PXD30-48WD05
PXD30-48WD05
    TDK(东电化)
    DIP6 模块
    隔离模块 直流转换器 2 输出 5V -5V 3A,3A 18V - 75V 输入
PXD30-48WD05 数据手册
PXD30-xxWDxx Dual Output DC/DC Converters 9 to 36 Vdc and 18 to 75 Vdc input, ±5 to ±15 Vdc Dual Output, 30W Features  RoHS compliant  Dual output up to ±3000mA  Six-sided continuous shield  No minimum load required  High power density  High efficiency up to 88%  Small size 2.00 x 1.00 x 0.400 inch (50.8 x 25.4 x 10.2 mm )  Input to output isolation (1600VDC)  4:1 ultra wide input voltage range  Fixed switching frequency  Input under-voltage protection  Output over-voltage protection  Over-current protection  Output short circuit protection  Remote on/off  Case grounding Applications  Wireless Network  Telecom/Datacom  Industry Control System  Measurement  Semiconductor Equipment Options  Negative logic Remote On/Off  Heatsink General Description The PXD30-xxWDxx dual output series offers 30 watts of output power from a 2 x 1.0 x 0.4 inch package. This converter has a 4:1 ultra wide input voltage of 9-36VDC, 18-75VDC and features 1600VDC of isolation, short circuit protection , over-voltage protection, over-current protection and six sided shielding. All models are particularly suited for telecommunications, industrial, mobile telecom and test equipment applications. Table of Contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Testing Configurations EMC Considerations Input Source Impedance Output Over Current Protection Output Over Voltage Protection Short Circuit Protection P2 P2 P3 P4 P5 P17 P18 P19 P19 P19 P19 Thermal Consideration Heatsink Consideration Remote ON/OFF Control Mechanical Data Recommended Pad Layout Soldering Consideration Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P20 P20 P21 P22 P22 P23 P24 P25 P25 P25 DataSheet 30W, Dual Output Absolute Maximum Ratings Parameter Model Input Voltage Continuous Min 24WDxx 48WDxx 24WDxx 48WDxx Transient (100ms) Operating Ambient Temperature without derating with derating Operating Case Temperature Storage Temperature All -40 50 All -55 Max Unit 40 80 50 100 Vdc ℃ 50 85 105 125 ℃ ℃ Output Specification Parameter Output Voltage (Vin = Vin(nom) ; Full Load ; TA=25°C) Model Min Typ Max xxWD05 4.95 5 5.05 xxWD12 11.88 12 12.12 xxWD15 14.85 15 15.15 All -0.2 +0.2 -1.0 +1.0 -5.0 +5.0 Unit Vdc Output Regulation Line (Vin(min) to Vin(max) at Full Load) Load (0% to 100% of Full Load) DIP type Cross Regulation Asymmetrical Load 25% / 100% of Full Load Output Ripple & Noise Peak-to-Peak (5Hz to 20MHz bandwidth) (Measured with a 1μF/50V MLCC) Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max) ; Full Load ; TA=25°C ℃) All xxWD05 100 xxWD12 150 xxWD15 All % Vo % Vo mVp-p 150 -0.02 +0.02 % Vo 5 % Vo All 0 All 300 mV All 250 μs Dynamic Load Response (Vin = Vin(nom) ; TA=25°C ) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Setting Time (Vo<10% peak deviation) Output Current xxWD05 0 ±3000 xxWD12 0 ±1250 xxWD15 0 ±1000 Output Over Voltage Protection xxWD05 6.2 (Zener diode clamp) xxWD12 15 xxWD15 18 Output Over Current Protection Output Short Circuit Protection All 150 mA Vdc % FL. Hiccup, automatic recovery VER:01 Page 2 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom) ; Full Load) Input Standby Current (Typical value at Vin = Vin(nom) ; No Load) Under Voltage Lockout Turn-on Threshold Under Voltage Lockout Turn-off Threshold Input reflected ripple current (5 to 20MHz, 12μH source impedance) Model Min Typ Max 24WDxx 9 24 36 48WDxx 18 48 75 24WD05 1488 24WD12 1506 24WD15 1506 48WD05 744 48WD12 744 48WD15 744 Unit Vdc mA 24WD05 90 24WD12 25 24WD15 25 48WD05 50 48WD12 15 48WD15 15 24WDxx 9 48WDxx 18 24WDxx 8 48WDxx 16 All 20 mAp-p 30 ms 30 ms mA Vdc Vdc Start Up Time (Vin = Vin(nom) and constant resistive load) Power up All Remote ON/OFF Remote ON/OFF Control (The On/Off pin voltage is referenced to -Vin) Positive logic (Standard) On/Off pin High Voltage (Module ON) On/Off pin Low Voltage (Module OFF) All 3.0 12 Vdc 0 1.2 Vdc 3.0 12 Vdc 0 1.2 Vdc Negative logic (Option) On/Off pin High Voltage (Module OFF) On/Off pin Low Voltage (Module ON) Remote Off Input Current All Input Current of Remote Control Pin All 3 -0.5 mA 0.5 mA VER:01 Page 3 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output General Specification Parameter Efficiency (Vin = Vin(nom) ; Full Load ; TA=25°C ) Model Min 24WD05 88.0 24WD12 87.0 24WD15 87.0 48WD05 88.0 48WD12 88.0 48WD15 Case grounding Typ All Max Unit % 88.0 Connect case to –Vin with decoupling Y cap. Isolation voltage Input to Output All Input to Case, Output to Case Vdc 1600 1600 Isolation resistance All 1 GΩ Isolation capacitance All Switching Frequency All 430 kHz Weight All 30.5 g All 