PH300S280-12
PH300S280-12
    TDK(东电化)
    PH300S280-12
PH300S280-12 数据手册
PH-S Series Simple function, 50 to 600W DC-DC converters Features  High Density  Wide Range Input  Output adjustment Capability  Remote On/Off  Fixed Switching Frequency  International Safety Approvals  Low component count Key Market Segments & Applications Specifications Model Input range Output Voltage Adj. Range Line Regulation Load Regulation Ripple and Noise Series Operation Over Voltage Protection Overload Protection Remote On/Off Remote Sensing Parallel operation Inverter Good signal Thermal Protection Cooling Operating Temperature Range Storage Temperature Temperature Coefficient Isolation Isolation Resistance Safety Agency Certification (1) Warranty 3.3V 5V 12V 15V 24V 28V 48V VDC 24V nom: 18-36, 48V nom: 36-76V, 110V nom: 82-185V, 280V nom: 200-400V VDC 2.97~3.63 4.5~5.5 10.8~13.2 13.5~16.5 21.6~26.4 25.2~30.8 43.2~52.8 0.4% or 20mV (whichever is greater) over entire input range with constant load 0.8% or 40mV (whichever is greater) from no load to full load with constant input line pk-pk 100mV 150mV 240mV 280mV 480mV Possible - Refer to installation manual % 150 - 180% 125 - 145% % Approximately 105 - 140%, automatic recovery Low = ON, Open = OFF PH100S, PH150S, PH300S, PH600S models PH300S & PH600S only: Requires external circuitry PH300S & PH600S only: Signal available for status of inverter Internal sensing, self resetting Conduction or forced air. See application notes for cooling and heatsink selection °C Baseplate temperature -20°C to +85°C (100°C on PH300 & PH600). -40°C start up possible - consult factory °C -40°C to +85°C (+100°C on PH300 & PH600) 0.02%/°C Input to output: 3000VAC, Input to Baseplate: 2500VAC(1) Output to Baseplate -100MOhm at 500VDC and 70%RH UL60950-1, CSA60950-1, EN60950-1 and CE Mark. yrs Two years Note: See Installation Manual for full details, test methods of parameters and application notes (1) No safety certification on PH50S48-3.3, PH75S48-3.3, PH150S48-3.3 Obsolete, except PH300S280 which has a last time buy of June 2018 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 155 Disclaimer: us.tdk-lambda.com/lp/legal.htm PH-S Series Model Selector Nominal Output Voltage (V) 3.3 3.3 3.3 3.3 3.3 3.3 5.0 5.0 5.0 5.0 5.0 5.0 12.0 12.0 12.0 12.0 12.0 12.0 15.0 15.0 15.0 15.0 15.0 15.0 24.0 24.0 24.0 24.0 24.0 24.0 28.0 28.0 28.0 28.0 28.0 28.0 48.0 48.0 Output Current (A) 10.0 15.0 20.0 30.0 50.0 100.0 10.0 15.0 20.0 30.0 50.0 100.0 4.2 6.3 8.4 12.5 25.0 50.0 3.4 5.0 6.7 10.0 20.0 40.0 2.1 3.2 4.2 6.3 12.5 25.0 1.8 2.7 3.6 5.4 10.8 21.5 6.3 12.5 Output Power (W) 33.0 49.5 66.0 99.0 165.0 330.0 50.0 75.0 100.0 150.0 250.0 500.0 50.0 75.0 100.0 150.0 300.0 600.0 50.0 75.0 100.0 150.0 300.0 600.0 50.0 75.0 100.0 150.0 300.0 600.0 50.0 75.0 100.0 150.0 302.0 602.0 302.0 600.0 Pinout Pin Description -Vin +Vin +S -S +V -V IOG TRIM CNT CS 24V input 48V input 110V input 280V input PH50S24-5 PH50S24-12 PH50S24-15 PH50S24-24 PH50S24-28 - PH50S48-3.3 PH75S48-3.3 PH100S48-3.3 PH150S48-3.3 PH50S48-5 PH75S48-5 PH100S48-5 PH150S48-5 PH50S48-12 PH75S48-12 PH100S48-12 PH150S48-12 PH50S48-15 PH75S48-15 PH100S48-15 PH150S48-15 PH50S48-24 PH75S48-24 PH100S48-24 PH150S48-24 PH50S48-28 PH75S48-28 PH100S48-28 PH150S48-28 - PH50S110-5 PH75S110-5 PH150S110-5 PH50S110-12 PH75S110-12 PH150S110-12 PH50S110-15 PH75110-15 PH150S110-15 PH50S110-24 PH75S110-24 PH150S110-24 PH50S110-28 PH75S110-28 PH150S110-28 - PH50S280-3.3 PH75S280-3.3 PH100S280-3.3 PH150S280-3.3 PH300S280-3.3 PH600S280-3.3 PH50S280-5 PH75S280-5 PH100S280-5 PH150S280-5 PH300S280-5 PH600S280-5 PH50S280-12 PH75S280-12 PH100S280-12 PH150S280-12 PH300S280-12 PH600S280-12 PH50S280-15 PH75S280-15 PH100S280-15 PH150S280-15 PH300S280-15 PH600S280-15 PH50S280-24 PH75S280-24 PH100S280-24 PH150S280-24 PH300S280-24 PH600S280-24 PH50S280-28 PH75S280-28 PH100S280-28 PH150S280-28 PH300S280-28 PH600S280-28 PH300S280-48 PH600S280-48 Other DC-DC Products Function Negative Input Terminal Positive Input Terminal Positive Remote sense Negative Remote sense Positive Output Terminal Negative Output Terminal Inverter Good Signal Output adjustment trim pin On/Off Control Terminal Current Monitor Signal PH Full Function PAQ, PAH, PAF PX CC-E 50 - 300W, full function versions of PH 50 - 700W quarter, half & full bricks 10-40W, 12-48V input, DC-DC 1.5-30W, 5-48V input, DC-DC For Additional Information, please visit us.tdk-lambda.com/lp/products/ph-series-sf.htm Obsolete, except PH300S280 which has a last time buy of June 2018 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 156 Revision B4: Jun 2017
PH300S280-12 价格&库存
很抱歉,暂时无法提供与“PH300S280-12”相匹配的价格&库存,您可以联系我们找货
