PFE1000FA-12
PFE1000FA-12
    TDK(东电化)
    插件,160x100mm
    高效300W至1008W AC-DC电源模块
PFE1000FA-12 数据手册
PFE-SA, PFE500-F & PFE1000-FA Series http://product.tdk.com/en/power/pfe www.emea.lambda.tdk.com/pfe 300-1008W AC-DC Power Modules The high efficiency PFE series of AC-DC 300W to 1008W power modules are for use in environments where convection or forced air cooling is not viable. Suitable for use in outdoor enclosures or liquid cooled applications, these pcb mounted power modules accept a wide range AC input and deliver an adjustable, regulated output. High ambient temperatures can be tolerated as the conduction cooled baseplate can withstand -40 up to 100°C temperatures. The fully featured PFE500F and PFE1000FA modules offer a parallel connection for increased power, a 12V auxiliary supply and remote on/off. The semi-regulated 48V output PFE700SA provides a very high power density and up to 92% efficiency. Features Benefits • Compact Low Profile Package Sizes • Space Saving in End Equipment • High Efficiency • Less Waste Heat to Manage and Reduced AC Power Consumption • Up to 100°C Rated Baseplate Temperature • Suitable for Rugged Environments • Conduction Cooled Via Baseplate • For Use in Convection Cooled or Sealed Enclosures Model Selector Model PFE300SA-12 PFE500SA-12 PFE500F-12 PFE1000FA-12 PFE300SA-28 PFE500SA-28 PFE500F-28 PFE1000FA-28 PFE300SA-48 PFE500SA-48 PFE500F-48 PFE1000FA-48 PFE700SA-48 Voltage (V) Adjustable Range (V) Max Current (A) Max Output Power (W) Ripple / Noise (mV) Input Current (A) 115/230Vac Efficiency (typ) % 115/230Vac 12 12 12 12 28 28 28 28 48 48 48 48 48 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 9.6 - 14.4 22.4 - 33.6 22.4 - 33.6 22.4 - 33.6 22.4 - 33.6 38.4 - 57.6 38.4 - 57.6 38.4 - 57.6 38.4 - 57.6 None 25 33 42 60 10.8 18 18 36 6.3 10.5 10.5 21 14 300 396 504 720 302 504 504 1008 302 504 504 1008 714 120 120 120 120 280 280 280 280 480 480 480 480 4000 3.3 / 1.6 4.2 / 2.1 6.8 / 3.4(1) 8.0 / 3.9 3.2 / 1.6 5.2 / 2.5 6.4 / 3.2(1) 10.8 / 5.3 3.1 / 1.6 5.1 / 2.5 6.4 / 3.2(1) 10.6 / 5.2 7.0 / 3.4 84 / 86 84 / 86 81 / 83 84.5 / 89.5 87.5 / 89.5 88 / 90 84 / 86 87 / 89.5 88 / 90.5 90 / 91 84 / 86 88 / 90.5 90 / 92 PFE500SA- 12 / T blank /T Output voltage 12, 28, 48 Threaded mounting hole non threaded mounting hole Related Products Type Heatsink for PFE300/500SA Heatsink for PFE300/500SA Heatsink for PFE300/500SA Heatsink for PFE500F Heatsink for PFE1000F 504W AC-DC Power Module Part Number(s) HAF-10L HAF-15L HAF-15T HAL-F12T HAM-F10T PFH500F series Size (mm) / Description 116.8 x 25.4 x 61 116.8 x 38.1 x 61 116.8 x 38.1 x 61 122 x 35 x 69.9 160 x 33.4 x 100 Next generation Power Modules PFE-SA, PFE500-F & PFE1000-FA Series 1 Specifications Model Input Input Voltage Range Vac Input Frequency Hz Input Current A Inrush Current at 230Vac (typ) (Cold Start) A Leakage Current mA Power Factor (100/200Vac) - Hold Up Time (typ) at 110/220Vac Input ms Efficiency - Conducted & Radiated EMI - Immunity - Safety Certifications and Markings - PFE300SA PFE500SA PFE700SA PFE500F PFE1000FA 85 - 265 47 - 63 (Contact factory for 400Hz operation) See model selector table 46 (with recommended inrush resistor) less than 0.75 >0.95 20 See model selector table EN55011/EN55032-A, FCC Class A, VCCI-A (External components are required, consult Evaluation Data) IEC61000-4-2, -3, -4, -5, -6, -8, -11 (External component are required, consult Immunity Data) IEC/UL/CSA/EN62368-1, 60950-1, CE Mark and UKCA Mark Immunity Test Standard ESD EN61000-4-2 Radiated Susceptibility EN61000-4-3 Electrical Fast Transient Burst EN61000-4-4 Surge EN61000-4-5 Conducted Susceptibility EN61000-4-6 Magnetic Fields EN61000-4-8 Voltage Dips EN61000-4-11 2 Test Level Criteria Notes Air ± 8kV and contact ± 4kV B 80M -1GHz: 10V/m 1.4 - 2.0GHz: 3V/m A 2.0 - 2.7GHz: 1V/m ± 2kV B Normal ± 2kV B Common ± 4kV 6kV with the external surge suppressor 10Vrms A 30A/m A 30% 500ms B 60% 10ms B 100% 20ms A 100% 5000ms B PFE-SA, PFE500-F & PFE1000-FA Series Specifications Model PFE300SA PFE500SA PFE700SA PFE500F PFE1000FA Output