PXB15-12S05/NT
PXB15-12S05/NT
    TDK(东电化)
    插件,25.4x25.4mm
    PXB15-12S05/NT
PXB15-12S05/NT 数据手册
PXB15-xxSxx Single Output 15 Watt DC/DC Converters The PXB15 series is approved to UL/CSA/EN/IEC 60950-1. Table of contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Testing Configurations EMC Consideration Input Source Impedance Output Over Current Protection Output Over Voltage Protection Output Voltage Adjustment P2 P2 P3 P4 P5 P29 P30 P32 P32 P32 P33 Short Circuit Protection Thermal Consideration Heat Sink Consideration Remote ON/OFF Control Mechanical Data Recommended Pad Layout Soldering Considerations Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P34 P34 P34 P35 P36 P37 P37 P38 P38 P39 P39 Data Sheet Jul. 20, 2010 15W, Single Output Absolute Maximum Rating Parameter Model Input Voltage Continuous Min Max 12SXX 24SXX 48SXX 12SXX 24SXX 48SXX Transient (100mS) Input Voltage Variation (complies with ETS300 132 part 4.4) Operating Ambient Temperature (with derating) Operating Case Temperature Storage Temperature Unit 18 36 75 36 50 100 All All -40 All -55 VDC 5 V/mS 85 105 125 ºC ºC ºC Output Specification Parameter Output Voltage Range (Vin = Vin(nom) ; Full Load ; TA=25 ºC) Voltage Adjustability(See Page 33) Model Min XXS3P3 3.267 3.3 Typ 3.333 Max Unit XXS05 4.95 5 5.05 XXS12 11.88 12 12.12 XXS15 14.85 15 15.15 All -10 +10 % All -0.2 +0.2 % -0.2 +0.2 VDC Output Regulation Line (Vin(min) to Vin(max) at Full Load) Load (0% to 100% of Full Load) Output Ripple & Noise(See Page 29) XXS3P3 Peak-to-Peak (20MHz bandwidth) XXS05 (Measured with a 1uF M/C and a 10uF T/C ) XXS12 75 mVP-P 100 XXS15 Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max) ; Full Load ; TA=25 ºC) All -0.02 +0.02 %/ ºC 3 % VOUT All 0 All 300 mV All 250 μS Dynamic Load Response (Vin = Vin(nom) ; TA=25 ºC) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Settling Time (VOUT<10% peak deviation) Output Current Output Over Voltage Protection (Voltage Clamped) XXS3P3 0 4000 XXS05 0 3000 XXS12 0 1300 XXS15 0 1000 XXS3P3 3.7 5.4 XXS05 5.6 7.0 XXS12 13.5 19.6 XXS15 16.8 20.5 Output Over Current Protection All Output Short Circuit Protection All 150 mA VDC % FL. Hiccup, automatic recovery PXB15-xxSxx 2 Data Sheet Jul. 20, 2010 15W, Single Output Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom); Full Load) Input Standby Current (Typical value at Vin = Vin(nom) ; No Load) Under Voltage Lockout Turn-on Threshold Min Typ Max 12SXX Model 9 12 18 24SXX 18 24 36 48SXX 36 48 75 12S3P3 1375 12S05 1524 12S12 1605 12S15 1506 24S3P3 671 24S05 763 24S12 783 24S15 744 48S3P3 336 48S05 372 48S12 387 48S15 372 12S3P3 Input Reflected Ripple Current (See Page 29) (5 to 20MHz, 12μH source impedance) VDC mA 120 12S05 90 12S12 40 12S15 40 24S3P3 50 24S05 65 24S12 20 24S15 20 48S3P3 40 48S05 40 48S12 15 48S15 15 mA 12SXX 9 24SXX 18 48SXX Under Voltage Lockout Turn-off Threshold Unit VDC 36 12SXX 8 24SXX 14.5 48SXX 30.5 VDC All 30 mAP-P All 30 mS Start Up Time (Vin = Vin(nom) and constant resistive load) Power up Remote ON/OFF 30 Remote ON/OFF Control (See Page 35) (The ON/OFF pin voltage is referenced to -VIN) Negative Logic DC-DC ON(Short) DC-DC OFF(Open) Positive Logic All DC-DC ON(Open) DC-DC OFF(Short) Remote Off Input Current All Input Current of Remote Control Pin All 0 1.2 3 15 3 15 0 1.2 2.5 -0.5 VDC mA 1.0 mA PXB15-xxSxx 3 Data Sheet Jul. 20, 2010 15W, Single Output General Specification Parameter Efficiency(See Page 29) (Vin = Vin(nom) ; Full Load ; TA=25 ºC) Model Min Typ 12S3P3 84 12S05 86 12S12 85 12S15 87 24S3P3 86 24S05 86 24S12 87 24S15 88 48S3P3 86 48S05 88 48S12 88 48S15 88 Max Unit % Isolation Voltage Input to Output All Input (Output) to Case 1600 VDC 1000 Isolation Resistance All Isolation