PFC3519QM-231K07B-00
    TDK(东电化)
PFC3519QM-231K07B-00 数据手册
January 2014 Choke Coils for PFC Pin terminal type PFC PFC3514QM PFC3318QM PFC3519QM PFC3819QM PFC4124QM PFC2723ER PFC3125ER PFC3525ER series (2/19) REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS ○ The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. ○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). ○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. ○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. ○ Use a wrist band to discharge static electricity in your body through the grounding wire. ○ Do not expose the products to magnets or magnetic fields. ○ Do not use for a purpose outside of the contents regulated in the delivery specifications. ○ The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (8) Public information-processing equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (9) Military equipment (3) Medical equipment (10) Electric heating apparatus, burning equipment (4) Power-generation control equipment (11) Disaster prevention/crime prevention equipment (5) Atomic energy-related equipment (12) Safety equipment (6) Seabed equipment (13) Other applications that are not considered general-purpose (7) Transportation control equipment applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. transformer_dk1_pfc_en (3/19) Choke Coils for PFC PFC Series Overview of the PFC Series ■ FEATURES ○ A low height(15.5 to 27mm in height) is achieved ○ Large current is achieved in a small shape ■ APPLICATION AV equipment, digital consumer electronics ■ PART NUMBER CONSTRUCTION PFC 3514QM Series name Core size - 351 K Inductance code Inductance tolerance 350 35uH (35x100) 351 350uH (35x101) 352 3500uH(35x102) J K L M 07 E Rated Peak current code✽1 ±5% ±10% ±15% ±20% 01 07 10 Control mark - ** Control mark 1A 7A 10A ■ OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Type PFC3514QM PFC3318QM PFC3519QM PFC3819QM PFC4124QM PFC2723ER PFC3125ER PFC3525ER Operating temperature✽2 Storage temperature✽3 Package quantity Individual weight✽4 (°C) –30 to +120 –30 to +120 –30 to +120 –30 to +120 –30 to +120 –30 to +120 –30 to +120 –30 to +120 (°C) –40 to +80 –40 to +80 –40 to +80 –40 to +80 –40 to +80 –40 to +80 –40 to +80 –40 to +80 (pieces/box) 175 140 140 100 90 150 120 120 (g) 40.0 27.6 50.3 60.5 91.9 34.1 49.7 57.3 ✽1 The rounded-off value. ✽2 Operating temperature range includes self-temperature rise. ✽3 The Storage temperature range is for after the circuit board is mounted. ✽4 Typical weight. ○ RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/ ○ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. · All specifications are subject to change without notice. transformer_dk1_pfc_en (4/19) PFC QM series PFC3514QM Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC3514QM 30.0max. 37.0max. 15.5max. 7.5 5.0 25.0 ■ RECOMMENDED LAND PATTERN 5 5 5 6 5 7 8 3 2 7.5 1 7.5 12.5 25 4 5 ■ CIRCUIT DIAGRAM Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (5/19) PFC QM series PFC3514QM Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3514QM-351K04B-00 Through hole 65 100 350 3.7 10.0 PFC3514QM-281K05B-00 Through hole 65 125 280 4.6 9.8 PFC3514QM-231K06B-00 Through hole 65 150 230 5.5 9.6 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH PFC3514QM-351K04B-00 PFC3514QM-281K05B-00 PFC3514QM-231K06B-00 DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (6/19) PFC QM series PFC3318QM Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC3318QM 28.0max. 35.0max. 20.0max. 7.5 5.0 22.5 ■ RECOMMENDED LAND PATTERN 5 3 5 6 5 7 2 7.5 8 1 7.5 22.5 4 5 11.25 5 ■ CIRCUIT DIAGRAM Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (7/19) PFC QM series PFC3318QM Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3318QM-601K03B-00 Through hole 50 75 600 2.8 9.0 PFC3318QM-601K03E-00 Through hole 50 75 600 2.8 9.6 PFC3318QM-451K04B-00 Through hole 50 100 450 3.7 9.0 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH PFC3318QM-601K03B-00 PFC3318QM-601K03E-00 PFC3318QM-451K04B-00 DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (8/19) PFC QM series PFC3519QM Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC3519QM 30.0max. 37.0max. 20.0max. 7.5 5.0 25.0 ■ RECOMMENDED LAND PATTERN 5 5 5 6 5 7 8 