J
015J
010J
10
Frequency(MHz)
012J
047J
056J
068J
R12J
R15J
R18J
100
039J
1000
Product No.
Manufacturer
4291A
4294A
(9/10)
I N D U C T O R S
NLV32-PFD Type
Q FREQUENCY CHARACTERISTICS GRAPH
70
068J
056J
60
039J
047J
082J
50
220J
4R7J
8R2J
40
033J
180J
1R2J
100J
6R8J
1R0J
027J
270J
1R5J
Q
010J
820J
120J
391J
1R8J
2R7J
2R2J
R82J
R56J
R39J
330J
R15J
390J
R12J
5R6J
150J
30
271J
221J
121J
3R3J
3R9J
R10J
012J
015J
018J
470J
R47J
R68J
R18J
331J
R22J
560J
022J
680J
10
R27J
101J
151J
R33J
181J
471J
1
10
Frequency(MHz)
100
1000
Product No.
Manufacturer
4291A
4294A
(10/10)
I N D U C T O R S
NLV32-PFD Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
NLV32-PFD
A
ø180
W1
9
W2
13
N
ø60
E
0.5
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
NLV32-PFD
A
2.8
B
3.5
B
W
F
E
øD0
øD0
1.5+0.1/-0
Dimensions in mm
E
F
P0
P1
P2
W
1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.30
K
2.3
t
0.4
很抱歉,暂时无法提供与“NLV32T-R56J-PFD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.539301+0.32920
- 10+2.1081010+0.27330
- 25+1.9524025+0.25310
- 100+1.50920100+0.19570
- 250+1.43740250+0.18630
- 1000+0.982201000+0.12740
- 2000+0.929502000+0.12050
- 4000+0.921104000+0.11940
- 10000+0.8325010000+0.10790
