• Low Voltage Outputs (1.2-5.0V)
3
• High Power Density up to 90.4W/in
• Industry Standard Footprint & Pinouts
• Safety Agency Approvals (UL1950, CSA22.2, CE, TUV)
• Constant Current Limit (Auto Restarting)
• Remote On / Off (Positive/Negative Logic Available)
• ASIC Design to Reduce Component Count
PAQ50/100
Key Market Segments & Applications
PAQ100
Central Office:
Broadband:
Wireless/Celluar:
PAQ Series
Remote Electronics:
Quarter Brick
DC-DC Converters
Customer Premise:
Industrial:
ATM, Sonet, DSL, ISDN, Frame Relay, WDM
Switching Equipment, Routers
Micro Cells (larger in size/10 sq. mi.)
Pico Cells (smaller in size/1 to 2 sq. mi.)
Fixed Local Loop, Fiber Optic
Transmission, Microwave Transmission,
Wireless Local Loop
PBX, PABX, Datacomm, Voice Systems,
Video Conferencing
ATE Test Equipment & Semi-Fab
PAQ Features and Benefits
Features
Benefits
• Industry Standard footprint/pinout
• ASIC Design
• Wide Range Operating Temperature (-40 to 100°C)
• High Efficiency at 3.3V, 88% (PAQ50), 89% (PAQ100)
• Allows for multi-sourcing
• Reduces number of components
• Supports Harsh Wireless Operating Environment
• Reduce footprint area/Operation without heatsink
Specifications
ITEMS
Nominal Output Voltage
Max Output Current
Max Output Power
Efficiency (Typ.)
Input Voltage Range
Input Current (Typ.)
Output Voltage Accuracy
Output Voltage Range
Max Ripple & Noise
Max Line Regulation
Max Load Regulation
Over Current Protection
Over Voltage Protection
Remote ON/OFF Control
Cooling
Isolation Voltage
Shock
Weight
Vibration
Size (W x H x D)
Warranty
MODEL
(1)
(1)
(1)
(6)
(6)
(2)
(3)
(4)
(5)
(5)
V
A
W
A
mV
mV
mV
°C
g
in
PAQ50S48-1R2
PAQ100S48-1R2
1.2
12 / 25
14.4 / 30
78 / 80
0.39 / 0.8
PAQ50S48-1R8
PAQ100S48-1R8
1.8
12 / 25
21.6 / 45
83 / 84
0.56 / 1.14
PAQ50S48-2R5
PAQ100S48-2R5
2.5
12 / 25
30 / 62.5
85 / 86
36-76 VDC
0.75 / 1.55
± 1%
PAQ50S48-3R3
PAQ100S48-3R3
3.3
12 / 25
39.6 / 82.5
88 / 89
PAQ50S48-5
PAQ100S48-5
5
10 / 20
50 / 100
90
0.96 / 1.98
1.18 / 2.37
-20%, +10%
±15%
100
10
10
PAQ50: 105-150%; PAQ100 105-140%; (self-Recovering /V option)
120% - 140% (Self-Recovering /V option)
Low=On, Open =Off (/P option: Low=Off, Open=On)
Ta=-40 to +85° (100°C /B Option PAQ100 only)
Convection Cooled / Forced Air Cooled
Input-Output: 1.5kVDC for 1 min.
196.1m/s2
50
Non Operating, 10-55Hz (Sweep for 1 min.)
Amplitude 0.825mm Constant (Maximum 49.0n/s2) X, Y, Z 1 hour each
1.45" x .33" x 2.3"; 0.5" height (/B option PAQ100 only)
2 Years
Notes:
1. At 48VDC, maximum output current, Air Velocity = 2m/s and Ta = +25°C.
2. 36 - 76VDC, constant load.
3. No load - Full load, constant input voltage.
4. Inverter shutdown method, manual reset. Auto restart option available.
PAQ Series
5. Refer to installation manual (website).
6. External components are needed for operation.
1
Openframe Drawing PAQ50/100
Baseplate Drawing PAQ100
2
PAQ Series
Derating Curve PAQ
Note: Open Frame PAQ100S48-3.3/V unit shown.
Series Output PAQ
PIN#
Label
Function
1
2
3
4
5
6
7
8
-Vin
CNT
+Vin
-V
-S
TRM
+S
+V
Negative Input Terminal
ON/OFF Control Terminal
Positive Input Terminal
Negative Output Terminal
Negative Remote Sensing
Output Voltage Adjustment Terminal
Positive Remote Sensing
Positive Output Terminal
Series Options PAQ
Suffix
Description
Blank
/V
/P
/B
/C
Manual Reset after OVP or OCP condition
Auto Reset after OVP or OCP condition
Positive Logic Remote On/Off
Baseplate version
Additional 1.5mm height clearance from PCB
/V, /PV, /BV, /BPV are preferred items.
PAQ Series
3
TDK-LAMBDA EMEA
www.emea.tdk-lambda.com
TDK-Lambda France SAS
TDK-Lambda UK Ltd.
Route de Grivery
ZAC des Delaches
CS 41077
91978 Courtaboeuf Cedex
France
Tel: +33 1 60 12 71 65
Fax: +33 1 60 12 71 66
france@fr.tdk-lambda.com
www.fr.tdk-lambda.com
Kingsley Avenue
Ilfracombe
Devon EX34 8ES
United Kingdom
Tel: +44 (0) 12 71 85 66 66
Fax: +44 (0) 12 71 86 48 94
powersolutions@uk.tdk-lambda.com
www.uk.tdk-lambda.com
Italy Sales Office
Nemic Lambda Ltd.
Via dei Lavoratori 128/130
20092 Cinisello Balsamo (MI)
Italy
Tel: +39 02 61 29 38 63
Fax: +39 02 61 29 09 00
info.italia@it.tdk-lambda.com
www.it.tdk-lambda.com
Kibbutz
Givat Hashlosha 48800
Israel
Tel: +9 723 902 4333
Fax: +9 723 902 4777
info@nemic.co.il
www.nemic.co.il
TDK-Lambda Germany GmbH
Russia
Karl-Bold-Strasse 40
77855 Achern
Germany
Tel: +49 7841 666 0
Fax: +49 7841 5000
info.germany@de.tdk-lambda.com
www.de.tdk-lambda.com
Technical Support:
St Petersburg
Tel: +7 (812) 6580463
Sales:
Moscow
Tel: +7 (499) 7557732
info@tdk-lambda.ru
www.tdk-lambda.ru
Austria Sales Office
Aredstrasse 22
2544 Leobersdorf
Austria
Tel: +43 2256 655 84
Fax: +43 2256 645 12
LOCAL DISTRIBUTION
PAQ June11 v2
4
PAQ Series
很抱歉,暂时无法提供与“PAQ50S481R2/P”相匹配的价格&库存,您可以联系我们找货
