• SIP Style Footprint
• 5V, 12V, 24V, & 48V Inputs
• Single and Dual Outputs
• Adjustable Output Voltages
• Input - Output Isolation
Key Market Segments & Applications
Telecom
& Datacom
Test & Measurement
Test
and
Measurement
Automated
Service
Factory
Point
of Automation
Load
General Purpose
LED Lighting & Display
PV Series
Single Inline Package
DC-DC Converters (1-3 Watts)
PV Features and Benefits
Features
Benefits
• Single Inline Package (SIP)
• Wide Input Voltage Range
• Isolated Output
• Wide Operating Temperature Range
• Uses Less PCB Area
• Accepts Unregulated Input Voltages
• Can Be Configured for + or - Outputs
• Supports Harsh Operating Environments
Specifications
Output Volt.
ITEMS
DC Input ranges
Efficiency (typical)
Output Voltage Accuracy
Output Voltage Adjustment
Preload
Ripple & Noise
Max Line Regulation
Max Load Regulation
Overcurrent Protection
Overvoltage Protection
Temperature Coefficient
Cooling
Isolation Voltage
Isolation Resistance
Shock
Vibration
Humidity (non condensing)
Storage Humidity
Operating Temp. Range
Storage Temperature
Weight (Typ)
Size (LxWxH)
Warranty
VDC
VDC
A
mV
mV
mV
A
VAC
Ohm
°C
g
mm
3.3V
5V
12V
5V: 4.5V-9V; 12V: 9V-18V, 24V: 18V-36V, 48V: 36V-72
77%
±5%
3.3V-3.67V
5V-6V
12V-15V
100mV
120mV
20mV
40mV
Auto recovery (1)
None
0.02%/°C
Convection cooled
Input-Output: 500VAC 1 min. (5mA)
Greater than 100M
20G
10-55Hz (sweep for 1 min.) 1.5mm constant amplitude max 9G X,Y,Z 2 hours each
30%-90% RH (non condensing)
10%-95% RH (non condensing)
-20 to 70°C, derate linearly to 50% load from 50 to 70°C
-30°C to +85°C
5
28.5x18x8.5(PV1R5); 33x18x8.5 (PV3)
2 years
Note: See Installation Manual for full details, test methods of parameters and application notes
1) Avoid operation in short circuit or overload for more than 30 seconds
PV Series
1
Model Selector
Model
Output
Voltage (V)
Output
Current (A)
Output
Power (W)
Input
Voltage (V)
Single Output
PV1R5-5-3.3
PV1R5-48-3.3
PV3-5-3.3
PV3-48-3.3
PV1R5-5-5
PV1R5-12-5
PV1R5-24-5
PV1R5-48-5
PV3-5-5
PV3-12-5
PV3-24-5
PV3-48-5
PV1R5-5-12
PV3-5-12
3.3
3.3
3.3
3.3
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
12.0
12.0
0.4
0.4
0.6
0.6
0.3
0.3
0.3
0.3
0.6
0.6
0.6
0.6
0.125
0.25
1.3
1.3
2.0
2.0
1.5
1.5
1.5
1.5
3.0
3.0
3.0
3.0
1.5
3.0
5.0
48.0
5.0
48.0
5.0
12.0
24.0
48.0
5.0
12.0
24.0
48.0
5.0
5.0
±12.0
±12.0
±12.0
±12.0
±12.0
±12.0
±12.0
±12.0
0.06
0.06
0.06
0.06
0.125
0.125
0.125
0.125
1.44
1.44
1.44
1.44
3.0
3.0
3.0
3.0
5.0
12.0
24.0
48.0
5.0
12.0
24.0
48.0
Dual Outputs
PVD1R5-5-1212
PVD1R5-12-1212
PVD1R5-24-1212
PVD1R5-48-1212
PVD3-5-1212
PVD3-12-1212
PVD3-24-1212
PVD3-48-1212
PIN Assignments
Pin Description
Function
-Vin
+Vin
+Vout
-Vout
NC
COM
TRM
Negative Input Terminal
Positive Input Terminal
Positive Output Terminal
Negative Output Terminal
No connection
Common
Trim
2
PV Series
Outline Drawing PV1R5 Series
Outline Drawing PVD1R5 Series
Outline Drawing PV3 Series
Outline Drawing PVD3 Series
PV Series
3
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
For Additional Information, please visit
https://product.tdk.com/en/power/
PV June11 v2
4
PV Series
很抱歉,暂时无法提供与“PV3-24-5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+165.737581+19.96508
