PC95EL13X4.4-Z
PC95EL13X4.4-Z
    TDK(东电化)
    PC95EL13X4.4-Z
PC95EL13X4.4-Z 数据手册
F E R R I T E S March 2021 Mn-Zn Ferrite Cores for Switching Power Supplies Planar series EL ELT PQI EIR ER EI (2/49) F E R R I T E S REMINDERS FOR USING THESE PRODUCTS Please be sure to read this manual thoroughly before using the products. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. When using the products for specific purposes, please first make confirmations in areas such as safety, reliability, and quality. Please understand that we are not in a position to be held responsible for any damage or the like caused by any use exceeding the range or conditions of this specification sheet or by any use in the specific applications. (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose standard applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc to ensure higher safety. 20210308 / ferrite_mz_sw_planar_en.fm (3/49) F E R R I T E S Ferrite Cores for Switching Power Supplies Product compatible with RoHS directive Halogen-free Overview of the Planar Series FEATURES Low profile shape suited to PCB mounting Available in a range of various shapes Available in a pair of E core and I core that easily can be mounted on PCBs A wide range of sizes is available from 10mm to 25mm APPLICATION Low profile DC/DC converters, transformers and coils for use in planers PART NUMBER CONSTRUCTION PC90 EL11X4 Material Size of E core PC90 PC95 Z - AL-value (Z: without air gap) EL core EL11X4 ELT core ELT11X3 ELT18X7.3 PQI core PQI16/7.8Z EIR core EIR14/4.5/9 ER core ER9.5/5 EI core EI14/5/5 EL13X4.4 EL15.5X5.8 EL18X7.3 EL20X7.7 EL22X8 EL25X8.6 ELT11X4 ELT20X5.7 ELT13X3.4 ELT20X7.7 ELT13X4.4 ELT22X6 ELT15.5X4.3 ELT22X8 ELT15.5X5.8 ELT25X6.6 ELT18X5.3 ELT25X8.6 PQI20/9Z PQI26/12Z EIR18/5/12 EIR22/5.5/15 ER11/5 ER14/4.5/9 ER14.5/6 ER18/5/12 ER22/5.5/15 ER25/5.5/18 EI18/6/10 EI22/8/16 RANGE OF USE AND STORAGE TEMPERATURE Temperature range Operating temperature (°C) –30 to +105 Storage temperature (°C) –30 to +85 RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (4/49) F E R R I T E S Mn-Zn EL Cores SHAPES AND DIMENSIONS A E C F2 F1 R1=F1/2 B D R2: 8 places ELH core PC95 EL11X4 Material Size of E core Part No.(ELH+ELH) PC95EL11X4-Z PC90EL11X4-Z PC95EL13X4.4-Z PC90EL13X4.4-Z PC95EL15.5X5.8-Z PC90EL15.5X5.8-Z PC95EL18X7.3-Z PC90EL18X7.3-Z PC95EL20X7.7-Z PC90EL20X7.7-Z PC95EL22X8-Z PC90EL22X8-Z PC95EL25X8.6-Z PC90EL25X8.6-Z Z - AL-value (Z: without air gap) Dimensions (mm) A B C D E F1 F2 R2 11.00±0.20 2.01±0.10 8.80±0.20 1.00±0.10 9.17±0.20 2.78±0.10 6.40±0.15 0.30 13.00±0.25 2.19±0.10 10.40±0.20 1.00±0.10 10.83±0.20 3.29±0.10 7.56±0.15 0.30 15.50±0.30 2.92±0.10 12.40±0.25 1.50±0.10 12.92±0.25 3.92±0.10 9.01±0.20 0.30 18.00±0.30 3.65±0.10 14.40±0.25 2.00±0.10 15.00±0.30 4.55±0.10 10.47±0.20 0.30 20.00±0.35 3.83±0.10 16.00±0.30 2.00±0.10 16.67±0.30 5.06±0.15 11.63±0.20 0.50 22.00±0.40 4.02±0.10 17.60±0.30 2.00±0.10 18.33±0.35 5.56±0.15 12.79±0.25 0.50 25.00±0.45 4.29±0.10 20.00±0.35 2.00±0.10 20.83±0.35 6.32±0.15 14.54±0.25 0.50 Effective parameter Core factor Part No.(ELH+ELH) PC95EL11X4-Z PC90EL11X4-Z PC95EL13X4.4-Z PC90EL13X4.4-Z PC95EL15.5X5.8-Z PC90EL15.5X5.8-Z PC95EL18X7.3-Z PC90EL18X7.3-Z PC95EL20X7.7-Z PC90EL20X7.7-Z PC95EL22X8-Z PC90EL22X8-Z PC95EL25X8.6-Z PC90EL25X8.6-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 0.826 13.7 16.5 226 15.9 6.39 1.3 0.667 15.4 23.1 357 22.4 7.54 2.0 0.597 19.6 32.9 646 31.9 13.5 3.5 0.538 23.8 44.3 1050 43.0 20.9 6.0 0.469 25.6 54.6 1400 52.9 23.2 7.8 0.413 27.3 66.2 1810 64.2 25.5 10 0.350 30.0 85.6 2570 83.0 29.0 15 2400±25% 1950±25% 3160±25% 2500±25% 3680±25% 3000±25% 4760±25% 3600±25% 5630±25% 4050±25% 6540±25% 5050±25% 7540±25% 5700±25% With air gap 50±3% 80±5% 125±7% 63±3% 100±5% 160±7% 63±3% 100±3% 160±5% 80±3% 125±3% 200±5% 80±3% 125±3% 200±5% 100±3% 160±3% 250±5% 100±3% 160±3% 250±5% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (5/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EL11X4-Z SHAPES AND DIMENSIONS 11.0±0.2 9.17±0.2 6.4±0.15 8.8±0.2 1.0±0.1 2.01±0.1 2.78±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 100°C 226 6.39 1.3 1950±25% 0.2 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.826 13.7 16.5 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 20% 40% AL-value(nH/N2) NI limit (AT) Center pole gap 101 101 Temp: 100°C 100 1 10 NI20%=6550.4×AL–1.000 NI40%=7446.9×AL–1.009 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=38.79×lg –0.7342 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (6/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EL11X4-Z SHAPES AND DIMENSIONS 11.0±0.2 9.17±0.2 6.4±0.15 8.8±0.2 1.0±0.1 2.01±0.1 2.78±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 226 6.39 1.3 2400±25% 0.2 0.18 0.2 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.826 13.7 16.5 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 AL-value(nH/N2) Center pole gap NI limit (AT) 40% 20% 101 101 Temp: 100°C 100 1 10 NI20%=5997.9×AL–0.993 NI40%=7200.1×AL–1.014 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=38.87×lg –0.7339 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (7/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EL13X4.4-Z SHAPES AND DIMENSIONS 13.0±0.25 10.83±0.2 7.56±0.15 10.4±0.2 1.0±0.1 2.19±0.1 3.29±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 357 7.54 2.0 2500±25% 0.25 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.667 15.4 100°C 23.