PAH Series
50W to 200W 48V Input Half brick DC-DC Converters
Features
Industry Standard Footprint & Pinouts
12V output for driving non-isolated converters
Safety Approved
Full power at 100ºC baseplate
Wide Adjustable Output Range
Zero Pre-load
ASIC Design
No potting materials
Key Market Segments & Applications
Specifications
Model
Efficiency (Typ)
Input Voltage range
Output Voltage Accuracy
Max Ripple & Noise
Max Line Regulation
Max Load Regulation
Overcurrent Protection
Overvoltage Protection
Remote Sense
Remote On/Off
Operating Temperature
Overtemperature
Cooling
Isolation Voltage
Shock
Vibration
Amplitude
Safety Agency Approvals
Weight (Typ)
Size (WxHxD)
Warranty
2.5V
(1)
3.3V
5V
12V
15V
24V
28V
48V
75-76
79-80
83-84
85-86
86-88
88
VDC
36-76
±1.6
mV
150
200
280
250
mV
10
24
30
48
56
96
mV
10
24
30
48
56
96
105 - 150% automatic recovery
120-160 120-140
125-145
135-155
Yes
Standard; Low = ON, Open = OFF /P option; Low = OFF, Open = ON)
ºC
-40ºC to +100ºC baseplate
ºC
Shutdown between 105 - 130ºC, Auto restart
Conduction (See Installation Manual for heatsink selection)
V
Input - Baseplate 1500VAC, Input - Output 1500VAC, Output-Baseplate 500VDC
196.1m/s2
Non Operating, 10-55Hz (sweep for 1 min.)
0.825mm constant (Max 49 m/s 2) X,Y,Z 1 hour each
UL60950-1, CSA60950-1, EN60950-1, CE LVD
g
80
in(mm)
2.28x0.5x2.4 (57.9x12.7x61) See outline drawing
yrs
2 Years
(1) See options table.
General: See Installation Manual for full details, test methods of parameters and application notes
Last Time Buy November 2019
1-800-526-2324 • www.us.tdk-lambda.com/lp/
244
Disclaimer: us.tdk-lambda.com/lp/legal.htm
PAH Series
Model Selector
Model
Name
PAH50S48-2.5
PAH75S48-2.5
PAH100S48-2.5
PAH150S48-2.5
PAH50S48-3.3
PAH75S48-3.3
PAH100S48-3.3
PAH150S48-3.3
PAH50S48-5
PAH75S48-5
PAH100S48-5
PAH150S48-5
PAH50S48-12
PAH75S48-12
PAH100S48-12
PAH150S48-12
PAH200S48-12
PAH50S48-15
PAH75S48-15
PAH100S48-15
PAH150S48-15
PAH200S48-15
PAH50S48-24
PAH75S48-24
PAH100S48-24
PAH150S48-24
PAH200S48-24
PAH50S48-28
PAH75S48-28
PAH100S48-28
PAH150S48-28
PAH200S48-28
PAH150S48-48
Output
Voltage
2.5
2.5
2.5
2.5
3.3
3.3
3.3
3.3
5.0
5.0
5.0
5.0
12.0
12.0
12.0
12.0
12.0
15.0
15.0
15.0
15.0
15.0
24.0
24.0
24.0
24.0
24.0
28.0
28.0
28.0
28.0
28.0
48.0
Outline Drawing
Adjustment
2.25 - 2.75
2.25 - 2.75
2.25 - 2.75
2.25 - 2.75
2.97 - 3.63
2.97 - 3.63
2.97 - 3.63
2.97 - 3.63
3.0 - 5.75
3.0 - 5.75
3.0 - 5.75
3.0 - 5.75
7.2 - 13.2
7.2 - 13.2
7.2 - 13.2
7.2 - 13.2
7.2 - 13.2
9.0 - 16.5
9.0 - 16.5
9.0 - 16.5
9.0 - 16.5
9.0 - 16.5
14.4 - 26.4
14.4 - 26.4
14.4 - 26.4
14.4 - 26.4
14.4 - 26.4
16.8 - 30.8
16.8 - 30.8
16.8 - 30.8
16.8 - 30.8
16.8 - 30.8
38.4 - 57.6
Output
Current
11.70
17.50
23.40
35.00
11.70
17.50
23.40
35.00
10.00
15.00
20.00
30.00
4.20
6.30
8.40
12.50
16.70
3.40
5.00
6.70
10.00
13.40
2.10
3.20
4.20
6.30
8.40
1.80
2.70
3.60
5.40
7.20
3.20
Options
ON/OFF
Suffix
Control
Negative
/P
Positive
/V*
Negative
/PV
Positive
* Standard US Stock Item.
Overvoltage
Manual Reset
Manual Reset
Auto Reset
Auto Reset
Maximum
Power
29.3
43.8
58.5
87.5
38.6
57.8
77.2
115.5
50.0
75.0
100.0
150.0
50.4
75.6
100.8
150.0
200.4
51.0
75.0
100.5
150.0
201.0
50.4
76.8
100.8
151.2
201.6
50.4
75.6
100.8
151.2
201.6
153.6
Pinout
Pin Description
-Vin
+Vin
Case
CNT
+V
-V
TRIM
+S
-S
Function
Negative Input Terminal
Positive Input Terminal
Baseplate Terminal
On / Off Control terminal
Positive Output Terminal
Negative Output Terminal
Output adjustment Trim pin
Positive Remote sense
Negative Remote sense
Other DC-DC Products
PAF
PAH75D
PAH200H
PAQ
CC-E
PX
400-700W Full Brick DC-DC
Dual output Half Bricks
High Efficiency Half Brick
Quarter brick DC-DC
1.5 to 30W, 5-48V Input DC-DC
10-60W, 12-48VDC Input DC-DC converters
For Additional Information, please visit
us.tdk-lambda.com/lp/products/pah-series.htm
245
Revision A6: Feb 2019
很抱歉,暂时无法提供与“PAH75S48-5/P”相匹配的价格&库存,您可以联系我们找货
