PFC2723ER-421K03B-50
    TDK(东电化)
    CHOKE COMMON MODE
PFC2723ER-421K03B-50 数据手册
T R A N S F O R M E R S August 2021 Pb RoHS Choke Coils for PFC Pin terminal type PFC series PFC3514QM PFC3318QM PFC3519QM PFC3819QM PFC4124QM PFC2723ER PFC3125ER PFC3525ER PFC3820QN PFC3831QN Dynamic characteristic data ・PFC-QM series ・PFC-ER series ・PFC-QN series REACH SVHC-Free Lead Free (2/26) T R A N S F O R M E R S An attention matter on use Please read this specifications before using this product by all means. An attention matter on security I undertake use with this product, and it is paid attention enough, and please design an attention matter safely. Attention on a design When designing the board, use our recommended hole diameter or pad. Magnetic flux to leak out occurs. Please confirm it about influence of magnetic flux beforehand. There is fear to cause false movement of machinery. When designing the board, ensure a distance from the transformer in accordance with the applicable safety standards. The product is not quakeproof structure. Accordingly please do not add vibration and a shock to it. The product produces possibility to lose a function. Attention on the handling Please do not use it when you let a product drop. The product produces possibility to lose a function. Be careful not to get injured because the tip of the terminal is sharpened by soldering. For storage, avoid dust, dust, fog, water droplets and direct sunlight. There is fear to cause false movement of machinery. Do not use or store in an environment with gas corrosion (salt, acid, alkali, etc.). The product produces possibility to lose a function. When mounting, do not apply excessive force to the product with metal tools or the like. The product produces possibility to lose a function. Attention The structure and number of turns (magnetic mounting) are determined in consideration of safety standards, power supply voltage, circuit drive conditions (drive frequency and maximum ON period), etc., so avoid using them outside the design conditions. There are destruction of a circuit part and fear of ignition. The operating temperature and humidity ranges are determined in consideration of the characteristics of the components and the self-temperature rise, so please avoid using in a range exceeding this range. There is a risk of burning or ignition. Avoid using it in an environment where dust and dirt are likely to adhere. There is a risk of cause a fire. The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please note that we are not responsible for any damages caused by exceeding the scope and conditions of this specification or by using it for a specific purpose If you exceed the scope and conditions of this specification, or plan to use it for a specific purpose, please contact us in advance. We will discuss specifications other than those listed in this specification according to the customer's application. (1) Aerospace/Aviation equipment (2)Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipmentapplications (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20210823 / trans_pfc-choke_pfc_en.fm (3/26) T R A N S F O R M E R S Choke Coils for PFC PFC series Contents Page Development Concept .................................................................................... 4 Overview.........................................................................................................5 PFC QM series PFC3514QM (Height from the board : 15.5mm) ........................................6 PFC3318QM (Height from the board : 20mm) ...........................................8 PFC3519QM (Height from the board : 21mm) .........................................10 PFC3819QM (Height from the board : 21mm) .........................................12 PFC4124QM (Height from the board : 25mm) .........................................14 PFC ER series PFC2723ER (Height from the board : 26mm) ..........................................16 PFC3125ER (Height from the board : 27mm) ..........................................18 PFC3525ER (Height from the board : 27mm) ..........................................20 PFC QN series PFC3820QN (Height from the board: 50mm Narrow floor space) ........... 