Capacitance All 1 GΩ Switching Frequency All 400 KHz Weight All 15 g All 1.330×10 1000 pF MTBF(See Page 39) Bellcore TR-NWT-000332, TC=40 ºC MIL-STD-217F 6 hours 5 5.630×10 PXB15-xxSxx 4 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves All test conditions are at 25 ºC. PXB15-12S3P3 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 5 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S3P3 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow, Vin = Vin(nom) PXB15-xxSxx 6 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S05 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 7 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S05 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 8 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S12 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 9 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S12 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 10 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S15 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 11 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-12S15 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 12 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S3P3 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 13 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC . PXB15-24S3P3 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 14 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S05 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom); Full Load PXB15-xxSxx 15 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S05 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 16 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S12 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 17 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S12 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom); Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 18 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S15 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 19 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-24S15 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 20 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S3P3 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 21 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S3P3 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom); Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 22 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S05 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 23 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S05 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom); Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 24 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S12 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom) ; Full Load PXB15-xxSxx 25 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S12 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 26 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC. PXB15-48S15 Efficiency versus Output Current Typical Output Ripple and Noise. Vin = Vin(nom) ; Full Load Efficiency versus Input Voltage. Full Load Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Derating OutputCurrentversus AmbientTemperature andAirflow Typical Input Start-Up and Output Rise Characteristic Vin = Vin(nom) Vin = Vin(nom); Full Load PXB15-xxSxx 27 Data Sheet Jul. 20, 2010 15W, Single Output Characteristic Curves (Continued) All test conditions are at 25 ºC . PXB15-48S15 Conduction Emission of EN55022 Class A Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class B Power Dissipation versus Output Current Vin = Vin(nom) ; Full Load Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) PXB15-xxSxx 28 Data Sheet Jul. 20, 2010 15W, Single Output Testing Configurations Input reflected-ripple current measurement CURRENT PROBEMEASURE POINT +Vin L + BATTERY C1 + C2 -Vin Component L C1 C2 Value 12μH 10μF 10μF Voltage ---100V 100V Reference ---Aluminum Electrolytic Capacitor Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement Output voltage and efficiency measurement Note: All measurements are taken at the module terminals.  