Output Voltage Adjustment % See model selector table Switching Frequency (Main converter) kHz 12V & 28V: 230, 48V: 180 180 230 230 Line Regulation mV 12V: 48, 28V: 56, 48V: 96. The semi regulated PFE700SA output changes from 50 - 57V output(2) Load Regulation mV 12V: 48, 28V: 56, 48V: 96. The semi regulated PFE700SA output changes from 50 - 57V output(2) Ripple & Noise mV See model selector table Temperature Coefficient %/°C 0.02 Minimum Load - No minimum load required Overcurrent Protection % 105 - 140. Auto recovery on all models except PFE1000FA (Cycle AC to reset) Overvoltage Protection - 125 - 145% 60 - 69.6V 125 - 145% 125 - 145% Overtemperature Protection % / V Yes Remote Sense - No No Yes Yes Remote On/Off - No Yes: High = Output On Parallel Operation - No Yes (Droop mode) Yes (Active Mode) Yes (Active Mode) Environmental Operating Temperature (Maximum) °C -40 to +100 (Baseplate)(3) Operating Humidity (non condensing) %RH 20 - 95 Storage Temperature °C -40 to +100 Humidity (non condensing) %RH 10 - 95 Cooling - Conduction Cooled Altitude m 3048 3048 3000 3048 Withstand Voltage (For 1 minute)(4) Vac/Vdc Input to Baseplate 2,500Vac, Input to Output 3,000Vac, Output to Baseplate 1,500Vdc for 1 minute Vibration (Non operating) - 10-55Hz (Sweep for 1min.) Amplitude 0.825mm constant (Max 49.0m/s2) X,Y,Z 1 hour each Shock (Non operating) - Less than 196m/s2, 11ms, ±X, ±Y, ±Z 3 times each Other Weight (Typ) g 200 200 300 420 Size (LxWxH) mm 116.8 x 61 x 12.7 116.8 x 61 x 12.7 122 x 70 x 12.7 160 x 100 x 13.4 Size (LxWxH) Inches 4.6 x 2.4 x 0.5 4.6 x 2.4 x 0.5 4.8 x 2.76 x 0.5 6.3 x 3.94 x 0.53 MTBF - Telcordia SR-332 issue 3(5) Hours 1,641,918 1,662,809 774,640 1,512,925 Warranty yrs 5 5 2 5 Notes See website for detailed specifications, test methods and installation manual Important: External components are required for operation. See instruction manual (1) 100 / 200Vac input (2) Total regulation range (Line and Load) (3) PFE500SA-12, PFE500F-12: -40 to 85°C. PFE1000FA, PFE1000FA-48: -40 to 85°C below 170Vac input. See instruction manuals for derating curves (4) PFE500F, PFE1000FA: 500Vdc Output to baseplate (5) 40°C baseplate, Ground Benign. 100Vac input PFE-SA, PFE500-F & PFE1000-FA Series 3 PFE500F Basic connection PFE300/500SA Outline Drawing 4 PFE-SA, PFE500-F & PFE1000-FA Series PFE700SA Outline Drawing PFE500F Outline Drawing PFE-SA, PFE500-F & PFE1000-FA Series 5 PFE1000FA Outline Drawing 6 PFE-SA, PFE500-F & PFE1000-FA Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 france@fr.tdk-lambda.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 powersolutions@us.tdk-lambda.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 info.italia@it.tdk-lambda.com www.emea.lambda.tdk.com/it Netherlands info@nl.tdk-lambda.com TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 info@de.tdk-lambda.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 powersolutions@cn.tdk-lambda.com www.lambda.tdk.com.cn TDK-Lambda Singapore Pte Ltd. Austria Sales Office Tel: +43 2256 655 84 info@at.tdk-lambda.com www.emea.lambda.tdk.com/at Switzerland Sales Office Tel: +41 44 850 53 53 info@ch.tdk-lambda.com Tel: +65 6251 7211 tls.mkt@sg.tdk-lambda.com www.sg.lambda.tdk.com TDK India Private Limited, Power Supply Division Tel: +91 80 4039-0660 mathew.philip@in.tdk-lambda.com www.sg.lambda.tdk.com www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +45 8853 8086 info@dk.tdk-lambda.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 info@uk.tdk-lambda.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 info@tdk-lambda.co.il www.emea.lambda.tdk.com/il C.I.S. Commercial Support: Tel: +7 (495) 665 2627 Technical Support: Tel: +7 (812) 658 0463 info@tdk-lambda.ru www.emea.lambda.tdk.com/ru PFE-SA, PFE500F_260867_March 24th, 2022 V1 For Additional Information, please visit https://product.tdk.com/en/power/ PFE-SA, PFE500-F & PFE1000-FA Series 7
PFE1000FA-12 价格&库存
很抱歉,暂时无法提供与“PFE1000FA-12”相匹配的价格&库存,您可以联系我们找货
PFE1000FA-12
  • 1+3510.23560
库存:5
PFE1000FA-12
  • 1+5653.814191+733.76189
  • 10+5481.2358610+711.36437
库存:207
