PXD10-24WS05-P
PXD10-24WS05-P
    TDK(东电化)
    DIP5 模块
    DC DC CONVERTER 5V 10W
PXD10-24WS05-P 数据手册
PXD10-xxWSxx Single Output DC/DC Converter 9 to 36 Vdc and 18 to 75 Vdc input, 3.3 to 15 Vdc Single Output, 10W Features  Single output current up to 2.5A  10 watts maximum output power  4:1 ultra wide input voltage range of 9-36 and 18-75VDC  Six-sided continuous shield  High efficiency up to 84%  Low profile: 2.001.000.40 inch (50.825.410.2 mm )  Fixed switching frequency  RoHS compliant  No minimum load  Input to output isolation: 1600Vdc,min  Operating case temperature range: 100°C max  Output over-voltage protection  Over-current protection, auto-recovery  Output short circuit protection Options  Heat sinks available for extended operation  Remote on/off and logic configurations Applications  Distributed power architectures  Computer equipment  Communications equipment General Description The PXD10-xxWSxx single output series offers 10 watts of output power from a 2 X 1 X 0.4 inch package. It has 4:1 ultra wide input voltage of 9-36VDC, 18-75VDC,features 1600VDC of isolation, short circuit, over voltage protection, and six sided shielding. All models are particularly suited to telecommunications, industrial, mobile telecom and test equipment applications. Table of Contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Test Configurations EMC Consideration Input Source Impedance Output Over Current Protection Output Over Voltage Protection Short Circuit Protection P2 P2 P3 P4 P5 P21 P22 P24 P24 P24 P24 Thermal Considerations Remote ON/OFF Control Heat Sink Mechanical Data Recommended Pad Layout Soldering Considerations Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P25 P26 P27 P27 P28 P28 P29 P29 P30 P30 DataSheet 10W, Single Output Absolute Maximum Rating Parameter Model Input Voltage Continuous Transient (100ms) Operating Ambient Temperature (with derating) Operating Case Temperature Storage Temperature Min 24WSxx 48WSxx 24WSxx 48WSxx All -40 All -55 Max Unit 36 75 50 100 85 100 105 VDC °C °C °C Output Specification Parameter Output Voltage Range (Vin = Vin(nom); Full Load ; TA=25 °C) Model Min Typ Max xxWS3P3 3.267 3.3 3.333 xxWS05 4.95 5 5.05 xxWS12 11.88 12 12.12 xxWS15 14.85 15 15.15 Unit VDC Output Regulation Line (Vin(min) to Vin(max) at Full Load) ±0.2 All Output Ripple & Noise Peak -to- Peak (20MHz bandwidth) Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max); Full Load ; TA=25°C) % ±0.5 Load (0% to 100% of Full Load) All 50 mVP-P All ±0.02 %/°C 5 % VOUT All 0 All 200 mV All 250 μS Dynamic Load Response (Vin = Vin(nom); TA=25°C) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Setting Time (VOUT 10% peak deviation) Output Current Output Over Voltage Protection (Zener diode clamp) xxWS3P3 0 2500 xxWS05 0 2000 xxWS12 0 830 xxWS15 0 670 xxWS3P3 3.9 xxWS05 6.2 xxWS12 15 xxWS15 18 Output Over Current Protection All Output Short Circuit Protection All 130 mA VDC 150 % FL. Hiccup, automatic recovery VER:00 Page 2 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom); Full Load) Input Standby Current (Typical value at Vin = Vin(nom); No Load) Input Reflected Ripple Current (5 to 20MHz, 12μH source impedance) Model Min Typ Max 24WSxx 9 24 36 48WSxx 18 48 75 24WS3P3 465 24WS05 548 24WS12 519 24WS15 544 48WS3P3 239 48WS05 270 48WS12 259 48WS15 262 24WS3P3 Unit Vdc mA 13 24WS05 11 24WS12 16 24WS15 26 48WS3P3 10 48WS05 9 48WS12 9 48WS15 11 All 30 mA mAP-P Start Up Time (Vin = Vin(nom) and constant resistive load) All Power up mS 20 Remote On/Off Control (Option) (The On/Off pin voltage is referenced to -VIN) Positive logic On/Off pin High Voltage (Remote On) Suffix –P 3.5 12 On/Off pin Low Voltage (Remote Off) Suffix –P 0 1.2 VDC Negative logic On/Off pin High Voltage (Remote On) Suffix –N 0 1.2 On/Off pin Low Voltage (Remote Off) Suffix –N 3.5 12 Remote Off Input Current All Input Current of Remote Control Pin All 20 -0.5 mA 1 mA VER:00 Page 3 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output General Specification Parameter Efficiency (Vin = Vin(nom); Full Load ; TA=25°C) Model Min Typ 24WS3P3 78 24WS05 80 24WS12 84 24WS15 81 48WS3P3 76 48WS05 81 48WS12 84 48WS15 84 Max Unit % Isolation Voltage Input to Output All Input to Case, Output to Case VDC 1600 1600 Isolation Resistance All 1 GΩ Isolation Capacitance All Switching Frequency All 300 kHz Weight All 27.0 g All 1.976×10 300 pF MTBF Bellcore TR-NWT-000332, TC=40°C MIL-HDBK-217F 6 hours 6 1.416×10 VER:00 Page 4 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves All test conditions are at 25°C.The figures are for PXD10-24WS3P3 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 5 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS3P3 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 6 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves All test conditions