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 NI limit (AT) 40% 20% 101 AL-value(nH/N2) Center pole gap 101 Temp: 100°C 100 1 10 NI20%=10915.6×AL–1.031 NI40%=12455.2×AL–1.040 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=52.02×lg –0.758 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (8/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EL13X4.4-Z SHAPES AND DIMENSIONS 13.0±0.25 10.83±0.2 7.56±0.15 10.4±0.2 1.0±0.1 2.19±0.1 3.29±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 357 7.54 2.0 3160±25% 0.25 0.2 0.25 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.667 15.4 23.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 NI limit (AT) 40% 20% 101 AL-value(nH/N2) Center pole gap 101 Temp: 100°C 100 1 10 NI20%=6550.4×AL–1.000 NI40%=7446.9×AL–1.009 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=52.17×lg –0.757 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (9/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EL15.5X5.8-Z SHAPES AND DIMENSIONS 15.5±0.3 12.92±0.25 9.01±0.2 12.4±0.25 1.5±0.1 2.92±0.1 3.92±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 646 13.5 3.5 3000±25% 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.597 19.6 100°C 32.9 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=12647.2×AL–0.989 NI40%=12041.0×AL–0.961 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=69.24×lg –0.774 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (10/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EL15.5X5.8-Z SHAPES AND DIMENSIONS 15.5±0.3 12.92±0.25 9.01±0.2 12.4±0.25 1.5±0.1 2.92±0.1 3.92±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 646 13.5 3.5 3680±25% 0.5 0.45 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.597 19.6 32.9 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=10782.9×AL–0.966 NI40%=10266.4×AL–0.938 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=67.92×lg –0.779 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (11/49) F E R R I T E S Mn-Zn ELT Cores SHAPES AND DIMENSIONS D A A E F1 R1=F1/2 R2: 8 places F2 B1 B2 C C ELH core PLT core PC95 ELT11X3 Material Size of E core Part No.(ELH+PLT) PC95ELT11X3-Z PC90ELT11X3-Z PC95ELT11X4-Z PC90ELT11X4-Z PC95ELT13X3.4-Z PC90ELT13X3.4-Z PC95ELT13X4.4-Z PC90ELT13X4.4-Z PC95ELT15.5X4.3-Z PC90ELT15.5X4.3-Z PC95ELT15.5X5.8-Z PC90ELT15.5X5.8-Z PC95ELT18X5.3-Z PC90ELT18X5.3-Z Z - AL-value (Z: without air gap) Dimensions (mm) A B1 B2 C D E F1 F2 R2 11.00±0.20 2.01±0.10 1.01±0.05 8.80±0.20 1.00±0.10 9.17±0.20 2.78±0.10 6.40±0.15 0.30 11.00±0.20 3.01±0.10 1.01±0.05 8.80±0.20 2.00±0.10 9.17±0.20 2.78±0.10 6.40±0.15 0.30 13.00±0.25 2.19±0.10 1.19±0.05 10.40±0.20 1.00±0.10 10.83±0.20 3.29±0.10 7.56±0.15 0.30 13.00±0.25 3.19±0.10 1.19±0.05 10.40±0.20 2.00±0.10 10.83±0.20 3.29±0.10 7.56±0.15 0.30 15.50±0.30 2.92±0.10 1.42±0.10 12.40±0.25 1.50±0.10 12.92±0.25 3.92±0.10 9.01±0.20 0.30 15.50±0.30 4.42±0.10 1.42±0.10 12.40±0.25 3.00±0.10 12.92±0.25 3.92±0.10 9.01±0.20 0.30 18.00±0.30 3.65±0.10 1.65±0.10 14.40±0.25 2.00±0.10 15.00±0.30 4.55±0.10 10.47±0.20 0.30 Effective parameter Core factor Part No.(ELH+ELH) PC95ELT11X3-Z PC90ELT11X3-Z PC95ELT11X4-Z PC90ELT11X4-Z PC95ELT13X3.4-Z PC90ELT13X3.4-Z PC95ELT13X4.4-Z PC90ELT13X4.4-Z PC95ELT15.5X4.3-Z PC90ELT15.5X4.3-Z PC95ELT15.5X5.8-Z PC90ELT15.5X5.8-Z PC95ELT18X5.3-Z PC90ELT18X5.3-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 0.702 11.7 16.6 194 15.9 3.20 1.1 0.826 13.7 16.5 226 15.9 6.39 1.3 0.578 13.4 23.2 312 22.4 3.77 1.8 0.667 15.4 23.1 357 22.4 7.54 2.0 0.503 16.6 33.1 550 31.9 6.75 3.0 0.597 19.6 32.9 646 31.9 13.5 3.5 0.446 19.8 44.5 882 43.0 10.5 5.0 2590±25% 1750±25% 2400±25% 1700±25% 3390±25% 2400±25% 3160±25% 2300±25% 4340±25% 2900±25% 3680±25% 2200±25% 5330±25% 3500±25% With air gap 50±3% 80±5% 125±7% 50±3% 80±5% 125±7% 63±3% 100±5% 160±7% 63±3% 100±5% 160±7% 63±3% 100±3% 160±5% 63±3% 100±3% 160±5% 80±3% 125±3% 200±5% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (12/49) F E R R I T E S Mn-Zn ELT Cores SHAPES AND DIMENSIONS D A A E F1 R1=F1/2 R2: 8 places F2 B1 B2 C C ELH core PLT core PC95 ELT18X7.3 Material Size of E core Part No.