PXA15-24S12/NT
PXA15-24S12/NT
    TDK(东电化)
    DIP-6
    PXA15-24S12/NT
PXA15-24S12/NT 数据手册
PXA15xxSxx Single Output 15 Watt DC-DC Converters The PXA15 series is approved to UL/CSA/EN/IEC 60950-1. Table of contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Thermal Consideration Short Circuit Protection Output Over Current Protection EMC Consideration External Trim Adjustment P2 P2 P3 P3 P4 P12 P12 P12 P13 P15 Remove ON/OFF Control Test Configurations Mechanical Data Recommended Pad Layout Soldering and Reflow Considerations Clearing and Drying Considerations Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P16 P17 P18 P19 P20 P21 P22 P23 P23 P23 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT ABSOLUTE MAXIMUM RATINGS Parameter Device Min Input Surge Voltage(100mS max) 24Sxx -0.3 48Sxx -0.3 Operating Ambient Temperature All -40 Storage Temperature All -55 I/O Isolation Voltage All 2250 Parameter Operating Output Range OUTPUT SPECIFICATIONS Device Min xxS3P3 3.267 xxS05 4.95 xxS12 11.88 xxS15 14.85 All -10 Voltage Adjustability (Note 1) Output Regulation Line (LL to HL at Full Load) Load(0% to 100% of Full Load) Output Ripple & Noise (Note 2) (Measured with a 1uF M/C and a 10uF T/C at 20MHz bandwidth ) Temperature Coefficient Output Voltage Overshoot Transient Response Recovery Time (50% to 75% to 50% load change, ΔIo/Δt=0.1A/us) Output Current Output Over Voltage Protection (Control voltage clamp) Output Over Current Protection Output Capacitor Load Typ Max 50 100 85 125 Unit Vdc Vdc ºC ºC Vdc Max 3.333 5.05 12.12 15.15 +10 Unit Vdc Vdc Vdc Vdc % All All 0.2 0.2 % % S3P3,S05 S12,S15 75 100 mVp-p +0.02 3 %/ ºC % All All -0.02 All xxS3P3 xxS05 xxS12 xxS15 xxS3P3 xxS05 xxS12 xxS15 xxS3P3 xxS05 xxS12 xxS15 xxS3P3 xxS05 xxS12 xxS15 Typ 3.3 5 12 15 μs 300 0 0 0 0 3.7 5.6 13.5 16.8 3.85 3.3 1.375 1.1 4.375 3.75 1.56 1.25 3.5 3.0 1.25 1.0 5.4 7.0 19.6 20.5 4.9 4.2 1.75 1.4 1000 1000 330 220 A A A A Vdc Vdc Vdc Vdc A A A A μF μF μF μF 2 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT INPUT SPECIFICATIONS Parameter Device Min Operating Input Voltage 24Sxx 18 48Sxx 36 Under Voltage Lockout Turn-on Threshold 24Sxx 48Sxx Under Voltage Lockout Turn-off Threshold 24Sxx 48Sxx Input reflected ripple current (Note 2) All Start Up Time Power Up All Remote ON/OFF All Typ 24 48 17 33 14.5 30.5 30 Max 36 75 Unit Vdc Vdc Vdc Vdc Vdc Vdc mAp-p 30 30 ms ms 1.2 15 15 1.2 Vdc Vdc Vdc Vdc Max 1000 270 470 Unit % % % % % % % % MΩ pF KHz KHz 300 μs 10.5 6 2.2×10 g hours (Test at Vin = Vin(nom) and constant resistive load) Remote ON/OFF (Note 3) Negative Logic DC-DC ON(Short) DC-DC OFF(Open) Positive Logic DC-DC ON(Open) DC-DC OFF(Short) All All All All -0.7 3 3 -0.7 GENERAL SPECIFICATIONS Parameter Device Min Efficiency (Note 2) 24S3P3 (Test at Vin = Vin(nom) and full load) 24S05 24S12 24S15 48S3P3 48S05 48S12 48S15 Isolation resistance All 10 Isolation Capacitance All Switching Frequency S3P3,S05 (Test at Vin = Vin(nom) and full load) S12,S15 Transient Response Recovery Time All (50% to 75% to 50% load change, ΔIo/Δt=0.1A/us) Weight MTBF (Note 4) Note 1: Please see the external trim adjustment. Note 2: Please see the testing configurations part. Note 3: Please see the remote ON/OFF control part. Note 4: Please see the MTBF and reliability part. All All Typ 86 87 87 88 85 87 87 88 3 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-24S3P3 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 87 86.5 85 Efficiency (%) 86 Efficiency (%) 80 75 36Vin 24Vin 18Vin 70 65 85.5 85 84.5 84 83.5 60 83 350 700 1050 1400 1750 2100 2450 2800 3150 3500 18 20 22 24 26 28 30 32 34 36 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 4.00 Output Current (A) 3.50 3.00 2.50 2.00 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 1.50 1.00 0.50 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Characteristic Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Characteristic Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 4 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-24S05 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 87 86.5 85 Efficiency (%) Efficiency (%) 86 80 36Vin 24Vin 18Vin 75 70 85.5 85 84.5 84 65 83.5 60 83 300 600 900 1200 1500 1800 2100 2400 2700 3000 18 20 22 24 26 28 30 32 34 36 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 