22 PFC3831QN (Height from the board: 50mm Narrow floor space) ........... 24 Specification Request Form ......................................................................... 26 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (4/26) T R A N S F O R M E R S Choke Coils for PFC Pin terminal type Development Concept of the PFC series This is a power - factor improvement circuit for choke coils for smaller, thinner and narrow floor space in recent years electronic equipment. MATERIAL Thanks to the development of an optimized core shape and materials, the choke coil has DC superimposition characteristics suitable for the design of various types of electronic devices. Optimized materials have been selected, and at the same time the original core shape for PFC has been developed. The product line-up has been expanded to cater for various types of electronic devices that need to become smaller, thinner and narrow floor space. MANUFACTURING METHOD Since the PFC Series supports automatic winding, the product is of a high quality and can be manufactured stably. It is designed to support automatic winding, which enables a remarkable reduction in the loss generated to achieve a proficient in manual winding until stable production. In addition, the characteristic variations of the winding wire and creepage tape have largely been removed, stabilizing the transformer's characteristics. OPTIMIZATION DESIGN While the existing line-up of standard products remains available, new products can also be manufactured to meet customers' requests. Using design tools developed with TDK's comprehensive know-how, high-precision design has been achieved in a short period of time. 1) For optimization design and high-quality stable production, customers can use a specification request form. If you provide the necessary information in the form, you will receive the optimization design in a short time. 2) TDK recommends design with a standard core gap (AL-value) for optimization and shorter trial and mass production lead time. ENVIRONMENT The PFC series is RoHS directive-compliant product. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (5/26) T R A N S F O R M E R S Product compatible with RoHS directive Compatible with lead-free solders Choke Coils for PFC Pin terminal type Overview of the PFC series FEATURES A low height(15.5 to 27mm in height) and narrow floor space(QN type) are achieved. Large current is achieved in a small shape. APPLICATION AV equipment, digital consumer electronics PART NUMBER CONSTRUCTION PFC Series name 3514QM Core shape PFC3514QM PFC3318QM PFC3519QM PFC3819QM PFC4124QM PFC2723ER PFC3125ER PFC3525ER PFC3820QN PFC3831QN 351 K 07 E-** Inductance code 350 35µH (35x100) 351 350µH (35x101) 352 3500µH(35x102) Inductance tolerance K ±10% Rated Peak current code1 01 1A 07 7A 10 10A Internal code 1The rounded-off value. OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage Type temperature2 temperature3 (°C) (°C) PFC3514QM –30 to +120 –40 to +80 PFC3318QM –30 to +120 –40 to +80 PFC3519QM –30 to +120 –40 to +80 PFC3819QM –30 to +120 –40 to +80 PFC4124QM –30 to +120 –40 to +80 PFC2723ER –30 to +120 –40 to +80 PFC3125ER –30 to +120 –40 to +80 PFC3525ER –30 to +120 –40 to +80 PFC3820QN –30 to +120 –40 to +80 PFC3831QN –30 to +120 –40 to +80 2Operating temperature range includes self-temperature rise. 3The Storage temperature range is for after the circuit board is mounted. 