are at 25°C.The figures are for PXD10-24WS05 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 7 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 8 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS12 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 9 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 10 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS15 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 11 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-24WS15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 12 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS3P3 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 13 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS3P3 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 14 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS05 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 15 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 16 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS12 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 17 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 18 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS15 Efficiency versus Output Current Power Dissipation versus Output Current Efficiency versus Input Voltage. Full Load Derating OutputCurrentversus AmbientTemperature andAirflow Vin = Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow ,Vin = Vin(nom) VER:00 Page 19 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXD10-48WS15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom) ; Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom) ; Full Load Vin = Vin(nom) ; Full Load VER:00 Page 20 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Testing Configurations Input reflected-ripple current measurement test: Component L C Value 12μH 100μF Voltage ---100V Reference ---Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement test Output voltage and efficiency measurement test Note: All measurements are taken at the module terminals.  V  Io Efficiency   o  Vin  I in    100%  VER:00 Page 21 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output EMC considerations Suggested schematic for EN55022 conducted emission Class A limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS A the following components are needed: PXD10-24WSxx Component C1 C2, C3 PXD10-48WSxx Component C1 C2, C3 Value 1μF 1000pF Voltage 50V 2KV 1210 MLCC 1808 MLCC Reference Value 1.5μF 1000pF Voltage 100V 2KV 1812 MLCC 1808 MLCC Reference VER:00 Page 22 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output EMC considerations (Continued) Suggested schematic for EN55022 conducted emission Class B limits Recommended layout with input filter To meet conducted emissions EN55022 CLASS B the following components are needed: PXD10-24WSxx Component C1 C3, C4 L1 PXD10-48WSxx Component C1, C2 C3, C4 L1 Value 2.2μF 1000pF 325μH Voltage 50V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke Value 2.2μF 1000pF 325μH Voltage 100V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke Common Choke L1 is defined as follows: ■ L-325μH±35% / DCR-35mΩ, max A height: 8.8 mm, Max ■ Test condition-100kHz / 100mV ■ Recommended through hole-Φ0.8mm ■ All dimensions in millimeters VER:00 Page 23 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Input Source Impedance The converter should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the converter Input external L-C filter is recommended to minimize input reflected ripple current. The inductor is a simulated source impedance of 12μH and the capacitor is Nippon chemi-con KY series 100μF/100V. The capacitor must be located as close as possible to the input terminals of the converter for lowest impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all converters. Normally, overload current is maintained at approximately 150 percent of rated current for PXF40-xxSxx series. Hiccup-mode is a method of operation in a converter whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also enables the converter to restart when the fault is removed. There are other ways of protecting the converter when it is over-loaded, such as the maximum current limiting or current foldback methods. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of these devices may exceed their specified limits. A protection mechanism has to be used to prevent these power devices from being damaged. The operation of hiccup is as follows. When the current sense circuit sees an over-current event, the controller shuts off the converter for a given time and then tries to start up the converter again. If the over-load condition has been removed, the converter will start up and operate normally; otherwise, the controller will see another over-current event and will shut off the converter again, repeating the previous cycle. Hiccup operation has none of the drawbacks of the other two protection methods, although its circuit is more complicated because it requires a timing circuit. The excess heat due to overload lasts for only a short duration in the hiccup cycle, hence the junction temperature of the power devices is much lower. Output Over Voltage Protection The output over-voltage protection consists of an output Zener diode that monitors the voltage on the output terminals. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode clamps the output voltage. Short Circuit Protection Continuous, hiccup and auto-recovery mode. VER:00 Page 24 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Thermal Consideration The converter operates in a variety of thermal environments; however, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as shown in the figure below. The temperature at this location should not exceed 100°C. When Operating, adequate cooling must be provided to maintain the test point temperature at or below 100°C. Although the maximum point temperature of the power modules is 100°C, lowering this temperature yields higher reliability. Measurement shown in inches(mm) TOP VIEW VER:00 Page 25 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Remote ON/OFF Control (Option) Remote control is an optional feature. Positive logic: Turns the module On during logic High on the On/Off pin and turns Off during logic Low. Negative logic: Turns the module On during logic Low on the On/Off pin and turns Off during logic High. The On/Off pin is an open collector/drain logic input signal (Von/off) that referenced to -VIN. Remote On/Off Implementation Isolated-Control Remote On/Off Level Control Using TTL Output Level Control Using Line Voltage VER:00 Page 26 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Heat Sink Use heat-sink (7G-0020A) for lowering temperature and higher reliability of the module. All dimensions in Inches (mm) Mechanical Data PIN 1 2 3 5 6 PIN CONNECTION Function + INPUT - INPUT + OUTPUT - OUTPUT CTRL (Option) 1.All dimensions in Inches (mm) Tolerance:x.xx±0.02 (x.x±0.5) x.xxx±0.01 (x.xx±0.25) 2. Pin pitch tolerance ±0.01(0.25) 3. Pin dimension tolerance ±0.014(0.35) VER:00 Page 27 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Recommended Pad Layout 1.All dimensions in Inches (mm) Tolerance:x.xx±0.02 (x.x±0.5) x.xxx±0.01 (x.xx±0.25) 2. Pin pitch tolerance ±0.01(0.25) Soldering Considerations Lead free wave solder profile for PXD10-xxWSxx series. Zone Preheat zone Reference Parameter Rise temp. speed : 3°C / sec max. Preheat temp. : 100~130°C Actual heating Peak temp. : 250~260°C Peak time (T1+T2 time) : 4~6 sec Reference Solder:Sn-Ag-Cu / Sn-Cu Hand Welding: Soldering iron-Power 90W Welding Time:2-4 sec Temp.: 380-400 °C VER:00 Page 28 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Packaging Information All dimensions in millimeters 20 PCS per Tube Part Number Structure PXD 10 – 48 WS 05 -P Max. Output Power 10 Watts Remote Control Input Voltage Range No Suffix: Without Remote Control Suffix –P: Positive Logic Suffix –N: Negative Logic 24 9 ~ 36V 48 18 ~ 75V 4:1 Ultra Wide Input Range Output Voltage Single Output 3P3 05 12 15 Model Number Input Range PXD10-24WS3P3 PXD10-24WS05 PXD10-24WS12 PXD10-24WS15 PXD10-48WS3P3 PXD10-48WS05 PXD10-48WS12 PXD10-48WS15 9 – 36 VDC 9 – 36 VDC 9 – 36 VDC 9 – 36 VDC 18 – 75 VDC 18 – 75 VDC 18 – 75 VDC 18 – 75 VDC Output Voltage 3.3VDC 5VDC 12VDC 15VDC 3.3VDC 5VDC 12VDC 15VDC 3.3VDC 5VDC 12VDC 15VDC Output Current Max. Load 2500mA 2000mA 830mA 670mA 2500mA 2000mA 830mA 670mA Input Current (1) Full Load 465mA 548mA 519mA 544mA 239mA 270mA 259mA 262mA (2) Eff (%) 78 80 84 81 76 81 84 84 Note 1. Maximum value at nominal input voltage and full load of standard type. Note 2. Typical value at nominal input voltage and full load. VER:00 Page 29 of 30 Issued Date:2009/03/02 DataSheet 10W, Single Output Safety and Installation Instruction Fusing Consideration Caution: This converter is not internally fused. An input line fuse must always be used. This encapsulated converter can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of a sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a slow-blow fuse with maximum rating of 5A. Based on the information provided in this data sheet on Inrush energy and maximum dc input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXD10-xxWSxx series of DC/DC converters has been calculated using Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40°C (Ground fixed and controlled 6 environment ). The resulting figure for MTBF is 1.976×10 hours. MIL-HDBK 217F NOTICE2 FULL LOAD, Operating Temperature at 25℃°C. The resulting figure for MTBF is 6 1.416 × 10 hours. VER:00 Page 30 of 30 Issued Date:2009/03/02
PXD10-24WS05-P 价格&库存
很抱歉,暂时无法提供与“PXD10-24WS05-P”相匹配的价格&库存,您可以联系我们找货