V  Io Efficiency   o  Vin  I in    100%  PXB15-xxSxx 29 Data Sheet Jul. 20, 2010 15W, Single Output EMC considerations C3 - INPUT C1 - INPUT +Vin +Vout -Vin -Vout C2 D/D Converter Suggested schematic for EN55022 conducted emission Class A limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS A, the following components are needed: Component C1 C2 C3,C4 Value 10uF ---470pF Voltage 25V ---2KV Component C1 C2 C3,C4 Value 6.8uF 6.8uF 470pF Voltage 50V 50V 2KV Component C1 C2 C3,C4 Value 2.2uF 2.2uF 470pF Voltage 100V 100V 2KV PXB15-12SXX Reference 1812 MLCC ---1808 MLCC PXB15-24SXX Reference 1812 MLCC 1812 MLCC 1808 MLCC PXB15-48SXX Reference 1812 MLCC 1812 MLCC 1808 MLCC PXB15-xxSxx 30 Data Sheet Jul. 20, 2010 15W, Single Output EMC considerations (Continued) Suggested schematic for EN55022 conducted emission Class B limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS B, the following components are needed: PXB15-12SXX Component Value C1,C3 10μF C2 ---C4,C5 470pF L1 145μH Voltage 25V ---2KV ---- Reference 1812 MLCC ---1808 MLCC Common Choke PXB15-24SXX Component Value C1,C3 6.8μF C2 ---C4,C5 470pF L1 325μH Voltage 50V ---2KV ---- Reference 1812 MLCC ---1808 MLCC Common Choke PXB15-48SXX Component Value C1,C3 2.2μF C2 2.2μF C4,C5 1000pF L1 325μH Voltage 100V 100V 2KV ---- Reference 1812 MLCC 1812 MLCC 1808 MLCC Common Choke PXB15-xxSxx 31 Data Sheet Jul. 20, 2010 15W, Single Output Input Source Impedance The power module should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the power module. The addition of an external C-L-C filter is recommended to minimize input reflected ripple current. The inductor is simulated source impedance of 12μH and capacitor is Nippon chemi-con KZE series 10μF/100V&10μF/100V. The capacitor must be located as close as possible to the input terminals of the power module for lower impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all power supplies. Normally, overload current is maintained at approximately 150 percent of rated current for PXB15 single output series. Hiccup-mode is a method of operation in a power supply whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also allows the power supply to restart when the fault is removed. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of those devices may exceed their specified limits. A protection mechanism has to be used to prevent those power devices from being damaged. Output Over Voltage Protection The output over-voltage protection consists of a Zener diode that monitors the output voltage on the feedback loop. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode will send a signal to the control IC to limit the output voltage. PXB15-xxSxx 32 Data Sheet Jul. 20, 2010 15W, Single Output Output Voltage Adjustment Output voltage set point adjustment allows the user to increase or decrease the output voltage set point of a module. This is accomplished by connecting an external resistor between the TRIM pin and either the Vo (+) or Vo (-) pins. With an external resistor between the TRIM and Vo (-) pin, the output voltage set point increases. With an external resistor between the TRIM and Vo (+) pin, the output voltage set point decreases.  