3.50 Output Current (A) 3.00 2.50 2.00 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 1.50 1.00 0.50 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 5 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-24S12 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 87 86.5 85 Efficiency (%) Efficiency (%) 86 80 36Vin 24Vin 18Vin 75 70 85.5 85 84.5 84 65 83.5 83 60 125 250 375 500 625 750 875 1000 1125 18 1250 20 22 24 26 28 30 32 34 36 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 1.40 1.20 Output Current (A) 1.00 0.80 0.60 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 0.40 0.20 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 6 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-24S15 Characteristic Curves 90 88 85 87.5 Efficiency (%) Efficiency (%) All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 80 36Vin 24Vin 18Vin 75 70 87 86.5 86 85.5 65 85 60 100 200 300 400 500 600 700 800 900 18 1000 20 22 24 26 28 30 32 34 36 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 1.20 Output Current (A) 1.00 0.80 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 0.60 0.40 0.20 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise C Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 7 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-48S3P3 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 86 85 85.5 85 Efficiency (%) Efficiency (%) 80 75 70 75Vin 48Vin 36Vin 65 60 55 84.5 84 83.5 83 82.5 82 50 350 700 1050 1400 1750 2100 2450 2800 3150 36 3500 40 44 48 52 56 60 64 68 75 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 4.00 Output Current (A) 3.50 3.00 2.50 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 2.00 1.50 1.00 0.50 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Ch Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 8 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-48S05 Characteristic Curves 90 90 85 89 80 88 Efficiency (%) Efficiency (%) All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 75 70 75Vin 48Vin 36Vin 65 60 87 86 85 84 55 83 50 300 600 900 1200 1500 1800 2100 2400 2700 3000 82 36 40 44 48 52 56 60 64 68 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 75 3.50 3.00 Output Current (A) 2.50 2.00 1.50 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 1.00 0.50 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Derating Output Current versus Ambient Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Temperature and Airflow Typical Output Ripple and Noise. Vin=Vin,nom, Io=Full Load Output voltage Output voltage ON/OFF Voltage Output Current Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Output Rise Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 9 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-48S12 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 88 85 87.5 75 75Vin 48Vin 36Vin 70 65 60 87 Efficiency (%) Efficiency (%) 80 86.5 86 85.5 85 55 84.5 84 50 125 250 375 500 625 750 875 1000 1125 1250 36 40 44 48 52 56 60 64 68 75 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load Output Current (A) 1.40 1.20 1.00 0.80 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 0.60 0.40 0.20 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 10 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT PXA15-48S15 Characteristic Curves All test conditions are at 25 ºC.The figures are identical for either option suffix part numbers: 90 90 89.5 85 89 Efficiency (%) Efficiency (%) 80 75 75Vin 48Vin 36Vin 70 65 60 88.5 88 87.5 87 86.5 86 55 85.5 85 50 100 200 300 400 500 600 700 800 900 1000 36 40 44 48 52 56 60 64 68 Output Current , Iout (mA) Input Voltage , Vin (V) Efficiency versus Output Current Efficiency versus Input Voltage. Io=Full Load 75 1.20 1.00 Output Current (A) 0.80 0.60 Nature convection 1.0m/s(200LFM) 2.0m/s(400LFM) 3.0m/s(600LFM) 0.40 0.20 0.00 -40 -20 0 20 40 60 80 100 Ambient Temperature , Ta (ºC) Conducted Emission of EN55022 Class B Temperature and Airflow Vin=Vin,nom, Io=Full Load Output voltage Output Voltage Input Voltage Derating Output Current versus Ambient Typical Input Start-Up and Output Rise Characteristic Typical Output Ripple and Noise. Output voltage Output voltage ON/OFF Voltage Output Current Vin=Vin,nom, Io=Full Load Using ON/OFF Voltage Start-Up and Output Rise Transient Response to Dynamic Load