PXE20-24WD05
PXE20-24WD05
    TDK(东电化)
    DIP7 模块
    隔离模块 直流转换器 2 输出 5V -5V 2A,2A 9V - 36V 输入
PXE20-24WD05 数据手册
PXE20/30 Series https://product.tdk.com/en/power/pxe www.emea.lambda.tdk.com/pxe 20-30W Single and Dual Output Isolated DC-DC Converters The PXE isolated DC-DC converters feature a 2:1 input range, and for some models, a wide 4:1 input range in a 2 x 1.6” (50.8 x 40.6mm) industry standard package. With IEC/UL/CSA/EN 62368-1 and single or dual output options, these models also feature a six-sided, shielded metal case for reduced radiated noise, making them suitable for a wide variety of Industrial, ICT (Information and Communications Technology) and Test and Measurement applications. Features Benefits • IEC/UL/CSA/EN 62368-1 Approvals • Easier System Approvals • Wide Range Input • Less Parts to Inventory • Six Sided Shielding • Reduced Radiated Noise • Up to 90% Efficiency • Long Field Life Related Products Type Part Number Accessory Smaller size DC-DC converter 7G0011A CCG PXE- 30 Series 20 20W Output Power 30 30W Output Power Description PXE heatsink with adhesive pad 1.3 to 30W single/dual output DC-DC converters (1 x 1 x 0.39”) -24 -12 9 - 18V input -24 18 - 36V input -48 36 - 75V input -24W 9 - 36V input -48W 18 - 75V input S S Single Output D Dual Output 05 Single Output 3P3 3.3V Output Voltage Single and Dual Output 05 5V Output Voltage 12 12V Output Voltage 15 15V Output Voltage -N Blank -N Positive Logic Remote On/Off *Negative Logic Remote On/Off Preferred model *PXE30 Wide Range Only PXE20/30 Series 1 Model Selector Model Input Output Voltage (V) Voltage (V) Maximum Current (A) No Load Input Current (mA) Ripple & Noise Efficiency (mVpk-pk) (%) Single Outputs PXE30-12S3P3 9 - 18 3.3 6 115 50 85 PXE30-24S3P3 18 - 36 3.3 6 50 50 88 PXE30-48S3P3 36 - 75 3.3 6 30 50 87 PXE30-24WS3P3 10 - 40 3.3 6 50 60 87 PXE30-48WS3P3 18 - 75 3.3 6 30 60 87 PXE20-24WS05 9 - 36 5 4 10 75 79 PXE20-48WS05 18 - 75 5 4 10 75 80 PXE30-12S05 9 - 18 5 6 95 50 87 PXE30-24S05 18 - 36 5 6 50 50 88 PXE30-48S05 36 - 75 5 6 35 50 89 PXE30-24WS05 10 - 40 5 6 65 75 87 PXE30-48WS05 18 - 75 5 6 30 75 88 PXE20-24WS12 9 - 36 12 1.67 20 100 81 PXE20-48WS12 18 - 75 12 1.67 10 100 81 PXE30-12S12 9 - 18 12 2.5 35 75 88 PXE30-24S12 18 - 36 12 2.5 30 75 89 PXE30-48S12 36 - 75 12 2.5 25 75 90 PXE30-24WS12 10 - 40 12 2.5 65 100 87 PXE30-48WS12 18 - 75 12 2.5 35 100 87 PXE20-24WS15 9 - 36 15 1.33 20 100 81 PXE20-48WS15 18 - 75 15 1.33 10 100 81 PXE30-12S15 9 - 18 15 2 45 75 88 PXE30-24S15 18 - 36 15 2 30 75 89 PXE30-48S15 36 - 75 15 2 25 75 90 PXE30-24WS15 10 - 40 15 2 70 100 88 PXE30-48WS15 18 - 75 15 2 45 100 88 Dual Outputs PXE20-24WD05 9 - 36 ±5 ±2.0 15 75 79 PXE20-48WD05 18 - 75 ±5 ±2.0 10 75 79 PXE20-24WD12 9 - 36 ±12 ±0.833 20 100 81 PXE20-48WD12 18 - 75 ±12 ±0.833 15 100 83 PXE30-12D12 9 - 18 ±12 ±1.25 60 100 87 PXE30-24D12 18 - 36 ±12 ±1.25 30 100 88 PXE30-48D12 36 - 75 ±12 ±1.25 20 100 88 PXE30-24WD12 10 - 40 ±12 ±1.25 30 100 84 PXE30-48WD12 18 - 75 ±12 ±1.25 25 100 85 PXE20-24WD15 9 - 36 ±15 ±0.666 25 100 82 PXE20-48WD15 18 - 75 ±15 ±0.666 20 100 84 PXE30-12D15 9 - 18 ±15 ±1.0 40 100 87 PXE30-24D15 18 - 36 ±15 ±1.0 30 100 88 PXE30-48D15 36 - 75 ±15 ±1.0 20 100 88 PXE30-24WD15 10 - 40 ±15 ±1.0 35 100 85 PXE30-48WD15 18 - 75 ±15 ±1.0 25 100 86 Specifications Maximum Load Capacitance (uF) 19,500 19,500 19,500 19,500 19,500 6,800 6,800 10,200 10,200 10,200 10,200 10,200 2,200 2,200 3,240 3,300 3,300 3,300 3,300 755 755 1,100 1,100 1,100 1,100 1,100 ±3400 ±3400 ±680 ±680 ±1020 ±1020 ±1020 ±1000 ±1000 ±450 ±450 ±675 ±675 ±675 ±680 ±680 Model PXE20W PXE30 Input Input Voltage Range - See Model Selector Table Input Surge Voltage Vdc 12V input: 36, 24V input: 50, 48V input: 100 (100ms maximum) Start-up Time ms 20 25 (10 for PXE30W Models) No Load Input Current - See Model Selector Table Efficiency - See Model Selector Table Conducted & Radiated EMI - EN55032-A (Class B - See installation diagrams for external circuitry) Immunity - See Immunity Section Safety Certifications