PSS34812/S
PSS34812/S
    TDK(东电化)
    PSS34812/S
PSS34812/S 数据手册
PSS/PSD Series Ultra Compact, 1.5W to 12W Single and Dual DC-DC Converters Features u Compact Footprint / Low Profile u Through Hole or SMT Versions u 5V, 12V, 24V & 48V Inputs u 3.3 to 30V* Single, ±12 to 15V Dual Outputs u Output Voltage Adjustment u Input - Output Isolation u RoHS Compliant Design u 5 Year Warranty u Self contained u Multiple Input Voltage configurations u Open frame (no potting) Key Market Segments & Applications Specifications Model DC Input Efficiency Output Voltage Accuracy Output Adjustment Line Regulation Load Regulation Temperature Coefficient Preload Output Ripple Overcurrent Protection Overvoltage protection Remote On/Off (1) Operating Temp. - Convection Operating Temp. - Forced Air Storage Temperature Humidity (Non condensing) Isolation Voltage Isolation Resistance Shock Vibration (non operating) Weight Size (L”x W”x H”) (Through hole and SMT package) Warranty 3.3V V % V mV mV %/ °C mV °C m/s2 in yrs 5V 12/15V (24/30V)* 5V: 4.5-9.0V, 12V: 9-18V, 24V: 18-36V, 48V: 36-76V 73 to 84% model dependant ±5% 2.84V-3.67V 4.3V-6V 12V-15V (24-30V)* PSS: 20mV, PSD: 40mV PSS: 40mV, PSD: 600mV 100M at 25°C and 70%RH, 500VDC Output-Chassis 196.1m/s2 10-55-10Hz (sweep for 1 min.) 0.825mm constant (Max 147m/s2) 1 hour X, Y, Z PS1R5: 4g, PS3: 5g, PS6: 8g, PS10:14g PSS/PSD1R5: 0.79 x 0.63 x 0.31; PSS/PSD3: 1.02 x 0.63 x 0.31 PSS/PSD6: 1.12 x 0.8 x 0.31, PSS10: 1.59 x 0.866 x 0.31 Five Years Note: See Installation Manual for full specifications, test methods of parameters and application notes * For 24/30V output use PSD models - connect across +Vout & -Vout and leave “common” pin not connected (1) Not available on PS1R5 Not Recomended For New Designs 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 13 Disclaimer: us.tdk-lambda.com/lp/legal.htm PSS/PSD Series Model Selector Output Output Max Output Voltage (V) Current (A) Power (W) Single Outputs 3.3 0.4 1.32 3.3 0.6 1.98 3.3 1.2 3.96 3.3 1.5 4.95 3.3 2.0 6.6 3.3 2.5 8.25 5.0 0.3 1.5 5.0 0.6 3.0 5.0 1.0 5.0 5.0 1.2 6.0 5.0 1.6 8.0 5.0 2.0 10.0 12 (15) 0.125 (0.1) 1.5 12 (15) 0.25 (0.2) 3.0 12 (15) 0.5 (0.4) 6.0 12 (15) 0.7 (0.56) 8.4 12 (15) 1.0 (0.8) 12.0 Dual Outputs ±12(15)* ±0.065 (0.052) 1.44 ±12(15)* ±0.13 (0.1) 3.0 ±12(15)* ±0.25 (0.2) 6.0 ±12(15)* ±0.35 (0.28) 8.4 ±12(15)* ±0.50 (0.40) 10.8 5V Input 12V Input 24V Input 48V Input PSS1R5-5-3R3 PSS3-5-3R3 PSS6-5-3R3 PSS1R5-12-3R3 PSS3-12-3R3 PSS1R5-24-3R3 PSS3-24-3R3 PSS1R5-48-3R3 PSS3-48-3R3 PSS6-12-3R3 PSS10-12-3R3 PSS6-24-3R3 PSS6-48-3R3 PSS1R5-12-5 PSS3-12-5 PSS6-12-5 PSS10-24-3R3 PSSIR5-24-5 PSS3-24-5 PSS6-24-5 PSS10-48-3R3 PSS1R5-48-5 PSS3-48-5 PSS6-48-5 PSS10-12-5 PSS1R5-12-12 PSS3-12-12 PSS6-12-12 PSS10-24-5 PSS1R5-24-12 PSS3-24-12 PSS6-24-12 PSS10-48-5 PSS1R5-48-12 PSS3-48-12 PSS6-48-12 PSS10-12-12 PSS10-24-12 PSS10-48-12 PSD1R5-12-1212 PSD3-12-1212 PSD6-12-1212 PSD1R5-24-1212 PSD3-24-1212 PSD6-24-1212 PSD1R5-48-1212 PSD3-48-1212 PSD6-48-1212 PSD10-12-1212 PSD10-24-1212 PSD10-48-1212 PSS10-5-3R3 PSS1R5-5-5 PSS3-5-5 PSS6-5-5 PSS10-5-5 PSS1R5-5-12 PSS3-5-12 PSS6-5-12 PSS10-5-12 PSD1R5-5-1212 PSD3-5-1212 PSD6-5-1212 PSD10-5-1212 PSS1R5 Outline Drawing PSS1R5/S Outline Drawing Options Other Industrial Products Suffix Blank /S Description Through hole mounting Surface mount X PX PAQ, PAH, PAF 10 - 20W, 24 & 48V input DC-DC converters 10 - 40W 12, 24, 48V DC-DC converters 50 -700W quarter, half & full bricks For Additional Information, please visit us.tdk-lambda.com/lp/products/ps-series.htm 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 14 Revision A5: May 2012
PSS34812/S 价格&库存
很抱歉,暂时无法提供与“PSS34812/S”相匹配的价格&库存,您可以联系我们找货