4Typical weight. Package quantity Individual weight4 (pieces/box) 175 140 140 100 90 150 120 120 105 63 (g) 40.0 27.6 50.3 60.5 91.9 34.1 49.7 57.3 71.9 115.3 RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (6/26) T R A N S F O R M E R S PFC QM series PFC3514QM Type SHAPE & DIMENSIONS 15.5max. 4.0±0.8 25.0 0.8 5- ø1 30.0max. 0.8 5 3 6 2 7 8 1 5.0 5.0 5.0 5.0 7.5 ø1 37.0max. 7.5 4 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 4 8-ø1.6 4 2 2 Np (Main) Npd (Sub) 6 1 7 1 7 5 7.5 5 6 5 5 7.5 5 3 5 3 8 12.5 8 8-ø4.0 25 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (7/26) T R A N S F O R M E R S PFC QM series PFC3514QM Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3514QM-351K04B-00 PFC3514QM-281K05B-00 PFC3514QM-231K06B-00 Through hole Through hole Through hole Frequency (kHz) min. 65 65 65 PFC output power (W) 100 125 150 Inductance (µH) 350 280 230 Rated peek current1 (A) 3.7 4.6 5.5 Turn ratio (Np/Npd) 10.0 9.8 9.6 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 400 350 PFC3514QM-351K04B-00 300 Inductance(µH) PFC3514QM-281K05B-00 250 PFC3514QM-231K06B-00 200 150 100 50 0 0 1 2 3 4 5 DC current(A) 6 7 8 9 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (8/26) T R A N S F O R M E R S PFC QM series PFC3318QM Type SHAPE & DIMENSIONS 28.0max. 22.5 4.0±0.8 0.8 5- ø1 .0 20.0max. 7.5 6 7 1 8 0.8 7.5 ø1 35.0max. 5 2 5.0 5.0 5.0 5.0 4 3 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 8-ø1.6 2 Np (Main) Npd (Sub) 6 5 6 5 2 5 3 7 1 8 11.25 1 7 5 7.5 7.5 5 5 4 3 4 8-ø4.0 8 22.5 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (9/26) T R A N S F O R M E R S PFC QM series PFC3318QM Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3318QM-601K03B-00 PFC3318QM-601K03E-00 PFC3318QM-451K04B-00 Through hole Through hole Through hole Frequency (kHz) min. 50 50 50 PFC output power (W) 75 75 100 Inductance (µH) 600 600 450 Rated peek current1 (A) 2.8 2.8 3.7 Turn ratio (Np/Npd) 9.0 9.6 9.0 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 700 PFC3318QM-601K03E-00 600 PFC3318QM-601K03B-00 Inductance(µH) 500 PFC3318QM-451K-04B-00 400 300 200 100 0 0 1 2 3 DC current(A) 4 5 6 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (10/26) T R A N S F O R M E R S PFC QM series PFC3519QM Type SHAPE & DIMENSIONS 21.0max. 4.0±0.8 25.0 0.8 5- ø1 30.0max. 7.5 6 2 7 1 8 0.8 7.5 ø1 37.0max. 5 5.0 5.0 5.0 5.0 4 3 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 8-ø1.6 4 5 3 4 5 6 2 Np (Main) Npd (Sub) 6 7 1 1 7 5 7.5 5 7.5 2 5 3 5 8 12.5 8-ø4.0 8 25 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (11/26) T R A N S F O R M E R S PFC QM series PFC3519QM Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3519QM-451K04E-00 PFC3519QM-301K06B-50 PFC3519QM-231K07B-50 Through hole Through hole Through hole Frequency (kHz) min. 50 50 50 PFC output power (W) 100 150 200 Rated peek current1 (A) 3.7 5.5 7.4 Inductance (µH) 450 300 230 Turn ratio (Np/Npd) 10 9.8 9.6 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 500 450 PFC3519QM-451K04E-00 400 Inductance(µH) 350 300 PFC3519QM-301K06B-50 250 200 PFC3519QM-231K07B-50 150 100 50 0 0 2 4 6 8 10 12 14 DC current(A) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (12/26) T R A N S F O R M E R S PFC QM series PFC3819QM Type SHAPE & DIMENSIONS 33.5max. 4.0±0.8 28.0 0.8 5- ø1 .0 21.0max. 7.5 6 2 7 1 8 0.8 7.5 ø1 40.0max. 5 5.0 5.0 5.0 5.0 4 3 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 4 8-ø1.6 4 5 5 3 2 Np (Main) Npd (Sub) 6 5 6 5 5 2 7.5 7.5 3 1 7 7 5 1 8 14 8 8-ø4.0 28 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (13/26) T R A N S F O R M E R S PFC QM series PFC3819QM Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3819QM-301K06E-50 PFC3819QM-231K07D-50 PFC3819QM-181K09B-50 PFC3819QM-151K11B-00 Through hole Through hole Through hole Through hole Frequency (kHz) min. 50 50 50 50 PFC output power (W) 150 200 250 300 Inductance (µH) 300 230 180 150 Rated peek current1 (A) 5.5 7.4 8.8 11.1 Turn ratio (Np/Npd) 9.8 9.6 9.5 9.8 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 350 300 Inductance(µH) 250 PFC3819QM-301K06E-50 PFC3819QM-231K07D-50 200 PFC3819QM-181K09B-50 150 PFC3819QM-151K11B-00 100 50 0 0 2 4 6 8 10 DC current(A) 12 14 16 18 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (14/26) T R A N S F O R M E R S PFC QM series PFC4124QM Type SHAPE & DIMENSIONS 25.0max. 32.0 4.0±0.8 0.8 5- ø1 38.0max. 6 7 1 8 0.8 7.5 ø1 7.5 43.0max. 5 2 5.0 5.0 5.0 5.0 4 3 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 8-ø1.6 4 2 Np (Main) Npd (Sub) 6 5 5 6 5 2 5 3 5 7.5 7.5 3 4 7 1 7 5 1 8 16 8-ø4.0 8 32 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (15/26) T R A N S F O R M E R S PFC QM series