PAH75S48-15/P
PAH75S48-15/P
    TDK(东电化)
    PAH75S48-15/P
PAH75S48-15/P 数据手册
PAH Series 50W to 200W 48V Input Half brick DC-DC Converters Features  Industry Standard Footprint & Pinouts  12V output for driving non-isolated converters  Safety Approved  Full power at 100ºC baseplate  Wide Adjustable Output Range  Zero Pre-load  ASIC Design  No potting materials Key Market Segments & Applications Specifications Model Efficiency (Typ) Input Voltage range Output Voltage Accuracy Max Ripple & Noise Max Line Regulation Max Load Regulation Overcurrent Protection Overvoltage Protection Remote Sense Remote On/Off Operating Temperature Overtemperature Cooling Isolation Voltage Shock Vibration Amplitude Safety Agency Approvals Weight (Typ) Size (WxHxD) Warranty 2.5V (1) 3.3V 5V 12V 15V 24V 28V 48V % 75-76 79-80 83-84 85-86 86-88 88 VDC 36-76 % ±1.6 mV 150 200 280 250 mV 10 24 30 48 56 96 mV 10 24 30 48 56 96 % 105 - 150% automatic recovery % 120-160 120-140 125-145 135-155 Yes Standard; Low = ON, Open = OFF /P option; Low = OFF, Open = ON) ºC -40ºC to +100ºC baseplate ºC Shutdown between 105 - 130ºC, Auto restart Conduction (See Installation Manual for heatsink selection) V Input - Baseplate 1500VAC, Input - Output 1500VAC, Output-Baseplate 500VDC 196.1m/s2 Non Operating, 10-55Hz (sweep for 1 min.) 0.825mm constant (Max 49 m/s 2) X,Y,Z 1 hour each UL60950-1, CSA60950-1, EN60950-1, CE LVD g 80 in(mm) 2.28x0.5x2.4 (57.9x12.7x61) See outline drawing yrs 2 Years (1) See options table. General: See Installation Manual for full details, test methods of parameters and application notes Last Time Buy November 2019 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 244 Disclaimer: us.tdk-lambda.com/lp/legal.htm PAH Series Model Selector Model Name PAH50S48-2.5 PAH75S48-2.5 PAH100S48-2.5 PAH150S48-2.5 PAH50S48-3.3 PAH75S48-3.3 PAH100S48-3.3 PAH150S48-3.3 PAH50S48-5 PAH75S48-5 PAH100S48-5 PAH150S48-5 PAH50S48-12 PAH75S48-12 PAH100S48-12 PAH150S48-12 PAH200S48-12 PAH50S48-15 PAH75S48-15 PAH100S48-15 PAH150S48-15 PAH200S48-15 PAH50S48-24 PAH75S48-24 PAH100S48-24 PAH150S48-24 PAH200S48-24 PAH50S48-28 PAH75S48-28 PAH100S48-28 PAH150S48-28 PAH200S48-28 PAH150S48-48 Output Voltage 2.5 2.5 2.5 2.5 3.3 3.3 3.3 3.3 5.0 5.0 5.0 5.0 12.0 12.0 12.0 12.0 12.0 15.0 15.0 15.0 15.0 15.0 24.0 24.0 24.0 24.0 24.0 28.0 28.0 28.0 28.0 28.0 48.0 Outline Drawing Adjustment 2.25 - 2.75 2.25 - 2.75 2.25 - 2.75 2.25 - 2.75 2.97 - 3.63 2.97 - 3.63 2.97 - 3.63 2.97 - 3.63 3.0 - 5.75 3.0 - 5.75 3.0 - 5.75 3.0 - 5.75 7.2 - 13.2 7.2 - 13.2 7.2 - 13.2 7.2 - 13.2 7.2 - 13.2 9.0 - 16.5 9.0 - 16.5 9.0 - 16.5 9.0 - 16.5 9.0 - 16.5 14.4 - 26.4 14.4 - 26.4 14.4 - 26.4 14.4 - 26.4 14.4 - 26.4 16.8 - 30.8 16.8 - 30.8 16.8 - 30.8 16.8 - 30.8 16.8 - 30.8 38.4 - 57.6 Output Current 11.70 17.50 23.40 35.00 11.70 17.50 23.40 35.00 10.00 15.00 20.00 30.00 4.20 6.30 8.40 12.50 16.70 3.40 5.00 6.70 10.00 13.40 2.10 3.20 4.20 6.30 8.40 1.80 2.70 3.60 5.40 7.20 3.20 Options ON/OFF Suffix Control Negative /P Positive /V* Negative /PV Positive * Standard US Stock Item. Overvoltage Manual Reset Manual Reset Auto Reset Auto Reset Maximum Power 29.3 43.8 58.5 87.5 38.6 57.8 77.2 115.5 50.0 75.0 100.0 150.0 50.4 75.6 100.8 150.0 200.4 51.0 75.0 100.5 150.0 201.0 50.4 76.8 100.8 151.2 201.6 50.4 75.6 100.8 151.2 201.6 153.6 Pinout Pin Description -Vin +Vin Case CNT +V -V TRIM +S -S Function Negative Input Terminal Positive Input Terminal Baseplate Terminal On / Off Control terminal Positive Output Terminal Negative Output Terminal Output adjustment Trim pin Positive Remote sense Negative Remote sense Other DC-DC Products PAF PAH75D PAH200H PAQ CC-E PX 400-700W Full Brick DC-DC Dual output Half Bricks High Efficiency Half Brick Quarter brick DC-DC 1.5 to 30W, 5-48V Input DC-DC 10-60W, 12-48VDC Input DC-DC converters For Additional Information, please visit us.tdk-lambda.com/lp/products/pah-series.htm Last Time Buy November 2019 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 245 Revision A6: Feb 2019
PAH75S48-15/P 价格&库存
很抱歉,暂时无法提供与“PAH75S48-15/P”相匹配的价格&库存,您可以联系我们找货
