PVD3-24-1212
PVD3-24-1212
    TDK(东电化)
    SIP9 模块
    隔离模块 直流转换器 2 输出 12V -12V 125mA,125mA 18V - 36V 输入
PVD3-24-1212 数据手册
Model Selector Model Output Voltage (V) Output Current (A) Output Power (W) Input Voltage (V) Single Output PV1R5-5-3.3 PV1R5-48-3.3 PV3-5-3.3 PV3-48-3.3 PV1R5-5-5 PV1R5-12-5 PV1R5-24-5 PV1R5-48-5 PV3-5-5 PV3-12-5 PV3-24-5 PV3-48-5 PV1R5-5-12 PV3-5-12 3.3 3.3 3.3 3.3 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 12.0 12.0 0.4 0.4 0.6 0.6 0.3 0.3 0.3 0.3 0.6 0.6 0.6 0.6 0.125 0.25 1.3 1.3 2.0 2.0 1.5 1.5 1.5 1.5 3.0 3.0 3.0 3.0 1.5 3.0 5.0 48.0 5.0 48.0 5.0 12.0 24.0 48.0 5.0 12.0 24.0 48.0 5.0 5.0 ±12.0 ±12.0 ±12.0 ±12.0 ±12.0 ±12.0 ±12.0 ±12.0 0.06 0.06 0.06 0.06 0.125 0.125 0.125 0.125 1.44 1.44 1.44 1.44 3.0 3.0 3.0 3.0 5.0 12.0 24.0 48.0 5.0 12.0 24.0 48.0 Dual Outputs PVD1R5-5-1212 PVD1R5-12-1212 PVD1R5-24-1212 PVD1R5-48-1212 PVD3-5-1212 PVD3-12-1212 PVD3-24-1212 PVD3-48-1212 PIN Assignments Pin Description Function -Vin +Vin +Vout -Vout NC COM TRM Negative Input Terminal Positive Input Terminal Positive Output Terminal Negative Output Terminal No connection Common Trim 2 PV Series Outline Drawing PV1R5 Series Outline Drawing PVD1R5 Series Outline Drawing PV3 Series Outline Drawing PVD3 Series PV Series 3 TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ PV April 2023 v3 4 PV Series
PVD3-24-1212
1. 物料型号:PV系列,包括PV1R5和PV3型号,提供单输出和双输出版本。
2. 器件简介:PV系列是单列直插式封装的DC-DC转换器,适用于1-3瓦特的功率需求。
3. 引脚分配: - -Vin:负输入端 - +Vin:正输入端 - +Vout:正输出端 - -Vout:负输出端 - NC:无连接 - COM:共用端 - TRM:调节端
4. 参数特性: - 输入电压范围:5V、12V、24V、48V - 输出电压可调范围:3.3V-3.67V、5V-6V、12V-15V - 效率(典型值):77% - 输出电压精度:±5% - 预载:0A - 纹波和噪声:100mV-120mV - 过流保护:自动恢复 - 隔离电压:输入-输出500VAC 1分钟(5mA) - 隔离电阻:大于100MΩ - 冲击:20G - 振动:10-55Hz扫描1分钟,1.5mm恒定幅度,最大9G XYZ 2小时 - 湿度(非凝结):30%-90%RH - 存储湿度:10%-95%RH - 工作温度范围:-20至70°C,从50至70°C负载减半 - 存储温度:-30°C至+85°C - 重量(典型值):5克 - 尺寸(长x宽x高):28.5x18x8.5mm(PV1R5)、33x18x8.5mm(PV3) - 保修期:2年
5. 功能详解:PV系列提供单输出和双输出配置,支持广泛的输入电压范围,具有隔离输出,可配置为正或负输出,适用于恶劣的工作环境。
6. 应用信息:适用于电信、数据通信、测试测量和点负载等关键市场领域。
7. 封装信息:PV系列采用单列直插式封装,具有较小的PCB占用面积。
PVD3-24-1212 价格&库存
很抱歉,暂时无法提供与“PVD3-24-1212”相匹配的价格&库存,您可以联系我们找货
