NTCG0805-KIT
NTCG0805-KIT
    TDK(东电化)
    NTC 热敏电阻套件 160 件(16 个值 - 每个值 10 件)
NTCG0805-KIT 数据手册
  NTCG0805‐KIT Series Thermistor Sample Kit  SMD Nega ve Temperature Coefficient Thermistor Sample Kit  Thermistor  TDK’s NTCG Series Thermistors are manufactured from sintered metal oxides. Each  Mul layer  thermistor consists of a combina on of two to four of the following materials:  Commercial  Manganese, Nickel, Cobalt, and Copper. NTC thermistors are semiconductor resistors  that exhibit decreasing resistance characteris cs with increasing temperature. TDK thermistors have low  thermal  me constants which result in extremely high rates of resistance change to accurately track the  temperature.  Features  Internal Structure of NTCG Series Mul layer Chip Thermistors   Lead (Pb) free product   Wide range of resistances and B constants available   Good stability of resistance value a er soldering   Standard opera ng temperature range of  –40 to +125°C   Storage temperature range of –40 to +125°C (a er PC board  moun ng)    Applica ons   Mobile communica on devices   DVC, DSC   Op cal Transmission System   Computer devices   Printer  Sample Kit Informa on  Size  Thickness  Nominal Resistance  B Value  B Value  [mm]  [mm]  [@ 25°C]±5%  [25/50°C]  [25/85°C]  1.0  470ohm to 150kohm  (3060‐4085K)  3150‐4150K  Series  2.0 x 1.2  NTCG  [EIA 0805]  Kit contains 160 pieces total—10 pieces each of 16 values  Digi‐Key Part Number:  NTCG0805‐KIT‐ND  Rev. March 2018    NTCG0805‐KIT Series Thermistor Sample Kit  SMD Nega ve Temperature Coefficient Thermistor Sample Kit  Digi‐Key Part Number  NTCG0805‐KIT‐ND  TDK Part Number  Part Number Descrip on  NTCG203BH102JT1  1kohm ± 5%, 3100K  NTCG203BH152JT1  1.5kohm ± 5%, 3100K  NTCG203EH471JT1  470ohm ± 5%, 3250K  NTCG203EH681JT1  680ohm ± 5%, 3250K  NTCG203FH222JT1  2.2kohm ± 5%, 3300K  NTCG203FH332JT1  3.3kohm ± 5%, 3300K  NTCG203JH472JT1  4.7kohm ± 5%, 3450K  NTCG203JH682JT1  6.8kohm ± 5%, 3450K  NTCG203NH103JT1  10kohm ± 5%, 3650K  NTCG203NH153JT1  15kohm ± 5%, 3650K  NTCG203SH223JT1  22kohm ± 5%, 3850K  NTCG203SH333JT1  33kohm ± 5%, 3850K  NTCG204AH473JT1  47kohm ± 5%, 4000K  NTCG204AH683JT1  68kohm ± 5%, 4000K  NTCG204CH104JT1  100kohm ± 5%, 4150K  NTCG204CH154JT1  150kohm ± 5%, 4150K  Rev. March 2018
NTCG0805-KIT 价格&库存
很抱歉,暂时无法提供与“NTCG0805-KIT”相匹配的价格&库存,您可以联系我们找货
NTCG0805-KIT
    库存:6