(ELH+PLT) PC95ELT18X7.3-Z PC90ELT18X7.3-Z PC95ELT20X5.7-Z PC90ELT20X5.7-Z PC95ELT20X7.7-Z PC90ELT20X7.7-Z PC95ELT22X6-Z PC90ELT22X6-Z PC95ELT22X8-Z PC90ELT22X8-Z PC95ELT25X6.6-Z PC90ELT25X6.6-Z PC95ELT25X8.6-Z PC90ELT25X8.6-Z Z - AL-value (Z: without air gap) Dimensions (mm) A B1 B2 C D E F1 F2 R2 18.00±0.30 5.65±0.10 1.65±0.10 14.40±0.25 4.00±0.15 15.00±0.30 4.55±0.10 10.47±0.20 0.30 20.00±0.35 3.83±0.10 1.83±0.10 16.00±0.30 2.00±0.10 16.67±0.30 5.06±0.15 11.63±0.20 0.50 20.00±0.35 5.83±0.15 1.83±0.10 16.00±0.30 4.00±0.15 16.67±0.30 5.06±0.15 11.63±0.20 0.50 22.00±0.40 4.02±0.10 2.02±0.10 17.60±0.30 2.00±0.10 18.33±0.35 5.56±0.15 12.79±0.25 0.50 22.00±0.40 6.02±0.15 2.02±0.10 17.60±0.30 4.00±0.15 18.33±0.35 5.56±0.15 12.79±0.25 0.50 25.00±0.45 4.29±0.10 2.29±0.10 20.00±0.35 2.00±0.10 20.83±0.35 6.32±0.15 14.54±0.25 0.50 25.00±0.45 6.29±0.15 2.29±0.10 20.00±0.35 4.00±0.15 20.83±0.35 6.32±0.15 14.54±0.25 0.50 Effective parameter Core factor Part No.(ELH+ELH) PC95ELT18X7.3-Z PC90ELT18X7.3-Z PC95ELT20X5.7-Z PC90ELT20X5.7-Z PC95ELT20X7.7-Z PC90ELT20X7.7-Z PC95ELT22X6-Z PC90ELT22X6-Z PC95ELT22X8-Z PC90ELT22X8-Z PC95ELT25X6.6-Z PC90ELT25X6.6-Z PC95ELT25X8.6-Z PC90ELT25X8.6-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 0.538 23.8 44.3 1050 43.0 20.9 6.0 0.393 21.6 54.9 1180 52.9 11.6 6.7 0.469 25.6 54.6 1400 52.9 23.2 7.8 0.351 23.4 66.6 1560 64.2 12.8 9.0 0.413 27.3 66.2 1810 64.2 25.5 10 0.302 26.0 86.0 2230 83.0 14.5 13 0.350 30.0 85.6 2570 83.0 29.0 15 4760±25% 3100±25% 6270±25% 4150±25% 5630±25% 3900±25% 7250±25% 4800±25% 6540±25% 4250±25% 8600±25% 6100±25% 7540±25% 5400±25% With air gap 80±3% 125±3% 200±5% 80±3% 125±3% 200±5% 80±3% 125±3% 200±5% 100±3% 160±3% 250±5% 100±3% 160±3% 250±5% 100±3% 160±3% 250±5% 100±3% 160±3% 250±5% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (13/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT11X3-Z 1.0±0.1 11.0±0.2 11.0±0.2 9.17±0.2 2.78±0.1 SHAPES AND DIMENSIONS 6.4±0.15 2.01±0.1 8.8±0.2 1.01±0.05 8.8±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 194 3.20 1.1 1750±25% 0.15 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.702 11.7 100°C 16.6 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 AL-value(nH/N2) 40% 10 2 NI limit (AT) 20% 101 10 2 Center pole gap 101 Temp: 100°C 100 1 10 NI20%=2106.0×AL–0.9047 NI40%=2352.6×AL–0.9193 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=12.081×lg –0.6732 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (14/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT11X3-Z 1.0±0.1 11.0±0.2 11.0±0.2 9.17±0.2 2.78±0.1 SHAPES AND DIMENSIONS 6.4±0.15 2.01±0.1 8.8±0.2 1.01±0.05 8.8±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 194 3.20 1.1 2590±25% 0.14 0.12 0.14 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.702 11.7 16.6 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 40% AL-value(nH/N2) 10 2 NI limit (AT) 20% 101 10 2 Center pole gap 101 Temp: 100°C 100 1 10 NI20%=2299.4×AL–0.9121 NI40%=7074.5×AL–1.0145 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=11.721×lg –0.6995 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (15/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT11X4-Z 2.0±0.1 11.0±0.2 11.0±0.2 9.17±0.2 2.78±0.1 SHAPES AND DIMENSIONS 6.4±0.15 3.01±0.1 8.8±0.2 1.01±0.05 8.8±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 226 6.39 1.3 1700±25% 0.18 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.826 13.7 100°C 16.5 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=79126×AL–1.0385 NI40%=8238.4×AL–1.0638 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=45.451×lg –0.6664 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (16/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT11X4-Z 2.0±0.1 11.0±0.2 11.0±0.2 9.17±0.2 2.78±0.1 SHAPES AND DIMENSIONS 6.4±0.15 3.01±0.1 8.8±0.2 1.01±0.05 8.8±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 226 6.39 1.3 2400±25% 0.16 0.15 0.16 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.826 13.7 16.5 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 AL-value(nH/N2) Center pole gap NI limit (AT) 40% 20% 101 101 Temp: 100°C 100 1 10 NI20%=6764.5×AL–1.0142 NI40%=7074.5×AL–1.0145 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=44.261×lg –0.7171 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (17/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT13X3.4-Z 13.0±0.25 13.0±0.25 3.29±0.1 10.83±0.2 SHAPES AND DIMENSIONS 7.56±0.15 1.0±0.1 2.19±0.1 10.4±0.2 1.19±0.05 10.4±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 312 3.77 1.8 2400±25% 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.578 13.4 100°C 23.2 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 NI limit (AT) 40% 20% 101 