3 2 7.5 1 7.5 12.5 25 4 5 ■ CIRCUIT DIAGRAM Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (9/19) PFC QM series PFC3519QM Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3519QM-451K04E-00 Through hole 50 100 450 3.7 10 PFC3519QM-301K06B-00 Through hole 50 150 300 5.5 9.8 PFC3519QM-231K07B-00 Through hole 50 200 230 7.4 9.6 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH PFC3519QM-451K04E-00 PFC3519QM-301K06B-00 PFC3519QM-231K07B-00 DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (10/19) PFC QM series PFC3819QM Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC3819QM 33.5max. 40.0max. 20.0max. 7.5 5.0 28.0 ■ RECOMMENDED LAND PATTERN 5 5 5 6 5 7 8 14 28 4 5 ■ CIRCUIT DIAGRAM 3 2 7.5 1 7.5 Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (11/19) PFC QM series PFC3819QM Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3819QM-301K06E-00 Through hole 50 150 300 5.5 9.8 PFC3819QM-231K07D-00 Through hole 50 200 230 7.4 9.6 PFC3819QM-181K09B-00 Through hole 50 250 180 8.8 9.5 PFC3819QM-151K11B-00 Through hole 50 300 150 11.1 9.8 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH PFC3819QM-301K06E-00 PFC3819QM-231K07D-00 PFC3819QM-181K09B-00 PFC3819QM-151K11B-00 DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (12/19) PFC QM series PFC4124QM Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC4124QM 38.0max. 43.0max. 25.0max. 7.5 5.0 32.0 ■ RECOMMENDED LAND PATTERN 5 5 5 6 5 7 8 16 32 4 5 ■ CIRCUIT DIAGRAM 3 2 7.5 1 7.5 Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (13/19) PFC QM series PFC4124QM Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC4124QM-181K09D-00 Through hole 50 250 180 8.8 9.5 PFC4124QM-151K11D-00 Through hole 50 300 150 11.1 9.8 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH PFC4124QM-181K09D-00 PFC4124QM-151K11D-00 DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (14/19) PFC ER series PFC2723ER Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 F PFC2723ER 25.0max. 28.0max. 25.0max. 20.0 10.0 20.0 ■ RECOMMENDED LAND PATTERN 10 10 4 5 2 1 20 10 20 3 ■ CIRCUIT DIAGRAM Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (15/19) PFC ER series PFC2723ER Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC2723ER-601K02B-00 Through hole 50 75 600 2.4 9.8 PFC2723ER-421K03B-00 Through hole 50 100 420 3.4 10.8 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (16/19) PFC ER series PFC3125ER Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 P3 P4 F PFC3125ER 26.0max. 33.0max. 27.0max. 9.5 3.5 16.5 6.5 21.0 ■ RECOMMENDED LAND PATTERN 9.5 16.5 3.5 13 7 8 5 4 6.5 3 6.5 6.5 2 1 10.5 21 6 ■ CIRCUIT DIAGRAM 6.5 Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (17/19) PFC ER series PFC3125ER Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3125ER-451K03E-00 Through hole 50 100 450 2.7 10.0 PFC3125ER-301K05B-00 Through hole 50 150 300 4.9 10.4 PFC3125ER-231K06B-00 Through hole 50 200 230 6.4 9.0 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en (18/19) PFC ER series PFC3525ER Type ■ SHAPE & DIMENSIONS Dimensions in mm Type D W H P1 P2 P3 P4 F PFC3525ER 27.5max. 37.0max. 27.0max. 9.5 3.5 16.5 6.5 22.0 ■ RECOMMENDED LAND PATTERN 9.5 16.5 3.5 13 7 8 5 4 6.5 3 6.5 6.5 2 1 6.5 11 22 6 ■ CIRCUIT DIAGRAM Dimensions in mm · All specifications are subject to change without notice. transformer_dk1_pfc_en (19/19) PFC ER series PFC3525ER Type ■ ELECTRICAL CHARACTERISTICS □ CHARACTERISTICS SPECIFICATION TABLE Mount method Part No. Frequency (kHz)min PFC output Inductance Rated peek Turn ratio power (µH) current✽1 (Np/Npd) (W) (A) PFC3525ER-301K04E-00 Through hole 50 150 300 4.1 10.4 PFC3525ER-231K06E-00 Through hole 50 200 225 5.6 10.0 PFC3525ER-181K09B-00 Through hole 50 250 180 9.5 10.5 ○ Measurement equipment✽2 Measurement item Inductance DC bias characteristics Product No. 4284A 4284A + 42841A Manufacturer Agilent Technologies Agilent Technologies ✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation. ✽2 Equivalent measurement equipment may be used. □ INDUCTANCE CHANGE vs. DC BIAS CHARACTERISTICS GRAPH DC current(A) · All specifications are subject to change without notice. transformer_dk1_pfc_en
PFC3519QM-231K07B-00 价格&库存
很抱歉,暂时无法提供与“PFC3519QM-231K07B-00”相匹配的价格&库存,您可以联系我们找货
    • 1+146.522791+18.96334