Change from 75% to 50% to 75% of Full Load 11 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Thermal Consideration The power module operates in a variety of thermal environments; however, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convention, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as the figure below. The temperature at this location should not exceed 120 ºC. When Operating, adequate cooling must be provided to maintain the test point temperature at or below 120 ºC.Although the maximum point temperature of the power modules is 120 ºC, maintaining a lower operating temperature will increase the reliability of this device. Temperature Measure Point Short Circuit Protection Continuous, hiccup and auto-recovery mode. During a short circuit condition the converter will shut down. The average current during this condition will be very low and damage to this device should not occur. Output over current protection When excessive output currents occur in the system, circuit protection is required on all power supplies. Normally, overload current is maintained at approximately 110~140 percent of rated current for PXA15 series. Hiccup-mode is a method of operation in a power supply whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also enables the power supply to restart when the fault is removed. There are other ways of protecting the power supply when it is over-loaded, such as the maximum current limiting or current foldback methods. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of those devices may exceed their specified limits.A protection mechanism has to be used to prevent those power devices from being damaged. The operation of hiccup is as follows. When the current sense circuit sees an over-current event, the controller shuts off the power supply for a given time and then tries to start up the power supply again. If the over-load condition has been removed, the power supply will start up and operate normally; otherwise, the controller will see another over-current event and shut off the power supply again, repeating the previous cycle. Hiccup operation has none of the drawbacks of the other two protection methods, although its circuit is more complicated because it requires a timing circuit. The excess heat due to overload lasts for only a short duration in the hiccup cycle, hence the junction temperature of the power devices is much lower. The hiccup operation can be done in various ways. For example, one can start hiccup operation any time an over-current event is detected; or prohibit hiccup during a designated start-up interval (usually a few milliseconds). The reason for the latter operation is that during start-up, the power supply needs to provide extra current to charge up the output capacitor. Thus the current demand during start-up is usually larger than during normal operation and it is easier for an over-current event to occur. During start-up, if the power supply starts to hiccup when there is an over-current, it might never start up successfully. Hiccup mode protection will give the best protection for a power supply against over current situations, since it will limit the average current to the load at a low level, so reducing power dissipation and case temperature in the power devices. 12 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT EMC considerations Suggested schematic for EN55022 conducted emission Class A limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS A, the following components are needed: Component Value L1 10μH C1 C2 & C3 6.8μF 470pF Component Value L1 18μH C1 C2 & C3 2.2μF 470pF PXA15-24Sxx Voltage Reference 1.4A 0.1Ω 0504 SMD Inductor ---50V 1812 MLCC 3KV 1808 MLCC PXA15-48Sxx Voltage Reference 1.2A 0.15Ω 0504 SMD Inductor ---100V 3KV 1812 MLCC 1808 MLCC 13 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT EMC considerations(Continued) Suggested Schematic for EN55022 Conducted Emission Class B Limits Recommended Layout With Input Filter To meet conducted emissions EN55022 CLASS B, the following components are needed: Component C1 & C2 C3 C4 & C5 L1 L2 Component C1 & C2 C3 C4 & C5 L1 L2 Value 6.8μF 6.8μF 470pF 145uH 10μH Value 2.2μF 2.2μF 470pF 145uH 18μH PXA15-24Sxx Voltage Reference 50V 1812 MLCC 50V 1812 MLCC 3KV 1808 MLCC ---Common Choke 1.44A 0.1Ω 0504 SMD Inductor ---PXA15-48Sxx Voltage Reference 100V 1812 MLCC 100V 1812 MLCC 3KV 1808 MLCC ---Common Choke 1.2A 0.15Ω 0504 SMD Inductor ---- 14 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT External trim adjustment Output voltage set point adjustment allows the user to increase or decrease the output voltage set point of a module. This is accomplished by connecting an external resistor between the TRIM pin and either the +Vout or -Vout pins. With an external resistor between the TRIM and +Vout pin, the output voltage set point decreases. With an external resistor between the TRIM and -Vout pin, the output voltage set point increases.  