AL-value(nH/N2) Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=12501.9×AL–1.053 NI40%=11455.4×AL–1.015 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=77.30×lg –0.602 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (18/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT13X3.4-Z 13.0±0.25 13.0±0.25 3.29±0.1 10.83±0.2 SHAPES AND DIMENSIONS 7.56±0.15 1.0±0.1 2.19±0.1 10.4±0.2 1.19±0.05 10.4±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 312 3.77 1.8 3390±25% 0.3 0.28 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.578 13.4 23.2 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 NI limit (AT) 40% 20% 101 AL-value(nH/N2) Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=6688.7×AL–0.937 NI40%=5844.7×AL–0.892 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=78.93×lg –0.596 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (19/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT13X4.4-Z 11.0±0.2 13.0±0.25 3.29±0.1 2.0±0.1 10.83±0.2 SHAPES AND DIMENSIONS 7.56±0.15 3.19±0.1 10.4±0.2 1.19±0.05 10.4±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 357 7.54 2.0 2300±25% 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.667 15.4 100°C 23.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=14878.1×AL–1.080 NI40%=16164.5×AL–1.085 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=61.57×lg –0.687 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (20/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT13X4.4-Z 11.0±0.2 13.0±0.25 3.29±0.1 2.0±0.1 10.83±0.2 SHAPES AND DIMENSIONS 7.56±0.15 3.19±0.1 10.4±0.2 1.19±0.05 10.4±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 357 7.54 2.0 3160±25% 0.3 0.28 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.667 15.4 23.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 20% 40% 101 AL-value(nH/N2) NI limit (AT) Center pole gap 101 Temp: 100°C 100 1 10 NI20%=9732.8×AL–1.030 NI40%=11097.7×AL–1.048 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=62.14×lg –0.683 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (21/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT15.5X4.3-Z 15.5±0.3 15.5±0.3 3.29±0.1 1.5±0.1 12.92±0.25 SHAPES AND DIMENSIONS 9.01±0.2 2.92±0.1 12.4±0.25 1.42±0.1 12.4±0.25 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 550 6.75 3.0 2900±25% 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.503 16.6 100°C 33.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 NI limit (AT) 10 2 40% 20% 101 AL-value(nH/N2) Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=13312.0×AL–1.008 NI40%=14620.9×AL–1.011 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=91.84×lg –0.683 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (22/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT15.5X4.3-Z 15.5±0.3 15.5±0.3 3.29±0.1 1.5±0.1 12.92±0.25 SHAPES AND DIMENSIONS 9.01±0.2 2.92±0.1 12.4±0.25 1.42±0.1 12.4±0.25 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 550 6.75 3.0 4340±25% 0.5 0.45 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.503 16.6 33.1 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 NI limit (AT) 10 2 40% 20% 101 AL-value(nH/N2) Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=14302.4×AL–1.010 NI40%=15381.9×AL–1.008 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=96.66×lg –0.626 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (23/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT18X7.3-Z 4.0±0.15 18.0±0.3 18.0±0.3 15.0±0.3 4.55±0.1 SHAPES AND DIMENSIONS 10.47±0.2 5.65±0.1 14.4±0.25 14.4±0.25 1.65±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 1050 20.9 6.0 3100±25% Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.538 23.8 100°C 44.3 NI limit vs. AL-value(Typ.) 0.7 AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=21202×AL–1.0393 NI40%=22470×AL–1.0421 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=101.52×lg –0.7339 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (24/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT18X7.3-Z 4.0±0.15 18.0±0.3 18.0±0.3 15.0±0.3 4.55±0.1 SHAPES AND DIMENSIONS 10.47±0.2 5.65±0.1 14.4±0.25 14.4±0.25 1.65±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 1050 20.9 6.0 4760±25% 0.6 0.55 0.6 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.538 23.8 44.3 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 40% 10 2 NI limit (AT) AL-value(nH/N2) 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=20017×AL–1.0437 NI40%=21538×AL–1.0502 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=101.1×lg –0.7549 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (25/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ELT25X8.6-Z 25.0±0.45 25.0±0.45 6.32±0.15 4.0±0.15 20.83±0.35 SHAPES AND DIMENSIONS 14.54±0.25 6.29±0.15 20.0±0.35 2.29±0.1 20.0±0.35 