Trim up equation   G L RU    H  VO ,up  L  K    -Vout RU Trim down equation -Vin  VO , down  L   G  RD    H   VO  VO , down    Trim +Vin RD Trim constants +Vout Module G H K L PXB15-XXS3P3 5110 2050 0.8 2.5 PXB15-XXS05 5110 2050 2.5 2.5 PXB15-XXS12 10000 5110 9.5 2.5 PXB15-XXS15 10000 5110 12.5 2.5 TRIM TABLE Trim up (%) VOUT (Volts)= RU (K Ohms)= PXB15-XXS3P3 1 2 3 3.333 3.366 3.399 385.071 191.511 126.990 4 3.432 94.730 5 3.465 75.374 6 3.498 62.470 7 3.531 53.253 8 3.564 46.340 9 3.597 10 3.630 40.963 36.662 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 3.267 3.234 3.201 3.168 3.135 3.102 3.069 3.036 3.003 2.970 RD (K Ohms)= 116.719 54.779 34.133 23.810 17.616 13.486 10.537 8.325 6.604 5.228 PXB15-XXS05 Trim up (%) VOUT (Volts)= RU (K Ohms)= 1 2 3 4 5 6 7 8 9 10 5.050 5.100 5.150 5.200 5.250 5.300 5.350 5.400 5.450 5.500 253.450 125.700 83.117 61.825 49.050 40.533 34.450 29.888 26.339 23.500 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 4.950 4.900 4.850 4.800 4.750 4.700 4.650 4.600 4.550 4.500 248.340 120.590 RD (K Ohms)= 78.007 56.715 43.940 35.423 29.340 24.778 21.229 18.390 PXB15-XXS12 Trim up (%) VOUT (Volts)= 1 12.120 2 12.240 3 12.360 4 12.480 5 12.600 6 12.720 7 12.840 8 12.960 9 13.080 10 13.200 RU (K Ohms)= 203.223 99.057 64.334 46.973 36.557 29.612 24.652 20.932 18.038 15.723 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 11.880 11.760 11.640 11.520 11.400 11.280 RD (K Ohms)= 776.557 380.723 248.779 182.807 143.223 116.834 97.985 11.160 83.848 11.040 72.853 10.920 64.057 10.800 Trim up (%) 1 2 5 6 7 8 9 10 PXB15-XXS15 VOUT (Volts)= 15.150 15.300 3 15.450 4 15.600 15.750 15.900 16.050 16.200 16.350 16.500 RU (K Ohms)= 161.557 78.223 50.446 36.557 28.223 22.668 18.700 15.723 13.409 11.557 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= RD (K Ohms)= 14.850 14.700 14.550 14.400 14.250 14.100 13.950 818.223 401.557 262.668 193.223 151.557 123.779 103.938 13.800 89.057 13.650 77.483 13.500 68.223 PXB15-xxSxx 33 Data Sheet Jul. 20, 2010 15W, Single Output Short Circuit Protection Continuous, hiccup and auto-recovery mode. During a short circuit condition the converter will shut down. The average current during this condition will be very low and damage to this device should not occur. Thermal Consideration The power module operates in a variety of thermal environments. However, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding Environment. Proper cooling can be verified by measuring the point as shown in the figure below. The temperature at this location should not exceed 105 ºC. When Operating, adequate cooling must be provided to maintain the test point temperature at or below 105 ºC. Although the maximum point Temperature of the power modules is 105 ºC, maintaining a lower operating temperature will increase the reliability of this device. Temperature Measurement Point Heat Sink Consideration The addition of a heat sink may be needed to decrease the temperature of the module; thus increasing its reliability. 7G-0047C-F All dimensions in millimeters PXB15-xxSxx 34 Data Sheet Jul. 20, 2010 15W, Single Output Remote ON/OFF Control The Remote ON/OFF Pin is used t o turn the DC/DC power module on and off. The user must connect a switch between the on/off pin and the Vi (-) pin. The switch can be an open collector transistor, FET, or Photo-Coupler. The switch must be capable of sinking up to 1 mA when using a low logic level voltage. When using a high logic level, the maximum signal voltage is 15V and the maximum allowable leakage current of the switch is 50 uA. Remote ON/OFF Implementation Circuits Isolated-Closure Remote ON/OFF Level Control Using TTL Output Level Control Using Line Voltage There are two remote control options available, positive logic and negative