PAF500F24-28/T
PAF500F24-28/T
    TDK(东电化)
    全砖
    DC DC CONVERTER 28V 500W
PAF500F24-28/T 数据手册
• 12V output for driving non-isolated converters • Safety Approved • Up to 80A output current (48V models) • Full power at 100°C baseplate • Opto Isolated Remote On / Off • Wide Adjustable Output Range Key Market Segments & Applications Central Office: Broadband: Wireless/Cellular: PAF500F Remote Electronics: 24V & 48V Input Full Brick DC-DC Converters Customer Premise: PAF500F Features and Benefits Features Benefits • Wide adjustment range • Parallel Pin • ASIC Design • No potting materials • Reduces need for custom modules • Modules can be connected together for higher current • Reduced component count, increased MTBF • Lower weight Specifications MODEL ITEMS Nominal Output Voltage VDC Output Current (Max) A Max Output Power W Efficiency (Typ) % Input Voltage range VDC Input Current (Typ) (24V/48V) A 7.3 Output Voltage Accuracy % Output Voltage Adjustment VDC Max Ripple & Noise mV Max Line Regulation mV Max Load Regulation mV Overcurrent Protection % Overvoltage Protection % Signals & Control Operating Temperature Cooling Isolation Voltage Shock Vibration Amplitude Safety Agency Approvals Weight (Typ) Size (WxHxD) Warranty Notes: ATM, Sonet, DSL, ISDN, Frame relay Switching Equipment, Routers Micro Cells (larger in size/10 sq. mi.) Pico Cells (smaller in size/1 to 2 sq. mi.) Fixed Local Loop, Fiber Optic Transmission, Microwave Transmission, Wireless Local Loop PBX, PABX, Datacomm, Voice Systems, Video Conferencing VDC g in(mm) - PAF500F48-3.3 3.3 80 264 78 10.4 2-4 100 10 10 PAF500F48-5 36-76 5 80 400 83 24 / 12.2 3-6 100 10 10 ±1 PAF500F24-12 PAF500F48-12 12 42 504 89 19-36 or 36-76 7.2 - 13.2 200 24 24 23.8 / 12.1 PAF500F24-28 PAF500F48-28 28 18 504 90 18-36 or 36-76 105 - 140% 130-160 125-145 115-135 Remote sense, remote On/Off, Parallel Pin, DC Good (12, 28V models), Adjustable OVP (3.3, 5V models), 7-10V Auxiliary voltage -40°C to +100°C baseplate Conduction (See Installation Manual for heatsink selection) Input - Baseplate 1500V, Input - Output 1500V, Output-Baseplate 500V 196.1m/s2 Non Operating, 10-55Hz (sweep for 1 min.) 0.825mm constant (Max 49m/s2) X, Y, Z 1 hour each IEC/UL/CSA/EN62368-1, 60950-1, CE Mark 250 2.4x0.5x4.6 (61x12.7x116.8) See outline drawing 2 years See Installation Manual for full details, test methods of parameters and application notes. PAF500F Series 16.8 - 30.8 280 56 56 115-135 1 Pinout Pin Description Options Function Negative Input Terminal Positive Input Terminal Remote On/Off negative terminal Remote On/Off positive terminal Positive Output Terminal Negative Output Terminal 7-10V Aux voltage DC Good / OVP adjustment Parallel control connection Output adjustment Trim pin Positive Remote sense Negative Remore sense -Vin +Vin - ON/OFF +ON/OFF +V -V AUX IOG/OVP PC TRIM +S -S Suffix Blank /T PAF500F48-12 INPUT:36-76V 18A OUTPUT:12V 42A -Vin AUX IOG PC TRIM +S -S Outline Drawing PAF500F -V +Vin -ON/OFF +ON/OFF US PAT. NO. 52891382 Heatsink Table Heatsink HAF-10L HAF-15L HAF-15T 2 Size (mm) 116.8 x 25.4 x 61 116.8 x 38.1 x 61 116.8 x 38.1 x 61 DC-DC +V MADE IN JAPAN Thermal Resistance 2.2°C/W 1.9°C/W 1.5°C/W PAF500F Series Description No thread in mounting holes Connection Example For full data and drawings please visit www.emea.tdk-lambda.com/www/paf PAF500F Series 3 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en PAF500F Oct20 v3 4 PAF500F Series For Additional Information, please visit https://product.tdk.com/en/power/
PAF500F24-28/T 价格&库存
很抱歉,暂时无法提供与“PAF500F24-28/T”相匹配的价格&库存,您可以联系我们找货
