PAQ50S481R8/P
PAQ50S481R8/P
    TDK(东电化)
    8-DIP模块,1/4砖
    DC/DC CONVERTER 1.8V 22W
PAQ50S481R8/P 数据手册
• Low Voltage Outputs (1.2-5.0V) 3 • High Power Density up to 90.4W/in • Industry Standard Footprint & Pinouts • Safety Agency Approvals (UL1950, CSA22.2, CE, TUV) • Constant Current Limit (Auto Restarting) • Remote On / Off (Positive/Negative Logic Available) • ASIC Design to Reduce Component Count PAQ50/100 Key Market Segments & Applications PAQ100 Central Office: Broadband: Wireless/Celluar: PAQ Series Remote Electronics: Quarter Brick DC-DC Converters Customer Premise: Industrial: ATM, Sonet, DSL, ISDN, Frame Relay, WDM Switching Equipment, Routers Micro Cells (larger in size/10 sq. mi.) Pico Cells (smaller in size/1 to 2 sq. mi.) Fixed Local Loop, Fiber Optic Transmission, Microwave Transmission, Wireless Local Loop PBX, PABX, Datacomm, Voice Systems, Video Conferencing ATE Test Equipment & Semi-Fab PAQ Features and Benefits Features Benefits • Industry Standard footprint/pinout • ASIC Design • Wide Range Operating Temperature (-40 to 100°C) • High Efficiency at 3.3V, 88% (PAQ50), 89% (PAQ100) • Allows for multi-sourcing • Reduces number of components • Supports Harsh Wireless Operating Environment • Reduce footprint area/Operation without heatsink Specifications ITEMS Nominal Output Voltage Max Output Current Max Output Power Efficiency (Typ.) Input Voltage Range Input Current (Typ.) Output Voltage Accuracy Output Voltage Range Max Ripple & Noise Max Line Regulation Max Load Regulation Over Current Protection Over Voltage Protection Remote ON/OFF Control Operating Temperature Cooling Isolation Voltage Shock Weight Vibration Size (W x H x D) Warranty MODEL (1) (1) (1) (6) (6) (2) (3) (4) (5) (5) V A W % A % mV mV mV °C g in - PAQ50S48-1R2 PAQ100S48-1R2 1.2 12 / 25 14.4 / 30 78 / 80 0.39 / 0.8 PAQ50S48-1R8 PAQ100S48-1R8 1.8 12 / 25 21.6 / 45 83 / 84 0.56 / 1.14 PAQ50S48-2R5 PAQ100S48-2R5 2.5 12 / 25 30 / 62.5 85 / 86 36-76 VDC 0.75 / 1.55 ± 1% PAQ50S48-3R3 PAQ100S48-3R3 3.3 12 / 25 39.6 / 82.5 88 / 89 PAQ50S48-5 PAQ100S48-5 5 10 / 20 50 / 100 90 0.96 / 1.98 1.18 / 2.37 -20%, +10% ±15% 100 10 10 PAQ50: 105-150%; PAQ100 105-140%; (self-Recovering /V option) 120% - 140% (Self-Recovering /V option) Low=On, Open =Off (/P option: Low=Off, Open=On) Ta=-40 to +85° (100°C /B Option PAQ100 only) Convection Cooled / Forced Air Cooled Input-Output: 1.5kVDC for 1 min. 196.1m/s2 50 Non Operating, 10-55Hz (Sweep for 1 min.) Amplitude 0.825mm Constant (Maximum 49.0n/s2) X, Y, Z 1 hour each 1.45" x .33" x 2.3"; 0.5" height (/B option PAQ100 only) 2 Years Notes: 1. At 48VDC, maximum output current, Air Velocity = 2m/s and Ta = +25°C. 2. 