logic. a. Positive logic - The DC/DC module is turned on when the ON/OFF pin is at a high logic level. A low logic signal is needed to turn off the device. When PXB15 module is turned off at When PXB15 module is turned on at Low logic level High logic level b. Negative logic – The DC/DC module is turned on when the ON/OFF pin is at low logic level. A high logic level signal is needed to turn off the device. When PXB15 module is turned on at When PXB15 module is turned off at Low logic level High logic level PXB15-xxSxx 35 Data Sheet Jul. 20, 2010 15W, Single Output Mechanical Data PIN CONNECTION PIN PXB15 Series 1 2 3 4 5 6 + INPUT - INPUT ON/OFF +VOUT TRIM -VOUT OPTIONS 1.All dimensions in inches(mm) 2.Tolerance : x.xx±0.02(x.x±0.5) x.xxx±0.010(x.xx±0.25) 3.Pin pitch tolerance ±0.014(0.35) Suffix Description P N T Positive Logic Negative Logic Trim EXTERNAL OUTPUT TRIMMING Output can be externally trimmed by using the method shown below. TRIM UP TRIM DOWN 6 5 RU 5 -NT as standard. Delete suffix if not required RD 4 PXB15-xxSxx 36 Data Sheet Jul. 20, 2010 15W, Single Output Recommended Pad Layout Soldering Considerations Lead free wave solder profile for PXB15-SERIES Zone Preheat zone Actual heating Reference Parameter. Rise temp. speed: 3 ºC /sec max. Preheat temp.: 100~130ºC Peak temp.: 250~260ºC Peak time(T1+T2 time): 4~6 sec Reference Solder: Sn-Ag-Cu; Sn-Cu Hand Welding: Soldering iron: Power 90W Welding Time: 2~4 sec Temp.: 380~400 ºC PXB15-xxSxx 37 Data Sheet Jul. 20, 2010 15W, Single Output Packaging Information 300 26.5 19 6 All dimensions in millimeters 10 PCS per TUBE Part Number Structure PXB 15 – 48 S 05 -A Total Output power 15 Watt Input Voltage Range 12xxx : 9~18V 24xxx : 18~36V 48xxx : 36~75V Model Number Option Suffix Output Voltage 3P3 : 3.3V 05 : 5V Single Output Input Range Output Voltage PXB15-12S3P3 9 - 18 VDC 3.3 VDC PXB15-12S05 9 - 18 VDC 5 VDC PXB15-12S12 9 - 18 VDC 12 VDC PXB15-12S15 9 - 18 VDC 15 VDC PXB15-24S3P3 18 - 36 VDC 3.3 VDC PXB15-24S05 18 - 36 VDC 5 VDC PXB15-12S12 18 - 36 VDC 12 VDC PXB15-24S15 18 - 36 VDC 15 VDC PXB15-48S3P3 36 - 75 VDC 3.3 VDC PXB15-48S05 36 - 75 VDC 5 VDC PXB15-48S12 36 - 75 VDC 12 VDC PXB15-48S15 36 - 75 VDC 15 VDC Note 1. Maximum value at nominal input voltage and full load. Note 2. Typical value at nominal input voltage and full load. (2) Output Current Full Load Input Current (1) Full Load Eff (%) 4000mA 3000mA 1300mA 1000mA 4000mA 3000mA 1300mA 1000mA 4000mA 3000mA 1300mA 1000mA 1375mA 1524mA 1605mA 1506mA 671mA 763mA 783mA 744mA 336mA 372mA 387mA 372mA 84 86 85 87 86 86 87 88 86 88 88 88 PXB15-xxSxx 38 Data Sheet Jul. 20, 2010 15W, Single Output Safety and Installation Instruction Fusing Consideration Caution: This power module is not internally fused. An input line fuse must always be used. This encapsulated power module can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a normal-blow fuse with maximum rating of 3A for PXB15-12SXX modules and 1.5A for PXB15-24SXX modules and 1A for PXB15-48SXX modules. Based on the information provided in this data sheet on Inrush energy and maximum DC input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXB15S SERIES of DC/DC converters has been calculated using Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40 ºC (Ground fixed and controlled 6 environment ). The resulting figure for MTBF is 1.330×10 hours. MIL-HDBK 217F NOTICE2 FULL LOAD, Operating Temperature at 25 ºC . The resulting figure for MTBF is 5 5.630×10 hours. PXB15-xxSxx 39
PXB15-12S05/NT 价格&库存
很抱歉,暂时无法提供与“PXB15-12S05/NT”相匹配的价格&库存,您可以联系我们找货
PXB15-12S05/NT
  • 1+543.546321+70.35641
  • 10+514.8031210+66.63590
  • 25+503.7595625+65.20643
  • 50+495.5581250+64.14484
  • 100+487.47702100+63.09882
库存:7
