PXA15-24WS15/NT
PXA15-24WS15/NT
    TDK(东电化)
    插件,27.9x23.9mm
    PXA15-24WS15/NT
PXA15-24WS15/NT 数据手册
PXA15-xxWSxx Single Output 15 Watt DC/DC Converters The PXA15 series is approved to UL/CSA/EN/IEC 62368­1, 60950-1 Table of contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Testing Configurations EMC Consideration Input Source Impedance Output Over Current Protection Output Over Voltage Protection Output Voltage Adjustment P2 P2 P3 P4 P5 P21 P22 P24 P24 P24 P25 Short Circuit Protection Thermal Consideration Remote ON/OFF Control Mechanical Data Recommended Pad Layout Soldering and Reflow Considerations Cleaning and Drying Considerations Part Number Structure Safety and Installation Instruction MTBF and Reliability P26 P26 P27 P28 P29 P30 P31 P32 P32 P32 Data Sheet 12 July, 2022 15W, Single Output Absolute Maximum Rating Parameter Model Input Voltage Continuous Transient (100mS) Operating Ambient Temperature (with derating) Storage Temperature 24WSXX 48WSXX 24WSXX 48WSXX All All Min Max -40 -55 36 75 50 100 85 125 Unit VDC ºC ºC Output Specification Parameter Output Voltage Range (Vin = Vin(nom) ; Full Load ; TA=25 ºC) Voltage Adjustability(See Page 25) Model Min XXWS3P3 3.267 Typ 3.3 Max Unit 3.333 XXWS05 4.95 5 5.05 XXWS12 11.88 12 12.12 XXWS15 14.85 15 15.15 VDC All -10 +10 % All -0.2 +0.2 % -0.2 +0.2 Output Regulation Line (Vin(min) to Vin(max) at Full Load) Load (0% to 100% of Full Load) Output Ripple & Noise(See Page 21) Peak-to-Peak (20MHz bandwidth) All 100 mVP-P (Measured with a 1uF M/C and a 10uF T/C ) Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max) ; Full Load ; TA=25 ºC) All -0.02 All +0.02 %/ ºC 3 % VOUT Dynamic Load Response (Vin = Vin(nom) ; TA=25 ºC) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Settling Time (VOUT<10% peak deviation) Output Current Output Over Voltage Protection (Voltage Clamped) All 300 mV All 250 μS XXWS3P3 0 4000 XXWS05 0 3000 XXWS12 0 1300 XXWS15 0 1000 XXWS3P3 3.7 5.4 XXWS05 5.6 7.0 XXWS12 13.8 17.5 XXWS15 16.8 Output Over Current Protection All Output Short Circuit Protection All mA VDC 20.5 150 % FL. Hiccup, automatics recovery PXA15-xxWSxx 2 Data Sheet 12 July, 2022 15W, Single Output Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom); Full Load) Model Min Typ Max 24WSXX 9 24 36 48WSXX 18 48 75 24WS3P3 680 24WS05 754 24WS12 793 24WS15 763 48WS3P3 340 48WS05 377 48WS12 397 48WS15 Input Standby Current (Typical value at Vin = Vin(nom); No Load) Under Voltage Lockout Turn-on Threshold Under Voltage Lockout Turn-off Threshold Input Reflected Ripple Current (See Page 21) (5 to 20MHz, 12μH source impedance) Unit VDC mA 382 24WS3P3 60 24WS05 70 24WS12 10 24WS15 10 48WS3P3 40 48WS05 40 48WS12 10 48WS15 10 mA 24WSXX 9 48WSXX 18 24WSXX 8 48WSXX 16 All 30 All 30 VDC VDC mAP-P Start Up Time (Vin = Vin(nom) and constant resistive load) Power up Remote ON/OFF mS 30 Remote ON/OFF Control (See Page 27) (The ON/OFF pin voltage is referenced to -VIN) Negative Logic DC-DC ON(Short) DC-DC OFF(Open) Positive Logic All DC-DC ON(Open) DC-DC OFF(Short) Remote Off Input Current All Input Current of Remote Control Pin All 0 1.2 3 15 3 15 0 1.2 2.5 -0.5 VDC mA 1.0 mA PXA15-xxWSxx 3 Data Sheet 12 July, 2022 15W, Single Output General Specification Parameter Efficiency(See Page 21) (Vin = Vin(nom) ; Full Load ; TA=25 ºC) Isolation Voltage Input to Output Isolation Resistance Model Min Typ 24WS3P3 85 24WS05 87 24WS12 86 24WS15 86 48WS3P3 85 48WS05 87 48WS12 86 48WS15 86 All All Unit % 2250 VDC 1 GΩ Isolation Capacitance All Switching Frequency XXWS3P3 350 XXWS05 350 XXWS12 400 Weight Max 1000 pF KHz XXWS15 400 All 10.5 All 1.322×10 g MTBF(See Page 32) Bellcore TR-NWT-000332, TC=40 ºC MIL-HDBK-217F 6 hours 5 5.147×10 PXA15-xxWSxx 4 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves All test conditions are at 25 ºC. PXA15-24WS3P3 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 5 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS3P3 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 6 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS05 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 7 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS05 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 8 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS12 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 9 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS12 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 10 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS15 