PH600A280-24
PH600A280-24
    TDK(东电化)
    半砖
    隔离模块 直流转换器 1 输出 24V 25A 200V - 425V 输入
PH600A280-24 数据手册
PH-A280 Series 50W to 600W, 200 to 425VDC Input DC-DC Converters www.us.tdk-lambda.com/lp/products/pha-series www.emea.lambda.tdk.com/ph-a The PH-A280 series of isolated DC-DC converters operate from a wide range 200 to 425Vdc input and are available in multiple power levels from 50 to 600W. Output voltages cover 3.3V to 48V and can be adjusted using the trim terminal by up to -60% to +20%. All models feature remote sense and remote on/off and can be conduction cooled to a cold plate or mounted with an optional heatsink. The 300 and 600W models are certified to EN 62477-1 (OVC III) for use in industrial robots connected to an incoming distribution panel, avoiding the requirement for an isolation transformer. These efficient converters are also well suited for HVDC (High Voltage Direct Current) power transmission systems and renewable energy applications. Features Benefits • Wide Range 200 to 425Vdc Input • Suitable for HVDC Applications • Baseplate Cooled • Can be Conduction or Convection Cooled (With an Optional Heatsink) • -40 to 100 C Baseplate Temperature • Operates in Harsh Environments • Certified to IEC/EN62477-1 (OVC III) • No External Transformer Needed • Up to 93% Efficient • Easier To Cool In the End System o Model Selector Model PH75A280-3.3 PH100A280-3.3 PH50A280-5 PH75A280-5 PH100A280-5 PH300A280-5 PH50A280-12 PH75A280-12 PH100A280-12 PH150A280-12 PH300A280-12 PH75A280-15 PH150A280-15 PH50A280-24 PH75A280-24 PH100A280-24 PH150A280-24 PH300A280-24 PH600A280-24 PH75A280-28 PH150A280-28 PH300A280-28 PH50A280-48 PH75A280-48 PH100A280-48 PH150A280-48 PH300A280-48 Output Voltage (V) Adjustment Range (V) Maximum Current (A) Maximum Power (W) Input Current (A) 280V input, 100% load Efficiency (%) 280V input, 100% load Overvoltage Protection (%) (2) 3.3 3.3 5 5 5 5 12 12 12 12 12 15 15 24 24 24 24 24 24 28 28 28 48 48 48 48 48 2.97 - 3.96 2.97 - 3.96 4-6 4-6 4-6 2.5 - 6 9.6 - 13.2 9.6 - 13.2 9.6 - 13.2 9.6 - 13.2 4.8 - 14.4 12 - 16.5 12 - 16.5 19.2 - 26.4 19.2 - 26.4 19.2 - 26.4 19.2 - 26.4 9.6 - 28.8 14.4 - 28.8 22.4 - 30.8 22.4 - 30.8 11.2 - 33.6 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 38.4 - 52.8 19.2 - 57.6 15 20 10 15 20 60 4.2 6.3 8.4 12.5 25 5 10 2.1 3.2 4.2 6.3 12.5 25 2.7 5.4 10.8 1.1 1.6 2.1 3.2 6.3 49.5 66 50.0 75.0 100.0 300.0 50.4 75.6 100.8 150.0 300.0 75.0 150.0 50.4 76.8 100.8 151.2 300.0 600.0 75.6 151.2 302.4 52.8 76.8 100.8 153.6 302.4 0.22 0.29 0.21 0.32 0.42 1.22 0.2 0.31 0.41 0.62 1.22 0.3 0.6 0.2 0.31 0.4 0.61 1.2 2.33 0.3 0.61 1.2 0.21 0.31 0.4 0.6 1.19 83 83 86 86 86 89 89 89 89 88 89 90 90 89 90 90 89 90.5 93 90 90 91 89 90 90 90 92 130 - 200 130 - 200 125 - 150 125 - 150 125 - 150 125 - 145 115 - 145 115 - 145 115 - 145 115 - 145 125 - 145 115 - 145 115 - 145 115 - 145 115 - 145 115 - 145 115 - 145 125 - 145 125 - 145 115 - 145 115 - 145 125 - 145 115 - 145 115 - 