Trim up equation   GL RU    H  ( Vo , up  L  K )    Trim down equation  (Vo , down  L )  G  RD    H  ( Vo  Vo , down )     Trim constants Module G H K L PXA15-××S15 10000 5110 12.5 2.5 PXA15-××S12 10000 5110 9.5 2.5 PXA15-××S05 5110 2050 2.5 2.5 PXA15-××S3P3 5110 2050 0.8 2.5 RU & RD List (Unit : KΩ) RU trim up %of Vo +1% +2% +3% +4% +5% +6% +7% +8% +9% +10% xxS15 161.557 78.223 50.446 36.557 28.223 22.668 18.700 15.723 13.409 11.557 xxS12 203.223 99.057 64.334 46.973 36.557 29.612 24.652 20.932 18.038 15.723 xxS05 253.450 125.700 83.117 61.825 49.050 40.533 34.450 29.888 26.339 23.500 xxS3P3 385.071 191.511 126.990 94.730 75.374 62.470 53.253 46.340 40.963 36.662 RD trim down %of Vo -1% -2% -3% -4% -5% -6% -7% -8% -9% -10% xxS15 818.223 401.557 262.668 193.223 151.557 123.779 103.938 89.057 77.483 68.223 xxS12 776.557 380.723 248.779 182.807 143.223 116.834 97.985 83.848 72.853 64.057 xxS05 248.340 120.590 78.007 56.715 43.940 35.423 29.340 24.778 21.229 18.390 xxS3P3 116.719 54.779 34.133 23.810 17.616 13.486 10.537 8.325 6.604 5.228 15 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Remote ON/OFF Control The Remote ON/OFF Pin is used to turn the DC/DC power module on and off. The user must connect a switch between the on/off pin and the Vi (-) pin. The switch can be open collector transistor, FET, or Photo-Coupler. The switch must be capable of sinking up to 1 mA at low logic level voltage. When using a high logic level, the maximum signal voltage is 15V and the maximum allowable leakage current of the switch is 50 uA. Remote ON/OFF Implementation Circuits Isolated-Closure Remote ON/OFF Level Control Using TTL Output Level Control Using Line Voltage There are two remote control options available, positive logic and negative logic. a. Positive logic - The DC/DC module is turned on when the ON/OFF pin is at a high logic level. A low logic signal is needed to turn off the device. When PXA15 module is turned off at When PXA15 module is turned on at Low logic level High logic level b. Negative logic – The DC/DC module is turned on when the ON/OFF pin is at low logic level. A high logic level signal is needed to turn off the device. When PXA15 module is turned on at When PXA15 module is turned off at Low logic level High logic level 16 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Testing Configurations Input reflected-ripple current measurement Peak-to-peak output ripple & noise measurement Output voltage and efficiency measurement Note:All measurements are taken at the module terminals.  Vout  Iout  Efficiency     100%  Vin  Iin  17 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Mechanical Data max m ax (0.6) m in stand-off height 0.09(2.3) SM D TYPE 0.03 (0.75) DIP TYPE SEC TION A-A 0.02(0.5) B-B A 0.02(0.5) max A 0.05(1.3)typ com pliance m ax EXTERNAL OUTPUT TRIMMING Output can be externally trimmed by using the method shown below. TRIM UP TRIM DOWN 5 RU 5 RD 4 0.94(23.88) 0.4(10.16) 0.30(7.62) 1.All dimensions in inches(mm) 2.Tolerance : x.xx±0.02(x.x±0.5) x.xxx±0.010(x.xx±0.25) 3.Pin pitch tolerance ±0.014(0.35) 6 0.80(20.32) 0.50(12.7) 0.07(1.78) 0.94(23.88) 0.4(10.16) 0.80(20.32) 0.50(12.7) 0.30(7.62) 0.07(1.78) SEC TIO N B-B PIN CONNECTION PIN PXA15 SERIES 1 2 3 4 5 6 + INPUT - INPUT ON/OFF +VOUT TRIM -VOUT PRODUCT STANDARD TABLE Option Negative remote ON/OFF with DIP Negative remote ON/OFF with SMT Positive remote ON/OFF with DIP Positive remote ON/OFF with SMT DIP type without ON/OFF pin SMT type without ON/OFF pin DIP type,negative remote ON/OFF without TRIM pin SMT type,negative remote ON/OFF without TRIM pin DIP type without ON/OFF&TRIM pin SMT type without ON/OFF&TRIM pin DIP type,positive