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 11 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-24WS15 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 12 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS3P3 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 13 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS3P3 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 14 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS05 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 15 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS05 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 16 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS12 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 17 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS12 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 18 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS15 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXA15-xxWSxx 19 Data Sheet 12 July, 2022 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXA15-48WS15 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load PXA15-xxWSxx 20 Data Sheet 12 July, 2022 15W, Single Output Testing Configurations Input reflected-ripple current measurement Component L C C Value 12μH 220μF 33μF Voltage ---100V 100V Reference ---Aluminum Electrolytic Capacitor Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement Output voltage and efficiency measurement Note: All measurements are taken at the module terminals.  V  Io  Efficiency   o   100%  Vin  I in  PXA15-xxWSxx 21 Data Sheet 12 July, 2022 15W, Single Output EMC considerations Suggested schematic for EN55022 conducted emission Class A limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS A, the following components are needed: Component Value Voltage L1 10μH ---- C1 C2 & C3 6.8μF 470pF 50V 3KV Component Value Voltage L1 18μH ---- C1 C2 & C3 2.2μF 470pF 100V 3KV PXA15-24WSXX Reference 2.6A 0.04Ω 0705 SMD Inductor 1812 MLCC 1808 MLCC PXA15-48WSXX Reference 1.6A 0.1Ω 0705 SMD Inductor 1812 MLCC 1808 MLCC PXA15-xxWSxx 22 Data Sheet 12 July, 2022 15W, Single Output EMC considerations (Continued) Suggested schematic for EN55022 conducted emission Class B limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS B, the following components are needed: PXA15-24WSXX Component Value C1 ---C2, C3 & C4 6.8μF C5 & C6 470pF L1 145μH L2 10μH PXA15-48WSXX Component Value C1 2.2μF C2, C3 & C4 2.2μF C5 & C6 470pF L1 325μH L2 33μH Voltage ---50V 3KV ------Voltage 100V 100V 3KV ------- Reference ---1812 MLCC 1808 MLCC Common Choke 2.6A 0.04Ω 0705 SMD Inductor Reference 1812 MLCC 1812 MLCC 1808 MLCC Common Choke 1.2A 0.13Ω 0705 SMD Inductor PXA15-xxWSxx 23 Data Sheet 12 July, 2022 15W, Single Output Input Source Impedance The power module should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the power module. Input external C-L-C filter is recommended to minimize input reflected ripple current. The inductor is simulated source impedance of 12μH and the capacitor is Nippon chemi-con KZE series 220μF/100V&33μF/100V. The capacitor must be located as close as possible to the input terminals of the power module for lower impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all power supplies. Normally, overload current is maintained at approximately 150 percent of rated current for PXA15WS single output series. Hiccup-mode is a method of operation in a power supply whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also enables the power supply to restart when the fault is removed. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of those devices may exceed their specified limits. A protection mechanism has to be used to prevent those power devices from being damaged. Output Over Voltage Protection The output over-voltage protection consists of a Zener diode that monitors the output voltage on the feedback loop. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode will send a signal to the control IC to limit the output voltage. PXA15-xxWSxx 24 Data Sheet 12 July, 2022 15W, Single Output Output Voltage Adjustment Output voltage set point adjustment allows the user to increase or decrease the output voltage set point of a module. This is accomplished by connecting an external resistor between the TRIM pin and either the Vo (+) or Vo (-) pins. With an external resistor between the TRIM and Vo (-) pin, the output voltage set point increases. With an external resistor between the TRIM and Vo (+) pin, the output voltage set point decreases.  