and Markings - IEC/UL/CSA/EN62368-1, CE Mark and UKCA Mark 2 PXE20/30 Series Immunity Test Standard Test Level Criteria Notes ESD EN61000-4-2 3 B Air ± 8kV and Contact ± 6kV Radiated Susceptibility EN61000-4-3 3 A / B 10V/m (Criteria A for PXE30W Models) With an input filter capacitor Electrical Fast Transient Burst EN61000-4-4 3 (±2kV) B (Nippon chemi-con KY series, 220μF/100V) Surge EN61000-4-5 2 (±1kV) B Conducted Susceptibility EN61000-4-6 3 A 10Vrms Magnetic Fields EN61000-4-8 5 A 100A/m continuous; 1000A/m 1s Specifications Model PXE20W PXE30 Output Output Voltage Accuracy % ±1 Output Voltage Adjustment % ±10 Switching Frequency kHz 270 - 330 Line Regulation % Single Output: ±0.2, Dual Output: ±-0.5 Load Regulation % Single Output: ±0.5, Dual Output: ±3 Single Output: ±0.5, Dual Output: ±1 Cross Regulation % Dual Output: ±5 (Asymmetrical 25% to 100% load change) External Load Capacitance - See Model Selector Table Ripple & Noise (1) - See Model Selector Table Temperature Coefficient %/°C ±0.02 Minimum Load (2) % 10 None Transient Response (25% step load) µs 500 300 Overcurrent Protection % 150 (Hiccup Mode with Auto-Recovery) Overvoltage Protection V 3.3V: 3.9, 5V: 6.2, 12V: 15, 15V: 18 (Zener Diode Clamp) Overtemperature Protection °C None 115 Short Circuit Protection - Hiccup Mode with Auto-Recovery Remote Sense - No Remote Sense Positive Logic (-P): ON: Open or 3-12V, Positive Logic (-P): ON: Open or 3.5-12V, Remote On/Off - OFF: Short or 0-1.2V (PXE30W Only) Negative Logic (-N): OFF: Short or 0-1.2V ON: Short or 0-1.2V, OFF Open or 3-12V Environmental Operating Temperature °C -40 to +85 (See Derating Curves below) Maximum Case Temperature °C 100 Thermal Impedance °C/W 10 Storage Temperature °C -55 to +125 Humidity (non condensing) %RH 5 - 95 (Operating & Storage) Cooling - Convection Withstand Voltage (For 1 minute) Vdc Input to Output, Input to Case, Output to Case: 1,600 Isolation Resistance Ω 109 Isolation Capacitance pF 300 1,000 Vibration (Operating) - MIL-STD-810F Thermal Shock - MIL-STD-810F Other Weight (Typ) g 48 Size (LxWxH) mm 50.8 x 40.6 x 10.2 Size (LxWxH) Inches 2 x 1.6 x 0.4 Case Material - Nickel-coated Copper Base Material - Non-conductive Black Plastic FR4 PCB Potting Material - Epoxy (UL94 V-0) MTBF - MIL-HDBK-217F, Full Load Hours 1,922,000 1,283,000 (759,800 for PXE30W Models) Warranty yrs 3 Notes See website for detailed specifications, test methods and installation manual (1) Measured with a 20MHz bandwidth oscilloscope across a 0.1uF/50V MLCC (2) To meet regulation & noise specifications. Operation at zero load will not damage the device PXE20/30 Series 3 PXE Outline Drawing PXE Pinout PIN Function Single O/P 1 +Vin 2 4 5 6 7 8 PXE20 Derating Curve 4 -Vin Remote On/Off No Pin +Vout -Vout Trim PXE30 Derating Curve PXE20/30 Series Dual O/P +Vin -Vin Remote On/Off +Vout Common -Vout Trim TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 france@fr.tdk-lambda.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 info.italia@it.tdk-lambda.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands info@nl.tdk-lambda.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 info@de.tdk-lambda.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn TDK-Lambda Singapore Pte Ltd. Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Austria Sales Office Tel: +43 2256 655 84 info@at.tdk-lambda.com www.emea.lambda.tdk.com/at TDK India Private Limited, Power Supply Division Switzerland Sales Office Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 info@ch.tdk-lambda.com www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +45 8853 8086 info@dk.tdk-lambda.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 info@uk.tdk-lambda.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 info@tdk-lambda.co.il emea.lambda.tdk.com/il-en For additional information, please visit https://product.tdk.com/en/power/ PXE20/30_260870 August 31st, 2022 V1 PXE20/30 Series 5
PXE20-24WD05 价格&库存
很抱歉,暂时无法提供与“PXE20-24WD05”相匹配的价格&库存,您可以联系我们找货