36 - 76VDC, constant load. 3. No load - Full load, constant input voltage. 4. Inverter shutdown method, manual reset. Auto restart option available. PAQ Series 5. Refer to installation manual (website). 6. External components are needed for operation. 1 Openframe Drawing PAQ50/100 Baseplate Drawing PAQ100 2 PAQ Series Derating Curve PAQ Note: Open Frame PAQ100S48-3.3/V unit shown. Series Output PAQ PIN# Label Function 1 2 3 4 5 6 7 8 -Vin CNT +Vin -V -S TRM +S +V Negative Input Terminal ON/OFF Control Terminal Positive Input Terminal Negative Output Terminal Negative Remote Sensing Output Voltage Adjustment Terminal Positive Remote Sensing Positive Output Terminal Series Options PAQ Suffix Description Blank /V /P /B /C Manual Reset after OVP or OCP condition Auto Reset after OVP or OCP condition Positive Logic Remote On/Off Baseplate version Additional 1.5mm height clearance from PCB /V, /PV, /BV, /BPV are preferred items. PAQ Series 3 TDK-LAMBDA EMEA www.emea.tdk-lambda.com TDK-Lambda France SAS TDK-Lambda UK Ltd. Route de Grivery ZAC des Delaches CS 41077 91978 Courtaboeuf Cedex France Tel: +33 1 60 12 71 65 Fax: +33 1 60 12 71 66 france@fr.tdk-lambda.com www.fr.tdk-lambda.com Kingsley Avenue Ilfracombe Devon EX34 8ES United Kingdom Tel: +44 (0) 12 71 85 66 66 Fax: +44 (0) 12 71 86 48 94 powersolutions@uk.tdk-lambda.com www.uk.tdk-lambda.com Italy Sales Office Nemic Lambda Ltd. Via dei Lavoratori 128/130 20092 Cinisello Balsamo (MI) Italy Tel: +39 02 61 29 38 63 Fax: +39 02 61 29 09 00 info.italia@it.tdk-lambda.com www.it.tdk-lambda.com Kibbutz Givat Hashlosha 48800 Israel Tel: +9 723 902 4333 Fax: +9 723 902 4777 info@nemic.co.il www.nemic.co.il TDK-Lambda Germany GmbH Russia Karl-Bold-Strasse 40 77855 Achern Germany Tel: +49 7841 666 0 Fax: +49 7841 5000 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com Technical Support: St Petersburg Tel: +7 (812) 6580463 Sales: Moscow Tel: +7 (499) 7557732 info@tdk-lambda.ru www.tdk-lambda.ru Austria Sales Office Aredstrasse 22 2544 Leobersdorf Austria Tel: +43 2256 655 84 Fax: +43 2256 645 12 info.germany@de.tdk-lambda.com www.de.tdk-lambda.com LOCAL DISTRIBUTION PAQ June11 v2 4 PAQ Series
PAQ50S481R8/P
物料型号:PAQ50/100系列
器件简介:这些转换器具有低电压输出(1.2-5.0V),高功率密度(高达90.4W/in³),符合行业标准的足迹和引脚分配,拥有安全机构认证。
引脚分配:文档提供了详细的引脚分配图,包括输入、输出和控制端子。
参数特性:包括最大输出电流、最大输出功率、效率、输入电压范围、输入电流、输出电压精度、输出电压范围、最大纹波和噪声、过电流保护、过电压保护、远程开关控制、工作温度范围、冷却方式、隔离电压、冲击和振动测试、尺寸、重量和保修期。
功能详解:包括ASIC设计以减少组件数量、宽工作温度范围、高效率、支持恶劣无线操作环境、无需散热器即可操作。
应用信息:适用于中央办公室、宽带、无线/蜂窝、远程电子和工业等多种市场和应用。
封装信息:提供了开框和基板的详细尺寸图,以及尺寸公差。
PAQ50S481R8/P 价格&库存
很抱歉,暂时无法提供与“PAQ50S481R8/P”相匹配的价格&库存,您可以联系我们找货