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 2570 29.0 15 5400±25% Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.350 30.0 100°C 85.6 NI limit vs. AL-value(Typ.) 1.8 AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=45556×AL–1.0498 NI40%=46960×AL–1.0467 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=166.92×lg –0.7706 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (26/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ELT25X8.6-Z 25.0±0.45 25.0±0.45 6.32±0.15 4.0±0.15 20.83±0.35 SHAPES AND DIMENSIONS 14.54±0.25 6.29±0.15 20.0±0.35 2.29±0.1 20.0±0.35 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 2570 29.0 15 7540±25% 1.6 1.5 1.6 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.350 30.0 85.6 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 10 2 NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 101 Temp: 100°C 100 1 10 NI20%=39397×AL–1.0349 NI40%=41868×AL–1.0374 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=188.04×lg –0.6956 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (27/49) F E R R I T E S Mn-Zn PQI Cores A1 E min. B A1 øC E min. SHAPES AND DIMENSIONS H A2 D A2 HPQ core PC95 PQI16/7.8Z Material Size of E core Part No.(HPQ+PQD) PC95PQI16/7.8Z-12 PC90PQI16/7.8Z-12 PC95PQI20/9Z-12 PC90PQI20/9Z-12 PC95PQI26/12Z-12 PC90PQI26/12Z-12 I PQD core 12 - AL-value (Z: without air gap) Dimensions (mm) A1 A2 B øC D E min. H I 16.40±0.30 11.20±0.30 14.40±0.30 7.00±0.20 5.40±0.10 9.60 3.05±0.15 2.35±0.10 20.50±0.40 14.00±0.40 18.00±0.40 8.80±0.20 6.00±0.10 12.00 3.05±0.15 2.95±0.10 26.50±0.45 19.00±0.45 22.50±0.45 12.00±0.20 7.30±0.10 15.50 3.10±0.15 4.20±0.10 Effective parameter Core factor Part No.(ELH+ELH) PC95PQI16/7.8Z-12 PC90PQI16/7.8Z-12 PC95PQI20/9Z-12 PC90PQI20/9Z-12 PC95PQI26/12Z-12 PC90PQI26/12Z-12 C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 0.467 19.5 41.8 815 37.6 11.3 5.0 0.346 22.9 66.0 1510 59.3 14.0 9.0 0.224 27.7 123 3410 109 16.3 21 4910±25% 3600±25% 7070±25% 5200±25% 11950±25% 8600±25% With air gap 63±3% 100±5% 160±7% 100±3% 160±5% 250±7% 100±3% 160±3% 250±5% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (28/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90PQI16/7.8Z-12 16.4±0.3 9.6min. 14.4±0.3 16.4±0.3 9.6min. ø7.0±0.2 SHAPES AND DIMENSIONS 11.2±0.3 3.05±0.15 11.2±0.15 2.35±0.1 5.4±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 100°C 815 11.3 5.0 3600±25% 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.467 19.5 41.8 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 40% NI limit (AT) AL-value(nH/N2) 20% 10 2 101 10 2 101 Temp: 100°C 100 1 10 NI20%=15271×AL–0.9935 NI40%=19105×AL–1.0297 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=79.28×lg –0.7555 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (29/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95PQI16/7.8Z-12 16.4±0.3 9.6min. 14.4±0.3 16.4±0.3 9.6min. ø7.0±0.2 SHAPES AND DIMENSIONS 11.2±0.3 3.05±0.15 11.2±0.15 2.35±0.1 5.4±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 815 11.3 5.0 4910±25% 0.45 0.35 0.45 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.467 19.5 41.8 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap AL-value(nH/N2) 40% 10 2 NI limit (AT) 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=15175×AL–1.0107 NI40%=16692×AL–1.0194 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=80.885×lg –0.6993 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (30/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90PQI20/9Z-12 20.5±0.4 12.0min. 20.5±0.4 18.0±0.4 12.0min. ø8.8±0.2 SHAPES AND DIMENSIONS 14.0±0.4 3.05±0.15 14.0±0.4 2.95±0.1 6.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 1510 14.0 9.0 5200±25% Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.346 22.9 100°C 66.0 NI limit vs. AL-value(Typ.) 0.8 AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=31243×AL–1.0397 NI40%=31082×AL–1.0308 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=108.98×lg –0.8221 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (31/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95PQI20/9Z-12 20.5±0.4 12.0min. 20.5±0.4 18.0±0.4 12.0min. ø8.8±0.2 SHAPES AND DIMENSIONS 14.0±0.4 3.05±0.15 14.0±0.4 2.95±0.1 6.