3.163×106 hours 1500 pF MTBF Bellcore TR-NWT-000332, TC=40°C ℃ 4.347×105 MIL-HDBK-217F Over Temperature Protection All 115 ℃ VER:01 Page 4 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves All test conditions are at 25°C. The figures are for PXD30-24WD05 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 5 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output VER:01 Page 6 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C . The figures are for PXD30-24WD05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 7 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-24WD12 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 8 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-24WD12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 9 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-24WD15 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 10 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-24WD15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 11 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C. The figures are for PXD30-48WD05. Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 12 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-48WD05. Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 13 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-48WD12. Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 14 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-48WD12. Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 15 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C .The figures are for PXD30-48WD15. Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) VER:01 Page 16 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C . The figures are for PXD30-48WD15. Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Vin=Vin(nom), Full Load VER:01 Page 17 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Testing Configurations Input reflected-ripple current measurement test: Component L C Value 12μH 47μF Voltage ---100V Reference ---Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement test: GROUND RING TO SCOPE +Vo -Vo Resistive Load Output voltage and efficiency measurement test: Note:All measurements are taken at the module terminals.  V  Io  Efficiency   o   100%  Vin  I in  VER:01 Page 18 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output EMC Considerations Suggested Schematic for EN55022 Conducted Emission Class A Limits Recommended Layout With Input Filter To meet conducted emissions EN55022 CLASS A the following components are needed: PXD30-24WDxx Component C1 C2、C3、C4 Value 4.7uF 1000pF Voltage 50V 2KV 1812 MLCC 1808 MLCC PXD30-48WDxx Component C1 C2、C3、C4 Value 2.2uF 1000pF Voltage 100V 2KV 1812 MLCC 1808 MLCC Reference Reference VER:01 Page 19 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Input Source Impedance The converter should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the converter. Input external L-C filter is recommended to minimize input reflected ripple current. The inductor has a simulated source impedance of 12μH and capacitor is Nippon chemi-con KY series 47μF/100V. The capacitor must be located as close as possible to the input terminals of the converter for lower impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all converters. Normally, overload current is maintained at approximately 150 percent of rated current for PXD30-xxWDxx series. Hiccup-mode is a method of operation in the converter whose purpose is to protect the converter from being damaged during an over-current fault condition. It also enables the converter to restart when the fault is removed. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of those devices may exceed their specified limits. A protection mechanism has to be used to prevent those power devices from being damaged. Output Over Voltage Protection The output over-voltage protection consists of an output Zener diode that monitors the voltage on the output terminals. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode clamps the output voltage. Short Circuit Protection Continuous, hiccup and auto-recovery. Thermal Consideration VER:01 Page 20 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output The converter operates in a variety of thermal environments. Sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as shown in the figure below. The temperature at this location should not exceed 105°C. When operating, adequate cooling must be provided to maintain the test point temperature at or below 105°C . Although the maximum point temperature of the converter is 105°C, limiting this temperature to a lower value will increase the reliability of this device. Measurement shown in inches and (millimeters) TOPVIEW Heat Sink Consideration Use heat-sink (7G-0020C) for lowering temperature; thus increasing the reliability of the converter. Heatsink + Clamp Heatsink Measurement shown in inches and (millimeters) VER:01 Page 21 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Remote ON/OFF Control Positive Logic – (no suffix) , the positive logic remote ON/OFF control circuit is included. Ex.: PXD30-24WD05 Turns the converter ON during logic High on the On/Off pin and turns the converter OFF during logic Low. The On/Off pin is an open collector/drain logic input signal (Von/off) that is referenced to GND. If not using the remote on/off feature, an open circuit between on/off pin and (–) input pin is needed to turn the module on. Negative Logic – (suffix -N), the negative logic remote ON/OFF control circuit is included. Ex.: PXD30-24WD05-N Turns the converter ON during logic Low on the On/Off pin and turns the converter OFF during logic High. The On/Off pin is an open collector/drain logic input signal (Von/off) that is referenced to GND. If not using the remote on/off feature, a short circuit between on/off pin and (–) input pin is needed to turn the module on. Remote ON/OFF Implementation Isolated Control Remote ON/OFF VER:01 Page 22 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Level Control Using TTL Output Level Control Using Line Voltage Mechanical Data 1.00(25.4) 0.600(15.24) 0.200(5.10) 0.200(5.08) 0.40(10.2) 6 5 0.300(7.62) SIDE VIEW 0.100(2.54) BOTTOM VIEW 2.00(50.8) 1.800(45.72) 2 1 3 4 0.100(2.54) 0.22(5.6) PIN 1 2 3 4 5 6 PIN CONNECTION FUNCTION + INPUT - INPUT CTRL +OUTPUT COM - OUTPUT 0.700(17.78) 1.All dimensions in Inches (mm) Tolerance: X.XX±0.02 (X.X±0.5) X.XXX±0.01 (X.XX±0.25) 2. Pin pitch tolerance ±0.01(0.25) 3. Pin dimension tolerance ±0.004 (0.1) VER:01 Page 23 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Recommended Pad Layout 1.00(25.4) 0.600(15.24) 0.200(5.10) 0.200(5.08) 0.100(2.54) 1 2 3 TOP VIEW 2.00(50.8) 1.800(45.72) AA VIEW KEEP OUT AREA 4 5 6 0.100(2.54) 0.300(7.62) 0.700(17.78) 1.All dimensions in Inches (mm) Tolerance: X.XX±0.02 (X.X±0.5) X.XXX±0.01 (X.XX±0.25) 2. Pin pitch tolerance ±0.01(0.25) 3. Pin dimension tolerance ±0.004 (0.1) Soldering and Reflow Considerations Lead free wave solder profile for PXD30-xxWDxx series. Zone Preheat zone Reference Parameter Rise temp. speed : 3°C/ sec max. Preheat temp. : 100~130°C Actual heating Peak temp. : 250~260°C ℃ Peak time (T1+T2 time) : 4~6 sec Reference Solder: Sn-Ag-Cu / Sn-Cu Hand Welding: Soldering iron - Power 90W VER:01 Page 24 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Welding Time::2-4 sec Temp.:380-400 °C Packaging Information TUBE 20 PCS per TUBE TRAY 20 PCS per TRAY VER:01 Page 25 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Part Number Structure PXD 30 – 24 WD 05 –N Max. Output Power 30Watts Remote ON/OFF Options No Suffix = Positive Logic Suffix –N = Negative Logic Input Voltage Range 24 : 9 ~ 36V 48 : 18 ~ 75V 4 : 1 Wide Input Range Model Number Input Range Output Voltage ±5 VDC PXD30-24WD05 9 – 36 VDC ±12 VDC PXD30-24WD12 9 – 36 VDC ±15 VDC PXD30-24WD15 9 – 36 VDC ±5 VDC PXD30-48WD05 18 – 75 VDC ±12 VDC PXD30-48WD12 18 – 75 VDC ±15 VDC PXD30-48WD15 18 – 75 VDC Note 1. Maximum value at nominal input voltage and full load. Note 2. Typical value at nominal input voltage and full load. Dual Output Output Current Max. Load ±3000mA ±1250mA ±1000mA ±3000mA ±1250mA ±1000mA Output Voltage 05 : ±5Vdc 12 : ±12Vdc 15 : ±15Vdc Input Current (1) Full Load 1488mA 1506mA 1506mA 744mA 744mA 744mA Eff (2) (%) 88 87 87 88 88 88 VER:01 Page 26 of 25 Issued Date:2009/06/22 DataSheet 30W, Dual Output Safety and Installation Instructions Fusing Consideration Caution: This converter is not internally fused. An input line fuse must always be used. This encapsulated converter can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of a sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a slow-blow fuse with a maximum rating of 10A. Based on the information provided in this data sheet on inrush energy and maximum dc input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXD30-xxWDxx series of DC/DC converters has been calculated using: Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40°C ℃ (Ground fixed and controlled 6 environment). The resulting figure for MTBF is 3.163×10 hours. MIL-HDBK 217F NOTICE2 FULL LOAD, Operating Temperature at 25°C ℃. The resulting figure for MTBF is 5 4.347×10 hours. VER:01 Page 27 of 25 Issued Date:2009/06/22
PXD30-48WD05 价格&库存
很抱歉,暂时无法提供与“PXD30-48WD05”相匹配的价格&库存,您可以联系我们找货
PXD30-48WD05
  • 1+1072.631701+138.87373