PFC4124QM Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC4124QM-181K09D-00 PFC4124QM-151K11D-00 Through hole Through hole Frequency (kHz) min. 50 50 PFC output power (W) 250 300 Rated peek current1 (A) 8.8 11.1 Inductance (µH) 180 150 Turn ratio (Np/Npd) 9.5 9.8 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 250 Inductance(µH) 200 PFC4124QM-181K09D-00 PFC4124QM-151K11D-00 150 100 50 0 0 2 4 6 8 10 12 DC current(A) 14 16 18 20 22 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (16/26) T R A N S F O R M E R S PFC ER series PFC2723ER Type SHAPE & DIMENSIONS 26.0max. 4.0±0.8 20 5- ø1 .0 25.0max. 2 4 10 20 29.0max. 10 3 1 5 Dimensions in mm RECOMMENDED LAND PATTERN 5-ø1.6 3 2 Np (Main) 3 Npd (Sub) 4 10 2 CIRCUIT DIAGRAM 1 5 10 20 4 1 5 10 5-ø4.0 20 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (17/26) T R A N S F O R M E R S PFC ER series PFC2723ER Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC2723ER-601K02B-00 PFC2723ER-421K03B-50 Through hole Through hole Frequency (kHz) min. 50 50 PFC output power (W) 75 100 Inductance (µH) 600 420 Rated peek current1 (A) 2.4 3.4 Turn ratio (Np/Npd) 9.8 10.8 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 700 PFC2723ER-601K02B-00 600 Inductance(µH) 500 PFC2723ER-421K03B-50 400 300 200 100 0 0 1 2 3 DC current(A) 4 5 6 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (18/26) T R A N S F O R M E R S PFC ER series PFC3125ER Type SHAPE & DIMENSIONS 3.5±0.8 21 ø1 .0 27.0max. 6- 26.0max. 5 33.0max. 7 9.5 13 6 13 16.5 3 8 1 Dimensions in mm RECOMMENDED LAND PATTERN 6-ø1.6 6 9.5 13 3 13 13 16.5 7 3 5 4 3.5 5 CIRCUIT DIAGRAM 2 6 Npd (Sub) Np (Main) 7 8 1 1 8 6-ø4.0 10.5 21 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (19/26) T R A N S F O R M E R S PFC ER series PFC3125ER Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3125ER-451K03E-00 PFC3125ER-301K05B-00 PFC3125ER-231K06B-00 Through hole Through hole Through hole Frequency (kHz) min. 50 50 50 PFC output power (W) 100 150 200 Inductance (µH) 450 300 230 Rated peek current1 (A) 2.7 4.9 6.4 Turn ratio (Np/Npd) 10.0 10.4 9.0 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 500 450 PFC3125ER-451K03E-00 400 Inductance(µH) 350 300 PFC3125ER-301K05B-00 250 PFC3125ER-231K06B-00 200 150 100 50 0 0 2 4 6 DC current(A) 8 10 12 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (20/26) T R A N S F O R M E R S PFC ER series PFC3525ER Type SHAPE & DIMENSIONS 3.5±0.8 22.0 .0 27.0max. 6ø1 27.5max. 5 37.0max. 13 9.5 6 7 13 16.5 3 8 1 Dimensions in mm RECOMMENDED LAND PATTERN 6-ø1.6 6 9.5 13 3 13 13 16.5 7 3 5 4 3.5 5 CIRCUIT DIAGRAM 2 6 Npd (Sub) Np (Main) 7 8 1 1 8 6-ø4.0 11 22 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (21/26) T R A N S F O R M E R S PFC ER series PFC3525ER Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3525ER-301K04E-00 PFC3525ER-231K06E-00 PFC3525ER-181K09B-00 Through hole Through hole Through hole Frequency (kHz) min. 50 50 50 PFC output power (W) 150 200 250 Inductance (µH) 300 225 180 Rated peek current1 (A) 4.1 5.6 9.5 Turn ratio (Np/Npd) 10.4 10.0 10.5 ○ Measurement equipment2 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 2 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 350 PFC3525ER-301K04E-00 300 Inductance(µH) 250 200 PFC3525ER-231K06E-00 PFC3525ER-181K09B-00 150 100 50 0 0 2 4 6 8 DC current(A) 10 12 14 16 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (22/26) T R A N S F O R M E R S PFC QN series PFC3820QN Type 50.0max. 4.0±0.8 14.0 5 3 6 2 6.5 4 13.0 6.5 6.5 33.0max. 6.5 7- 22.5max. ø1 .2 SHAPE & DIMENSIONS 1 8 Dimensions in mm CIRCUIT DIAGRAM 4 5 3 6 Npd (Sub) 8 Np (Main) 4 5 6.5 6.5 RECOMMENDED LAND PATTERN 6.5 2 1 7-ø1.8 14 7-ø4.0 1 8 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (23/26) T R A N S F O R M E R S PFC QN series PFC3820QN Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3820QN-900K11B-00 Through hole Frequency (kHz) min. 35 PFC output power1 (W) 800 Inductance (µH) 90 Rated peek current2 (A) 11 Turn ratio (Np/Npd) 7 ○ Measurement equipment3 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 Output power at 220 Vac input. 