PAF600F280-24/T
PAF600F280-24/T
    TDK(东电化)
    PAF600F280-24/T
PAF600F280-24/T 数据手册
PAF-F280 Series 200V to 400VDC Input Full brick DC-DC Converters Features u Output Voltages from 7.2V to 57V u 450W to 600W Output Power u Current Share u Operation to 100°C Baseplate u Wide Adjustable Output Range u Parallel Pin u High Efficiency - up to 91% Key Market Segments & Applications Specifications PAF450F280-12 PAF450F280-24 PAF450F280-28 PAF450F280-48 Model PAF600F280-12 PAF600F280-24 PAF600F280-28 PAF600F280-48 Nominal Output Voltage VDC Output Current (Max) 450W A 600W Max Output Power 450W W 600W Efficiency (Typ) % Input Voltage Range VDC Output Voltage Accuracy % Output Voltage Adjustment VDC Max Ripple & Noise mV Max Line Regulation mV Max Load Regulation mV Temperature Coefficient °C Overcurrent Protection % Overvoltage Protection % Signals & Control - Baseplate Temperature - Humidity (non condensing) - Cooling - Isolation Voltage - Shock - Vibration - Safety Agency Approvals - Weight (Typ) g Size (WxHxD) mm Warranty yrs 12 38 50 456 600 89-90 24 19 25 456 600 91 28 16.5 21.5 462 602 91 48 9.5 12.5 456 600 91 200-400VDC ±1 7.2 - 14.4 14.4 - 28.8 16.8 - 33.6 28.8 - 57.6 270 240 280 480 48 56 56 96 48 56 56 96 0.02%/°C 105 - 140% 125 - 145% Remote Sense, Remote On/Off, Parallel Pin, Inverter Good, 11-14V Auxiliary voltage -40°C to +100°C Baseplate: (See derating chart) 5 - 95% RH Operating, 5 - 95% RH Non Operating Conduction (See Installation Manual for heatsink selection) Input to Baseplate: 2500VAC (20mA); Input to Output 3000VAC for 1 min.; Output to Baseplate: 500VDC for 1 min 196.1m/s2 Non Operating, 10-55Hz (sweep for 1 min.) Amplitude 0.825mm constant (Max 49 m/s2) X,Y,Z 1 hour each IEC/UL/CSA/EN62368-1, 60950-1, CE Mark 200 2.4 x 0.5 x 4.6 (61 x 12.7 x 116.8) See outline drawing 2 years Note: See Installation Manual for full details, test methods of parameters and application notes. PAF450F280 last time buy September 2023 PAF600F280 not recommended for new designs PAF-F280 Series Derating Curve PAF450F280 AUX IOG PC TRM +S -S PAF Outline Drawing PAF600F280-12 -Vin INPUT:200-400V OUTPUT:12V 4A 50A -V +Vin SG CNT +V DC-DC MADE IN JAPAN 94 PAF450F280-12,-24,-28 PAF450F280-48 Vinput >380V Connection Example Derating Curve PAF600F280 Pinout Pin Description -Vin +Vin CNT +V -V AUX PC TRIM +S -S SG Function Negative Input Terminal Positive Input Terminal Remote On/Off Positive Output Terminal Negative Output Terminal 11-14V Aux Voltage Parallel Control Connection Output Adjustment Trim Pin Positive Remote Sense Negative Remote Sense Remote ON/OFF Return Heatsink Table Heatsink HAF-10L HAF-15L HAF-15T Size (mm) 116.8 x 25.4 x 61 116.8 x 38.1 x 61 116.8 x 38.1 x 61 Thermal Resistance 2.2°C/W 1.9°C/W 1.5°C/W PAF600F280-12,-24,-28 PAF600F280-48 Vinput >380V Options Suffix Blank /T Description M3 tapped mounting inserts (4) 3.3mm non-threaded inserts (4) For Additional Information, please visit https://product.tdk.com/info/en/products/power/index.html Revision B3: Jul 2023
PAF600F280-24/T 价格&库存
很抱歉,暂时无法提供与“PAF600F280-24/T”相匹配的价格&库存,您可以联系我们找货
PAF600F280-24/T
  • 1+2557.573511+331.29522