145 115 - 145 115 - 145 125 - 145 PH-A280 Series 1 Options Suffix Heat Sink Accessories Description Suffix Description Blank M3 tapped mounting inserts HAQ-10T PH50A to 150A 25mm transverse fins /T 3.3mm non-threaded inserts HAH-10T PH300A and 600A 25mm transverse fins HAH-15L PH300A and 600A 38mm longitudinal fins Specifications Model Input Input Voltage range Input Current (280Vdc) No Load Power Consumption Efficiency (280Vdc) Safety Agency Certifications Output Line Regulation Load Regulation Ripple & Noise Temperature Coefficient Minimum Load Overcurrent Protection Overvoltage Protection Remote Sense Remote On/Off Parallel Operation Series Operation Environmental Operating Temperature Storage Temperature Humidity (non condensing) Cooling Altitude Withstand Voltage (For 1 minute) Isolation Resistance Vibration Shock Other Weight (Typ) Size (WxHxD) Size (WxHxD) MTBF - Telcordia SR-332 issue 3 (3) Warranty PH50A to PH150A PH300A to PH600A Vdc A W - 200 - 425V See model selector See evaluation data on website See model selector IEC/UL/CSA/EN62368-1, 60950-1, EN62477-1 OVC III (PH300A and 600A only), CE Mark (LVD and RoHS) mV mV mV %/°C V - 3.3V - 5V: 10mV; 12V: 24mV; 15V: 30mV, 24V: 48mV, 28V: 56mV, 48V: 96mV 3.3V - 5V: 10mV; 12V: 24mV; 15V: 30mV, 24V: 48mV, 28V: 56mV, 48V: 96mV 3.3V - 5V: 100mV; 12V - 15V: 150mV; 24V: 240mV, 28V: 280mV, 48V: 400mV (1) 0.02%/oC No minimum load required 102 - 150% Constant current style. (PH600A constant current and hiccup) Yes, see model selector Yes Yes; Low = ON, High = OFF Not possible Possible, see installation manual °C °C %RH m VAC MΩ - -40°C to +100°C Base-plate, -40°C to +85°C Ambient (See derating section) -40°C to +100°C 5 - 95% RH Operating and Non Operating Conduction, convection or forced air (See Installation Manual for heatsink selection) 3,000m Input to Base-plate: 2.5kVAC; Input to Output 3.0kVAC; Output to Base-plate: 500VAC >100MΩ at 25°C, 70%RH & 500VDC Non Operating, 10-55Hz (sweep for 1 min.) Amplitude 0.825mm constant (Max 49 m/s2) X,Y,Z 1 hour each 196.1m/s2 g mm Inches Hours yrs 55 37.2 x 12.7 x 58.3 1.46 x 0.5 x 2.30 2 128,235 100 61.0 x 12.7 x 57.9 2.4 x 0.5 x 2.28 1,174,511 5 years Notes See website for detailed specifications, test methods and installation manual (1) PH300A280-48 480mV (2) Cycle input or remote on/off to reset (3) PH100A280-48 model, 40°C baseplate, full load, 280Vdc input. PH300A280-24 model, 40°C baseplate, full load, 280Vdc input, ground benign (See full reliability data on website) 2 PH-A280 Series Derating Curve (PH50A to PH300A) Derating Curve (PH600A) PH-A280 Series 3 Outline Drawing PH50A to PH150A Outline Drawing PH300A to PH600A 4 PH-A280 Series www.us.tdk-lambda.com/lp/products/pha-series www.emea.lambda.tdk.com/ph-a CUS30-60M Dec 20th, 2019 v1.4 10 PH-A280 Series
PH600A280-24 价格&库存
很抱歉,暂时无法提供与“PH600A280-24”相匹配的价格&库存,您可以联系我们找货
PH600A280-24
  • 1+2382.995101+308.68121
  • 10+2256.7504810+292.32812
  • 25+2208.2396425+286.04427