2 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 3 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 120 100 PFC3820QN-900K11B-00 Inductance(µH) 80 60 40 20 0 0 2 4 6 8 10 DC current(A) 12 14 16 18 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (24/26) T R A N S F O R M E R S PFC QN series PFC3831QN Type 50.0max. 4.0±0.8 25.0 5 3 6 2 6.5 4 13.0 6.5 6.5 33.0max. 6.5 7- 34.6max. ø1 .2 SHAPE & DIMENSIONS 1 8 Dimensions in mm RECOMMENDED LAND PATTERN 5 3 6 6.5 4 CIRCUIT DIAGRAM 6.5 Np (Main) 1 8 6.5 2 1 7-ø1.8 8 25.0 7-ø4.0 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (25/26) T R A N S F O R M E R S PFC QN series PFC3831QN Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Part number Mount method PFC3831QN-351K08B-00 Through hole PFC output power1 (W) 900 Frequency (kHz) min. 50 Rated peek current2 (A) 8 Inductance (µH) 350 Turn ratio (Np/Npd) — ○ Measurement equipment3 Measurement item Product No. Manufacturer Inductance 4284A Keysight Technologies DC bias characteristics 4284A + 42841A Keysight Technologies 1 Output power at 220 Vac input. 2 The rated peak current is the peak value of the triangular wave current flowing through the PFC coil. 3 Equivalent measurement equipment may be used. INDUCTANCE CHANGE VS. DC BIAS CHARACTERISTICS GRAPH (100°C) 400 350 PFC3831QN-351K08B-00 Inductance(µH) 300 250 200 150 100 50 0 0 2 4 6 8 10 12 14 DC current(A) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm (26/26) T R A N S F O R M E R S PFC Circuit Inductance Specification Request Form Issued on / / 1. Company name Address 2. Department, applicant's name Name: Person in Charge from Sales Promotion Dep.: Recorded Date / / TEL/FAX: Person in Charge from Sales Dep.: Recorded Date / / Prototype No: Recorded Date / / E-mail: 3. Circuit system (Fill in the (□) square like this (■) to make your selection.) □Continuous mode □Critical mode □Interleave □Other ( ) 4. Input specifications AC input voltage: Rated Frequency Operating range: (V) to (V) Minimum operating input voltage: (V) to (V) (V) (V) to (Hz) 5. Design condition (1) Clock frequency (Fill in the (□) square like this (■) to make your selection.) □Continuous mode(fixed frequency): (kHz) □Critical mode(lowest frequency): (kHz) (2) Output voltage (Vdc) (3) Rated output power/Maximum peak power (W) / (W) (4) Minimum operating input voltage (Vac) (5) Overcurrent point condition (ex.: 130% in (3)Rated output power and (4) Minimum operating input voltage) (%) (6) Maximum temperature rise ΔT (℃) Condition in temperature evaluation (ex.: minimum input, rated load) (7) Auxiliary winding (Fill in the (□) square like this (■) to make your selection.) □Yes       □No (Windings) Number of windings (mA) (V) / Desired voltage value and current □Functional insulation □Reinforced insulation Necessity of insulation (Fill in the (□) square like this (■) to make your selection.) (8) Circuit diagram (If you desire any pin number, attach a circuit diagram.) □Yes       □No 6. Inductance value and saturated current value for reference μ(H) Inductance value: (A) Saturated current value: 7. Desired core size and external size Core size: External size L: W: H(Height from the board): mm max. 8. IC expected to be used Manufacturer name: Product No.: 9. Production quantity information Desired price/Currency: Final set name: Acceptance conditions of the above price (FCA CHN, CIP LA, DDP Paris etc.): k/M Production start period: Production volume: Prototyping time: (ES1) (ES2) Production place: (PP1) (PP2) (MP1) 10. Sample information Required sample quantity pcs. Requested delivery time: 11. Note company regulations, such as safe distance and dielectric voltage strength, if there are any. 12. If there are any other requests (priorities in the company, size or price, etc.) or alterable items, please provide a description. TDK Corporation Magnetics Business Group, Strategic Product Marketing Division 2-5-1 Nihonbashi, Chuo-ku, Tokyo, 103-6128, Japan TEL: 81-3-6778-1034, FAX: 81-3-6778-1155 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210823 / trans_pfc-choke_pfc_en.fm
PFC2723ER-421K03B-50 价格&库存
很抱歉,暂时无法提供与“PFC2723ER-421K03B-50”相匹配的价格&库存,您可以联系我们找货