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 1510 14.0 9.0 7070±25% 0.75 0.65 0.75 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.346 22.9 66.0 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) 20% 101 AL-value(nH/N2) 40% 10 2 10 2 101 Temp: 100°C 100 1 10 NI20%=25802×AL–1.0258 NI40%=24743×AL–1.0086 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=108.84×lg –0.8199 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (32/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90PQI26/12Z-12 26.5±0.45 15.5min. 26.5±0.45 ø12.0±0.2 15.5min. 22.5±0.45 SHAPES AND DIMENSIONS 4.2±0.1 19.0±0.45 3.1±0.15 19.0±0.45 7.3±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 3410 16.3 21 8600±25% 1.6 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.224 27.7 100°C 123 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 20% 40% NI limit (AT) AL-value(nH/N2) 10 2 101 Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=74915.0×AL–1.0468 NI40%=8564.0×AL–1.0607 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=284.51×lg –0.831 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (33/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95PQI26/12Z-12 26.5±0.45 15.5min. 26.5±0.45 ø12.0±0.2 15.5min. 22.5±0.45 SHAPES AND DIMENSIONS 4.2±0.1 19.0±0.45 3.1±0.15 19.0±0.45 7.3±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 3410 16.3 21 11950±25% 1.5 1.4 1.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.224 27.7 123 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 4 10 2 10 3 40% 20% 101 AL-value(nH/N2) NI limit (AT) Center pole gap 102 Temp: 100°C 100 2 10 NI20%=72721×AL–1.0548 NI40%=71923×AL–1.0453 10 3 10 4 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 101 0.01 AL=287.77×lg –0.8483 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (34/49) F E R R I T E S Mn-Zn EIR Cores A2 E H F A1 øD H SHAPES AND DIMENSIONS B C2 C1 HER core PLT core PC95 EIR14/4.5/9 Material Size of E core Part No.(ELH+ELH) PC95EIR14/4.5/9-Z PC90EIR14/4.5/9-Z PC95EIR18/5/12-Z PC90EIR18/5/12-Z PC95EIR22/5.5/15-Z PC90EIR22/5.5/15-Z I Z - AL-value (Z: without air gap) Dimensions (mm) A1 B C1 øD E F 13.85±0.25 3.20±0.10 9.00±0.20 5.20±0.10 11.35±0.15 18.15±0.30 3.50±0.10 12.00±0.20 22.10±0.35 3.75±0.10 15.25±0.25 H A2 C2 I 1.90±0.10 1.25 14.00±0.20 9.20±0.20 1.30±0.10 6.00±0.10 15.75±0.25 2.00±0.10 1.20 18.20±0.25 12.20±0.20 1.50±0.10 6.80±0.10 19.70±0.30 2.00±0.10 1.20 22.20±0.30 15.50±0.20 1.75±0.10 Effective parameter Core factor Part No.(HPQ+PQD) PC95EIR14/4.5/9-Z PC90EIR14/4.5/9-Z PC95EIR18/5/12-Z PC90EIR18/5/12-Z PC95EIR22/5.5/15-Z PC90EIR22/5.5/15-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 0.679 15.4 22.7 349 21.2 5.84 2.0 0.601 19.7 32.8 645 28.3 9.75 3.8 0.505 23.2 46.1 1070 36.3 12.9 6.5 2800±25% 2050±25% 3690±25% 2500±25% 4150±25% 3000±25% With air gap 63±3% 100±5% 160±7% 80±3% 125±5% 200±7% 80±3% 125±5% 200±7% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (35/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EIR14/4.5/9-Z 14.0±0.2 13.85±0.25 ø5.2±0.1 1.25 11.35±0.15 1.25 SHAPES AND DIMENSIONS 1.9±0.1 3.2±0.1 1.3±0.1 9.2±0.2 9.0±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 349 5.84 2.0 2050±25% 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.679 15.4 100°C 22.7 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 101 Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=9794.7×AL–1.0231 NI40%=11668×AL–1.0519 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=44.153×lg –0.7138 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (36/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EIR14/4.5/9-Z 14.0±0.2 13.85±0.25 ø5.2±0.1 1.25 11.35±0.15 1.25 SHAPES AND DIMENSIONS 1.9±0.1 3.2±0.1 1.3±0.1 9.2±0.2 9.0±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 349 5.84 2.0 2800±25% 0.25 0.2 0.25 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.679 15.4 22.7 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 40% AL-value(nH/N2) NI limit (AT) 10 2 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=9192.1×AL–1.021 NI40%=11113×AL–1.0546 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=44.199×lg –0.7139 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (37/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EIR18/5/12-Z 18.2±0.25 18.15±0.3 ø6.0±0.1 1.25 15.75±0.25 1.25 SHAPES AND DIMENSIONS 2.0±0.1 3.5±0.1 1.5±0.1 12.2±0.2 12.2±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 645 9.75 3.8 2500±25% Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.601 19.7 100°C 32.8 NI limit vs. AL-value(Typ.) 0.45 AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 40% 20% NI limit (AT) AL-value(nH/N2) 10 2 101 10 2 101 Temp: 100°C 100 1 10 NI20%=10781×AL–0.9789 NI40%=17608×AL–1.0637 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=62.293×lg –0.6882 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (38/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EIR18/5/12-Z 18.2±0.25 18.15±0.3 ø6.0±0.1 1.25 15.75±0.25 1.25 SHAPES AND DIMENSIONS 2.0±0.1 3.5±0.1 1.5±0.1 12.2±0.2 12.2±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 645 9.75 3.8 3690±25% 0.4 0.35 0.4 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.601 19.7 32.8 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap 40% NI limit (AT) AL-value(nH/N2) 20% 10 2 101 10 2 101 Temp: 100°C 100 1 10 NI20%=15611×AL–1.0039 NI40%=14533×AL–0.9802 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=62.305×lg –0.6887 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (39/49) F E R R I T E S Mn-Zn ER Cores F C E A øD A B 2B H F E øD H SHAPES AND DIMENSIONS B 2B C Fig.1 Fig.2 PC95 ER9.5/5 Material Size of E core Part No.