Trim up equation   G L RU    H  VO ,up  L  K    RU Trim down equation  VO , down  L   G  RD    H   VO  VO , down    RD Trim constants Module G H K L PXA15-XXWS3P3 5110 2050 0.8 2.5 PXA15-XXWS05 5110 2050 2.5 2.5 PXA15-XXWS12 10000 5110 9.5 2.5 PXA15-XXWS15 10000 5110 12.5 2.5 TRIM TABLE Trim up (%) VOUT (Volts)= RU (K Ohms)= PXA15-XXWS3P3 1 2 3 3.333 3.366 3.399 385.071 191.511 126.990 4 3.432 94.730 5 3.465 75.374 6 3.498 62.470 7 3.531 53.253 8 3.564 46.340 9 3.597 10 3.630 40.963 36.662 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 3.267 3.234 3.201 3.168 3.135 3.102 3.069 3.036 3.003 2.970 RD (K Ohms)= 116.719 54.779 34.133 23.810 17.616 13.486 10.537 8.325 6.604 5.228 PXA15-XXWS05 Trim up (%) VOUT (Volts)= RU (K Ohms)= 1 2 3 4 5 6 7 8 9 10 5.050 5.100 5.150 5.200 5.250 5.300 5.350 5.400 5.450 5.500 253.450 125.700 83.117 61.825 49.050 40.533 34.450 29.888 26.339 23.500 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 4.950 4.900 4.850 4.800 4.750 4.700 4.650 4.600 4.550 4.500 248.340 120.590 RD (K Ohms)= 78.007 56.715 43.940 35.423 29.340 24.778 21.229 18.390 PXA15-XXWS12 Trim up (%) VOUT (Volts)= 1 12.120 2 12.240 3 12.360 4 12.480 5 12.600 6 12.720 7 12.840 8 12.960 9 13.080 10 13.200 RU (K Ohms)= 203.223 99.057 64.334 46.973 36.557 29.612 24.652 20.932 18.038 15.723 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 11.880 11.760 11.640 11.520 11.400 11.280 RD (K Ohms)= 776.557 380.723 248.779 182.807 143.223 116.834 97.985 11.160 83.848 11.040 72.853 10.920 64.057 Trim up (%) 1 2 5 6 7 8 9 10 10.800 PXA15-XXWS15 VOUT (Volts)= 15.150 15.300 3 15.450 4 15.600 15.750 15.900 16.050 16.200 16.350 16.500 RU (K Ohms)= 161.557 78.223 50.446 36.557 28.223 22.668 18.700 15.723 13.409 11.557 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= RD (K Ohms)= 14.850 14.700 14.550 14.400 14.250 14.100 13.950 818.223 401.557 262.668 193.223 151.557 123.779 103.938 13.800 89.057 13.650 77.483 13.500 68.223 PXA15-xxWSxx 25 Data Sheet 12 July, 2022 15W, Single Output Short Circuit Protection Continuous, hiccup and auto-recovery mode. During a short circuit condition the converter will shut down. The average current during this condition will be very low and damage to this device should not occur. Thermal Consideration The power module operates in a variety of thermal environments. However, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as shown in the figure below. The temperature at this location should not exceed 120 ºC. When Operating, adequate cooling must be provided to maintain the test point temperature at or below 120 ºC. Although the maximum point temperature of the power module is 120 ºC, maintaining a lower operating temperature will increase the reliability of this device. TOP VIEW PXA15-xxWSxx 26 Data Sheet 12 July, 2022 15W, Single Output Remote ON/OFF Control The Remote ON/OFF Pin is used to turn the DC/DC power module on and off. The user must connect a switch between the on/off pin and the Vi (-) pin. The switch can be open collector transistor, FET, or Photo-Coupler. The switch must be capable of sinking up to 1 mA at low logic level voltage. When using a high logic level, the maximum signal voltage is 15V and the maximum allowable leakage current of the switch is 50 uA. Remote ON/OFF Implementation Circuits Isolated-Closure Remote ON/OFF Level Control Using TTL Output Level Control Using Line Voltage There are two remote control options available, positive logic and negative logic. a. Positive logic - The DC/DC module is turned on when the ON/OFF pin is at a high logic level. A low logic signal is needed to turn off the device. When PXA15WS module is turned off When PXA15WS module is turned on at Low logic level at High logic level b. Negative logic – The DC/DC module is turned on when the ON/OFF pin is at low logic level. Ahigh logic level signal is needed to turn off the device. When PXA15WS module is turned on When PXA15WS module is turned off at Low logic level at High logic level PXA15-xxWSxx 27 Data Sheet 12 July, 2022 15W, Single Output Mechanical Data 1.All dimensions in inches(mm) 2.Tolerance : x.xx±0.02(x.x±0.5) x.xxx±0.010(x.xx±0.25) 3.Pin pitch tolerance ±0.014(0.35) PIN CONNECTION PIN PXA15WS SERIES 1 2 3 4 5 6 + INPUT - INPUT ON/OFF +VOUT TRIM -VOUT EXTERNAL OUTPUT TRIMMING Output can be externally trimmed by using the method shown below. 