P i e z o H a p t TM A c t u a t o r s
May 2020
PiezoHaptTM Actuators
For general use
PHU series
PHUA8060-35A-33-000
PHUA3015-30A-21-000
(2/8)
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
In use of this product, it should be minded by notes and please perform a safety design, after checking the individual standard for every unit
enough.
Do not apply DC bias to the product. In addition, the insulation resistance may be reduced and the function may not be performed.
Use piezoelectric devices so that moisture-containing substances and water droplets do not come into contact with each other.
There is a risk of performance degradation, adhere to the following matters.
Store the product in a packaged condition to avoid sudden temperature changes, condensation, direct sunlight, corrosive gas, dust, and dust.
Use within six months.
Do not apply strong shocks (fall etc.) or pressure by which a crack goes into a product.
Do not supply any voltage higher than applicable to the product.
Do not use the piezoelectric buzzer outdoors. It is designed for indoor use.
Do not apply the temperature more than 150°C.
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
Do not wash the product in such a way that solvent or gas can penetrate the product.
Handle piezoelectric devices with care so that they do not touch them by hand. It can cause corrosion and the charge being charged may be
discharged to the hands.
Discharge the product before connecting it to the measuring instrument.
Do not remove the piezoelectric element from the diaphragm.
When soldering, be careful not to attach flux or other foreign matter to the piezoelectric device.
When soldering a terminal pin, perform the soldering in clean conditions without contamination or rust in order to avoid poor connections.
Check the resonant frequency in the mounting condition, and use the product within the range where the resonant frequency is not affected by
the resonance with a reference value of 1/2 or less of the resonant frequency.
When fixing the product by adhesion, etc., investigate the type, amount, adhesion, etc. of the adhesive, conduct a reliability evaluation test,
and confirm that there are no abnormalities.
Do not use the product on a device that allows consumers to touch the product.
Do not rework the product.
The characteristics may vary depending on the shape and location of the mounting part. Check the mounted condition.
Please take appropriate measures such as acquiring protective circuits and devices that meet the uses, applications, and conditions of the
instruments and keeping backup circuits.
We are not liable for any damage caused by the use of equipment (automobiles, aircraft, medical equipment, nuclear power equipment, etc.)
that requires high safety and reliability, or that may cause damage to human life, body, property, etc., or that may have a significant social
impact due to a product failure, malfunction, or failure, as well as the use of the product beyond the scope and conditions of this catalog.
Do not use it in the following environments
・Corrosive gases (Cl2, NH3, H2S, SOx, NOx, etc.)
・Environments with highly conductive substances (electrolytes, water, saltwater, etc.)
・Environments with acid, alkali, or organic solvents
・Places to be exposed to dust.
20200515 / piezohapt_commercial_phu_en.fm
(3/8)
Product compatible with RoHS directive
PiezoHaptTM actuators
For general use
Overview of the PHU series
FEATURES
It is thin and can support various application.
It is possible to obtain a clear response by low-voltage drive.
It answers in an instant and can respond to a variegated vibration pattern (vibrational frequency).
APPLICATION
Touchpad, displays, amusement equipment, game controller, wearable devices etc.
DRIVE CIRCUIT BLOCK DIAGRAM EXAMPLE
Discrete
Micro-computer
Circumference control
(SW/ LED/ LCD)
Profit adjustment
circuit
AMP
PiezoHapt
Boost circuit
(3V→12V : PHUA3015-30A-21-000)
(3V→24V : PHUA8060-35A-33-000)
Haptic driver IC
Micro-computer
Haptic
driver IC
PiezoHapt
(SW/ LED/ LCD)
RoHS Directive Compliant Product: See the following for more details. https://product.tdk.com/info/en/environment/rohs/index.html
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/8)
PART NUMBER CONSTRUCTION
PHU
Series name
A
B
A
8060
Application
External vibration
plate
dimensions
(L×W)
For general use
For automotive
8060
3015
80×60mm
30×15mm
35
A
Total thickness
35
30
0.35mm
0.30mm
Type
A
42Ni-Fe + FPC
33
External
piezoelectric
element
dimensions
(L×W)
33
30×30mm
21
20×10mm
000
Internal
code
PRODUCT LINEUP
SPECIFICATIONS
Part No.
Dimensions
PHUA8060-35A-33-000
PHUA3015-30A-21-000
Vibration plate
(mm)
80×60×0.25
30×15×0.1
Element
(mm)
30×30×0.1
20×10×0.2
Vibration plate specifications
42Ni-Fe
42Ni-Fe
Electrode specification
FPC
FPC
PHUA8060-35A-33-000
PHUA3015-30A-21-000
Wearable devices
Operation voltage
Touchpad
Displays
24VP-P(±12V)max.
12VP-P(±6V)max.
Operating temperature range
–10 to +60°C
–10 to +60°C
CHARACTERISTICS
Part No.
Application
(5/8)
PHUA8060-35A-33-000
APPLICATION
Suitable for touch panel and display.
SHAPE & DIMENSIONS
RECOMMENDED WIRING
(0.4)
9.7 10.6 9.7
5±1.0
C385-01-001
2.5
30
80
30
60
Dimensions in mm
・Product shape are subject to change without notice.
SPECIFICATIONS
FPC
Width
Number of cores
Electrode
Insulation length
specification
Lead pitch
Stripping length
Reinforcement
Operation voltage
42Ni-Fe
12mm
2
30mm
7.0mm
5.0mm
8.0mm
24VP-P(±12V)max.
–10 to +60°C
(6/8)
PHUA8060-35A-33-000
PACKAGING STYLE/PACKING NUMBER/MINIMUM ORDERING UNIT
PHUA8060-35A-33-000
Packaging style
Packing number
Minimum ordering unit
Bulk (Tray)
200 pieces / corrugated cardboard
(20 trays containing 10 pieces)
200 pieces
(1 boxes of corrugated cardboard containing 200 piece)
Tray
350±1
R1
257±1
80.5
15
4-
P55x3=165
260±1
Y
P83.5x2=167
P64x4=256
X
2.3
X
64
0.5
Y
UNDER STACKS
DEPTH 4
347±1
1
60.5
4.75
12.75
7.5
8
6.5
(7/8)
PHUA3015-30A-21-000
APPLICATION
Suitable for small equipment such as wearable devices.
SHAPE & DIMENSIONS
RECOMMENDED WIRING
30.0
10.0
5±1.0
23.5
15.0
20.0
Dimensions in mm
SPECIFICATIONS
Insulation specifications
FPC
Width
Number of cores
Electrode
Insulation length
specification
Lead pitch
Stripping length
Reinforcement
Operation voltage
42Ni-Fe
Without insulation
12mm
2
14.5mm
7.0mm
5.0mm
8.0mm
12VP-P(±6V)max.
–10 to +60°C
(8/8)
PHUA3015-30A-21-000
PHUA3015-30A-21-000
Packaging style
Packing number
Bulk (Tray)
1200 pieces / corrugated cardboard
(20 trays containing 60 pieces)
1200 pieces
(1 boxes of corrugated cardboard containing 1200 piece)
Tray
350±1
P32x9=288
R1
Y
X
Y
7
X
P60x4=240
30.5
14
254±1
P60x3=180
260±1
P39.5x5=197.5
4-
0.5
UNDER STACKS
DEPTH 4
1
8
344±1
4.75
15.5
12.75
7.5
8
7