remote ON/OFF without TRIM pin SMT type,positive remote ON/OFF without TRIM pin Suffix -A -B -C -D -E -F -G -H -I -J -K 18 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Recommended Pad Layout Recommended pad layout for DIP type Recommended pad layout for SMD type 19 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Soldering and Reflow Considerations Lead free wave solder profile for DIP type Zone Preheat zone Actual heating Reference Parameter. Rise temp. speed: 3 ºC /sec max. Preheat temp.100~130 ºC Peak temp. :250~260 ºC Peak time(T1+T2 time):4~6 sec Lead free reflow profile for SMD type Zone Preheat zone Actual heating Cooling Reference Parameter. Rise temp. speed:1~3 ºC /sec Preheat time:60~90sec Preheat temp.155~185 ºC Rise temp. speed:1~3 ºC /sec Melting time:20~40 sec Melting temp:220 ºC Peak temp. :230~240v Peak time:10~20 sec Rise temp. speed: -1~-5 ºC /sec 20 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Clearing and Drying Considerations Cleaning process a. PWB cooling prior to cleaning: Power modules and their associated application PWB assemblies should not be cleaned after soldering until the power modules have had an opportunity to cool to within the cleaning solution temperature. This will prevent vacuum absorption of the cleaning liquid into the module between the pins and the potting during cooling. b. Cleaning process: In aqueous cleaning, it is preferred to have an in-line system consisting of several cleaning stages (prewash, wash, rinse, final rinse, and drying). De-ionized (DI) water is recommended for aqueous cleaning; the minimum resistivity level is 1MΩ-cm. Tap-water quality varies per region in terms of hardness, chloride, and solid contents; therefore, the use of tap water is not recommended for aqueous cleaning. The total time of ultrasonic wave shall be less than 3 minutes. Drying After cleaning, dry converters at 100 ºC, more than 10minutes to assure that the moisture and other potential foreign contaminants are driven out. For open power module construction with having transformers and inductors that have unspotted windings, a baking process of 100 ºC for 30 min. is recommended for the assembly to ensure that the moisture and other potential foreign contaminants are driven out from the open windings. The drying section of the cleaning system should be equipped with blowers capable of generating 1000 cfm-1500 cfm of air so that the amount of rinse water left to be dried off with heat is minimal. Handheld air guns are not recommended due to the variability and inconsistency of the operation. Product Post-wash external appearance The marking or date-code may fade or disappear after cleaning. 21 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Packaging Information Packaging information for DIP type Packaging information for SMD type 22 Data Sheet JUN. 06, 2011 15W SINGLE OUTPUT Part Number Structure PXA 15 – 24 S 05 -A Total Output power 15 Watt Option Suffix Input Voltage Range 24xxx : 18~36V 48xxx : 36~75V Single Output Output Voltage 3P3 : 3.3V 05 : 5V Safety and Installation Instruction Isolation consideration The PXA15 series features 2250 Volt DC isolation from input to output. The input to output resistance is greater than 10 megohms. Nevertheless, if the system using the power module needs to receive safety agency approval, certain rules must be followed in the design of the system using the model. In particular, all of the creepage and clearance requirements of the end-use safety requirement must be observed. These documents include UL60950-1, EN60950-1 and CSA 22.2-960, although specific applications may have other or additional requirements. Fusing Consideration Caution: This power module is not internally fused.An input line fuse must always be used. This encapsulated power module can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a normal-blow fuse with maximum rating of 2A. Based on the information provided in this data sheet on Inrush energy and maximum dc input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXA15 series of DC/DC converters has been calculated using Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40 ºC (Ground fixed and controlled environment) The resulting figure for MTBF is 2.2× 106 hours. 23
PXA15-24S12/NT 价格&库存
很抱歉,暂时无法提供与“PXA15-24S12/NT”相匹配的价格&库存,您可以联系我们找货
