PAF500F48-12
PAF500F48-12
    TDK(东电化)
    Module
    隔离模块 直流转换器 1 输出 12V 42A 36V - 76V 输入
PAF500F48-12 数据手册
DENSEI-LAMBDA PAF500F48-* SPECIFICATIONS C160-01-01B 26 Isolation Resistance 27 Vibration 28 Shock 29 Weight (Typ.) 30 Size (W x H x D) V A W % A % mV mV mV g mm =NOTES= *1. At 48VDC, 80% of Maximum Output Current and Baseplate Temperature = +25°C. *2. At 48VDC and Maximum Output Current. *3. 36 - 76VDC, Constant Load. *4. No load - Full load, Constant input voltage. *5. Constant current limiting with automatic recovery. *6. Inverter shutdown method, Manual Reset. *7. Ratings - Refer to Derating Curve on the Right. - Load(%) is Percent of Maximum Output Current. *8. Heatsink has to be Chosen According to Instruction Manual. *9. Refer to Instruction Manual. *10 External Components are Needed for Operation. (Refer to Basic Connection and Instruction Manual) PAF500F48-3.3 PAF500F48-5 PAF500F48-12 PAF500F48-28 3.3 80 264 78 5 80 400 83 12 42 504 89 28 18 504 90 12.2 12.1 36 - 76VDC 7.3 10.4 ±1 -40%, +10% -40%, +20% 100 10 10 200 24 24 100 10 10 280 56 56 105% - 140% 125% - 145% 115% - 135% Possible Possible (SHORT : ON OPEN : OFF) Possible Possible Possible (Open Collector Output) -40°C - +100°C(Baseplate) Ambient Temperature min=-40°C 20 - 95%RH (No Dewdrop) -40°C - +100°C 10 - 95%RH (No Dewdrop) Conduction Cooled 0.02%/°C Input-Baseplate : 1.5kVDC, Input-Output : 1.5kVDC for 1min. Output-Baseplate : 500VDC for 1min. More than 100MΩ at 25°C and 70%RH Output-Baseplate...500VDC At No Operating, 10-55Hz (Sweep for 1min.) Amplitude 0.825mm Constant (Maximum 49.0m/s2) X,Y,Z 1 Hour each 196.1m/s2 250 61 x 12.7 x 116.8 (Refer to Outline Drawing) 130% - 160% Derating Curve 100% 80% Load (%) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 MODEL ITEMS Nominal Output Voltage Maximum Output Current Nominal Output Power Efficiency (Typ.) (*1) Input Voltage Range Input Current (Typ.) (*2) Output Voltage Accuracy (*2) Output Voltage Range (*10) Maximum Ripple & Noise (*10) Maximum Line Regulation (*3) Maximum Load Regulation (*4) Over Current Protection (*5) Over Voltage Protection (*6)(*9) Remote Sensing (*9) Remote ON/OFF Control (*9) Parallel Operation (*9) Series Operation (*9) I.O.G. Signal (*9) Operating Temperature (*7) Operating Humidity Storage Temperature Storage Humidity Cooling (*8) Temperature Coefficient (%) Withstand Voltage 60% 40% 20% 0% -40 -20 0 20 40 60 Baseplate Temperature (°C) 80 100
PAF500F48-12 价格&库存
很抱歉,暂时无法提供与“PAF500F48-12”相匹配的价格&库存,您可以联系我们找货
PAF500F48-12
  • 1+2686.734701+348.06203
库存:1