(HER+HER) Core Dimensions (mm) A B C øD E F H Fig.1 +0 9.5 –0.3 +0 2.5 –0.1 +0 5.0 –0.2 +0 3.5 –0.2 7.0min. +0.15 1.6 –0 — Fig.1 11.0 –0.35 +0 2.5 –0.1 6.0 –0.2 4.25 –0.25 +0 7.9min. 1.5 –0 +0.15 — Fig.2 13.85±0.25 2.25±0.10 9.00±0.20 5.20±0.10 11.35±0.15 0.95±0.10 1.25 Fig.2 14.5±0.2 3.0 –0.1 6.7±0.1 4.7±0.1 11.8±0.2 1.65±0.1 1.35 Fig.2 18.15±0.30 2.50±0.10 12.00±0.20 6.00±0.10 15.75±0.25 1.00±0.10 1.20 Fig.2 22.10±0.35 2.75±0.10 15.25±0.25 6.80±0.10 19.70±0.30 1.00±0.10 1.20 Fig.2 25.30±0.40 2.75±0.10 18.00±0.40 7.00±0.15 22.90±0.40 1.00±0.10 1.20 PC95ER9.5/5-Z PC90ER9.5/5-Z PC95ER11/5-Z PC90ER11/5-Z PC95ER14/4.5/9-Z PC90ER14/4.5/9-Z PC95ER14.5/6-Z PC90ER14.5/6-Z PC95ER18/5/12-Z PC90ER18/5/12-Z PC95ER22/5.5/15-Z PC90ER22/5.5/15-Z PC95ER25/5.5/18-Z PC90ER25/5.5/18-Z Z - AL-value (Z: without air gap) +0 +0 +0 Effective parameter Core factor Part No.(HER+HER) PC95ER9.5/5-Z PC90ER9.5/5-Z PC95ER11/5-Z PC90ER11/5-Z PC95ER14/4.5/9-Z PC90ER14/4.5/9-Z PC95ER14.5/6-Z PC90ER14.5/6-Z PC95ER18/5/12-Z PC90ER18/5/12-Z PC95ER22/5.5/15-Z PC90ER22/5.5/15-Z PC95ER25/5.5/18-Z PC90ER25/5.5/18-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 1.67 14.2 8.47 120 7.6 7.07 0.7 1.23 14.7 11.9 174 10.3 7.44 1.1 0.679 15.4 22.7 349 21.2 5.84 2.0 1.08 19.0 17.6 333 17.3 8.42 2.0 0.601 19.7 32.8 645 28.3 9.75 3.8 0.505 23.2 46.1 1070 36.3 12.9 6.5 0.486 26.1 53.7 1400 38.5 15.9 8.5 1190±25% 610min. 1680±25% 1300±25% 2550±25% 2100±25% 1880±25% 1300±25% 3500±25% 2900±25% 4300±25% 3200±25% 4400±25% 3400±25% With air gap 63±5% 100±7% 63±5% 100±7% 63±3% 100±5% 160±7% 100±5% 160±7% 80±3% 125±5% 200±7% 80±3% 125±5% 200±7% 80±3% 125±3% 200±5% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (40/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ER9.5/5-Z +0 9.5 –0.3 7.0min. +0 ø3.5 –0.2 SHAPES AND DIMENSIONS +0.15 1.6 –0 +0 2.5 –0.1 +0 5.0 –0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 120 7.07 0.7 610min. 0.1 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 1.67 14.2 100°C 8.47 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 AL-value(nH/N2) 10 2 NI limit (AT) 40% 20% 101 10 2 Center pole gap 101 Temp: 100°C 100 1 10 NI20%=3109.2×AL1.0106 NI40%=3298.3×AL1.0159 10 2 A L-value (nH/N 2) 10 3 The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=18.26×lg –0.7831 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (41/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ER9.5/5-Z +0 9.5 –0.3 7.0min. +0 ø3.5 –0.2 SHAPES AND DIMENSIONS +0.15 1.6 –0 +0 2.5 –0.1 +0 5.0 –0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 120 7.07 0.7 1190±25% 0.1 0.09 0.1 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 1.67 14.2 8.47 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 AL-value(nH/N2) 10 2 NI limit (AT) 40% 20% 101 10 2 Center pole gap 101 Temp: 100°C 100 1 10 NI20%=2721.3×AL–1.0066 NI40%=2921.8×AL–1.0149 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=18.225×lg –0.783 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (42/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ER14/4.5/9-Z 13.85±0.25 ø5.2±0.1 1.25 11.35±0.15 1.25 SHAPES AND DIMENSIONS 0.95±0.1 2.25±0.1 9.0±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 349 5.84 2.0 2100±25% 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.679 15.4 100°C 22.7 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=9022.4×AL–1.0034 NI40%=9982×AL–1.0153 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=41.575×lg –0.7757 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (43/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ER14/4.5/9-Z 13.85±0.25 ø5.2±0.1 1.25 11.35±0.15 1.25 SHAPES AND DIMENSIONS 0.95±0.1 2.25±0.1 9.0±0.2 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 349 5.84 2.0 2550±25% 0.25 0.2 0.25 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.679 15.4 22.7 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 10 2 101 101 Temp: 100°C 100 1 10 NI20%=8453.1×AL–1.0008 NI40%=9337.8×AL–1.0133 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=41.576×lg –0.7762 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (44/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ER14.5/6-Z 11.8±0.2 14.5±0.2 1.35 ø4.7±0.2 1.35 SHAPES AND DIMENSIONS 1.65±0.1 +0 6.7±0.1 3.0 –0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 333 8.42 2.0 3500±25% 0.3 0.28 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 1.08 19.0 17.6 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 AL-value(nH/N2) 10 2 NI limit (AT) 40% 20% 10 2 101 101 Temp: 100°C 100 1 10 NI20%=4507×AL–0.9671 NI40%=4424×AL–0.9516 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=38.79×lg –0.7342 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (45/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90ER18/5/12-Z 18.15±0.3 ø6.0±0.1 1.2 15.75±0.25 1.2 SHAPES AND DIMENSIONS 1.0±0.1 2.5±0.1 12.