PXD-M30-24WS24
PXD-M30-24WS24
    TDK(东电化)
    DIP6
    PXD-M30-24WS24
PXD-M30-24WS24 数据手册
PXD-M Series https://product.tdk.com/en/power/pxd-m www.emea.tdk-lambda.com/pxd-m 30W Medical and Industrial DC-DC Converters The PXD-M series of medical and industrial DC-DC converters feature a wide 4:1 input range in a compact 2 x 1” (50.8 x 25mm) industry standard package. With 5kV input to output isolation, 2.5uA touch current and a low off-load power draw, these encapsulated modules are ideal for fixed and portable applications. Features Benefits • Wide 4:1 Input Range • Supports Dual 12/24V or 24/48V System Voltages • Compact 2” x 1” Industry Package • Less Board Area Needed • Certified to IEC 60601-1 and IEC 62368-1 • Suitable For Medical and Industrial Applications • 2 x MOPP Isolation • High Input to Output Isolation • Low No Load Power Consumption • Longer Battery Life Model Selector Model Single Outputs PXD-M30-24WS05 PXD-M30-24WS12 PXD-M30-24WS15 PXD-M30-24WS24 PXD-M30-48WS05 PXD-M30-48WS12 PXD-M30-48WS15 PXD-M30-48WS24 Dual Outputs PXD-M30-24WD05 PXD-M30-24WD12 PXD-M30-24WD15 PXD-M30-48WD05 PXD-M30-48WD12 PXD-M30-48WD15 PXD-M- Input Voltage (V) Output Voltage (V) Maximum Current (A) Maximum Power (W) No Load Input Current (mA) Efficiency (%) Maximum Load Capacitance (uF) 9 - 36 9 - 36 9 - 36 9 - 36 18 - 75 18 - 75 18 - 75 18 - 75 5 12 15 24 5 12 15 24 6 2.5 2 1.25 6 2.5 2 1.25 30 30 30 30 30 30 30 30 9 10 10 10 8 9 8 9 88.5 89 90.5 89.5 89 89 90 89 7200 1200 1000 375 7200 1200 1000 375 9 - 36 9 - 36 9 - 36 18 - 75 18 - 75 18 - 75 ±5 ±12 ±15 ±5 ±12 ±15 ±3.0 ±1.25 ±1.0 ±3.0 ±1.25 ±1.0 30 30 30 30 30 30 10 10 9 9 9 8 86 89.5 90 86.5 90 89.5 ±3600 ±750 ±500 ±3600 ±750 ±500 30 30 30W Output Power -24W S -24W 9 - 36V input -48W 18 - 75V input S Single Output D Dual Output Preferred model PXD-M Series 05 05 12 15 24 5V Output Voltage 12V Output Voltage 15V Output Voltage 24V Output Voltage -N Blank No Remote On/Off -N Negative Logic Remote On/Off -P Positive Logic Remote On/Off 1 Specifications Model Input Input Voltage Range Input Surge Voltage Input Shutdown Voltage Start-up Time Touch Current No Load Power Consumption Efficiency Conducted & Radiated EMI Immunity Safety Agency Certifications PXD-M30 Vdc Vdc Vdc ms uA W - See model selector table -24W models: 50, -48W models: 100. (3s maximum) -24W models: 7.8 - 8.6, -48W models: 15.8 - 17.4 60 max 2.5 maximum See model selector table See model selector table EN55011-A, EN55032-A without external components. Class B with external components See immunity section IEC/UL/CSA/EN62368-1, IEC/ANSI/AAMI ES/CSA/EN60601-1, CE Mark (LVD and RoHS) Immunity Test Standard Test Level Criteria Notes ESD Radiated Susceptibility Electrical Fast Transient Burst Surge EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 Air ± 15kV and Contact ± 8kV 10V/m ± 2kV ± 2kV A A A A Conducted Susceptibility Magnetic Fields EN61000-4-6 EN61000-4-8 10 Vrms 100A/m continuous; 1000A/m 1s A A With an input filter of two 220uF capacitors and a TVS (SMDJ58A for PXG-M24W or SMDJ120A for PXG-M48W) - 2 PXD-M Series Specifications Model Output Output Voltage Tolerance Output Voltage Adjustment Switching Frequency Line Regulation Load Regulation Cross Regulation External Load Capacitance Ripple & Noise (1) PXD-M30 % % kHz % % % uF mV Temperature Coefficient Minimum Load Transient Loading Overcurrent Protection Overvoltage Protection Overtemperature Protection Remote Sense Remote On/Off %/°C V - Parallel Operation Series Operation Environmental Operating Temperature (2) - Maximum Case Temperature Thermal Impedance Storage Temperature Humidity (non condensing) Cooling Altitude Withstand Voltage (For 1 minute) Isolation Capacitance Vibration (Operating) Thermal Shock Other Weight (Typ) Size (LxWxH) Size (LxWxH) Case Material MTBF - MIL-HDBK-217F, Full Load Warranty °C ±1 Single output only. 5V: 4.5 -5.5V, 12V: -10.8 - 13.2V, 15V: 13.5 - 18V, 24V: 21.6 - 28.8V 225 - 285 Single output: ±0.2. Dual output: ±0.5 Single output: ±0.2. Dual output: ±1 Dual output: ±5 (Asymmetrical 25% to 100% load change) See model selector table Single output: 5V outputs: 50, 12V outputs: 75, 15/24V outputs: 100 Dual output: ±5V outputs: 50, ±12/15V outputs: 75 ±0.02 No minimum load required 250us recovery time for a 25% load change Hiccup mode. 150 - 185% Zener clamp method. 5V: 6.2V, 12V: 15V, 15V: 20V, 24V: 30V (typical) Shutdown, typically 115°C No remote sense Positive Logic (-P): ON: Open or 3.5-12V, OFF Short or 0-1.2V Negative Logic (-N): ON: Short or 0-1.2V, OFF: Open or 3.5-12V Not possible Possible °C °C/W °C %RH m VAC pF - Convection:-40 to +105, derate linearly to zero load from +40 to 105 Forced air (200LFM):-40 to +105, derate linearly to zero load from +73 to 105. (Model dependent, confirm case temperatures in end system) 105. Measured centrally on the upper case (module top view) 12.85 -55 to +125 5 - 95 (Operating & Storage) Convection or forced air 5,000 (operating) Input to output 5,000 (2xMOPPs) 20 MIL-STD-810F MIL-STD-810F g mm Inches Hours yrs 32 50.8 x 25.4 x 10.2 2 x 1 x 0.4 Non-conductive black plastic. (Silicone (UL94 V-0) potting) 1,137,000 5 Notes See website for detailed specifications, test methods and installation manual (1): Measured with a 20MHz bandwidth oscilloscope across a 10uF 25V X7R MLCC (4.7uF 50V for 24V models) (2). The case temperature must be confirmed in end application. The product rating may be affected by airflow direction and physical obstructions near the module. PXD-M Series 3 Outline Drawing Recommended Hole Pattern Pinout PIN Function Single 1 2 3 4 5 6 4 Dual Hole diameter: 0.05” [1.30mm) Top side pad diameter: 0.064” [1.63mm] Bottom side pad diameter: 0.102” [2.60mm] +Vin -Vin Remote On/Off (Option) +Vout -Vout Trim Com -Vout PXD-M Series For additional information, please visit https://product.tdk.com/en/power/ PXD-M_Datasheet_260663 August 5th, 2020 v1.5 PXD-M Series 5
PXD-M30-24WS24 价格&库存
很抱歉,暂时无法提供与“PXD-M30-24WS24”相匹配的价格&库存,您可以联系我们找货