6 TRIM RU UP OPTIONS Suffix Description P N S T Positive Logic Negative Logic Surface Mount Trim 5 TRIM DOWN 4 RD -NST or NT as standard Delete suffix if not required PXA15-xxWSxx 28 Data Sheet 12 July, 2022 15W, Single Output Recommended Pad Layout Recommended pad layout for DIP type Recommended pad layout for SMD type PXA15-xxWSxx 29 Data Sheet 12 July, 2022 15W, Single Output Soldering and Reflow Considerations Lead free wave solder profile for DIP type Zone Preheat zone Actual heating Reference Parameter. Rise temp. speed: 3 ºC /sec max. Preheat temp.100~130 ºC Peak temp. :250~260 ºC Peak time(T1+T2 time):4~6 sec Lead free reflow profile for SMD type Zone Preheat zone Actual heating Cooling Reference Parameter. Rise temp. speed:1~3 ºC /sec Preheat time:60~90sec Preheat temp.155~185 ºC Rise temp. speed:1~3℃/sec Melting time:20~40 sec Melting temp:220 ºC Peak temp. :230~240 ºC Peak time:10~20 sec Rise temp. speed: -1~-5 ºC /sec PXA15-xxWSxx 30 Data Sheet 12 July, 2022 15W, Single Output Cleaning and Drying Considerations Cleaning process a. PWB cooling prior to cleaning: Power modules and their associated application PWB assemblies should not be cleaned after soldering until the power modules have had an opportunity to cool to within the cleaning solution temperature. This will prevent vacuum absorption of the cleaning liquid into the module between the pins and the potting during cooling. b. Cleaning process: In aqueous cleaning, it is preferred to have an in-line system consisting of several cleaning stages (prewash, wash, rinse, final rinse, and drying). De-Ionized (DI) water is recommended for aqueous cleaning; the minimum resistivity level is 1MΩ-cm. Tap-water quality varies per region in terms of hardness, chloride, and solid contents; therefore, the use of tap water is not recommended for aqueous cleaning. The total time of ultrasonic wave shall be less than 3 minutes. Drying After cleaning, dry converters at 100 ºC, more than 10minutes to assure that the moisture and other potential foreign contaminants are driven out. For open power module construction having transformers and inductors that have unspotted windings, a baking process of 100 ºC for 30 min. is recommended for the assembly to ensure that the moisture and other potential foreign contaminants are driven out from the open windings. The drying section of the cleaning system should be equipped with blowers capable of generating 1000 cfm-1500 cfm of air so that the amount of rinse water left to be dried off with heat is minimal. Handheld air guns are not recommended due to the variability and inconsistency of the operation. Product Post-wash external appearance The marking or date-code may fade or disappear after cleaning. PXA15-xxWSxx 31 Data Sheet 12 July, 2022 15W, Single Output Part Number Structure PXA 15 – 24W S 05 -A Total Output power 15 Watt Option Suffix Input Voltage Range 24xxx : 9~36V 48xxx : 18~75V Output Voltage 3P3 : 3.3V 05 : 5V 12: 12V 15: 15V Single Output Model Number Input Range Output Voltage (2) Output Current Full Load Input Current (1) Full Load Eff (%) 4000mA 3000mA 1300mA 1000mA 4000mA 3000mA 1300mA 1000mA 680mA 754mA 793mA 763mA 340mA 377mA 397mA 382mA 85 87 86 86 85 87 86 86 PXA15-24WS3P3 9 - 36 VDC 3.3 VDC PXA15-24WS05 9 - 36 VDC 5 VDC PXA15-24WS12 9 - 36 VDC 12 VDC PXA15-24WS15 9 - 36 VDC 15 VDC PXA15-48WS3P3 18 - 75 VDC 3.3 VDC PXA15-48WS05 18 - 75 VDC 5 VDC PXA15-48WS12 18 - 75 VDC 12 VDC PXA15-48WS15 18 - 75 VDC 15 VDC Note 1. Maximum value at nominal input voltage and full load. Note 2. Typical value at nominal input voltage and full load. Safety and Installation Instruction Fusing Consideration Caution: This power module is not internally fused. An input line fuse must always be used. This encapsulated power module can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a normal-blow fuse with maximum rating of 3A for PXA15-24WSXX modules and 1.5A for PXA15-48WSXX modules. Based on the information provided in this data sheet on Inrush energy and maximum DC input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXA15WS SERIES of DC/DC converters has been calculated using: Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40 ºC (Ground fixed and controlled 6 environment ). The resulting figure for MTBF is 1.322×10 hours. MIL-HDBK 217F NOTICE2 FULL LOAD, Operating Temperature at 25 . The resulting figure for MTBF is 5 5.147×10 hours. PXA15-xxWSxx 32
PXA15-24WS15/NT 价格&库存
很抱歉,暂时无法提供与“PXA15-24WS15/NT”相匹配的价格&库存,您可以联系我们找货
PXA15-24WS15/NT
  • 1+542.484241+70.40456
  • 10+513.8035510+66.68233
  • 25+502.7809225+65.25179
  • 50+494.5956250+64.18949
  • 100+486.53031100+63.14276
库存:19