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 645 9.75 3.8 2900±25% 0.5 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.601 19.7 100°C 32.8 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 NI limit (AT) 40% 20% 101 AL-value(nH/N2) Center pole gap 101 Temp: 100°C 100 1 10 NI20%=8664.9×AL–0.9482 NI40%=8641.1×AL–0.9377 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=61.29×lg –0.7237 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (46/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95ER18/5/12-Z 18.15±0.3 ø6.0±0.1 1.2 15.75±0.25 1.2 SHAPES AND DIMENSIONS 1.0±0.1 2.5±0.1 12.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 645 9.75 3.8 3500±25% 0.45 0.4 0.45 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 0.601 19.7 32.8 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 10 2 10 2 NI limit (AT) 40% 20% AL-value(nH/N2) Center pole gap 101 101 Temp: 100°C 100 1 10 NI20%=8250×AL–0.9491 NI40%=8177.2×AL–0.9384 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=61.294×lg –0.7242 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature:25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (47/49) F E R R I T E S Mn-Zn EI Cores F B A H J A D E H SHAPES AND DIMENSIONS I C C HE core PC95 EI14/5/5 Material Size of E core Part No.(HE+PLT) PC95EI14/5/5-Z PC90EI14/5/5-Z PC95EI18/6/10-Z PC90EI18/6/10-Z PC95EI22/8/16-Z PC90EI22/8/16-Z PLT core Z - AL-value (Z: without air gap) Dimensions (mm) A B C D E F H I J 14.00±0.30 3.50±0.10 5.00±0.10 3.00±0.10 11.00±0.25 2.00±0.10 1.50 1.50±0.05 1.50 18.00±0.35 4.00±0.10 10.00±0.20 4.00±0.10 14.00±0.30 2.00±0.10 2.00 2.00±0.05 2.00 21.80±0.40 5.70±0.10 15.80±0.30 5.00±0.10 16.80±0.40 3.20±0.10 2.50 2.50±0.05 2.50 Effective parameter Core factor Part No.(HER+HER) PC95EI14/5/5-Z PC90EI14/5/5-Z PC95EI18/6/10-Z PC90EI18/6/10-Z PC95EI22/8/16-Z PC90EI22/8/16-Z C1(mm–1) Effective magnetic path length ℓe(mm) Electrical characteristics Effective cross-sectional area Ae(mm2) Effective core volume Amin. Acw Weigh AL-value Ve(mm3) (mm2) (mm2) (g) (nH/N2) 1kHz 0.5mA 100Ts Without air gap 1.11 16.7 15.0 251 15.0 8.00 1.3 0.507 20.3 40.0 811 40.0 10.0 4.4 0.330 26.1 79.0 2060 79.0 18.9 11 1550±25% 1200±25% 4720±25% 3100±25% 8010±25% 5300±25% With air gap 63±3% 100±5% 160±7% 100±3% 160±3% 250±5% 160±3% 250±3% 315±3% Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (48/49) F E R R I T E S Mn-Zn Planar series Part No.: PC90EI14/5/5-Z 14.0±0.3 14.0±0.3 3.0±0.1 2.0±0.1 1.5 1.5 11.0±0.25 1.5 SHAPES AND DIMENSIONS 3.5±0.1 5.0±0.1 1.5±0.05 5.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 251 8.0 1.3 1200±25% 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 1.11 16.7 100°C 15.0 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 Center pole gap NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 101 10 2 101 Temp: 100°C 100 1 10 NI20%=5602.2×AL–0.9893 NI40%=5612.1×AL–0.9697 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. AL=37.239×lg –0.6627 100 0.01 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level: 0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm (49/49) F E R R I T E S Mn-Zn Planar series Part No.: PC95EI14/5/5-Z 14.0±0.3 14.0±0.3 3.0±0.1 2.0±0.1 1.5 1.5 11.0±0.25 1.5 SHAPES AND DIMENSIONS 3.5±0.1 5.0±0.1 1.5±0.05 5.0±0.1 Dimensions in mm Effective parameter Core factor Electrical characteristics Weigh AL-value  Core loss Ve (mm3) Cross-sectional winding area of core Acw (mm2) (g/set) (nH/N2) 1kHz 0.5mA (W)max. 100kHz 200mT 25°C 80°C 120°C 251 8.0 1.3 1550±25% 0.3 0.25 0.3 Effective core volume C1 (mm–1) Effective magnetic Effective path length cross-sectional area ℓe Ae (mm) (mm2) 1.11 16.7 15.0 NI limit vs. AL-value(Typ.) AL-value vs. Air gap length(Typ.) 10 3 10 3 NI limit (AT) AL-value(nH/N2) 40% 10 2 20% 101 Center pole gap 10 2 101 Temp: 100°C 100 1 10 NI20%=5271.1×AL–0.9877 NI40%=5298.5×AL–0.9694 10 2 10 3 A L-value (nH/N 2) The 20% and 40% graph shows when a 20% and 40% drop from the initial ALvalue has been made due to the DC superimposition. 100 0.01 AL=37.242×lg –0.6633 0.10 1 Air gap length (mm) 10 Measuring conditions • Coil:ø0.18 2UEW 100Ts • Frequency:1kHz • Current level:0.5mA • Ambient temperature: 25°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210308 / ferrite_mz_sw_planar_en.fm
PC95EL13X4.4-Z 价格&库存
很抱歉,暂时无法提供与“PC95EL13X4.4-Z”相匹配的价格&库存,您可以联系我们找货
