I N D U C T O R S
Inductors for power circuits
Thin-film metal magnetic material
PLE series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
PLEA67BBA type
FEATURES
Thin-film power inductor based on the thin-film processing techniques and metallic magnetic materials.
Due to the high magnetic permeability magnetic material, it has both high inductance of 2.2uH and low DC resistance in spite of its
small size of 1006 (L1.0xW0.6xT0.7mm).
The low-loss magnetic material makes it possible to achieve low AC loss and provide a highly efficient power supply circuit in solutions
that emphasize AC loss.
APPLICATION
Wearable product (wireless earphones and smart watch), small power supply module and low power consumption communication
module of Bluetooth Low Energy
Application guides: Smart phones/tablets
PART NUMBER CONSTRUCTION
PLE
A67
BBA
Series name
L×W×H dimensions
1.0x0.6x0.7 mm
Characteristic
type
2R2
M
Inductance
(µH)
Inductance
tolerance
1P
T
00
Number of
lines
Packaging
style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
L measuring
frequency
Rated current
DC resistance
Isat
Itemp
(µH)
Tolerance (MHz)
(m )max. (m )typ.
(A)max.
(A)typ.
(A)max.
2.2
±20%
1.0
620
510
0.5
0.6
0.5
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
(A)typ.
0.8
PLEA67BBA2R2M-1PT00
Measurement equipment
Measurement item
Product No.
L
E4991
DC resistance
4338A
Rated current Isat
E4991+16200B
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating temperature range
Storage temperature range
–40 to +125 °C
–40 to +85 °C
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
Individual weight
3 mg
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20210114
inductor_commercial_power_plea67bba_en.fm
I N D U C T O R S
PLEA67BBA type
L FREQUENCY CHARACTERISTICS
4
Inductance(nH)
3
2
1
10
100
1000
Frequency(MHz)
Product No.
Manufacturer
E4991
INDUCTANCE VS. DC BIAS CHARACTERISTICS
2.5
Inductance(µH)
2
1.5
1
0.5
0.2
0.3
0.4
0.5
DC current(A)
0.6
0.7
0.8
0.9
Product No.
Manufacturer
E4991+16200B
(2/4)
20210114
I N D U C T O R S
PLEA67BBA type
SHAPE & DIMENSIONS
PACKAGING STYLE
0.60max.
0.80max.
REEL DIMENSIONS
ø60min.
1.0
0.60±0.10
1.00±0.10
2.0±0.5
9.0±0.3
ø13±0.2
14.4max.
ø21±0.8
0.20±0.10
ø180±2.0
Dimensions in mm
Dimensions in mm
1.5 +0.1
–0.0
2.0±0.05
4.0±0.1
0.31
0.58
8.0±0.2
B
0.32
RECOMMENDED LAND PATTERN
3.5±0.05
Sprocket
hole
1.75±0.1
TAPE DIMENSIONS
A
K
0.31
Cavity
2.0±0.05
Dimensions in mm
Dimensions in mm
Type
PLEA67
160min.
A
0.76
Taping
B
1.22
K
0.98
100 to 200min.
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Drawing direction
400 or over
Peak
Dimensions in mm
245°C
PACKAGE QUANTITY
Temperature
230°C
230°C
Package quantity
5000 pcs/reel
180°C
5s max.
150°C
60 to 120s
10 to 30s
Time
(3/4)
20210114
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20210114
PLEA67BBA2R2M-1PT00 价格&库存
很抱歉,暂时无法提供与“PLEA67BBA2R2M-1PT00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+3.16796
- 100+2.59844
- 500+2.44419
- 1000+2.08824
- 2500+1.95773
- 5000+1.82721
- 国内价格 香港价格
- 1+3.580101+0.45600
- 10+2.9737010+0.37870
- 100+2.43730100+0.31040
- 500+2.27400500+0.28960
- 1000+1.959101000+0.24950
- 5000+1.714305000+0.21830
- 国内价格 香港价格
- 5000+1.775385000+0.23072
- 10000+1.6743110000+0.21758
- 15000+1.6179615000+0.21026
- 25000+1.5497225000+0.20139
- 35000+1.5221535000+0.19781
- 国内价格 香港价格
- 1+3.702691+0.48118
- 10+3.0709910+0.39909
- 100+2.52285100+0.32785
- 1000+2.074721000+0.26962
- 国内价格
- 5+2.00448
- 50+1.65262
- 150+1.50185
- 500+1.31382
- 2500+1.23002
- 5000+1.17980
- 国内价格
- 1+1.36400
- 100+1.05710
- 1250+0.88000
- 2500+0.80080
- 5000+0.74250
